path: root/arch/powerpc/kernel
2010-01-18powerpc: Handle VSX alignment faults correctly in little-endian modeNeil Campbell
commit bb7f20b1c639606def3b91f4e4aca6daeee5d80a upstream. This patch fixes the handling of VSX alignment faults in little-endian mode (the current code assumes the processor is in big-endian mode). The patch also makes the handlers clear the top 8 bytes of the register when handling an 8 byte VSX load. This is based on 2.6.32. Signed-off-by: Neil Campbell <neilc@linux.vnet.ibm.com> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18powerpc: Disable VSX or current process in giveup_fpu/altivecMichael Neuling
commit 7e875e9dc8af70d126fa632446e967327ac3fdda upstream. When we call giveup_fpu, we need to need to turn off VSX for the current process. If we don't, on return to userspace it may execute a VSX instruction before the next FP instruction, and not have its register state refreshed correctly from the thread_struct. Ditto for altivec. This caused a bug where an unaligned lfs or stfs results in fix_alignment calling giveup_fpu so it can use the FPRs (in order to do a single <-> double conversion), and then returning to userspace with FP off but VSX on. Then if a VSX instruction is executed, before another FP instruction, it will proceed without another exception and hence have the incorrect register state for VSX registers 0-31. lfs unaligned <- alignment exception turns FP off but leaves VSX on VSX instruction <- no exception since VSX on, hence we get the wrong VSX register values for VSX registers 0-31, which overlap the FPRs. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24powerpc/pseries: Fix to handle slb resize across migrationBrian King
commit 46db2f86a3b2a94e0b33e0b4548fb7b7b6bdff66 upstream. The SLB can change sizes across a live migration, which was not being handled, resulting in possible machine crashes during migration if migrating to a machine which has a smaller max SLB size than the source machine. Fix this by first reducing the SLB size to the minimum possible value, which is 32, prior to migration. Then during the device tree update which occurs after migration, we make the call to ensure the SLB gets updated. Also add the slb_size to the lparcfg output so that the migration tools can check to make sure the kernel has this capability before allowing migration in scenarios where the SLB size will change. BenH: Fixed #include <asm/mmu-hash64.h> -> <asm/mmu.h> to avoid breaking ppc32 build Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-02powerpc: Sanitize stack pointer in signal handling codeJosh Boyer
This has been backported to 2.6.27.x from commit efbda86098 in Linus' tree. On powerpc64 machines running 32-bit userspace, we can get garbage bits in the stack pointer passed into the kernel. Most places handle this correctly, but the signal handling code uses the passed value directly for allocating signal stack frames. This fixes the issue by introducing a get_clean_sp function that returns a sanitized stack pointer. For 32-bit tasks on a 64-bit kernel, the stack pointer is masked correctly. In all other cases, the stack pointer is simply returned. Additionally, we pass an 'is_32' parameter to get_sigframe now in order to get the properly sanitized stack. The callers are know to be 32 or 64-bit statically. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-16powerpc: Fix load/store float double alignment handlerMichael Neuling
commit 49f297f8df9adb797334155470ea9ca68bdb041e upstream. When we introduced VSX, we changed the way FPRs are stored in the thread_struct. Unfortunately we missed the load/store float double alignment handler code when updating how we access FPRs in the thread_struct. Below fixes this and merges the little/big endian case. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-20powerpc/vsx: Fix VSX alignment handler for regs 32-63Michael Neuling
commit 26456dcfb8d8e43b1b64b2a14710694cf7a72f05 upstream. Fix the VSX alignment handler for VSX registers > 32. 32-63 are stored in the VMX part of the thread_struct not the FPR part. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-17powerpc: Fix swapcontext system for VSX + old ucontext sizeMichael Neuling
commit 16c29d180becc5bdf92fd0fc7314a44a671b5f4e upstream. Since VSX support was added, we now have two sizes of ucontext_t; the older, smaller size without the extra VSX state, and the new larger size with the extra VSX state. A program using the sys_swapcontext system call and supplying smaller ucontext_t structures will currently get an EINVAL error if the task has used VSX (e.g. because of calling library code that uses VSX) and the old_ctx argument is non-NULL (i.e. the program is asking for its current context to be saved). Thus the program will start getting EINVAL errors on calls that previously worked. This commit changes this behaviour so that we don't send an EINVAL in this case. It will now return the smaller context but the VSX MSR bit will always be cleared to indicate that the ucontext_t doesn't include the extra VSX state, even if the task has executed VSX instructions. Both 32 and 64 bit cases are updated. [paulus@samba.org - also fix some access_ok() and get_user() calls] Thanks to Ben Herrenschmidt for noticing this problem. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-13powerpc/virtex5: Fix Virtex5 machine check handlingGrant Likely
commit 640d17d60e83401e10e66a0ab6e9e2d6350df656 upstream. The 440x5 core in the Virtex5 uses the 440A type machine check (ie, they have MCSRR0/MCSRR1). They thus need to call the appropriate fixup function to hook the right variant of the exception. Without this, all machine checks become fatal due to loss of context when entering the exception handler. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-30Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix failure to shutdown with CPU hotplug powerpc: Fix PCI in Holly device tree
2008-09-30powerpc: Fix failure to shutdown with CPU hotplugJohannes Berg
I tracked down the shutdown regression to CPUs not dying when being shut down during power-off. This turns out to be due to the system_state being SYSTEM_POWER_OFF, which this code doesn't take as a valid state for shutting off CPUs in. This has never made sense to me, but when I added hotplug code to implement hibernate I only "made it work" and did not question the need to check the system_state. Thomas Gleixner helped me dig, but the only thing we found is that it was added with the original commit that added CPU hotplug support. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Joel Schopp <jschopp@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-09-26kgdb, x86, arm, mips, powerpc: ignore user space single steppingJason Wessel
On the x86 arch, user space single step exceptions should be ignored if they occur in the kernel space, such as ptrace stepping through a system call. First check if it is kgdb that is executing a single step, then ensure it is not an accidental traversal into the user space, while in kgdb, any other time the TIF_SINGLESTEP is set, kgdb should ignore the exception. On x86, arm, mips and powerpc, the kgdb_contthread usage was inconsistent with the way single stepping is implemented in the kgdb core. The arch specific stub should always set the kgdb_cpu_doing_single_step correctly if it is single stepping. This allows kgdb to correctly process an instruction steps if ptrace happens to be requesting an instruction step over a system call. Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2008-09-17Fix compile failure with non modular buildsJames Bottomley
Commit deac93df26b20cf8438339b5935b5f5643bc30c9 ("lib: Correct printk %pF to work on all architectures") broke the non modular builds by moving an essential function into modules.c. Fix this by moving it out again and into asm/sections.h as an inline. To do this, the definition of struct ppc64_opd_entry has been lifted out of modules.c and put in asm/elf.h where it belongs. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-09lib: Correct printk %pF to work on all architecturesJames Bottomley
It was introduced by "vsprintf: add support for '%pS' and '%pF' pointer formats" in commit 0fe1ef24f7bd0020f29ffe287dfdb9ead33ca0b2. However, the current way its coded doesn't work on parisc64. For two reasons: 1) parisc isn't in the #ifdef and 2) parisc has a different format for function descriptors Make dereference_function_descriptor() more accommodating by allowing architecture overrides. I put the three overrides (for parisc64, ppc64 and ia64) in arch/kernel/module.c because that's where the kernel internal linker which knows how to deal with function descriptors sits. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-03powerpc: Fix for getting CPU number in power_save_ppc32_restore()Kumar Gala
The calculation to get TI_CPU based off of SPRG3 was just plain wrong, meaning that we were getting garbage for the CPU number on 6xx/G3/G4 based SMP boxes in this code. Just offset off the stack pointer (to get to thread_info) like all the other references to TI_CPU do. This was pointed out by Chen Gong <G.Chen@freescale.com> [paulus@samba.org - use rlwinm r12,r11,... instead of rlwinm r12,r1,...; tophys()] Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Work around gcc's -fno-omit-frame-pointer bugTony Breeds
This bug is causing random crashes (http://bugzilla.kernel.org/show_bug.cgi?id=11414). -fno-omit-frame-pointer is only needed on powerpc when -pg is also supplied, and there is a gcc bug that causes incorrect code generation on 32-bit powerpc when -fno-omit-frame-pointer is used---it uses stack locations below the stack pointer, which is not allowed by the ABI because those locations can and sometimes do get corrupted by an interrupt. This ensures that CONFIG_FRAME_POINTER is only selected by ftrace. When CONFIG_FTRACE is enabled we also pass -mno-sched-epilog to work around the gcc codegen bug. Patch based on work by: Andreas Schwab <schwab@suse.de> Segher Boessenkool <segher@kernel.crashing.org> Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Make sure _etext is after all kernel textStephen Rothwell
This makes core_kernel_text() (and therefore kernel_text_address()) return the correct result. Currently all the __devinit routines (at least) will not be considered to be kernel text. This is just a quick fix for 2.6.27 - hopefully we will be able to fix this better in 2.6.28. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-03powerpc: Fix uninitialised variable in VSX alignment codeMichael Neuling
This fixes an uninitialised variable in the VSX alignment code. It can cause warnings from GCC (noticed with gcc-4.1.1). Gcc is actually correct in this instance, and this bug could cause the alignment interrupt handler to send a SIGSEGV to the process on a legitimate access. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20powerpc: Fix vio_bus_probe oops on probe errorBrian King
When CMO is enabled and booted on a non CMO system and the VIO device's probe function fails, an oops can result since vio_cmo_bus_remove is called when it should not. This fixes it by avoiding the vio_cmo_bus_remove call on platforms that don't implement CMO. cpu 0x0: Vector: 300 (Data Access) at [c00000000e13b3d0] pc: c000000000020d34: .vio_cmo_bus_remove+0xc0/0x1f4 lr: c000000000020ca4: .vio_cmo_bus_remove+0x30/0x1f4 sp: c00000000e13b650 msr: 8000000000009032 dar: 0 dsisr: 40000000 current = 0xc00000000e0566c0 paca = 0xc0000000006f9b80 pid = 2428, comm = modprobe enter ? for help [c00000000e13b6e0] c000000000021d94 .vio_bus_probe+0x2f8/0x33c [c00000000e13b7a0] c00000000029fc88 .driver_probe_device+0x13c/0x200 [c00000000e13b830] c00000000029fdac .__driver_attach+0x60/0xa4 [c00000000e13b8c0] c00000000029f050 .bus_for_each_dev+0x80/0xd8 [c00000000e13b980] c00000000029f9ec .driver_attach+0x28/0x40 [c00000000e13ba00] c00000000029f630 .bus_add_driver+0xd4/0x284 [c00000000e13baa0] c0000000002a01bc .driver_register+0xc4/0x198 [c00000000e13bb50] c00000000002168c .vio_register_driver+0x40/0x5c [c00000000e13bbe0] d0000000003b3f1c .ibmvfc_module_init+0x70/0x109c [ibmvfc] [c00000000e13bc70] c0000000000acf08 .sys_init_module+0x184c/0x1a10 [c00000000e13be30] c000000000008748 syscall_exit+0x0/0x40 Signed-off-by: Brian King <brking@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20powerpc/ibmebus: Restore "name" sysfs attribute on ibmebus devicesJoachim Fenkes
Recent of_platform changes made of_bus_type_init() overwrite the bus type's .dev_attrs list, meaning that the "name" attribute that ibmebus devices previously had is no longer present. This is a user-visible regression which breaks the userspace eHCA support, since the eHCA userspace driver relies on the name attribute to check for valid adapters. This fixes it by providing the "name" attribute in the generic OF device code instead. Tested on POWER. Signed-off-by: Joachim Fenkes <fenkes@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-20powerpc: Fix /dev/oldmem interface for kdumpMichael Ellerman
A change to __ioremap() broke reading /dev/oldmem because we're no longer able to ioremap pfn 0 (d177c207, "[PATCH] powerpc: IOMMU: don't ioremap null addresses"). We actually don't need to ioremap for anything that's part of the linear mapping, so just read it directly. Also make sure we're only reading one page or less at a time. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Sachin Sant <sachinp@in.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Use generic compat_sys_old_readdirChristoph Hellwig
Use the generic compat_sys_old_readdir instead of the powerpc one which is almost the same except for the almost complete lack of error handling. Note that we can't just use SYSCALL() in systbl.h because the native syscall is named old_readdir, not sys_old_readdir. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc/kexec: Fix up KEXEC_CONTROL_CODE_SIZE missed during conversionPaul Collins
Commit 163f6876f5c3ff8215e900b93779e960a56b3694 missed one, resulting in the following compile error: AS arch/powerpc/kernel/misc_32.o arch/powerpc/kernel/misc_32.S: Assembler messages: arch/powerpc/kernel/misc_32.S:902: Error: unsupported relocation against KEXEC_CONTROL_CODE_SIZE make[2]: *** [arch/powerpc/kernel/misc_32.o] Error 1 make[1]: *** [arch/powerpc/kernel] Error 2 make: *** [vmlinux] Error 2 I grepped arch/ and found no further instances. Signed-off-by: Paul Collins <paul@ondioline.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Remove dead module_find_bug codeSteven Rostedt
Doing some various "make randconfig", I came across an error when CONFIG_BUG was not set: arch/powerpc/kernel/module.c: In function 'module_find_bug': arch/powerpc/kernel/module.c:111: error: increment of pointer to unknown structure arch/powerpc/kernel/module.c:111: error: arithmetic on pointer to an incomplete type arch/powerpc/kernel/module.c:112: error: dereferencing pointer to incomplete type Looking further into this, I found that module_find_bug, defined in powerpc arch code, is not called anywhere, so this just removes it. There is a static module_find_bug in lib/bug.c but that is a separate issue. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Add CMO enabled flag and paging space data to lparcfgRobert Jennings
Add a field in lparcfg output to indicate whether the kernel is running on a dedicated or shared memory lpar. Added fields to show the paging space pool IDs and the CMO page size. Submitted-by: Robert Jennings <rcj@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-18powerpc: Fix TLB invalidation on boot on 32-bitRocky Craig
The intent of "flush_tlbs" is to invalidate all TLB entries by doing a TLB invalidate instruction for all pages in the address range 0 to 0x00400000. A loop counter is set up at the high value and decremented by page size. However, the loop is only done once as the sense of the conditional branch at the loop end does not match the setup/decrement. This fixes it to do the whole range by correcting the branch condition. Signed-off-by: Rocky Craig <rocky.craig@hp.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-15kexec jump: rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZEHuang Ying
Rename KEXEC_CONTROL_CODE_SIZE to KEXEC_CONTROL_PAGE_SIZE, because control page is used for not only code on some platform. For example in kexec jump, it is used for data and stack too. [akpm@linux-foundation.org: unbreak powerpc and arm, finish conversion] Signed-off-by: Huang Ying <ying.huang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-11powerpc/pci: Don't keep ISA memory hole resources in the treeBenjamin Herrenschmidt
When we have an ISA memory hole (ie, a PCI window that allows us to generate PCI memory cycles at low PCI address) mixed with other resources using a different CPU <=> PCI mapping, we must not keep the ISA hole in the bridge resource list. If we do, things might start trying to allocate device resources in there and will get the PCI addresses wrong. This fixes it by arranging to remove the ISA memory hole resource in this case. This fixes various cases of PCMCIA breakage on PowerBooks using the MPC106 "grackle" bridge. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-11powerpc: Zero fill the return values of rtas argument bufferNathan Fontenot
The kernel copy of the rtas args struct contains the return value(s) for the specified rtas call. These are copied back to user space with the assumption that every value has been set by the rtas call, which turns out to be not always true. Thus userspace can see random values and think the call failed when in fact it succeeded, but for some reason didn't set one of the return values. This fixes the problem by zeroing out the return value fields of the rtas args struct before processing the rtas call. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-08-04powerpc: Remove use of CONFIG_PPC_MERGEKumar Gala
Now that arch/ppc is gone and CONFIG_PPC_MERGE is always set, remove the dead code associated with !CONFIG_PPC_MERGE from arch/powerpc and include/asm-powerpc. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-07-30powerpc: Don't use the wrong thread_struct for ptrace get/set VSX regsMichael Neuling
In PTRACE_GET/SETVSRREGS, we should be using the thread we are ptracing rather than current. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-30powerpc: Fix ptrace buffer size for VSXMichael Neuling
Fix cut-and-paste error in the size setting for ptrace buffers for VSX. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-30powerpc: Correctly hookup PTRACE_GET/SETVSRREGS for 32 bit processesMichael Neuling
Fix bug where PTRACE_GET/SETVSRREGS are not connected for 32 bit processes. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-30powerpc: Allow non-hcall return values for lparcfg writesNathan Fontenot
The code to handle writes to /proc/ppc64/lparcfg incorrectly assumes that the return code from the helper routines to update processor or memory entitlement return a hcall return value. It then assumes any non-hcall return value is bad and sets the return code for the write to be -EIO. The update_[mp]pp routines can return values other than a hcall return value. This patch removes the automatic setting of any return code that is not an hcall return value from these routines to -EIO. Signed-off-by: Nathan Fontenot <nfont@austin.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc/powermac: Fixup default serial port device for pmac_zilogBenjamin Herrenschmidt
This removes the non-working code in legacy_serial that tried to handle the powermac SCC ports, and instead add a (now working) function to the powermac platform code to find the default serial console if any. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Show processor cache information in sysfsNathan Lynch
Collect cache information from the OF device tree and display it in the cpu hierarchy in sysfs. This is intended to be compatible at the userspace level with x86's implementation[1], hence some of the funny attribute names. The arrangement of cache info is not immediately intuitive, but (again) it's for compatibility's sake. The cache attributes exposed are: type (Data, Instruction, or Unified) level (1, 2, 3...) size coherency_line_size number_of_sets ways_of_associativity All of these can be derived on platforms that follow the OF PowerPC Processor binding. The code "publishes" only those attributes for which it is able to determine values; attributes for values which cannot be determined are not created at all. [1] arch/x86/kernel/cpu/intel_cacheinfo.c BenH: Turned some printk's into pr_debug, added better NULL checking in a couple of places. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Make core id information available to userspaceNathan Lynch
Existing Open Firmware practice is to report each processor core as a separate node in the device tree. Report the value of the "reg" OF property corresponding to a logical CPU's device node as the core_id attribute in /sys/devices/system/cpu/cpu*/topology/core_id. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Make core sibling information available to userspaceNathan Lynch
Implement the notion of "core siblings" for powerpc. This makes /sys/devices/system/cpu/cpu*/topology/core_siblings present sensible values, indicating online CPUs which share an L2 cache. BenH: Made cpu_to_l2cache() use of_find_node_by_phandle() instead of IBM-specific open coded search Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc/vio: More fallout from dma_mapping_error API changeStephen Rothwell
arch/powerpc/kernel/vio.c:533: error: too few arguments to function 'dma_mapping_error' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Add TIF_NOTIFY_RESUME support for tracehookRoland McGrath
This adds TIF_NOTIFY_RESUME support for powerpc. When set, we call tracehook_notify_resume() on the way to user mode. This overloads do_signal() to do the work, but changes its arguments to it has the TIF_* bits handy in a register and drops the useless first argument that was always zero. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Make syscall tracing use tracehook.h helpersRoland McGrath
This changes powerpc syscall tracing to use the new tracehook.h entry points. There is no change, only cleanup. In addition, the assembly changes allow do_syscall_trace_enter() to abort the syscall without losing the information about the original r0 value. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Call tracehook_signal_handler() when setting up signal framesRoland McGrath
This makes the powerpc signal handling code call tracehook_signal_handler() after a handler is set up. This means that using PTRACE_SINGLESTEP to enter a signal handler will report to ptrace on the first instruction of the handler, instead of the second. This is consistent with what x86 and other machines do, and what users and debuggers want. BenH: Fixed up the test for the trap value. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Update cpu_sibling_maps dynamicallyNathan Lynch
Rather doing one initialization pass over all the per-cpu cpu_sibling_maps at boot, update the maps at cpu online/offline time. This is a behavior change -- the thread_siblings attribute now reflects only online siblings, whereas it would display offline siblings before. The new behavior matches that of x86, and is arguably more useful. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: register_cpu_online should be __cpuinitNathan Lynch
It is called only in cpu online paths. (caught by CONFIG_DEBUG_SECTION_MISMATCH=y) Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: kill useless SMT code in prom_hold_cpusNathan Lynch
This piece of code is broken for >2 threads, and possibly in some other subtle ways (such as comparing a value obtained from an "ibm,ppc-interrupt-server#s" property to a value obtained from a "reg" property) and doesn't seem to have any useful purpose in the first place other than a dubious warning in case NR_CPUS is too small, which probably isn't the right place to do so. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Fix vio build warningsNathan Lynch
arch/powerpc/kernel/vio.c:1034: warning: function declaration isn’t a prototype arch/powerpc/kernel/vio.c:1035: warning: function declaration isn’t a prototype Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc/booke: Clean up the hardware watchpoint supportKumar Gala
* CONFIG_BOOKE is selected by CONFIG_44x so we dont need both * Fixed a few comments * Go back to only using DBCR0_IDM to determine if we are using debug resources. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-28powerpc: Removed duplicated include in stacktrace.cHuang Weiyi
Removed duplicated include file <linux/module.h> in arch/powerpc/kernel/stacktrace.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kexec jumpHuang Ying
This patch provides an enhancement to kexec/kdump. It implements the following features: - Backup/restore memory used by the original kernel before/after kexec. - Save/restore CPU state before/after kexec. The features of this patch can be used as a general method to call program in physical mode (paging turning off). This can be used to call BIOS code under Linux. kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 Usage example of calling some physical mode code and return: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_KEXEC=y CONFIG_PM=y CONFIG_KEXEC_JUMP=y 2. Build patched kexec-tool or download the pre-built one. 3. Build some physical mode executable named such as "phy_mode" 4. Boot kernel compiled in step 1. 5. Load physical mode executable with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context --args-none phy_mode 6. Call physical mode executable with following shell command line: /sbin/kexec -e Implementation point: To support jumping without reserving memory. One shadow backup page (source page) is allocated for each page used by kexeced code image (destination page). When do kexec_load, the image of kexeced code is loaded into source pages, and before executing, the destination pages and the source pages are swapped, so the contents of destination pages are backupped. Before jumping to the kexeced code image and after jumping back to the original kernel, the destination pages and the source pages are swapped too. C ABI (calling convention) is used as communication protocol between kernel and called code. A flag named KEXEC_PRESERVE_CONTEXT for sys_kexec_load is added to indicate that the loaded kernel image is used for jumping back. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26powerpc: Fix boot problem due to AT_BASE_PLATFORM changeNathan Lynch
Commit 9115d13453dee22473a1e8cacc90a8d64a9c4bc9 ("powerpc: Enable AT_BASE_PLATFORM aux vector") broke boot on 32-bit powerpc systems; we have to use PTRRELOC to initialize powerpc_base_platform this early in boot. Bug reported by Jon Smirl. Signed-off-by: Nathan Lynch <ntl@pobox.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
