path: root/arch/powerpc/kernel/machine_kexec_64.c
2008-07-16Merge commit 'origin/master'Benjamin Herrenschmidt
Manual merge of: arch/powerpc/Kconfig arch/powerpc/kernel/stacktrace.c arch/powerpc/mm/slice.c arch/ppc/kernel/smp.c
2008-07-03generic-ipi: fix linux-next tree build failureStephen Rothwell
Today's linux-next build (powerpc ppc64_defconfig) failed like this: arch/powerpc/mm/tlb_64.c: In function 'pgtable_free_now': arch/powerpc/mm/tlb_64.c:66: error: too many arguments to function 'smp_call_function' arch/powerpc/kernel/machine_kexec_64.c: In function 'kexec_prepare_cpus': arch/powerpc/kernel/machine_kexec_64.c:175: error: too many arguments to function 'smp_call_function' Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Mackerras <paulus@samba.org> Cc: <linuxppc-dev@ozlabs.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-14[POWERPC] Fix sparse warnings in arch/powerpc/kernelMichael Ellerman
Make a few things static in lparcfg.c Make init and exit routines static in rtas_flash.c Make things static in rtas_pci.c Make some functions static in rtas.c Make fops static in rtas-proc.c Remove unneeded extern for do_gtod in smp.c Make clocksource_init() static in time.c Make last_tick_len and ticklen_to_xs static in time.c Move the declaration of the pvr per-cpu into smp.h Make kexec_smp_down() and kexec_stack static in machine_kexec_64.c Don't return void in arch_teardown_msi_irqs() in msi.c Move declaration of GregorianDay()into asm/time.h Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Rename get_property to of_get_property: arch/powerpcStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] Make struct property's value a void *Stephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-25Merge branch 'merge'Paul Mackerras
2006-08-17[POWERPC] Make crash.c work on 32-bit and 64-bitMichael Ellerman
To compile kexec on 32-bit we need a few more bits and pieces. Rather than add empty definitions, we can make crash.c work on 32-bit, with only a couple of kludges. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-08-17[POWERPC] Move some kexec logic into machine_kexec.cMichael Ellerman
We're missing a few functions for kexec to compile on 32-bit. There's nothing really 64-bit specific about the 64-bit versions, so make them generic rather than adding empty definitions for 32-bit. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-07-31[POWERPC] Constify & voidify get_property()Jeremy Kerr
Now that get_property() returns a void *, there's no need to cast its return value. Also, treat the return value as const, so we can constify get_property later. powerpc core changes. Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-28[POWERPC] Make kexec_setup() a regular initcallMichael Ellerman
There's no reason kexec_setup() needs to be called explicitly from setup_system(), it can just be a regular initcall. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-19[PATCH] powerpc: Move crashkernel= handling into the kernel.Michael Ellerman
This was missing a quilt ref. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-19[PATCH] powerpc: Unify mem= handlingMichael Ellerman
We currently do mem= handling in three seperate places. And as benh pointed out I wrote two of them. Now that we parse command line parameters earlier we can clean this mess up. Moving the parsing out of prom_init means the device tree might be allocated above the memory limit. If that happens we'd have to move it. As it happens we already have logic to do that for kdump, so just genericise it. This also means we might have reserved regions above the memory limit, if we do the bootmem allocator will blow up, so we have to modify lmb_enforce_memory_limit() to truncate the reserves as well. Tested on P5 LPAR, iSeries, F50, 44p. Tested moving device tree on P5 and 44p and F50. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-24[PATCH] powerpc: Only calculate htab_size in one place for kexecMichael Ellerman
For kexec we need to know the size of the MMU hash table. Currently we calculate the size once in the htab code, and then twice more in the kexec code, once using htab_hash_mask and once using ppc64_pft_size. On some machines the ppc64_pft_size calculation is broken because ppc64_pft_size is not set. So we need to fix the second calculation, but better still we should just calculate the size once and use it everywhere else. Tested on Power5 LPAR, Power4 non-LPAR and Power3. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Add arch dependent basic infrastructure for Kdump.Michael Ellerman
Implementing the machine_crash_shutdown which will be called by crash_kexec (called in case of a panic, sysrq etc.). Disable the interrupts, shootdown cpus using debugger IPI and collect regs for all CPUs. elfcorehdr= specifies the location of elf core header stored by the crashed kernel. This command line option will be passed by the kexec-tools to capture kernel. savemaxmem= specifies the actual memory size that the first kernel has and this value will be used for dumping in the capture kernel. This command line option will be passed by the kexec-tools to capture kernel. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Separate usage of KERNELBASE and PAGE_OFFSETMichael Ellerman
This patch separates usage of KERNELBASE and PAGE_OFFSET. I haven't looked at any of the PPC32 code, if we ever want to support Kdump on PPC we'll have to do another audit, ditto for iSeries. This patch makes PAGE_OFFSET the constant, it'll always be 0xC * 1 gazillion for 64-bit. To get a physical address from a virtual one you subtract PAGE_OFFSET, _not_ KERNELBASE. KERNELBASE is the virtual address of the start of the kernel, it's often the same as PAGE_OFFSET, but _might not be_. If you want to know something's offset from the start of the kernel you should subtract KERNELBASE. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-09[PATCH] powerpc: Merge kexecMichael Ellerman
This patch merges, to some extent, the PPC32 and PPC64 kexec implementations. We adopt the PPC32 approach of having ppc_md callbacks for the kexec functions. The current PPC64 implementation becomes the "default" implementation for PPC64 which platforms can select if they need no special treatment. I've added these default callbacks to pseries/maple/cell/powermac, this means iSeries no longer supports kexec - but it never worked anyway. I've renamed PPC32's machine_kexec_simple to default_machine_kexec, inline with PPC64. Judging by the comments it might be better named machine_kexec_non_of, or something, but at the moment it's the only implementation for PPC32 so it's the "default". Kexec requires machine_shutdown(), which is in machine_kexec.c on PPC32, but we already have in setup-common.c on powerpc. All this does is call ppc_md.nvram_sync, which only powermac implements, so instead make machine_shutdown a ppc_md member and have it call core99_nvram_sync directly on powermac. I've also stuck relocate_kernel.S into misc_32.S for powerpc. Built for ARCH=ppc, and 32 & 64 bit ARCH=powerpc, with KEXEC=y/n. Booted on P5 LPAR and successfully kexec'ed. Should apply on top of 493f25ef4087395891c99fcfe2c72e62e293e89f. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14powerpc: Move most remaining ppc64 files over to arch/powerpcPaul Mackerras
Also deletes files in arch/ppc64 that are no longer used now that we don't compile with ARCH=ppc64 any more. Signed-off-by: Paul Mackerras <paulus@samba.org>
