kdump fails because we try to execute an HV only instruction. Feature
fixups are being applied after we copy the exception vectors down to 0
so they miss out on any updates.
We have always had this issue but it only became critical in v3.0
when we added CFAR support (breaks POWER5) and v3.1 when we added
POWERNV (breaks everyone).
Cc: <stable@kernel.org> [v3.0+]
u64 is used rather than phys_addr_t to keep things simple, as
this is called from assembly code.
Update callers to pass a 64-bit address in r3/r4. Other unused
register assignments that were once parameters to machine_init
are dropped.
For FSL BookE, look up the physical address of the device tree from the
effective address passed in r3 by the loader. This is required for
situations where memory does not start at zero (due to AMP or IOMMU-less
virtualization), and thus the IMA doesn't start at zero, and thus the
device tree effective address does not equal the physical address.
Kernel loadable module can use hard_smp_processor_id() if building with SMP
kernel. In order to make it work for UP kernels too, boot_cpuid_phys
symbol (which is what hard_smp_processor_id() macro resolves to
in non-SMP configuration) must be exported.
Signed-off-by: Andrew Gabbasov <andrew_gabbasov@mentor.com>
Since other OS's may be running on the other cores don't use tlbivax
Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Signed-off-by: Tony Breeds <tony@bakeyournoodle.com>
Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Cc: linuxppc-dev@lists.ozlabs.org
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
smp_release_cpus() waits for all cpus (including the bootcpu) due to an
off-by-one count on boot_cpu_count (which is all CPUs). This patch replaces
that with spinning_secondaries (which is all secondary CPUs).
Signed-off-by: Matt Evans <matt@ozlabs.org>
We need to wait a bit for them to have done their CPU setup
or we might end up with translation and EE on with different
LPCR values between threads
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (71 commits)
powerpc/44x: Update ppc44x_defconfig
powerpc/watchdog: Make default timeout for Book-E watchdog a Kconfig option
fsl_rio: Add comments for sRIO registers.
powerpc/fsl-booke: Add e55xx (64-bit) smp defconfig
powerpc/fsl-booke: Add p5020 DS board support
powerpc/fsl-booke64: Use TLB CAMs to cover linear mapping on FSL 64-bit chips
powerpc/fsl-booke: Add support for FSL Arch v1.0 MMU in setup_page_sizes
powerpc/fsl-booke: Add support for FSL 64-bit e5500 core
powerpc/85xx: add cache-sram support
powerpc/85xx: add ngPIXIS FPGA device tree node to the P1022DS board
powerpc: Fix compile error with paca code on ppc64e
powerpc/fsl-booke: Add p3041 DS board support
oprofile/fsl emb: Don't set MSR[PMM] until after clearing the interrupt.
powerpc/fsl-booke: Add PCI device ids for P2040/P3041/P5010/P5020 QoirQ chips
powerpc/mpc8xxx_gpio: Add support for 'qoriq-gpio' controllers
powerpc/fsl_booke: Add support to boot from core other than 0
powerpc/p1022: Add probing for individual DMA channels
powerpc/fsl_soc: Search all global-utilities nodes for rstccr
powerpc: Fix invalid page flags in create TLB CAM path for PTE_64BIT
powerpc/mpc83xx: Support for MPC8308 P1M board
Fix up conflict with the generic irq_work changes in arch/powerpc/kernel/time.c
First we check to see if we are the first core booting up. This
is accomplished by comparing the boot_cpuid with -1, if it is we
assume this is the first core coming up.
Secondly, we need to update the initial thread info structure
to reflect the actual cpu we are running on otherwise
smp_processor_id() and related functions will return the default
initialization value of the struct or 0.
Signed-off-by: Matthew McClintock <msm@freescale.com>
arch/x86/kernel/trampoline.c
mm/memblock.c
Merge reason: Resolve the conflicts, update to latest upstream.
The interrupt stacks need to be indexed by the physical cpu since the
critical, debug and machine check handlers use the contents of SPRN_PIR to
index the critirq_ctx, dbgirq_ctx, and mcheckirq_ctx arrays.
This introduce memblock.current_limit which is used to limit allocations
from memblock_alloc() or memblock_alloc_base(..., MEMBLOCK_ALLOC_ACCESSIBLE).
The old MEMBLOCK_ALLOC_ANYWHERE changes value from 0 to ~(u64)0 and can still
be used with memblock_alloc_base() to allocate really anywhere.
It is -no-longer- cropped to MEMBLOCK_REAL_LIMIT which disappears.
Note to archs: I'm leaving the default limit to MEMBLOCK_ALLOC_ANYWHERE. I
strongly recommend that you ensure that you set an appropriate limit
during boot in order to guarantee that an memblock_alloc() at any time
results in something that is accessible with a simple __va().
The reason is that a subsequent patch will introduce the ability for
the array to resize itself by reallocating itself. The MEMBLOCK core will
honor the current limit when performing those allocations.
via following scripts
FILES=$(find * -type f | grep -vE 'oprofile|[^K]config')
sed -i \
-e 's/lmb/memblock/g' \
-e 's/LMB/MEMBLOCK/g' \
$FILES
for N in $(find . -name lmb.[ch]); do
M=$(echo $N | sed 's/lmb/memblock/g')
mv $N $M
done
and remove some wrong change like lmbench and dlmb etc.
also move memblock.c from lib/ to mm/
Suggested-by: Ingo Molnar <mingo@elte.hu>
Acked-by: "H. Peter Anvin" <hpa@zytor.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Irq stacks provide an essential protection from stack overflows through
external interrupts, at the cost of two additionals stacks per CPU.
Enable them unconditionally to simplify the kernel build and prevent
people from accidentally disabling them.
powerpc initializes swiotlb before parsing the kernel boot options so
swiotlb options (e.g. specifying the swiotlb buffer size) are ignored.
Any time before freeing bootmem works for swiotlb so this patch moves
powerpc's swiotlb initialization after parsing the kernel boot
options, mem_init (as x86 does).
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Tested-by: Becky Bruce <beckyb@kernel.crashing.org>
Tested-by: Albert Herranz <albert_herranz@yahoo.es>
This enables us to avoid printing swiotlb memory info when we
initialize swiotlb. After swiotlb initialization, we could find
that we don't need swiotlb.
This patch removes the code to print swiotlb memory info in
swiotlb_init() and exports the function to do that.
Cc: chrisw@sous-sol.org
Cc: dwmw2@infradead.org
Cc: joerg.roedel@amd.com
Cc: muli@il.ibm.com
Cc: tony.luck@intel.com
Cc: benh@kernel.crashing.org
LKML-Reference: <1257849980-22640-9-git-send-email-fujita.tomonori@lab.ntt.co.jp>
[ -v2: merge up conflict ]
Remove the reliance on a staticly defined NVRAM size, allowing
platforms to support NVRAMs with sizes differing from the standard.
A fall back value is provided for platforms not supporting this extension.
Signed-off-by: Martyn Welch <martyn.welch@gefanuc.com>
Based on initial work from: Dale Farnsworth <dale@farnsworth.org>
Add the low level irq tracing hooks for 32-bit powerpc needed
to enable full lockdep functionality.
The approach taken to deal with the code in entry_32.S is that
we don't trace all the transitions of MSR:EE when we just turn
it off to peek at TI_FLAGS without races. Only when we are
calling into C code or returning from exceptions with a state
that have changed from what lockdep thinks.
There's a little bugger though: If we take an exception that
keeps interrupts enabled (such as an alignment exception) while
interrupts are enabled, we will call trace_hardirqs_on() on the
way back spurriously. Not a big deal, but to get rid of it would
require remembering in pt_regs that the exception was one of the
type that kept interrupts enabled which we don't know at this
stage. (Well, we could test all cases for regs->trap but that
sucks too much).
Tested-by: Kumar Gala <galak@kernel.crashing.org>
This patch includes the basic infrastructure to use swiotlb
bounce buffering on 32-bit powerpc. It is not yet enabled on
any platforms. Probably the most interesting bit is the
addition of addr_needs_map to dma_ops - we need this as
a dma_op because the decision of whether or not an addr
can be mapped by a device is device-specific.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Wire up the trampoline code for ppc32 to relay exceptions from the
vectors at address 0 to vectors at address 32MB, and modify Kconfig
to enable Kdump support for all classic powerpcs.
Signed-off-by: Dale Farnsworth <dale@farnsworth.org>
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This makes the MMU context code used for CPUs with no hash table
(except 603) dynamically allocate the various maps used to track
the state of contexts.
Only the main free map and CPU 0 stale map are allocated at boot
time. Other CPU maps are allocated when those CPUs are brought up
and freed if they are unplugged.
This also moves the initialization of the MMU context management
slightly later during the boot process, which should be fine as
it's really only needed when userland if first started anyways.
We're soon running out of CPU features and I need to add some new
ones for various MMU related bits, so this patch separates the MMU
features from the CPU features. I moved over the 32-bit MMU related
ones, added base features for MMU type families, but didn't move
over any 64-bit only feature yet.
smp_hw_index isn't used on 64-bit, so move it from smp.c to
setup_32.c.
Signed-off-by: Nathan Lynch <ntl@pobox.com>
The `have_of' variable is a relic from the arch/ppc time, it isn't
useful nowadays.
The "phys" argument to machine_init() isn't used and isn't likely to
ever be so let's remove it.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The file arch/powerpc/kernel/sysfs.c is currently only compiled for
64-bit kernels. It contain code to register CPU sysdevs in sysfs and
add various properties such as cache topology and raw access by root
to performance monitor counters (PMCs). A lot of that can be re-used
as is on 32-bits.
This makes the file be built for both, with appropriate ifdef'ing
for the few bits that are really 64-bit specific, and adds some
support for the raw PMCs for 75x and 74xx processors.
This patch removes the old kgdb reminants from ARCH=powerpc and
implements the new style arch specific stub for the common kgdb core
interface.
It is possible to have xmon and kgdb in the same kernel, but you
cannot use both at the same time because there is only one set of
debug hooks.
The arch specific kgdb implementation saves the previous state of the
debug hooks and restores them if you unconfigure the kgdb I/O driver.
Kgdb should have no impact on a kernel that has no kgdb I/O driver
configured.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Manual fixup of:
arch/powerpc/Kconfig
To allow for a single kernel image on e500 v1/v2/mc we need to fixup lwsync
at runtime. On e500v1/v2 lwsync causes an illop so we need to patch up
the code. We default to 'sync' since that is always safe and if the cpu
is capable we will replace 'sync' with 'lwsync'.
We introduce CPU_FTR_LWSYNC as a way to determine at runtime if this is
needed. This flag could be moved elsewhere since we dont really use it
for the normal CPU_FTR purpose.
Finally we only store the relative offset in the fixup section to keep it
as small as possible rather than using a full fixup_entry.
The e500 core enter DOZE/NAP power-saving modes when the core go to
cpu_idle routine.
The power management default running mode is DOZE, If the user
echo 1 > /proc/sys/kernel/powersave-nap
the system will change to NAP running mode.
Signed-off-by: Dave Liu <daveliu@freescale.com>
For the additonal exception levels (critical, debug, machine check) on
40x/book-e we were using "static" allocations of the stack in the
associated head.S.
Move to a runtime allocation to make the code a bit easier to read as
we mimic how we handle IRQ stacks. Its also a bit easier to setup the
stack with a "dummy" thread_info in C code.
Acked-by: Paul Mackerras <paulus@samba.org>
This patch cleans up the ftrace code in PowerPC based on the comments from
Michael Ellerman.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
Cc: Michael Ellerman <michael@ellerman.id.au>
Cc: proski@gnu.org
Cc: a.p.zijlstra@chello.nl
Cc: Pekka Paalanen <pq@iki.fi>
Cc: Steven Rostedt <srostedt@redhat.com>
Cc: linuxppc-dev@ozlabs.org
Cc: Soeren Sandmann Pedersen <sandmann@redhat.com>
Cc: paulus@samba.org
This patch adds full support for ftrace for PowerPC (both 64 and 32 bit).
This includes dynamic tracing and function filtering.
This makes it possible to use separate stacks for hard and soft IRQs
on 32-bit powerpc as well as on 64-bit. The code for 32-bit is just
the 32-bit analog of the 64-bit code.
* Added allocation and initialization of the irq stacks. We limit the
stacks to be in lowmem for ppc32.
* Implemented ppc32 versions of call_do_softirq() and call_handle_irq()
to switch the stack pointers
* Reworked how we do stack overflow detection. We now keep around the
limit of the stack in the thread_struct and compare against the limit
to see if we've overflowed. We can now use this on ppc64 if desired.
[ paulus@samba.org: Fixed bug on 6xx where we need to reload r9 with the
thread_info pointer. ]
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc
* 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (202 commits)
[POWERPC] Fix compile breakage for 64-bit UP configs
[POWERPC] Define copy_siginfo_from_user32
[POWERPC] Add compat handler for PTRACE_GETSIGINFO
[POWERPC] i2c: Fix build breakage introduced by OF helpers
[POWERPC] Optimize fls64() on 64-bit processors
[POWERPC] irqtrace support for 64-bit powerpc
[POWERPC] Stacktrace support for lockdep
[POWERPC] Move stackframe definitions to common header
[POWERPC] Fix device-tree locking vs. interrupts
[POWERPC] Make pci_bus_to_host()'s struct pci_bus * argument const
[POWERPC] Remove unused __max_memory variable
[POWERPC] Simplify xics direct/lpar irq_host setup
[POWERPC] Use pseries_setup_i8259_cascade() in pseries_mpic_init_IRQ()
[POWERPC] Turn xics_setup_8259_cascade() into a generic pseries_setup_i8259_cascade()
[POWERPC] Move xics_setup_8259_cascade() into platforms/pseries/setup.c
[POWERPC] Use asm-generic/bitops/find.h in bitops.h
[POWERPC] 83xx: mpc8315 - fix USB UTMI Host setup
[POWERPC] 85xx: Fix the size of qe muram for MPC8568E
[POWERPC] 86xx: mpc86xx_hpcn - Temporarily accept old dts node identifier.
[POWERPC] 86xx: mark functions static, other minor cleanups
* Add special cases for pplus and prep to ide_default_{irq,io_base}()
(+ FIXMEs about the need to use IDE platform host driver instead).
* Remove no longer needed ppc_ide_md and struct ide_machdep_calls.
* Then remove <linux/ide.h> include from:
- arch/powerpc/kernel/setup_32.c
- arch/ppc/kernel/ppc_ksyms.c
- arch/ppc/kernel/setup.c
- arch/ppc/platforms/pplus.c
- arch/ppc/platforms/prep_setup.c
There should be no functional changes caused by this patch.
Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
* PAGE_OFFSET is not always the start of code, use _stext instead.
* grab PAGE_SIZE and KERNELBASE from asm/page.h like ppc64 does. Makes the
code a bit more common and provide a single place to manipulate the
defines for things like kdump.
Old-world powermacs don't set L2CR or L3CR on processor upgrade cards.
This simple patch allows the setting of L3CR via a kernel parameter
(like the existing kernel parameter to set L2CR).
Signed-off-by: Robert Brose <bob@qbjnet.com>
This allows platforms which don't have anything to do at setup_arch time
(like a bunch of the 4xx platforms) to eliminate an empty setup_arch hook.
These are the symptom error messages:
CC arch/powerpc/kernel/setup_32.o
In file included from include/linux/blkdev.h:17,
from include/linux/ide.h:13,
from arch/powerpc/kernel/setup_32.c:13:
include/linux/bsg.h:67: warning: 'struct request_queue' declared inside parameter list
include/linux/bsg.h:67: warning: its scope is only this definition or declaration, which is probably not what you want
include/linux/bsg.h:71: warning: 'struct request_queue' declared inside parameter list
In file included from arch/powerpc/kernel/setup_32.c:13:
include/linux/ide.h:857: error: field 'wrq' has incomplete type
CC arch/powerpc/kernel/ppc_ksyms.o
from arch/powerpc/kernel/ppc_ksyms.c:15:
In file included from arch/powerpc/kernel/ppc_ksyms.c:15:
The fix tries to use the smallest scope CONFIG_* symbols that will fix
the build problem. In this case <linux/ide.h> needs to be included
only if IDE=y or IDE=m were selected. Also, ppc_ide_md is needed only
if BLK_DEV_IDE=y or BLK_DEV_IDE=m
Moved the EXPORT_SYMBOL(ppc_ide_md) from ppc_ksysms.c next to its
declaration in setup_32.c which made <linux/ide.h> not needed. With
<linux/ide.h> gone from ppc_ksyms.c, <asm/cacheflush.h> is needed to
address the following warnings and errors:
arch/powerpc/kernel/ppc_ksyms.c:122: error: '__flush_icache_range' undeclared here (not in a function)
arch/powerpc/kernel/ppc_ksyms.c:122: warning: type defaults to 'int' in declaration of '__flush_icache_range'
arch/powerpc/kernel/ppc_ksyms.c:123: error: 'flush_dcache_range' undeclared here (not in a function)
arch/powerpc/kernel/ppc_ksyms.c:123: warning: type defaults to 'int' in declaration of 'flush_dcache_range'
Signed-off-by: Emil Medve <Emilian.Medve@Freescale.com>
Remove includes of files that existed in arch/ppc that we dont need in
arch/powerpc anymore. The following includes were removed:
<asm/amigappc.h>
<asm/bootinfo.h>
<asm/ppcboot.h>
<asm/ppc_sys.h>
<asm/residual.h>
<asm/m8260_pci.h>
This also caused platforms/embedded6xx/mpc7448_hpc2.h to no longer be
needed and thus removed.
Currently the powerpc kernel has a 64-bit only feature,
COHERENT_ICACHE used for those CPUS which maintain icache/dcache
coherency in hardware (POWER5, essentially). It also has a feature,
SPLIT_ID_CACHE, which is used on CPUs which have separate i and
d-caches, which is to say everything except 601 and Freescale E200.
In nearly all the places we check the SPLIT_ID_CACHE, what we actually
care about is whether the i and d-caches are coherent (which they will
be, trivially, if they're the same cache).
This tries to clarify the situation a little. The COHERENT_ICACHE
feature becomes availble on 32-bit and is set for all CPUs where i and
d-cache are effectively coherent, whether this is due to special logic
(POWER5) or because they're unified. We check this, instead of
SPLIT_ID_CACHE nearly everywhere.
The SPLIT_ID_CACHE feature itself is replaced by a UNIFIED_ID_CACHE
feature with reversed sense, set only on 601 and Freescale E200. In
the two places (one Freescale BookE specific) where we really care
whether it's a unified cache, not whether they're coherent, we check
this feature. The CPUs with unified cache are so few, we could
consider replacing this feature bit with explicit checks against the
PVR.
This will make unifying the 32-bit and 64-bit cache flush code a
little more straightforward.
Signed-off-by: David Gibson <dwg@au1.ibm.com>
72486f1f8f0a2bc828b9d30cf4690cf2dd6807fc inverted the sense for enabling
hotplug CPU controls without reference to any other architecture other than
i386, ia64 and PowerPC. This left everyone else without hotplug CPU control.
Fix powerpc for this brain damage.
(akpm: patch adapted from rmk's ARM fix. Changelog stolen from rmk)
Signed-off-by: Giuliano Pochini <pochini@shiny.it>
Currently, early_init() in setup_32.c zeroes from '_bss_start' to '_end'.
It should only zero from '__bss_start' to '__bss_stop'. This patch does that.
Signed-off-by: Mark A. Greer <mgreer@mvista.com>
udbg_early_init() is a function used on 64 bit systems, which
initializes whichever early udbg backend is configured. This function
is not called on 32-bit, however if btext early debug is enabled it
does have an explicit, inline, #ifdef-ed assignment performing
analagous initialization.
This patch makes things more uniform by folding the btext
initialization as an option into udbg_early_init() and calling that
from the 32-bit setup path.
The following macro :
include/asm-powerpc/vga.h:#define VGA_MAP_MEM(x,s) (x + vgacon_remap_base)
is used by drivers/video/console/vgacon.c which can be compiled as a module
(drivers/video/vga16fb.ko).
Therefore, vgacon_remap_base should be exported.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
This adds code to look at the properties firmware puts in the device
tree to determine what compatibility mode the partition is in on
POWER6 machines, and set the ELF aux vector AT_HWCAP and AT_PLATFORM
entries appropriately.
Specifically, we look at the cpu-version property in the cpu node(s).
If that contains a "logical" PVR value (of the form 0x0f00000x), we
call identify_cpu again with this PVR value. A value of 0x0f000001
indicates the partition is in POWER5+ compatibility mode, and a value
of 0x0f000002 indicates "POWER6 architected" mode, with various
extensions disabled. We also look for various other properties:
ibm,dfp, ibm,purr and ibm,spurr.
dev_t boot_dev is declared in arch/powerpc/kernel/setup_32.c
and in arch/powerpc/kernel/setup_64.c but not used in these files.
It is only used in arch/powerpc/platforms/powermac/setup.c, so make
it static in this file.
This patch reworks the feature fixup mecanism so vdso's can be fixed up.
The main issue was that the construct:
.long label (or .llong on 64 bits)
will not work in the case of a shared library like the vdso. It will
generate an empty placeholder in the fixup table along with a reloc,
which is not something we can deal with in the vdso.
The idea here (thanks Alan Modra !) is to instead use something like:
1:
.long label - 1b
That is, the feature fixup tables no longer contain addresses of bits of
code to patch, but offsets of such code from the fixup table entry
itself. That is properly resolved by ld when building the .so's. I've
modified the fixup mecanism generically to use that method for the rest
of the kernel as well.
Another trick is that the 32 bits vDSO included in the 64 bits kernel
need to have a table in the 64 bits format. However, gas does not
support 32 bits code with a statement of the form:
.llong label - 1b (Or even just .llong label)
That is, it cannot emit the right fixup/relocation for the linker to use
to assign a 32 bits address to an .llong field. Thus, in the specific
case of the 32 bits vdso built as part of the 64 bits kernel, we are
using a modified macro that generates:
.long 0xffffffff
.llong label - 1b
Note that is assumes that the value is negative which is enforced by
the .lds (those offsets are always negative as the .text is always
before the fixup table and gas doesn't support emiting the reloc the
other way around).
