path: root/arch/powerpc/kernel
2013-05-06powerpc/topology: Fix spurr attribute permissionBenjamin Herrenschmidt
We are registering the attribute with permission 0600 but it doesn't have a store callback, which causes WARN_ON's during boot. Fix the permission. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pci: Support per-aperture memory offsetBenjamin Herrenschmidt
The PCI core supports an offset per aperture nowadays but our arch code still has a single offset per host bridge representing the difference betwen CPU memory addresses and PCI MMIO addresses. This is a problem as new machines and hypervisor versions are coming out where the 64-bit windows will have a different offset (basically mapped 1:1) from the 32-bit windows. This fixes it by using separate offsets. In the long run, we probably want to get rid of that intermediary struct pci_controller and have those directly stored into the pci_host_bridge as they are parsed but this will be a more invasive change. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/pci: Don't add bogus empty resources to PHBsBenjamin Herrenschmidt
When converting to use the new pci_add_resource_offset() we didn't properly account for empty resources (0 flags) and add those bogons to the PHBs. The result is some annoying messages in the log. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cputable: Advertise support for ISEL/HTM/DSCR/TAR on POWER8Nishanth Aravamudan
Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc/cputable: Advertise ISEL support on appropriate embedded processorsNishanth Aravamudan
2013-05-06powerpc/cputable: Advertise DSCR support on P7/P7+Nishanth Aravamudan
2013-05-06powerpc/pseries: Perform proper max_bus_speed detectionKleber Sacilotto de Souza
On pseries machines the detection for max_bus_speed should be done through an OpenFirmware property. This patch adds a function to perform this detection and a hook to perform dynamic adding of the function only for pseries. This is done by overwriting the weak pcibios_root_bridge_prepare function which is called by pci_create_root_bus(). From: Lucas Kannebley Tavares <lucaskt@linux.vnet.ibm.com> Signed-off-by: Kleber Sacilotto de Souza <klebers@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-06powerpc: Emulate non privileged DSCR read and writeAnton Blanchard
POWER8 allows read and write of the DSCR in userspace. We added kernel emulation so applications could always use the instructions regardless of the CPU type. Unfortunately there are two SPRs for the DSCR and we only added emulation for the privileged one. Add code to match the non privileged one. A simple test was created to verify the fix: http://ozlabs.org/~anton/junkcode/user_dscr_test.c Without the patch we get a SIGILL and it passes with the patch. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-05Merge tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull kvm updates from Gleb Natapov: "Highlights of the updates are: general: - new emulated device API - legacy device assignment is now optional - irqfd interface is more generic and can be shared between arches x86: - VMCS shadow support and other nested VMX improvements - APIC virtualization and Posted Interrupt hardware support - Optimize mmio spte zapping ppc: - BookE: in-kernel MPIC emulation with irqfd support - Book3S: in-kernel XICS emulation (incomplete) - Book3S: HV: migration fixes - BookE: more debug support preparation - BookE: e6500 support ARM: - reworking of Hyp idmaps s390: - ioeventfd for virtio-ccw And many other bug fixes, cleanups and improvements" * tag 'kvm-3.10-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (204 commits) kvm: Add compat_ioctl for device control API KVM: x86: Account for failing enable_irq_window for NMI window request KVM: PPC: Book3S: Add API for in-kernel XICS emulation kvm/ppc/mpic: fix missing unlock in set_base_addr() kvm/ppc: Hold srcu lock when calling kvm_io_bus_read/write kvm/ppc/mpic: remove users kvm/ppc/mpic: fix mmio region lists when multiple guests used kvm/ppc/mpic: remove default routes from documentation kvm: KVM_CAP_IOMMU only available with device assignment ARM: KVM: iterate over all CPUs for CPU compatibility check KVM: ARM: Fix spelling in error message ARM: KVM: define KVM_ARM_MAX_VCPUS unconditionally KVM: ARM: Fix API documentation for ONE_REG encoding ARM: KVM: promote vfp_host pointer to generic host cpu context ARM: KVM: add architecture specific hook for capabilities ARM: KVM: perform HYP initilization for hotplugged CPUs ARM: KVM: switch to a dual-step HYP init code ARM: KVM: rework HYP page table freeing ARM: KVM: enforce maximum size for identity mapped code ARM: KVM: move to a KVM provided HYP idmap ...
2013-05-02Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc update from Benjamin Herrenschmidt: "The main highlights this time around are: - A pile of addition POWER8 bits and nits, such as updated performance counter support (Michael Ellerman), new branch history buffer support (Anshuman Khandual), base support for the new PCI host bridge when not using the hypervisor (Gavin Shan) and other random related bits and fixes from various contributors. - Some rework of our page table format by Aneesh Kumar which fixes a thing or two and paves the way for THP support. THP itself will not make it this time around however. - More Freescale updates, including Altivec support on the new e6500 cores, new PCI controller support, and a pile of new boards support and updates. - The usual batch of trivial cleanups & fixes" * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (156 commits) powerpc: Fix build error for book3e powerpc: Context switch the new EBB SPRs powerpc: Turn on the EBB H/FSCR bits powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207S powerpc: Setup BHRB instructions facility in HFSCR for POWER8 powerpc: Fix interrupt range check on debug exception powerpc: Update tlbie/tlbiel as per ISA doc powerpc: Print page size info during boot powerpc: print both base and actual page size on hash failure powerpc: Fix hpte_decode to use the correct decoding for page sizes powerpc: Decode the pte-lp-encoding bits correctly. powerpc: Use encode avpn where we need only avpn values powerpc: Reduce PTE table memory wastage powerpc: Move the pte free routines from common header powerpc: Reduce the PTE_INDEX_SIZE powerpc: Switch 16GB and 16MB explicit hugepages to a different page table format powerpc: New hugepage directory format powerpc: Don't truncate pgd_index wrongly powerpc: Don't hard code the size of pte page powerpc: Save DAR and DSISR in pt_regs on MCE ...
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-05-02powerpc: Context switch the new EBB SPRsMichael Ellerman
This context switches the new Event Based Branching (EBB) SPRs. The three new SPRs are: - Event Based Branch Handler Register (EBBHR) - Event Based Branch Return Register (EBBRR) - Branch Event Status and Control Register (BESCR) Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Matt Evans <matt@ozlabs.org> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02powerpc: Turn on the EBB H/FSCR bitsMichael Neuling
This turns Event Based Branching (EBB) on in the Hypervisor Facility Status and Control Register (HFSCR) and Facility Status and Control Register (FSCR). Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02powerpc: Replace CPU_FTR_BCTAR with CPU_FTR_ARCH_207SMichael Ellerman
We are getting low on cpu feature bits. So rather than add a separate bit for every new Power8 feature, add a bit for arch 2.07 server catagory and use that instead. Hijack the value we had for BCTAR, but swap the value with CFAR so that all the ARCH defines are together. Note we don't touch CPU_FTR_TM, because it is conditionally enabled if the kernel is built with TM support. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02powerpc: Setup BHRB instructions facility in HFSCR for POWER8Anshuman Khandual
Make BHRB instructions available in problem and privileged states. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-02powerpc: Fix interrupt range check on debug exceptionBharat Bhushan
We do not want to take single step and branch-taken debug exception in kernel exception code. But the address range check was not covering all kernel exception handlers address range. With this patch we defined the interrupt_end label which defines the end on kernel exception code. So now we check interrupt_base to interrupt_end range for not handling debug exception in kernel exception entry. Signed-off-by: Bharat Bhushan <bharat.bhushan@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-05-01ppc: Clean up rtas_flash driver somewhatDavid Howells
Clean up some of the problems with the rtas_flash driver: (1) It shouldn't fiddle with the internals of the procfs filesystem (altering pde->count). (2) If pid namespaces are in effect, then you can get multiple inodes connected to a single pde, thereby rendering the pde->count > 2 test useless. (3) The pde->count fudging doesn't work for forked, dup'd or cloned file descriptors, so add static mutexes and use them to wrap access to the driver through read, write and release methods. (4) The driver can only handle one device, so allocate most of the data previously attached to the pde->data as static variables instead (though allocate the validation data buffer with kmalloc). (5) We don't need to save the pde pointers as long as we have the filenames available for removal. (6) Don't try to multiplex what the update file read method does based on the filename. Instead provide separate file ops and split the function. Whilst we're at it, tabulate the procfile information and loop through it when creating or destroying them rather than manually coding each one. [Folded fixes from Vasant Hegde <hegdevasant@linux.vnet.ibm.com>] Signed-off-by: David Howells <dhowells@redhat.com> cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> cc: Paul Mackerras <paulus@samba.org> cc: Anton Blanchard <anton@samba.org> cc: linuxppc-dev@lists.ozlabs.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01proc: Supply PDE attribute setting accessor functionsDavid Howells
Supply accessor functions to set attributes in proc_dir_entry structs. The following are supplied: proc_set_size() and proc_set_user(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> cc: linuxppc-dev@lists.ozlabs.org cc: linux-media@vger.kernel.org cc: netdev@vger.kernel.org cc: linux-wireless@vger.kernel.org cc: linux-pci@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-30dump_stack: unify debug information printed by show_regs()Tejun Heo
show_regs() is inherently arch-dependent but it does make sense to print generic debug information and some archs already do albeit in slightly different forms. This patch introduces a generic function to print debug information from show_regs() so that different archs print out the same information and it's much easier to modify what's printed. show_regs_print_info() prints out the same debug info as dump_stack() does plus task and thread_info pointers. * Archs which didn't print debug info now do. alpha, arc, blackfin, c6x, cris, frv, h8300, hexagon, ia64, m32r, metag, microblaze, mn10300, openrisc, parisc, score, sh64, sparc, um, xtensa * Already prints debug info. Replaced with show_regs_print_info(). The printed information is superset of what used to be there. arm, arm64, avr32, mips, powerpc, sh32, tile, unicore32, x86 * s390 is special in that it used to print arch-specific information along with generic debug info. Heiko and Martin think that the arch-specific extra isn't worth keeping s390 specfic implementation. Converted to use the generic version. Note that now all archs print the debug info before actual register dumps. An example BUG() dump follows. kernel BUG at /work/os/work/kernel/workqueue.c:4841! invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #7 Hardware name: empty empty/S3992, BIOS 080011 10/26/2007 task: ffff88007c85e040 ti: ffff88007c860000 task.ti: ffff88007c860000 RIP: 0010:[<ffffffff8234a07e>] [<ffffffff8234a07e>] init_workqueues+0x4/0x6 RSP: 0000:ffff88007c861ec8 EFLAGS: 00010246 RAX: ffff88007c861fd8 RBX: ffffffff824466a8 RCX: 0000000000000001 RDX: 0000000000000046 RSI: 0000000000000001 RDI: ffffffff8234a07a RBP: ffff88007c861ec8 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff8234a07a R13: 0000000000000000 R14: 0000000000000000 R15: 0000000000000000 FS: 0000000000000000(0000) GS:ffff88007dc00000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: ffff88015f7ff000 CR3: 00000000021f1000 CR4: 00000000000007f0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Stack: ffff88007c861ef8 ffffffff81000312 ffffffff824466a8 ffff88007c85e650 0000000000000003 0000000000000000 ffff88007c861f38 ffffffff82335e5d ffff88007c862080 ffffffff8223d8c0 ffff88007c862080 ffffffff81c47760 Call Trace: [<ffffffff81000312>] do_one_initcall+0x122/0x170 [<ffffffff82335e5d>] kernel_init_freeable+0x9b/0x1c8 [<ffffffff81c47760>] ? rest_init+0x140/0x140 [<ffffffff81c4776e>] kernel_init+0xe/0xf0 [<ffffffff81c6be9c>] ret_from_fork+0x7c/0xb0 [<ffffffff81c47760>] ? rest_init+0x140/0x140 ... v2: Typo fix in x86-32. v3: CPU number dropped from show_regs_print_info() as dump_stack_print_info() has been updated to print it. s390 specific implementation dropped as requested by s390 maintainers. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Chris Metcalf <cmetcalf@tilera.com> [tile bits] Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30dump_stack: consolidate dump_stack() implementations and unify their behaviorsTejun Heo
Both dump_stack() and show_stack() are currently implemented by each architecture. show_stack(NULL, NULL) dumps the backtrace for the current task as does dump_stack(). On some archs, dump_stack() prints extra information - pid, utsname and so on - in addition to the backtrace while the two are identical on other archs. The usages in arch-independent code of the two functions indicate show_stack(NULL, NULL) should print out bare backtrace while dump_stack() is used for debugging purposes when something went wrong, so it does make sense to print additional information on the task which triggered dump_stack(). There's no reason to require archs to implement two separate but mostly identical functions. It leads to unnecessary subtle information. This patch expands the dummy fallback dump_stack() implementation in lib/dump_stack.c such that it prints out debug information (taken from x86) and invokes show_stack(NULL, NULL) and drops arch-specific dump_stack() implementations in all archs except blackfin. Blackfin's dump_stack() does something wonky that I don't understand. Debug information can be printed separately by calling dump_stack_print_info() so that arch-specific dump_stack() implementation can still emit the same debug information. This is used in blackfin. This patch brings the following behavior changes. * On some archs, an extra level in backtrace for show_stack() could be printed. This is because the top frame was determined in dump_stack() on those archs while generic dump_stack() can't do that reliably. It can be compensated by inlining dump_stack() but not sure whether that'd be necessary. * Most archs didn't use to print debug info on dump_stack(). They do now. An example WARN dump follows. WARNING: at kernel/workqueue.c:4841 init_workqueues+0x35/0x505() Hardware name: empty Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.9.0-rc1-work+ #9 0000000000000009 ffff88007c861e08 ffffffff81c614dc ffff88007c861e48 ffffffff8108f50f ffffffff82228240 0000000000000040 ffffffff8234a03c 0000000000000000 0000000000000000 0000000000000000 ffff88007c861e58 Call Trace: [<ffffffff81c614dc>] dump_stack+0x19/0x1b [<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0 [<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20 [<ffffffff8234a071>] init_workqueues+0x35/0x505 ... v2: CPU number added to the generic debug info as requested by s390 folks and dropped the s390 specific dump_stack(). This loses %ksp from the debug message which the maintainers think isn't important enough to keep the s390-specific dump_stack() implementation. dump_stack_print_info() is moved to kernel/printk.c from lib/dump_stack.c. Because linkage is per objecct file, dump_stack_print_info() living in the same lib file as generic dump_stack() means that archs which implement custom dump_stack() - at this point, only blackfin - can't use dump_stack_print_info() as that will bring in the generic version of dump_stack() too. v1 The v1 patch broke build on blackfin due to this issue. The build breakage was reported by Fengguang Wu. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [s390 bits] Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Richard Kuo <rkuo@codeaurora.org> [hexagon bits] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual stuff, mostly comment fixes, typo fixes, printk fixes and small code cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (45 commits) mm: Convert print_symbol to %pSR gfs2: Convert print_symbol to %pSR m32r: Convert print_symbol to %pSR iostats.txt: add easy-to-find description for field 6 x86 cmpxchg.h: fix wrong comment treewide: Fix typo in printk and comments doc: devicetree: Fix various typos docbook: fix 8250 naming in device-drivers pata_pdc2027x: Fix compiler warning treewide: Fix typo in printks mei: Fix comments in drivers/misc/mei treewide: Fix typos in kernel messages pm44xx: Fix comment for "CONFIG_CPU_IDLE" doc: Fix typo "CONFIG_CGROUP_CGROUP_MEMCG_SWAP" mmzone: correct "pags" to "pages" in comment. kernel-parameters: remove outdated 'noresidual' parameter Remove spurious _H suffixes from ifdef comments sound: Remove stray pluses from Kconfig file radio-shark: Fix printk "CONFIG_LED_CLASS" doc: put proper reference to CONFIG_MODULE_SIG_ENFORCE ...
2013-04-30Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull SMP/hotplug changes from Ingo Molnar: "This is a pretty large, multi-arch series unifying and generalizing the various disjunct pieces of idle routines that architectures have historically copied from each other and have grown in random, wildly inconsistent and sometimes buggy directions: 101 files changed, 455 insertions(+), 1328 deletions(-) this went through a number of review and test iterations before it was committed, it was tested on various architectures, was exposed to linux-next for quite some time - nevertheless it might cause problems on architectures that don't read the mailing lists and don't regularly test linux-next. This cat herding excercise was motivated by the -rt kernel, and was brought to you by Thomas "the Whip" Gleixner." * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits) idle: Remove GENERIC_IDLE_LOOP config switch um: Use generic idle loop ia64: Make sure interrupts enabled when we "safe_halt()" sparc: Use generic idle loop idle: Remove unused ARCH_HAS_DEFAULT_IDLE bfin: Fix typo in arch_cpu_idle() xtensa: Use generic idle loop x86: Use generic idle loop unicore: Use generic idle loop tile: Use generic idle loop tile: Enter idle with preemption disabled sh: Use generic idle loop score: Use generic idle loop s390: Use generic idle loop powerpc: Use generic idle loop parisc: Use generic idle loop openrisc: Use generic idle loop mn10300: Use generic idle loop mips: Use generic idle loop microblaze: Use generic idle loop ...
2013-04-30Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates from Ingo Molnar: "Features: - Add "uretprobes" - an optimization to uprobes, like kretprobes are an optimization to kprobes. "perf probe -x file sym%return" now works like kretprobes. By Oleg Nesterov. - Introduce per core aggregation in 'perf stat', from Stephane Eranian. - Add memory profiling via PEBS, from Stephane Eranian. - Event group view for 'annotate' in --stdio, --tui and --gtk, from Namhyung Kim. - Add support for AMD NB and L2I "uncore" counters, by Jacob Shin. - Add Ivy Bridge-EP uncore support, by Zheng Yan - IBM zEnterprise EC12 oprofile support patchlet from Robert Richter. - Add perf test entries for checking breakpoint overflow signal handler issues, from Jiri Olsa. - Add perf test entry for for checking number of EXIT events, from Namhyung Kim. - Add perf test entries for checking --cpu in record and stat, from Jiri Olsa. - Introduce perf stat --repeat forever, from Frederik Deweerdt. - Add --no-demangle to report/top, from Namhyung Kim. - PowerPC fixes plus a couple of cleanups/optimizations in uprobes and trace_uprobes, by Oleg Nesterov. Various fixes and refactorings: - Fix dependency of the python binding wrt libtraceevent, from Naohiro Aota. - Simplify some perf_evlist methods and to allow 'stat' to share code with 'record' and 'trace', by Arnaldo Carvalho de Melo. - Remove dead code in related to libtraceevent integration, from Namhyung Kim. - Revert "perf sched: Handle PERF_RECORD_EXIT events" to get 'perf sched lat' back working, by Arnaldo Carvalho de Melo - We don't use Newt anymore, just plain libslang, by Arnaldo Carvalho de Melo. - Kill a bunch of die() calls, from Namhyung Kim. - Fix build on non-glibc systems due to libio.h absence, from Cody P Schafer. - Remove some perf_session and tracing dead code, from David Ahern. - Honor parallel jobs, fix from Borislav Petkov - Introduce tools/lib/lk library, initially just removing duplication among tools/perf and tools/vm. from Borislav Petkov ... and many more I missed to list, see the shortlog and git log for more details." * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (136 commits) perf/x86/intel/P4: Robistify P4 PMU types perf/x86/amd: Fix AMD NB and L2I "uncore" support perf/x86/amd: Remove old-style NB counter support from perf_event_amd.c perf/x86: Check all MSRs before passing hw check perf/x86/amd: Add support for AMD NB and L2I "uncore" counters perf/x86/intel: Add Ivy Bridge-EP uncore support perf/x86/intel: Fix SNB-EP CBO and PCU uncore PMU filter management perf/x86: Avoid kfree() in CPU_{STARTING,DYING} uprobes/perf: Avoid perf_trace_buf_prepare/submit if ->perf_events is empty uprobes/tracing: Don't pass addr=ip to perf_trace_buf_submit() uprobes/tracing: Change create_trace_uprobe() to support uretprobes uprobes/tracing: Make seq_printf() code uretprobe-friendly uprobes/tracing: Make register_uprobe_event() paths uretprobe-friendly uprobes/tracing: Make uprobe_{trace,perf}_print() uretprobe-friendly uprobes/tracing: Introduce is_ret_probe() and uretprobe_dispatcher() uprobes/tracing: Introduce uprobe_{trace,perf}_print() helpers uprobes/tracing: Generalize struct uprobe_trace_entry_head uprobes/tracing: Kill the pointless local_save_flags/preempt_count calls uprobes/tracing: Kill the pointless seq_print_ip_sym() call uprobes/tracing: Kill the pointless task_pt_regs() calls ...
2013-04-30powerpc: Reduce PTE table memory wastageAneesh Kumar K.V
We allocate one page for the last level of linux page table. With THP and large page size of 16MB, that would mean we are wasting large part of that page. To map 16MB area, we only need a PTE space of 2K with 64K page size. This patch reduce the space wastage by sharing the page allocated for the last level of linux page table with multiple pmd entries. We call these smaller chunks PTE page fragments and allocated page, PTE page. In order to support systems which doesn't have 64K HPTE support, we also add another 2K to PTE page fragment. The second half of the PTE fragments is used for storing slot and secondary bit information of an HPTE. With this we now have a 4K PTE fragment. We use a simple approach to share the PTE page. On allocation, we bump the PTE page refcount to 16 and share the PTE page with the next 16 pte alloc request. This should help in the node locality of the PTE page fragment, assuming that the immediate pte alloc request will mostly come from the same NUMA node. We don't try to reuse the freed PTE page fragment. Hence we could be waisting some space. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-30powerpc: Save DAR and DSISR in pt_regs on MCEAneesh Kumar K.V
We were not saving DAR and DSISR on MCE. Save then and also print the values along with exception details in xmon. Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-30powerpc/booke: Remove obsolete macro FINISH_EXCEPTIONKevin Hao
This is stale and not used by anyone now. Signed-off-by: Kevin Hao <haokexin@gmail.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-30powerpc/rtas_flash: Fix bad memory accessVasant Hegde
We use kmem_cache_alloc() to allocate memory to hold the new firmware which will be flashed. kmem_cache_alloc() calls rtas_block_ctor() to set memory to NULL. But these constructor is called only for newly allocated slabs. If we run below command multiple time without rebooting, allocator may allocate memory from the area which was free'd by kmem_cache_free and it will not call constructor. In this situation we may hit kernel oops. dd if=<fw image> of=/proc/ppc64/rtas/firmware_flash bs=4096 oops message: ------------- [ 1602.399755] Oops: Kernel access of bad area, sig: 11 [#1] [ 1602.399772] SMP NR_CPUS=1024 NUMA pSeries [ 1602.399779] Modules linked in: rtas_flash nfsd lockd auth_rpcgss nfs_acl sunrpc fuse loop dm_mod sg ipv6 ses enclosure ehea ehci_pci ohci_hcd ehci_hcd usbcore sd_mod usb_common crc_t10dif scsi_dh_alua scsi_dh_emc scsi_dh_hp_sw scsi_dh_rdac scsi_dh ipr libata scsi_mod [ 1602.399817] NIP: d00000000a170b9c LR: d00000000a170b64 CTR: c00000000079cd58 [ 1602.399823] REGS: c0000003b9937930 TRAP: 0300 Not tainted (3.9.0-rc4-0.27-ppc64) [ 1602.399828] MSR: 8000000000009032 <SF,EE,ME,IR,DR,RI> CR: 22000428 XER: 20000000 [ 1602.399841] SOFTE: 1 [ 1602.399844] CFAR: c000000000005f24 [ 1602.399848] DAR: 8c2625a820631fef, DSISR: 40000000 [ 1602.399852] TASK = c0000003b4520760[3655] 'dd' THREAD: c0000003b9934000 CPU: 3 GPR00: 8c2625a820631fe7 c0000003b9937bb0 d00000000a179f28 d00000000a171f08 GPR04: 0000000010040000 0000000000001000 c0000003b9937df0 c0000003b5fb2080 GPR08: c0000003b58f7200 d00000000a179f28 c0000003b40058d4 c00000000079cd58 GPR12: d00000000a171450 c000000007f40900 0000000000000005 0000000010178d20 GPR16: 00000000100cb9d8 000000000000001d 0000000000000000 000000001003ffff GPR20: 0000000000000001 0000000000000000 00003fffa0b50d30 000000001001f010 GPR24: 0000000010020888 0000000010040000 d00000000a171f08 d00000000a172808 GPR28: 0000000000001000 0000000010040000 c0000003b4005880 8c2625a820631fe7 [ 1602.399924] NIP [d00000000a170b9c] .rtas_flash_write+0x7c/0x1e8 [rtas_flash] [ 1602.399930] LR [d00000000a170b64] .rtas_flash_write+0x44/0x1e8 [rtas_flash] [ 1602.399934] Call Trace: [ 1602.399939] [c0000003b9937bb0] [d00000000a170b64] .rtas_flash_write+0x44/0x1e8 [rtas_flash] (unreliable) [ 1602.399948] [c0000003b9937c60] [c000000000282830] .proc_reg_write+0x90/0xe0 [ 1602.399955] [c0000003b9937ce0] [c0000000001ff374] .vfs_write+0x114/0x238 [ 1602.399961] [c0000003b9937d80] [c0000000001ff5d8] .SyS_write+0x70/0xe8 [ 1602.399968] [c0000003b9937e30] [c000000000009cdc] syscall_exit+0x0/0xa0 [ 1602.399973] Instruction dump: [ 1602.399977] eb698010 801b0028 2f80dcd6 419e00a4 2fbc0000 419e009c ebfb0030 2fbf0000 [ 1602.399989] 409e0010 480000d8 60000000 7c1f0378 <e81f0008> 2fa00000 409efff4 e81f0000 [ 1602.400012] ---[ end trace b4136d115dc31dac ]--- [ 1602.402178] [ 1602.402185] Sending IPI to other CPUs [ 1602.403329] IPI complete This patch uses kmem_cache_zalloc() instead of kmem_cache_alloc() to allocate memory, which makes sure memory is set to 0 before using. Also removes rtas_block_ctor(), which is no longer required. Signed-off-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-29early_printk: consolidate random copies of identical codeThomas Gleixner
The early console implementations are the same all over the place. Move the print function to kernel/printk and get rid of the copies. [akpm@linux-foundation.org: arch/mips/kernel/early_printk.c needs kernel.h for va_list] [paul.gortmaker@windriver.com: sh4: make the bios early console support depend on EARLY_PRINTK] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Russell King <linux@arm.linux.org.uk> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Reviewed-by: Ingo Molnar <mingo@kernel.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30Merge remote-tracking branch 'kumar/next' into nextBenjamin Herrenschmidt
From Kumar Gala: << Add support for T4 and B4 SoC families from Freescale, e6500 altivec support, some various board fixes and other minor cleanups. >>
2013-04-29mm/ppc: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Anatolij Gustschin <agust@denx.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-26KVM: PPC: Book3S HV: Speed up wakeups of CPUs on HV KVMBenjamin Herrenschmidt
Currently, we wake up a CPU by sending a host IPI with smp_send_reschedule() to thread 0 of that core, which will take all threads out of the guest, and cause them to re-evaluate their interrupt status on the way back in. This adds a mechanism to differentiate real host IPIs from IPIs sent by KVM for guest threads to poke each other, in order to target the guest threads precisely when possible and avoid that global switch of the core to host state. We then use this new facility in the in-kernel XICS code. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26KVM: PPC: Book3S HV: Report VPA and DTL modifications in dirty mapPaul Mackerras
At present, the KVM_GET_DIRTY_LOG ioctl doesn't report modifications done by the host to the virtual processor areas (VPAs) and dispatch trace logs (DTLs) registered by the guest. This is because those modifications are done either in real mode or in the host kernel context, and in neither case does the access go through the guest's HPT, and thus no change (C) bit gets set in the guest's HPT. However, the changes done by the host do need to be tracked so that the modified pages get transferred when doing live migration. In order to track these modifications, this adds a dirty flag to the struct representing the VPA/DTL areas, and arranges to set the flag when the VPA/DTL gets modified by the host. Then, when we are collecting the dirty log, we also check the dirty flags for the VPA and DTL for each vcpu and set the relevant bit in the dirty log if necessary. Doing this also means we now need to keep track of the guest physical address of the VPA/DTL areas. So as not to lose track of modifications to a VPA/DTL area when it gets unregistered, or when a new area gets registered in its place, we need to transfer the dirty state to the rmap chain. This adds code to kvmppc_unpin_guest_page() to do that if the area was dirty. To simplify that code, we now require that all VPA, DTL and SLB shadow buffer areas fit within a single host page. Guests already comply with this requirement because pHyp requires that these areas not cross a 4k boundary. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Alexander Graf <agraf@suse.de>
2013-04-26powerpc: Initialise PMU related regs on Power8Michael Ellerman
For both HV and guest kernels, intialise PMU regs to something sane. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc: Fix "attempt to move .org backwards" errorPaul Mackerras
Building a 64-bit powerpc kernel with PR KVM enabled currently gives this error: AS arch/powerpc/kernel/head_64.o arch/powerpc/kernel/exceptions-64s.S: Assembler messages: arch/powerpc/kernel/exceptions-64s.S:258: Error: attempt to move .org backwards make[2]: *** [arch/powerpc/kernel/head_64.o] Error 1 This happens because the MASKABLE_EXCEPTION_PSERIES macro turns into 33 instructions, but we only have space for 32 at the decrementer interrupt vector (from 0x900 to 0x980). In the code generated by the MASKABLE_EXCEPTION_PSERIES macro, we currently have two instances of the HMT_MEDIUM macro, which has the effect of setting the SMT thread priority to medium. One is the first instruction, and is overwritten by a no-op on processors where we save the PPR (processor priority register), that is, POWER7 or later. The other is after we have saved the PPR. In order to reduce the code at 0x900 by one instruction, we omit the first HMT_MEDIUM. On processors without SMT this will have no effect since HMT_MEDIUM is a no-op there. On POWER5 and RS64 machines this will mean that the first few instructions take a little longer in the case where a decrementer interrupt occurs when the hardware thread is running at low SMT priority. On POWER6 and later machines, the hardware automatically boosts the thread priority when a decrementer interrupt is taken if the thread priority was below medium, so this change won't make any difference. The alternative would be to branch out of line after saving the CFAR. However, that would incur an extra overhead on all processors, whereas the approach adopted here only adds overhead on older threaded processors. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/pseries: Add /proc interface to control topology updatesNathan Fontenot
There are instances in which we do not want topology updates to occur. In order to allow this a /proc interface (/proc/powerpc/topology_updates) is introduced so that topology updates can be enabled and disabled. This patch also adds a prrn_is_enabled() call so that PRRN events are handled in the kernel only if topology updating is enabled. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/pseries: Enable PRRN handlingNathan Fontenot
The Linux kernel and platform firmware negotiate their mutual support of the PRRN option via the ibm,client-architecture-support interface. This patch simply sets the appropriate fields in the client architecture vector to indicate Linux support for PRRN and will allow the firmware to report PRRN events via the RTAS event-scan mechanism. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/pseries: Update firmware_has_feature() to check architecture vector ↵Nathan Fontenot
5 bits The firmware_has_feature() function makes it easy to check for supported features of the hypervisor. This patch extends the capability of firmware_has_feature() to include checking for specified bits in vector 5 of the architecture vector as reported in the device tree. As part of this the #defines used for the architecture vector are re-defined such that each option has the index into vector 5 and the feature bit encoded into it. This makes checking for architecture bits when initiating data for firmware_has_feature much easier. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/pseries: Move architecture vector definitions to prom.hNathan Fontenot
As part of handling of PRRN events we need to check vector 5 of the architecture vector bits reported in the device tree to ensure PRRN event handling is enabled. To do this firmware_has_feature() is updated (in a subsequent patch) to make this check vector 5 bits. To avoid having to re-define bits in the architecture vector the bit definitions are moved to prom.h. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/pseries: Add PRRN RTAS event handlerJesse Larrew
A PRRN event is signaled via the RTAS event-scan mechanism, which returns a Hot Plug Event message "fixed part" indicating "Platform Resource Reassignment". In response to the Hot Plug Event message, we must call ibm,update-nodes to determine which resources were reassigned and then ibm,update-properties to obtain the new affinity information about those resources. The PRRN event-scan RTAS message contains only the "fixed part" with the "Type" field set to the value 160 and no Extended Event Log. The four-byte Extended Event Log Length field is re-purposed (since no Extended Event Log message is included) to pass the "scope" parameter that causes the ibm,update-nodes to return the nodes affected by the specific resource reassignment. This patch adds a handler for RTAS events. The function pseries_devicetree_update() (from mobility.c) is used to make the ibm,update-nodes/ibm,update-properties RTAS calls. Updating the NUMA maps (handled by a subsequent patch) will require significant processing, so pseries_devicetree_update() is called from an asynchronous workqueue to allow event processing to continue. PRRN RTAS events on pseries systems are rare events that have to be initiated from the HMC console for the system by an IBM tech. This allows us to assume that these events are widely spaced. Additionally, all work on the queue is flushed before handling any new work to ensure we only have one event in flight being handled at a time. Signed-off-by: Nathan Fontenot <nfont@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc: Fix hardware IRQs with MMU on exceptions when HV=0Michael Neuling
POWER8 allows us to take interrupts with the MMU on. This gives us a second set of vectors offset at 0x4000. Unfortunately when coping these vectors we missed checking for MSR HV for hardware interrupts (0x500). This results in us trying to use HSRR0/1 when HV=0, rather than SRR0/1 on HW IRQs The below fixes this to check CPU_FTR_HVMODE when patching the code at 0x4500. Also we remove the check for CPU_FTR_ARCH_206 since relocation on IRQs are only available in arch 2.07 and beyond. Thanks to benh for helping find this. Signed-off-by: Michael Neuling <mikey@neuling.org> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc/power8: Fix secondary CPUs hanging on boot for HV=0Michael Neuling
In __restore_cpu_power8 we determine if we are HV and if not, we return before setting HV only resources. Unfortunately we forgot to restore the link register from r11 before returning. This will happen on boot and with secondary CPUs not coming online. This adds the missing link register restore. Signed-off-by: Michael Neuling <mikey@neuling.org> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-26powerpc: Add isync to copy_and_flushMichael Neuling
In __after_prom_start we copy the kernel down to zero in two calls to copy_and_flush. After the first call (copy from 0 to copy_to_here:) we jump to the newly copied code soon after. Unfortunately there's no isync between the copy of this code and the jump to it. Hence it's possible that stale instructions could still be in the icache or pipeline before we branch to it. We've seen this on real machines and it's results in no console output after: calling quiesce... returning from prom_init The below adds an isync to ensure that the copy and flushing has completed before any branching to the new instructions occurs. Signed-off-by: Michael Neuling <mikey@neuling.org> CC: <stable@vger.kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-24Merge remote-tracking branch 'origin/master' into nextBenjamin Herrenschmidt
Merge upstream to get the audit fixes
2013-04-24powerpc/rtas_flash: New return code to indicate FW entitlement expiryVasant Hegde
Add new return code to rtas_flash to indicate firmware entitlement expiry. Strictly we don't need this update. But to keep it in sync with PAPR, this was added. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-24powerpc/rtas_flash: Update return token commentsVasant Hegde
Add proper comment to ibm,validate-flash-image RTAS call update result tokens. Note: Only comment section is modified, no code change. Signed-off-by: Vasant Hegde <hegdevasant@linux.vnet.ibm.com> Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-24Merge remote-tracking branch 'mpe/master' into nextBenjamin Herrenschmidt
Merge the tentative powerpc-next branch maintained by Michael while I was on vacation
2013-04-23powerpc/pseries/lparcfg: Fix possible overflow are more than 1026Chen Gang
need set '\0' for 'local_buffer'. SPLPAR_MAXLENGTH is 1026, RTAS_DATA_BUF_SIZE is 4096. so the contents of rtas_data_buf may truncated in memcpy. if contents are really truncated. the splpar_strlen is more than 1026. the next while loop checking will not find the end of buffer. that will cause memory access violation. Signed-off-by: Chen Gang <gang.chen@asianux.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-23ptrace/powerpc: Don't flush_ptrace_hw_breakpoint() on fork()Oleg Nesterov
arch_dup_task_struct() does flush_ptrace_hw_breakpoint(src), this destroys the parent's breakpoints for no reason. We should clear child->thread.ptrace_bps[] copied by dup_task_struct() instead. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-23powerpc: Add VDSO version of timeAdhemerval Zanella
On 04/18/2013 07:38 PM, Anton Blanchard wrote: > Since you are only reading one long you shouldn't need to check the > update count and loop, you will always see a consistent value. The > system call version of time() just does an unprotected load for example. Fixed. > With the above change and with Michael's comments covered (decent > changelog entry and Signed-off-by): > > Acked-by: Anton Blanchard <anton@samba.org> Thanks for the review, below the updated patch: From: Adhemerval Zanella <azanella@linux.vnet.ibm.com> This patch implement the time syscall as vDSO. The performance speedups are: Baseline PPC32: 380 nsec Baseline PPC64: 350 nsec vdso PPC32: 20 nsec vsdo PPC64: 20 nsec Tested on 64 bit build with both 32 bit and 64 bit userland. Acked-by: Anton Blanchard <anton@samba.org> Signed-off-by: Adhemerval Zanella <azanella@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
