path: root/arch/powerpc/kernel/pci-common.c
2011-11-06Merge branch 'modsplit-Oct31_2011' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux * 'modsplit-Oct31_2011' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: (230 commits) Revert "tracing: Include module.h in define_trace.h" irq: don't put module.h into irq.h for tracking irqgen modules. bluetooth: macroize two small inlines to avoid module.h ip_vs.h: fix implicit use of module_get/module_put from module.h nf_conntrack.h: fix up fallout from implicit moduleparam.h presence include: replace linux/module.h with "struct module" wherever possible include: convert various register fcns to macros to avoid include chaining crypto.h: remove unused crypto_tfm_alg_modname() inline uwb.h: fix implicit use of asm/page.h for PAGE_SIZE pm_runtime.h: explicitly requires notifier.h linux/dmaengine.h: fix implicit use of bitmap.h and asm/page.h miscdevice.h: fix up implicit use of lists and types stop_machine.h: fix implicit use of smp.h for smp_processor_id of: fix implicit use of errno.h in include/linux/of.h of_platform.h: delete needless include <linux/module.h> acpi: remove module.h include from platform/aclinux.h miscdevice.h: delete unnecessary inclusion of module.h device_cgroup.h: delete needless include <linux/module.h> net: sch_generic remove redundant use of <linux/module.h> net: inet_timewait_sock doesnt need <linux/module.h> ... Fix up trivial conflicts (other header files, and removal of the ab3550 mfd driver) in - drivers/media/dvb/frontends/dibx000_common.c - drivers/media/video/{mt9m111.c,ov6650.c} - drivers/mfd/ab3550-core.c - include/linux/dmaengine.h
2011-10-31powerpc: add export.h to files making use of EXPORT_SYMBOLPaul Gortmaker
With module.h being implicitly everywhere via device.h, the absence of explicitly including something for EXPORT_SYMBOL went unnoticed. Since we are heading to fix things up and clean module.h from the device.h file, we need to explicitly include these files now. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-26powerpc/pci: Don't configure PCIe settings when PCI_PROBE_ONLY is setBenjamin Herrenschmidt
We don't want to configure PCI Express Max Payload Size or Max Read Request Size on systems that set that flag. The firmware will have done it for us, and under hypervisors such as pHyp we don't even see the parent switches and bridges and thus can make no assumption on what values are safe to use. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-09-20powerpc/pci: Call pcie_bus_configure_settings()Benjamin Herrenschmidt
This new function is used to properly setup the PCI Express Max Payload Size (and in some circumstances Max Read Request Size). Some systems will not operate properly if these aren't set correctly and the firmware doesn't always do it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-07-26Merge branch 'next/cross-platform' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc * 'next/cross-platform' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/linux-arm-soc: ARM: Consolidate the clkdev header files ARM: set vga memory base at run-time ARM: convert PCI defines to variables ARM: pci: make pcibios_assign_all_busses use pci_has_flag ARM: remove unnecessary mach/hardware.h includes pci: move microblaze and powerpc pci flag functions into asm-generic powerpc: rename ppc_pci_*_flags to pci_*_flags Fix up conflicts in arch/microblaze/include/asm/pci-bridge.h
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-12powerpc: rename ppc_pci_*_flags to pci_*_flagsRob Herring
This renames pci flags functions and enums in preparation for creating generic version in asm-generic/pci-bridge.h. The following search and replace is done: s/ppc_pci_/pci_/ s/PPC_PCI_/PCI_/ Direct accesses to ppc_pci_flag variable are replaced with helper functions. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org>
2011-06-22powerpc/pci: Move FSL fixup from 32-bit to commonKumar Gala
We need the FSL specific header fixup code on both 32-bit and 64-bit platforms so just move the code into pci-common.c. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-08pci/of: Match PCI devices to OF nodes dynamicallyBenjamin Herrenschmidt
powerpc has two different ways of matching PCI devices to their corresponding OF node (if any) for historical reasons. The ppc64 one does a scan looking for matching bus/dev/fn, while the ppc32 one does a scan looking only for matching dev/fn on each level in order to be agnostic to busses being renumbered (which Linux does on some platforms). This removes both and instead moves the matching code to the PCI core itself. It's the most logical place to do it: when a pci_dev is created, we know the parent and thus can do a single level scan for the matching device_node (if any). The benefit is that all archs now get the matching for free. There's one hook the arch might want to provide to match a PHB bus to its device node. A default weak implementation is provided that looks for the parent device device node, but it's not entirely reliable on powerpc for various reasons so powerpc provides its own. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-03-29powerpc: Convert to new irq_* function namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-04powerpc/pci: Make both ppc32 and ppc64 use sysdata for pci_controllerGrant Likely
Currently, ppc32 uses sysdata for the pci_controller pointer, and ppc64 uses it to hold the device_node pointer. This patch moves the of_node pointer into (struct pci_bus*)->dev.of_node and (struct pci_dev*)->dev.of_node so that sysdata can be converted to always use the pci_controller pointer instead. It also fixes up the allocating of pci devices so that the of_node pointer gets assigned consistently and increments the ref count. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-04of/pci: move of_irq_map_pci() into generic codeSebastian Andrzej Siewior
There is a tiny difference between PPC32 and PPC64. Microblaze uses the PPC32 variant. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> [grant.likely@secretlab.ca: Added comment to #endif, moved documentation block to function implementation, fixed for non ppc and microblaze compiles] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-10-13powerpc/pci: Cleanup device dma setup codeNishanth Aravamudan
Use set_dma_ops and remove unused oddly-named temp pointer sd. Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2010-08-01of/address: Clean up function declarationsGrant Likely
This patch moves the declaration of of_get_address(), of_get_pci_address(), and of_pci_address_to_resource() out of arch code and into the common linux/of_address header file. This patch also fixes some of the asm/prom.h ordering issues. It still includes some header files that it ideally shouldn't be, but at least the ordering is consistent now so that of_* overrides work. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-06-11PCI: clear bridge resource range if BIOS assigned bad oneYinghai Lu
Yannick found that video does not work with 2.6.34. The cause of this bug was that the BIOS had assigned the wrong range to the PCI bridge above the video device. Before 2.6.34 the kernel would have shrunk the size of the bridge window, but since d65245c PCI: don't shrink bridge resources the kernel will avoid shrinking BIOS ranges. So zero out the old range if we fail to claim it at boot time; this will cause us to allocate a new range at startup, restoring the 2.6.34 behavior. Fixes regression https://bugzilla.kernel.org/show_bug.cgi?id=16009. Reported-by: Yannick <yannick.roehlly@free.fr> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-05-18of: eliminate of_device->node and dev_archdata->{of,prom}_nodeGrant Likely
This patch eliminates the node pointer from struct of_device and the of_node (or prom_node) pointer from struct dev_archdata since the node pointer is now part of struct device proper when CONFIG_OF is set, and all users of the old pointer locations have already been converted over to use device->of_node. Also remove dev_archdata_{get,set}_node() as it is no longer used by anything. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-28driver-core: Add device node pointer to struct deviceGrant Likely
Currently, platforms using CONFIG_OF add a 'struct device_node *of_node' to dev->archdata. However, with CONFIG_OF becoming generic for all architectures, it makes sense for commonality to move it out of archdata and into struct device proper. This patch adds a struct device_node *of_node member to struct device and updates all locations which currently write the device_node pointer into archdata to also update dev->of_node. Subsequent patches will modify callers to use the archdata location and ultimately remove the archdata member entirely. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> CC: Michal Simek <monstr@monstr.eu> CC: Greg Kroah-Hartman <gregkh@suse.de> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: "David S. Miller" <davem@davemloft.net> CC: Stephen Rothwell <sfr@canb.auug.org.au> CC: Jeremy Kerr <jeremy.kerr@canonical.com> CC: microblaze-uclinux@itee.uq.edu.au CC: linux-kernel@vger.kernel.org CC: linuxppc-dev@ozlabs.org CC: sparclinux@vger.kernel.org
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-12dma-mapping: powerpc: use generic pci_set_dma_mask and ↵FUJITA Tomonori
pci_set_consistent_dma_mask This converts powerpc to use the generic pci_set_dma_mask and pci_set_consistent_dma_mask (drivers/pci/pci.c). The generic pci_set_dma_mask does what powerpc's pci_set_dma_mask does. Unlike powerpc's pci_set_consistent_dma_mask, the gneric pci_set_consistent_dma_mask sets only coherent_dma_mask. It doesn't work for powerpc? pci_set_consistent_dma_mask API should set only coherent_dma_mask? Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-23PCI: add pci_bus_for_each_resource(), remove direct bus->resource[] refsBjorn Helgaas
No functional change; this converts loops that iterate from 0 to PCI_BUS_NUM_RESOURCES through pci_bus resource[] table to use the pci_bus_for_each_resource() iterator instead. This doesn't change the way resources are stored; it merely removes dependencies on the fact that they're in a table. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: mark struct resource as constDominik Brodowski
Now that we return the new resource start position, there is no need to update "struct resource" inside the align function. Therefore, mark the struct resource as const. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-02-22resource/PCI: align functions now return start of resourceDominik Brodowski
As suggested by Linus, align functions should return the start of a resource, not void. An update of "res->start" is no longer necessary. Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-12-16PCI/cardbus: Add a fixup hook and fix powerpcBenjamin Herrenschmidt
The cardbus code creates PCI devices without ever going through the necessary fixup bits and pieces that normal PCI devices go through. There's in fact a commented out call to pcibios_fixup_bus() in there, it's commented because ... it doesn't work. I could make pcibios_fixup_bus() do the right thing on powerpc easily but I felt it cleaner instead to provide a specific hook pci_fixup_cardbus for which a weak empty implementation is provided by the PCI core. This fixes cardbus on powerbooks and probably all other PowerPC platforms which was broken completely for ever on some platforms and since 2.6.31 on others such as PowerBooks when we made the DMA ops mandatory (since those are setup by the fixups). Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-10-14powerpc/pci: Fix MODPOST warningHeiko Schocher
making a powerpc target with PCI support, shows the following warning: MODPOST vmlinux.o WARNING: vmlinux.o(.text+0x10430): Section mismatch in reference from the function pcibios_allocate_bus_resources() to the function .init.text:reparent_resources() The function pcibios_allocate_bus_resources() references the function __init reparent_resources(). This is often because pcibios_allocate_bus_resources lacks a __init annotation or the annotation of reparent_resources is wrong. This patch fix this warning by removing the __init annotation before reparent_resources. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-24powerpc: Change archdata dma_data to a unionBecky Bruce
Sometimes this is used to hold a simple offset, and sometimes it is used to hold a pointer. This patch changes it to a union containing void * and dma_addr_t. get/set accessors are also provided, because it was getting a bit ugly to get to the actual data. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-09-02powerpc/pci: Merge ppc32 and ppc64 versions of phb_scan()Grant Likely
The two versions are doing almost exactly the same thing. No need to maintain them as separate files. This patch also has the side effect of making the PCI device tree scanning code available to 32 bit powerpc machines, but no board ports actually make use of this feature at this point. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc/pci: Pull ppc32 PCI features into commonKumar Gala
Some of the PCI features we have in ppc32 we will need on ppc64 platforms in the future. These include support for: * ppc_md.pci_exclude_device * indirect config cycles * early config cycles We also simplified the logic in fake_pci_bus() to assume it will always get a valid pci_controller. Since all current callers seem to pass it one. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc/pci: move pci_64.c device tree scanning code into pci-common.cGrant Likely
The PCI device tree scanning code in pci_64.c is some useful functionality. It allows PCI devices to be described in the device tree instead of being probed for, which in turn allows pci devices to use all of the device tree facilities to describe complex PCI bus architectures like GPIO and IRQ routing (perhaps not a common situation for desktop or server systems, but useful for embedded systems with on-board PCI devices). This patch moves the device tree scanning into pci-common.c so it is available for 32-bit powerpc machines too. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc/pci: Remove dead checks for CONFIG_PPC_OFGrant Likely
PPC_OF is always selected for arch/powerpc. This patch removes the stale #defines Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-08-28powerpc: use dma_map_ops structFUJITA Tomonori
This converts uses dma_map_ops struct (in include/linux/dma-mapping.h) instead of POWERPC homegrown dma_mapping_ops. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Becky Bruce <beckyb@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-06-02powerpc/pci: Fix annotation of pcibios_claim_one_busStephen Rothwell
It was __devinit, but it is also within a CONFIG_HOTPLUG guarded section of code, so the __devinit does nothing but cause the following warning: WARNING: vmlinux.o(.text+0x107a8): Section mismatch in reference from the function pcibios_finish_adding_to_bus() to the function .devinit.text:pcibios_claim_one_bus() The function pcibios_finish_adding_to_bus() references the function __devinit pcibios_claim_one_bus(). This is often because pcibios_finish_adding_to_bus lacks a __devinit annotation or the annotation of pcibios_claim_one_bus is wrong. It is also only (externally) used in arch/powerpc/kernel/of_platform.c which cannot be built as a module so don't export it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-05-15powerpc: Fix PCI ROM accessBenjamin Herrenschmidt
A couple of issues crept in since about 2.6.27 related to accessing PCI device ROMs on various powerpc machines. First, historically, we don't allocate the ROM resource in the resource tree. I'm not entirely certain of why, I susepct they often contained garbage on x86 but it's hard to tell. This causes the current generic code to always call pci_assign_resource() when trying to access the said ROM from sysfs, which will try to re-assign some new address regardless of what the ROM BAR was already set to at boot time. This can be a problem on hypervisor platforms like pSeries where we aren't supposed to move PCI devices around (and in fact probably can't). Second, our code that generates the PCI tree from the OF device-tree (instead of doing config space probing) which we mostly use on pseries at the moment, didn't set the (new) flag IORESOURCE_SIZEALIGN on any resource. That means that any attempt at re-assigning such a resource with pci_assign_resource() would fail due to resource_alignment() returning 0. This fixes this by doing these two things: - The code that calculates resource flags based on the OF device-node is improved to set IORESOURCE_SIZEALIGN on any valid BAR, and while at it also set IORESOURCE_READONLY for ROMs since we were lacking that too - We now allocate ROM resources as part of the resource tree. However to limit the chances of nasty conflicts due to busted firmwares, we only do it on the second pass of our two-passes allocation scheme, so that all valid and enabled BARs get precedence. This brings pSeries back the ability to access PCI ROMs via sysfs (and thus initialize various video cards from X etc...). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-24powerpc/pci: Default to dma_direct_ops for pci dma_opsKumar Gala
This will allow us to remove the ppc32 specific checks in get_dma_ops() that defaults to dma_direct_ops if the archdata is NULL. We really should always have archdata set to something going forward. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc/pci: Fix typo: s/resouces/resources/ in a pr_debugWolfram Sang
Fix typo: s/resouces/resources/ in a pr_debug Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-11powerpc/pci: Move hose_list and pci_address_to_pio to pci-commonMilton Miller
move the definition of hose_list next to its hotplug spinlock. create pcibios_io_size to encapsulate ifdef in existing pci-common function pcibios_vaddr_is_ioport move pci_address_to_pio to pci-common, using new pcibios_io_size, and protect this GPL exported function against concurrent hotplug removal Signed-off-by: Milton Miller <miltonm@bga.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-10powerpc/pci: mmap anonymous memory when legacy_mem doesn't existBenjamin Herrenschmidt
The new legacy_mem file in sysfs is causing problems with X on machines that don't support legacy memory access. The way I initially implemented it, we would fail with -ENXIO when trying to mmap it, thus exposing to X that we do support the API but there is no legacy memory. Unfortunately, X poor error handling is causing it to fail to start when it gets this error. This implements a workaround hack that instead maps anonymous memory instead (using shmem if VM_SHARED is set, just like /dev/zero does). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-02-02powerpc: Fix oops on some machines due to incorrect pr_debug()Benjamin Herrenschmidt
Recently, a patch left DEBUG enabled in the powerpc common PCI code, resulting in an old bug in a pr_debug() statement to show up and cause a NULL dereference on some machines. This fixes the pr_debug() statement and reverts to DEBUG not being force-enabled in that file. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-01-08powerpc/pci: Reserve legacy regions on PCIBenjamin Herrenschmidt
There's a problem on some embedded platforms when we re-assign everything on PCI, such as 44x. The generic code tries to avoid assigning devices to addresses overlapping the low legacy addresses such as VGA hard decoded areas using constants that are unfortunately no good for us, as they don't take into account the address translation we do to access PCI busses. Thus we end up allocating things like IO BARs to 0, which is technically legal, but will shadow hard decoded ports for use by things like VGA cards. This works around it by attempting to reserve legacy regions before we try to assign addresses. NOTE: This may have nasty side effects in cases I haven't tested yet: - We try to use FW mappings (ie. powermac) and the FW has allocated a conflicting address over those legacy regions. This will typically happen. I would expect the new code to just fail with an informative message without harm but I haven't had a chance to test that scenario yet. - A device with fixed BARs overlapping those legacy addresses such as an IDE controller in legacy mode is in the system. I don't know for sure yet what will happen there, I have to test :-) Ideally, we should change PCIBIOS_MIN_IO/MIN_MEM accross the board to take a bus pointer so they can provide appropriate per-bus translated values to the generic code but that's a more invasive patch. I will do that in the future, but in the meantime, this fixes the problem locally Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-21powerpc/mm: Rework usage of _PAGE_COHERENT/NO_CACHE/GUARDEDBenjamin Herrenschmidt
Currently, we never set _PAGE_COHERENT in the PTEs, we just OR it in in the hash code based on some CPU feature bit. We also manipulate _PAGE_NO_CACHE and _PAGE_GUARDED by hand in all sorts of places. This changes the logic so that instead, the PTE now contains _PAGE_COHERENT for all normal RAM pages thay have I = 0 on platforms that need it. The hash code clears it if the feature bit is not set. It also adds some clean accessors to setup various valid combinations of access flags and change various bits of code to use them instead. This should help having the PTE actually containing the bit combinations that we really want. I also removed _PAGE_GUARDED from _PAGE_BASE on 44x and instead set it explicitely from the TLB miss. I will ultimately remove it completely as it appears that it might not be needed after all but in the meantime, having it in the TLB miss makes things a lot easier. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-12-16powerpc: Remove `have_of' global variableAnton Vorontsov
The `have_of' variable is a relic from the arch/ppc time, it isn't useful nowadays. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-06powerpc/pci: Cosmetic cleanups of pci-common.cBenjamin Herrenschmidt
This does a few cosmetic cleanups, moving a couple of things around but without actually changing what the code does. (There is a minor change in ordering of operations in pcibios_setup_bus_devices but it should have no impact). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-06powerpc/pci: Fix various pseries PCI hotplug issuesBenjamin Herrenschmidt
The pseries PCI hotplug code has a number of issues, ranging from incorrect resource setup to crashes, depending on what is added, when, whether it contains a bridge, etc etc.... This fixes a whole bunch of these, while actually simplifying the code a bit, using more generic code in the process and factoring out common code between adding of a PHB, a slot or a device. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-06powerpc/pci: Make pcibios_allocate_bus_resources more robustBenjamin Herrenschmidt
To properly fix PCI hotplug, it's useful to be able to make the fixup passes on all devices whether they were just hot plugged or already there. However, pcibios_allocate_bus_resources() wouldn't cope well with being called twice for a given bus. This makes it ignore resources that have already been allocated, along with adding a bit of debug output. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-06powerpc/pci: Split pcibios_fixup_bus() into bus setup and device setupBenjamin Herrenschmidt
Currently, our PCI code uses the pcibios_fixup_bus() callback, which is called by the generic code when probing PCI buses, for two different things. One is to set up things related to the bus itself, such as reading bridge resources for P2P bridges, fixing them up, or setting up the iommu's associated with bridges on some platforms. The other is some setup for each individual device under that bridge, mostly setting up DMA mappings and interrupts. The problem is that this approach doesn't work well with PCI hotplug when an existing bus is re-probed for new children. We fix this problem by splitting pcibios_fixup_bus into two routines: pcibios_setup_bus_self() is now called to setup the bus itself pcibios_setup_bus_devices() is now called to setup devices pcibios_fixup_bus() is then modified to call these two after reading the bridge bases, and the OF based PCI probe is modified to avoid calling into the first one when rescanning an existing bridge. [paulus@samba.org - fixed eeh.h for 32-bit compile now that pci-common.c is including it unconditionally.] Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Remove pcibios_do_bus_setup()Benjamin Herrenschmidt
The function pcibios_do_bus_setup() was used by pcibios_fixup_bus() to perform setup that is different between the 32-bit and 64-bit code. This difference no longer exists, thus the function is removed and the setup now done directly from pci-common.c. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Use common PHB resource hookupBenjamin Herrenschmidt
The 32-bit and 64-bit powerpc PCI code used to set up the resource pointers of the root bus of a given PHB in completely different places. This unifies this in large part, by making 32-bit use a routine very similar to what 64-bit does when initially scanning the PCI busses. The actual setup of the PHB resources itself is then moved to a common function in pci-common.c. This should cause no functional change on 64-bit. On 32-bit, the effect is that the PHB resources are going to be setup a bit earlier, instead of being setup from pcibios_fixup_bus(). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc/pci: Cleanup debug printk'sBenjamin Herrenschmidt
This removes the various DBG() macro from the powerpc PCI code and makes it use the standard pr_debug instead. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-11-05powerpc: Fix domain numbers in /proc on 64-bitBenjamin Herrenschmidt
The code to properly expose domain numbers in /proc is somewhat bogus on ppc64 as it depends on the "buid" field being non-0, but that field is really pseries specific. This removes that code and makes ppc64 use the same code as 32-bit which effectively decides whether to expose domains based on ppc_pci_flags set by the platform, and sets the default for 64-bit to enable domains and enable compatibility for domain 0 (which strips the domain number for domain 0 to help with X servers). Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
