path: root/arch/powerpc/mm
2015-11-05Merge tag 'powerpc-4.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: - Kconfig: remove BE-only platforms from LE kernel build from Boqun Feng - Refresh ps3_defconfig from Geoff Levand - Emit GNU & SysV hashes for the vdso from Michael Ellerman - Define an enum for the bolted SLB indexes from Anshuman Khandual - Use a local to avoid multiple calls to get_slb_shadow() from Michael Ellerman - Add gettimeofday() benchmark from Michael Neuling - Avoid link stack corruption in __get_datapage() from Michael Neuling - Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar K.V - Add ppc64le_defconfig from Michael Ellerman - pseries: extract of_helpers module from Andy Shevchenko - Correct string length in pseries_of_derive_parent() from Nathan Fontenot - Free the MSI bitmap if it was slab allocated from Denis Kirjanov - Shorten irq_chip name for the SIU from Christophe Leroy - Wait 1s for secondaries to enter OPAL during kexec from Samuel Mendoza-Jonas - Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V - powerpc/pseries/hvcserver: don't memset pi_buff if it is null from Colin Ian King - Disable hugepd for 64K page size, from Aneesh Kumar K.V - Differentiate between hugetlb and THP during page walk from Aneesh Kumar K.V - Make PCI non-optional for pseries from Michael Ellerman - Individual System V IPC system calls from Sam bobroff - Add selftest of unmuxed IPC calls from Michael Ellerman - discard .exit.data at runtime from Stephen Rothwell - Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul Gortmaker - Use of_get_next_parent to simplify code from Christophe Jaillet - Paginate some xmon output from Sam bobroff - Add some more elements to the xmon PACA dump from Michael Ellerman - Allow the tm-syscall selftest to build with old headers from Michael Ellerman - Run EBB selftests only on POWER8 from Denis Kirjanov - Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael Ellerman - Avoid reference to potentially freed memory in prom.c from Christophe Jaillet - Quieten boot wrapper output with run_cmd from Geoff Levand - EEH fixes and cleanups from Gavin Shan - Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan - Use of_get_next_parent() in of_get_ibm_chip_id() from Michael Ellerman - Fix section mismatch warning in msi_bitmap_alloc() from Denis Kirjanov - Fix ps3-lpm white space from Rudhresh Kumar J - Fix ps3-vuart null dereference from Colin King - nvram: Add missing kfree in error path from Christophe Jaillet - nvram: Fix function name in some errors messages, from Christophe Jaillet - drivers/macintosh: adb: fix misleading Kconfig help text from Aaro Koskinen - agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov - cxl: Free virtual PHB when removing from Andrew Donnellan - scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from Michael Ellerman - scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building with O= from Michael Ellerman - Freescale updates from Scott: Highlights include 64-bit book3e kexec/kdump support, a rework of the qoriq clock driver, device tree changes including qoriq fman nodes, support for a new 85xx board, and some fixes. - MPC5xxx updates from Anatolij: Highlights include a driver for MPC512x LocalPlus Bus FIFO with its device tree binding documentation, mpc512x device tree updates and some minor fixes. * tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits) powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc() powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id() powerpc/pseries: Correct string length in pseries_of_derive_parent() powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s) powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes powerpc: handle error case in cpm_muram_alloc() powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake powerpc/book3e-64: Enable kexec powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32 powerpc/book3e-64/kexec: Enable SMP release powerpc/book3e-64/kexec: create an identity TLB mapping powerpc/book3e-64: Don't limit paca to 256 MiB powerpc/book3e/kdump: Enable crash_kexec_wait_realmode powerpc/book3e: support CONFIG_RELOCATABLE powerpc/booke64: Fix args to copy_and_flush powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts powerpc/e6500: kexec: Handle hardware threads ...
2015-11-05arch/powerpc/mm/numa.c: do not allocate bootmem memory for non existing nodesRaghavendra K T
With the setup_nr_nodes(), we have already initialized node_possible_map. So it is safe to use for_each_node here. There are many places in the kernel that use hardcoded 'for' loop with nr_node_ids, because all other architectures have numa nodes populated serially. That should be reason we had maintained the same for powerpc. But, since sparse numa node ids possible on powerpc, we unnecessarily allocate memory for non existent numa nodes. For e.g., on a system with 0,1,16,17 as numa nodes nr_node_ids=18 and we allocate memory for nodes 2-14. This patch we allocate memory for only existing numa nodes. The patch is boot tested on a 4 node tuleta, confirming with printks that it works as expected. Signed-off-by: Raghavendra K T <raghavendra.kt@linux.vnet.ibm.com> Cc: Vladimir Davydov <vdavydov@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Anton Blanchard <anton@samba.org> Cc: Nishanth Aravamudan <nacc@linux.vnet.ibm.com> Cc: Greg Kurz <gkurz@linux.vnet.ibm.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Nikunj A Dadhania <nikunj@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-27powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same ↵Kevin Hao
tlb entry In order to workaround Erratum A-008139, we have to invalidate the tlb entry with tlbilx before overwriting. Due to the performance consideration, we don't add any memory barrier when acquire/release the tcd lock. This means the two load instructions for esel_next do have the possibility to return different value. This is definitely not acceptable due to the Erratum A-008139. We have two options to fix this issue: a) Add memory barrier when acquire/release tcd lock to order the load/store to esel_next. b) Just make sure to invalidate and write to the same tlb entry and tolerate the race that we may get the wrong value and overwrite the tlb entry just updated by the other thread. We observe better performance using option b. So reserve an additional register to save the value of the esel_next. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-10-27powerpc/fsl-booke-64: Don't limit ppc64_rma_size to one TLB entryScott Wood
This is required for kdump to work when loaded at at an address that does not fall within the first TLB entry -- which can easily happen because while the lower limit is enforced via reserved memory, which doesn't affect how much is mapped, the upper limit is enforced via a different mechanism that does. Thus, more TLB entries are needed than would normally be used, as the total memory to be mapped might not be a power of two. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-10-22powerpc/85xx: Load all early TLB entries at onceScott Wood
Use an AS=1 trampoline TLB entry to allow all normal TLB1 entries to be loaded at once. This avoids the need to keep the translation that code is executing from in the same TLB entry in the final TLB configuration as during early boot, which in turn is helpful for relocatable kernels (e.g. kdump) where the kernel is not running from what would be the first TLB entry. On e6500, we limit map_mem_in_cams() to the primary hwthread of a core (the boot cpu is always considered primary, as a kdump kernel can be entered on any cpu). Each TLB only needs to be set up once, and when we do, we don't want another thread to be running when we create a temporary trampoline TLB1 entry. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-10-15powerpc/numa: Use of_get_next_parent to simplify codeChristophe Jaillet
of_get_next_parent can be used to simplify the while() loop and avoid the need of a temp variable. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-12powerpc/mm: Differentiate between hugetlb and THP during page walkAneesh Kumar K.V
We need to properly identify whether a hugepage is an explicit or a transparent hugepage in follow_huge_addr(). We used to depend on hugepage shift argument to do that. But in some case that can result in wrong results. For ex: On finding a transparent hugepage we set hugepage shift to PMD_SHIFT. But we can end up clearing the thp pte, via pmdp_huge_get_and_clear. We do prevent reusing the pfn page via the usage of kick_all_cpus_sync(). But that happens after we updated the pte to 0. Hence in follow_huge_addr() we can find hugepage shift set, but transparent huge page check fail for a thp pte. NOTE: We fixed a variant of this race against thp split in commit 691e95fd7396905a38d98919e9c150dbc3ea21a3 ("powerpc/mm/thp: Make page table walk safe against thp split/collapse") Without this patch, we may hit the BUG_ON(flags & FOLL_GET) in follow_page_mask occasionally. In the long term, we may want to switch ppc64 64k page size config to enable CONFIG_ARCH_WANT_GENERAL_HUGETLB Reported-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-12powerpc/mm: Disable hugepd for 64K page size.Aneesh Kumar K.V
After commit e2b3d202d1dba8f3546ed28224ce485bc50010be ("powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format"), we don't need to support is_hugepd() for 64K page size. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-09powerpc: Fix checkstop in native_hpte_clear() with lockdepCyril Bur
native_hpte_clear() is called in real mode from two places: - Early in boot during htab initialisation if firmware assisted dump is active. - Late in the kexec path. In both contexts there is no need to disable interrupts are they are already disabled. Furthermore, locking around the tlbie() is only required for pre POWER5 hardware. On POWER5 or newer hardware concurrent tlbie()s work as expected and on pre POWER5 hardware concurrent tlbie()s could result in deadlock. This code would only be executed at crashdump time, during which all bets are off, concurrent tlbie()s are unlikely and taking locks is unsafe therefore the best course of action is to simply do nothing. Concurrent tlbie()s are not possible in the first case as secondary CPUs have not come up yet. Signed-off-by: Cyril Bur <cyrilbur@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-01powerpc/slb: Use a local to avoid multiple calls to get_slb_shadow()Michael Ellerman
For no reason other than it looks ugly. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-10-01powerpc/slb: Define an enum for the bolted indexesAnshuman Khandual
This patch defines macros for the three bolted SLB indexes we use. Switch the functions that take the indexes as an argument to use the enum. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-18Merge tag 'powerpc-4.3-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: - Fix 32-bit TCE table init in kdump kernel from Nish - Fix kdump with non-power-of-2 crashkernel= from Nish - Abort cxl_pci_enable_device_hook() if PCI channel is offline from Andrew - Fix to release DRC when configure_connector() fails from Bharata - Wire up sys_userfaultfd() - Fix race condition in tearing down MSI interrupts from Paul - Fix unbalanced pci_dev_get() in cxl_probe() from Daniel - Fix cxl build failure due to -Wunused-variable gcc behaviour change from Ian - Tell the toolchain to use ABI v2 when building an LE boot wrapper from Benh - Fix THP to recompute hash value after a failed update from Aneesh - 32-bit memcpy/memset: only use dcbz once cache is enabled from Christophe * tag 'powerpc-4.3-2' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc32: memset: only use dcbz once cache is enabled powerpc32: memcpy: only use dcbz once cache is enabled powerpc/mm: Recompute hash value after a failed update powerpc/boot: Specify ABI v2 when building an LE boot wrapper cxl: Fix build failure due to -Wunused-variable behaviour change cxl: Fix unbalanced pci_dev_get in cxl_probe powerpc/MSI: Fix race condition in tearing down MSI interrupts powerpc: Wire up sys_userfaultfd() powerpc/pseries: Release DRC when configure_connector fails cxl: abort cxl_pci_enable_device_hook() if PCI channel is offline powerpc/powernv/pci-ioda: fix kdump with non-power-of-2 crashkernel= powerpc/powernv/pci-ioda: fix 32-bit TCE table init in kdump kernel
2015-09-16powerpc/mm: Recompute hash value after a failed updateAneesh Kumar K.V
If we had secondary hash flag set, we ended up modifying hash value in the updatepp code path. Hence with a failed updatepp we will be using a wrong hash value for the following hash insert. Fix this by recomputing hash before insert. Without this patch we can end up with using wrong slot number in linux pte. That can result in us missing an hash pte update or invalidate which can cause memory corruption or even machine check. Fixes: 6d492ecc6489 ("powerpc/THP: Add code to handle HPTE faults for hugepages") Cc: stable@vger.kernel.org # v3.11+ Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Reviewed-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-09-08Merge tag 'libnvdimm-for-4.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm Pull libnvdimm updates from Dan Williams: "This update has successfully completed a 0day-kbuild run and has appeared in a linux-next release. The changes outside of the typical drivers/nvdimm/ and drivers/acpi/nfit.[ch] paths are related to the removal of IORESOURCE_CACHEABLE, the introduction of memremap(), and the introduction of ZONE_DEVICE + devm_memremap_pages(). Summary: - Introduce ZONE_DEVICE and devm_memremap_pages() as a generic mechanism for adding device-driver-discovered memory regions to the kernel's direct map. This facility is used by the pmem driver to enable pfn_to_page() operations on the page frames returned by DAX ('direct_access' in 'struct block_device_operations'). For now, the 'memmap' allocation for these "device" pages comes from "System RAM". Support for allocating the memmap from device memory will arrive in a later kernel. - Introduce memremap() to replace usages of ioremap_cache() and ioremap_wt(). memremap() drops the __iomem annotation for these mappings to memory that do not have i/o side effects. The replacement of ioremap_cache() with memremap() is limited to the pmem driver to ease merging the api change in v4.3. Completion of the conversion is targeted for v4.4. - Similar to the usage of memcpy_to_pmem() + wmb_pmem() in the pmem driver, update the VFS DAX implementation and PMEM api to provide persistence guarantees for kernel operations on a DAX mapping. - Convert the ACPI NFIT 'BLK' driver to map the block apertures as cacheable to improve performance. - Miscellaneous updates and fixes to libnvdimm including support for issuing "address range scrub" commands, clarifying the optimal 'sector size' of pmem devices, a clarification of the usage of the ACPI '_STA' (status) property for DIMM devices, and other minor fixes" * tag 'libnvdimm-for-4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/nvdimm/nvdimm: (34 commits) libnvdimm, pmem: direct map legacy pmem by default libnvdimm, pmem: 'struct page' for pmem libnvdimm, pfn: 'struct page' provider infrastructure x86, pmem: clarify that ARCH_HAS_PMEM_API implies PMEM mapped WB add devm_memremap_pages mm: ZONE_DEVICE for "device memory" mm: move __phys_to_pfn and __pfn_to_phys to asm/generic/memory_model.h dax: drop size parameter to ->direct_access() nd_blk: change aperture mapping from WC to WB nvdimm: change to use generic kvfree() pmem, dax: have direct_access use __pmem annotation dax: update I/O path to do proper PMEM flushing pmem: add copy_from_iter_pmem() and clear_pmem() pmem, x86: clean up conditional pmem includes pmem: remove layer when calling arch_has_wmb_pmem() pmem, x86: move x86 PMEM API to new pmem.h header libnvdimm, e820: make CONFIG_X86_PMEM_LEGACY a tristate option pmem: switch to devm_ allocations devres: add devm_memremap libnvdimm, btt: write and validate parent_uuid ...
2015-08-27mm: ZONE_DEVICE for "device memory"Dan Williams
While pmem is usable as a block device or via DAX mappings to userspace there are several usage scenarios that can not target pmem due to its lack of struct page coverage. In preparation for "hot plugging" pmem into the vmemmap add ZONE_DEVICE as a new zone to tag these pages separately from the ones that are subject to standard page allocations. Importantly "device memory" can be removed at will by userspace unbinding the driver of the device. Having a separate zone prevents allocation and otherwise marks these pages that are distinct from typical uniform memory. Device memory has different lifetime and performance characteristics than RAM. However, since we have run out of ZONES_SHIFT bits this functionality currently depends on sacrificing ZONE_DMA. Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Dave Hansen <dave.hansen@linux.intel.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Jerome Glisse <j.glisse@gmail.com> [hch: various simplifications in the arch interface] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com>
2015-08-27Merge branch 'next' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/scottwood/linux into next Freescale updates from Scott: "Highlights include 32-bit memcpy/memset optimizations, checksum optimizations, 85xx config fragments and updates, device tree updates, e6500 fixes for non-SMP, and misc cleanup and minor fixes."
2015-08-18powerpc/numa: initialize distance lookup table from drconf pathNikunj A Dadhania
In some situations, a NUMA guest that supports ibm,dynamic-memory-reconfiguration node will end up having flat NUMA distances between nodes. This is because of two problems in the current code. 1) Different representations of associativity lists. There is an assumption about the associativity list in initialize_distance_lookup_table(). Associativity list has two forms: a) [cpu,memory]@x/ibm,associativity has following format: <N> <N integers> b) ibm,dynamic-reconfiguration-memory/ibm,associativity-lookup-arrays <M> <N> <M associativity lists each having N integers> M = the number of associativity lists N = the number of entries per associativity list Fix initialize_distance_lookup_table() so that it does not assume "case a". And update the caller to skip the length field before sending the associativity list. 2) Distance table not getting updated from drconf path. Node distance table will not get initialized in certain cases as ibm,dynamic-reconfiguration-memory path does not initialize the lookup table. Call initialize_distance_lookup_table() from drconf path with appropriate associativity list. Reported-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Signed-off-by: Nikunj A Dadhania <nikunj@linux.vnet.ibm.com> Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-18powerpc/mm: Drop CONFIG_PPC_HAS_HASH_64KMichael Ellerman
The relation between CONFIG_PPC_HAS_HASH_64K and CONFIG_PPC_64K_PAGES is painfully complicated. But if we rearrange it enough we can see that PPC_HAS_HASH_64K essentially depends on PPC_STD_MMU_64 && PPC_64K_PAGES. We can then notice that PPC_HAS_HASH_64K is used in files that are only built for PPC_STD_MMU_64, meaning it's equivalent to PPC_64K_PAGES. So replace all uses and drop it. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2015-08-18powerpc/cell: Drop support for 64K local store on 4K kernelsMichael Ellerman
Back in the olden days we added support for using 64K pages to map the SPU (Synergistic Processing Unit) local store on Cell, when the main kernel was using 4K pages. This was useful at the time because distros were using 4K pages, but using 64K pages on the SPUs could reduce TLB pressure there. However these days the number of Cell users is approaching zero, and supporting this option adds unpleasant complexity to the memory management code. So drop the option, CONFIG_SPU_FS_64K_LS, and all related code. Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Acked-by: Jeremy Kerr <jk@ozlabs.org>
2015-08-17powerpc/e6500: hw tablewalk: optimize a bit for tcd lock acquiring codesKevin Hao
It makes no sense to put the instructions for calculating the lock value (cpu number + 1) and the clearing of eq bit of cr1 in lbarx/stbcx loop. And when the lock is acquired by the other thread, the current lock value has no chance to equal with the lock value used by current cpu. So we can skip the comparing for these two lock values in the lbz/bne loop. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-12powerpc/slb: Add documentation on runtime patching of SLB encodingAnshuman Khandual
This patch adds some documentation to patch_slb_encoding() explaining how it works. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> [mpe: Update change log and mention the signedness of the immediate] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-12powerpc/slb: Rename all the 'slot' occurrences to 'entry'Anshuman Khandual
The SLB code uses 'slot' and 'entry' interchangeably, change it to always use 'entry'. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> [mpe: Rewrite change log] Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-12powerpc/slb: Remove a duplicate extern variableAnshuman Khandual
This patch just removes one redundant entry for one extern variable 'slb_compare_rr_to_size' from the scope. This patch does not change any functionality. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-08-07powerpc/fsl: Force coherent memory on e500mc derivativesScott Wood
In CoreNet systems it is not allowed to mix M and non-M mappings to the same memory, and coherent DMA accesses are considered to be M mappings for this purpose. Ignoring this has been observed to cause hard lockups in non-SMP kernels on e6500. Furthermore, e6500 implements the LRAT (logical to real address table) which allows KVM guests to control the WIMGE bits. This means that KVM cannot force the M bit on the way it usually does, so the guest had better set it itself. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-07powerpc/booke64: Move mb() to __set_pte_at() with kernel-addr testScott Wood
map_kernel() doesn't catch all places that create kernel PTEs. In particular, vmalloc() calls set_pte_at() directly. This causes a crash when booting a non-SMP kernel on e6500. Move the sync to __set_pte(), to be executed only for kernel addresses. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-08-07powerpc/mm: Don't call __flush_dcache_icache_phys() with PA>VAScott Wood
__flush_dcache_icache_phys() requires the ability to access the memory with the MMU disabled, which means that on a 32-bit system any memory above 4 GiB is inaccessible. In particular, mpc86xx is 32-bit and can have more than 4 GiB of RAM. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-07-06powerpc: Add plain English description for alignment exception oopsesAnton Blanchard
If we take an alignment exception which we cannot fix, the oops currently prints: Unable to handle kernel paging request for unknown fault Lets print something more useful: Unable to handle kernel paging request for unaligned access at address 0xc0000000f77bba8f Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-02Merge tag 'module_init-alternate_initcall-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull module_init replacement part two from Paul Gortmaker: "Replace module_init with appropriate alternate initcall in non modules. This series converts non-modular code that is using the module_init() call to hook itself into the system to instead use one of our alternate priority initcalls. Unlike the previous series that used device_initcall and hence was a runtime no-op, these commits change to one of the alternate initcalls, because (a) we have them and (b) it seems like the right thing to do. For example, it would seem logical to use arch_initcall for arch specific setup code and fs_initcall for filesystem setup code. This does mean however, that changes in the init ordering will be taking place, and so there is a small risk that some kind of implicit init ordering issue may lie uncovered. But I think it is still better to give these ones sensible priorities than to just assign them all to device_initcall in order to exactly preserve the old ordering. Thad said, we have already made similar changes in core kernel code in commit c96d6660dc65 ("kernel: audit/fix non-modular users of module_init in core code") without any regressions reported, so this type of change isn't without precedent. It has also got the same local testing and linux-next coverage as all the other pull requests that I'm sending for this merge window have got. Once again, there is an unused module_exit function removal that shows up as an outlier upon casual inspection of the diffstat" * tag 'module_init-alternate_initcall-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: x86: perf_event_intel_pt.c: use arch_initcall to hook in enabling x86: perf_event_intel_bts.c: use arch_initcall to hook in enabling mm/page_owner.c: use late_initcall to hook in enabling lib/list_sort: use late_initcall to hook in self tests arm: use subsys_initcall in non-modular pl320 IPC code powerpc: don't use module_init for non-modular core hugetlb code powerpc: use subsys_initcall for Freescale Local Bus x86: don't use module_init for non-modular core bootflag code netfilter: don't use module_init/exit in core IPV4 code fs/notify: don't use module_init for non-modular inotify_user code mm: replace module_init usages with subsys_initcall in nommu.c
2015-06-26Merge tag 'driver-core-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg KH: "Here is the driver core / firmware changes for 4.2-rc1. A number of small changes all over the place in the driver core, and in the firmware subsystem. Nothing really major, full details in the shortlog. Some of it is a bit of churn, given that the platform driver probing changes was found to not work well, so they were reverted. All of these have been in linux-next for a while with no reported issues" * tag 'driver-core-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (31 commits) Revert "base/platform: Only insert MEM and IO resources" Revert "base/platform: Continue on insert_resource() error" Revert "of/platform: Use platform_device interface" Revert "base/platform: Remove code duplication" firmware: add missing kfree for work on async call fs: sysfs: don't pass count == 0 to bin file readers base:dd - Fix for typo in comment to function driver_deferred_probe_trigger(). base/platform: Remove code duplication of/platform: Use platform_device interface base/platform: Continue on insert_resource() error base/platform: Only insert MEM and IO resources firmware: use const for remaining firmware names firmware: fix possible use after free on name on asynchronous request firmware: check for file truncation on direct firmware loading firmware: fix __getname() missing failure check drivers: of/base: move of_init to driver_init drivers/base: cacheinfo: fix annoying typo when DT nodes are absent sysfs: disambiguate between "error code" and "failure" in comments driver-core: fix build for !CONFIG_MODULES driver-core: make __device_attach() static ...
2015-06-24mm: clarify that the function operates on hugepage pteAneesh Kumar K.V
We have confusing functions to clear pmd, pmd_clear_* and pmd_clear. Add _huge_ to pmdp_clear functions so that we are clear that they operate on hugepage pte. We don't bother about other functions like pmdp_set_wrprotect, pmdp_clear_flush_young, because they operate on PTE bits and hence indicate they are operating on hugepage ptes Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24powerpc/mm: use generic version of pmdp_clear_flush()Aneesh Kumar K.V
Also move the pmd_trans_huge check to generic code. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/thp: split out pmd collapse flush into separate functionsAneesh Kumar K.V
Architectures like ppc64 [1] need to do special things while clearing pmd before a collapse. For them this operation is largely different from a normal hugepage pte clear. Hence add a separate function to clear pmd before collapse. After this patch pmdp_* functions operate only on hugepage pte, and not on regular pmd_t values pointing to page table. [1] ppc64 needs to invalidate all the normal page pte mappings we already have inserted in the hardware hash page table. But before doing that we need to make sure there are no parallel hash page table insert going on. So we need to do a kick_all_cpus_sync() before flushing the older hash table entries. By moving this to a separate function we capture these details and mention how it is different from a hugepage pte clear. This patch is a cleanup and only does code movement for clarity. There should not be any change in functionality. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/hugetlb: reduce arch dependent code about huge_pmd_unshareZhang Zhen
Currently we have many duplicates in definitions of huge_pmd_unshare. In all architectures this function just returns 0 when CONFIG_ARCH_WANT_HUGE_PMD_SHARE is N. This patch puts the default implementation in mm/hugetlb.c and lets these architectures use the common code. Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Tony Luck <tony.luck@intel.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Rientjes <rientjes@google.com> Cc: James Yang <James.Yang@freescale.com> Cc: Aneesh Kumar <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24Merge tag 'powerpc-4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - disable the 32-bit vdso when building LE, so we can build with a 64-bit only toolchain. - EEH fixes from Gavin & Richard. - enable the sys_kcmp syscall from Laurent. - sysfs control for fastsleep workaround from Shreyas. - expose OPAL events as an irq chip by Alistair. - MSI ops moved to pci_controller_ops by Daniel. - fix for kernel to userspace backtraces for perf from Anton. - merge pseries and pseries_le defconfigs from Cyril. - CXL in-kernel API from Mikey. - OPAL prd driver from Jeremy. - fix for DSCR handling & tests from Anshuman. - Powernv flash mtd driver from Cyril. - dynamic DMA Window support on powernv from Alexey. - LLVM clang fixes & workarounds from Anton. - reworked version of the patch to abort syscalls when transactional. - fix the swap encoding to support 4TB, from Aneesh. - various fixes as usual. - Freescale updates from Scott: Highlights include more 8xx optimizations, an e6500 hugetlb optimization, QMan device tree nodes, t1024/t1023 support, and various fixes and cleanup. * tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits) cxl: Fix typo in debug print cxl: Add CXL_KERNEL_API config option powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma() powerpc/mm: Change the swap encoding in pte. powerpc/mm: PTE_RPN_MAX is not used, remove the same powerpc/tm: Abort syscalls in active transactions powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off powerpc/include: Add opal-prd to installed uapi headers powerpc/powernv: fix construction of opal PRD messages powerpc/powernv: Increase opal-irqchip initcall priority powerpc: Make doorbell check preemption safe powerpc/powernv: pnv_init_idle_states() should only run on powernv macintosh/nvram: Remove as unused powerpc: Don't use gcc specific options on clang powerpc: Don't use -mno-strict-align on clang powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it powerpc: Only use -mabi=altivec if toolchain supports it powerpc: Fix duplicate const clang warning in user access code vfio: powerpc/spapr: Support Dynamic DMA windows vfio: powerpc/spapr: Register memory and define IOMMU v2 ...
2015-06-19Merge branch 'next' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/scottwood/linux into next Freescale updates from Scott: "Highlights include more 8xx optimizations, an e6500 hugetlb optimization, QMan device tree nodes, t1024/t1023 support, and various fixes and cleanup."
2015-06-16powerpc: don't use module_init for non-modular core hugetlb codePaul Gortmaker
The hugetlbpage.o is obj-y (always built in). It will never be modular, so using module_init as an alias for __initcall is somewhat misleading. Fix this up now, so that we can relocate module_init from init.h into module.h in the future. If we don't do this, we'd have to add module.h to obviously non-modular code, and that would be a worse thing. Note that direct use of __initcall is discouraged, vs. one of the priority categorized subgroups. As __initcall gets mapped onto device_initcall, our use of arch_initcall (which makes sense for arch code) will thus change this registration from level 6-device to level 3-arch (i.e. slightly earlier). However no observable impact of that small difference has been observed during testing, or is expected. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-06-11powerpc/mmu: Add userspace-to-physical addresses translation cacheAlexey Kardashevskiy
We are adding support for DMA memory pre-registration to be used in conjunction with VFIO. The idea is that the userspace which is going to run a guest may want to pre-register a user space memory region so it all gets pinned once and never goes away. Having this done, a hypervisor will not have to pin/unpin pages on every DMA map/unmap request. This is going to help with multiple pinning of the same memory. Another use of it is in-kernel real mode (mmu off) acceleration of DMA requests where real time translation of guest physical to host physical addresses is non-trivial and may fail as linux ptes may be temporarily invalid. Also, having cached host physical addresses (compared to just pinning at the start and then walking the page table again on every H_PUT_TCE), we can be sure that the addresses which we put into TCE table are the ones we already pinned. This adds a list of memory regions to mm_context_t. Each region consists of a header and a list of physical addresses. This adds API to: 1. register/unregister memory regions; 2. do final cleanup (which puts all pre-registered pages); 3. do userspace to physical address translation; 4. manage usage counters; multiple registration of the same memory is allowed (once per container). This implements 2 counters per registered memory region: - @mapped: incremented on every DMA mapping; decremented on unmapping; initialized to 1 when a region is just registered; once it becomes zero, no more mappings allowe; - @used: incremented on every "register" ioctl; decremented on "unregister"; unregistration is allowed for DMA mapped regions unless it is the very last reference. For the very last reference this checks that the region is still mapped and returns -EBUSY so the userspace gets to know that memory is still pinned and unregistration needs to be retried; @used remains 1. Host physical addresses are stored in vmalloc'ed array. In order to access these in the real mode (mmu off), there is a real_vmalloc_addr() helper. In-kernel acceleration patchset will move it from KVM to MMU code. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-10powerpc/mm: Add trace point for tracking hash pte faultAneesh Kumar K.V
This enables us to understand how many hash fault we are taking when running benchmarks. For ex: -bash-4.2# ./perf stat -e powerpc:hash_fault -e page-faults /tmp/ebizzy.ppc64 -S 30 -P -n 1000 ... Performance counter stats for '/tmp/ebizzy.ppc64 -S 30 -P -n 1000': 1,10,04,075 powerpc:hash_fault 1,10,03,429 page-faults 30.865978991 seconds time elapsed NOTE: The impact of the tracepoint was not noticeable when running test. It was within the run-time variance of the test. For ex: without-patch: -------------- Performance counter stats for './a.out 3000 300': 643 page-faults # 0.089 M/sec 7.236562 task-clock (msec) # 0.928 CPUs utilized 2,179,213 stalled-cycles-frontend # 0.00% frontend cycles idle 17,174,367 stalled-cycles-backend # 0.00% backend cycles idle 0 context-switches # 0.000 K/sec 0.007794658 seconds time elapsed And with-patch: --------------- Performance counter stats for './a.out 3000 300': 643 page-faults # 0.089 M/sec 7.233746 task-clock (msec) # 0.921 CPUs utilized 0 context-switches # 0.000 K/sec 0.007854876 seconds time elapsed Performance counter stats for './a.out 3000 300': 643 page-faults # 0.087 M/sec 649 powerpc:hash_fault # 0.087 M/sec 7.430376 task-clock (msec) # 0.938 CPUs utilized 2,347,174 stalled-cycles-frontend # 0.00% frontend cycles idle 17,524,282 stalled-cycles-backend # 0.00% backend cycles idle 0 context-switches # 0.000 K/sec 0.007920284 seconds time elapsed Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-08Merge 4.1-rc7 into driver-core-nextGreg Kroah-Hartman
We want the fixes in this branch as well for testing and merge resolution. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-03cxl: Move include file cxl.h -> cxl-base.hMichael Neuling
This moves the current include file from cxl.h -> cxl-base.h. This current include file is used only to pass information between the base driver that needs to be built into the kernel and the cxl module. This is to make way for a new include/misc/cxl.h which will contain just the kernel API for other driver to use Signed-off-by: Michael Neuling <mikey@neuling.org> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03powerpc/copro: Fix faulting kernel segmentsMichael Neuling
This fixes calculating the key bits (KP and KS) in the SLB VSID for kernel mappings. I'm not CCing this to stable as there are no uses of this currently. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-02powerpc/mm: Use PFN_PHYS() in devmem_is_allowed()Scott Wood
This function can run on systems where physical addresses don't fit in unsigned long, so make sure to use the macro that contains the proper cast. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-06-02powerpc/e6500: Optimize hugepage TLB missesScott Wood
Some workloads take a lot of TLB misses despite using traditional hugepages. Handle these TLB misses in the asm fastpath rather than going through a bunch of C code. With this patch I measured around a 5x speedup in handling hugepage TLB misses. Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-06-02Merge branch 'linus' into sched/core, to resolve conflictIngo Molnar
Conflicts: arch/sparc/include/asm/topology_64.h Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-02powerpc/mm: Fix build break with STRICT_MM_TYPECHECKS && DEBUG_PAGEALLOCMichael Ellerman
If both STRICT_MM_TYPECHECKS and DEBUG_PAGEALLOC are enabled, the code in kernel_map_linear_page() is built, and so we fail with: arch/powerpc/mm/hash_utils_64.c:1478:2: error: incompatible type for argument 1 of 'htab_convert_pte_flags' Fix it by using pgprot_val(). Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-05-27sched/topology: Rename topology_thread_cpumask() to topology_sibling_cpumask()Bartosz Golaszewski
Rename topology_thread_cpumask() to topology_sibling_cpumask() for more consistency with scheduler code. Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Benoit Cousson <bcousson@baylibre.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Jean Delvare <jdelvare@suse.de> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Viresh Kumar <viresh.kumar@linaro.org> Link: http://lkml.kernel.org/r/1432645896-12588-2-git-send-email-bgolaszewski@baylibre.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-20module: add extra argument for parse_params() callbackLuis R. Rodriguez
This adds an extra argument onto parse_params() to be used as a way to make the unused callback a bit more useful and generic by allowing the caller to pass on a data structure of its choice. An example use case is to allow us to easily make module parameters for every module which we will do next. @ parse @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ extern char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )); @ parse_mod @ identifier name, args, params, num, level_min, level_max; identifier unknown, param, val, doing; type s16; @@ char *parse_args(const char *name, char *args, const struct kernel_param *params, unsigned num, s16 level_min, s16 level_max, + void *arg, int (*unknown)(char *param, char *val, const char *doing + , void *arg )) { ... } @ parse_args_found @ expression R, E1, E2, E3, E4, E5, E6; identifier func; @@ ( R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | R = parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, &func); | parse_args(E1, E2, E3, E4, E5, E6, + NULL, NULL); ) @ parse_args_unused depends on parse_args_found @ identifier parse_args_found.func; @@ int func(char *param, char *val, const char *unused + , void *arg ) { ... } @ mod_unused depends on parse_args_found @ identifier parse_args_found.func; expression A1, A2, A3; @@ - func(A1, A2, A3); + func(A1, A2, A3, NULL); Generated-by: Coccinelle SmPL Cc: cocci@systeme.lip6.fr Cc: Tejun Heo <tj@kernel.org> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Hellwig <hch@infradead.org> Cc: Felipe Contreras <felipe.contreras@gmail.com> Cc: Ewan Milne <emilne@redhat.com> Cc: Jean Delvare <jdelvare@suse.de> Cc: Hannes Reinecke <hare@suse.de> Cc: Jani Nikula <jani.nikula@intel.com> Cc: linux-kernel@vger.kernel.org Reviewed-by: Tejun Heo <tj@kernel.org> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-19mm/fault, arch: Use pagefault_disable() to check for disabled pagefaults in ↵David Hildenbrand
the handler Introduce faulthandler_disabled() and use it to check for irq context and disabled pagefaults (via pagefault_disable()) in the pagefault handlers. Please note that we keep the in_atomic() checks in place - to detect whether in irq context (in which case preemption is always properly disabled). In contrast, preempt_disable() should never be used to disable pagefaults. With !CONFIG_PREEMPT_COUNT, preempt_disable() doesn't modify the preempt counter, and therefore the result of in_atomic() differs. We validate that condition by using might_fault() checks when calling might_sleep(). Therefore, add a comment to faulthandler_disabled(), describing why this is needed. faulthandler_disabled() and pagefault_disable() are defined in linux/uaccess.h, so let's properly add that include to all relevant files. This patch is based on a patch from Thomas Gleixner. Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David.Laight@ACULAB.COM Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: akpm@linux-foundation.org Cc: benh@kernel.crashing.org Cc: bigeasy@linutronix.de Cc: borntraeger@de.ibm.com Cc: daniel.vetter@intel.com Cc: heiko.carstens@de.ibm.com Cc: herbert@gondor.apana.org.au Cc: hocko@suse.cz Cc: hughd@google.com Cc: mst@redhat.com Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: schwidefsky@de.ibm.com Cc: yang.shi@windriver.com Link: http://lkml.kernel.org/r/1431359540-32227-7-git-send-email-dahi@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-19sched/preempt, mm/kmap: Explicitly disable/enable preemption in kmap_atomic_*David Hildenbrand
The existing code relies on pagefault_disable() implicitly disabling preemption, so that no schedule will happen between kmap_atomic() and kunmap_atomic(). Let's make this explicit, to prepare for pagefault_disable() not touching preemption anymore. Reviewed-and-tested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Hildenbrand <dahi@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David.Laight@ACULAB.COM Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: airlied@linux.ie Cc: akpm@linux-foundation.org Cc: benh@kernel.crashing.org Cc: bigeasy@linutronix.de Cc: borntraeger@de.ibm.com Cc: daniel.vetter@intel.com Cc: heiko.carstens@de.ibm.com Cc: herbert@gondor.apana.org.au Cc: hocko@suse.cz Cc: hughd@google.com Cc: mst@redhat.com Cc: paulus@samba.org Cc: ralf@linux-mips.org Cc: schwidefsky@de.ibm.com Cc: yang.shi@windriver.com Link: http://lkml.kernel.org/r/1431359540-32227-5-git-send-email-dahi@linux.vnet.ibm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-12powerpc/mm: Return NULL for not present hugetlb pageAneesh Kumar K.V
We need to check whether pte is present in follow_huge_addr() and properly return NULL if mapping is not present. Also use READ_ONCE when dereferencing pte_t address. Without this patch, we may wrongly return a zero pfn page in follow_huge_addr(). Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
