path: root/arch/powerpc/kernel/iommu.c
2006-06-28[POWERPC] kdump: Reserve the existing TCE mappings left by the first kernelHaren Myneni
During kdump boot, noticed some machines checkstop on dma protection fault for ongoing DMA left in the first kernel. Instead of initializing TCE entries in iommu_init() for the kdump boot, this patch fixes this issue by walking through the each TCE table and checks whether the entries are in use by the first kernel. If so, reserve those entries by setting the corresponding bit in tbl->it_map such that these entries will not be available for the kdump boot. However it could be possible that all TCE entries might be used up due to the driver bug that does continuous mapping. My observation is around 1700 TCE entries are used on some systems (Ex: P4) at some point of time during kdump boot and saving dump (either write into the disk or sending to remote machine). Hence, this patch will make sure that minimum of 2048 entries will be available such that kdump boot could be successful in some cases. Signed-off-by: Haren Myneni <haren@us.ibm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-15[POWERPC] node local IOMMU tablesAnton Blanchard
Allocate IOMMU tables local to the relevant node. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-10powerpc: Fix bug in iommu_alloc_coherent causing hang during bootPaul Mackerras
In commit 8eb6c6e3b9c8bfed3d75536ab142d7694627c2e5, Christoph Hellwig made iommu_alloc_coherent able to do node-local allocations, but unfortunately got the order of the arguments to alloc_pages_node wrong. This fixes it. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-06-09[PATCH] powerpc: node-aware dma allocationsChristoph Hellwig
Make sure dma_alloc_coherent allocates memory from the local node. This is important on Cell where we avoid going through the slow cpu interconnect. Note: I could only test this patch on Cell, it should be verified on some pseries machine by those that have the hardware. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-04-21[PATCH] powerpc: IOMMU support for honoring dma_maskOlof Johansson
Some devices don't support full 32-bit DMA address space, which we currently assume. Add the required mask-passing to the IOMMU allocators. Signed-off-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-10[PATCH] powerpc: trivial: modify comments to refer to new location of filesJon Mason
This patch removes all self references and fixes references to files in the now defunct arch/ppc64 tree. I think this accomplises everything wanted, though there might be a few references I missed. Signed-off-by: Jon Mason <jdmason@us.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-07[PATCH] powerpc: IOMMU SG paranoiaJake Moilanen
This addresses two items, which are unlikely to be hit if we trust drivers. The first is moving a memory barrier below where the vmerged SG count is passed back, but before the list is set to end. If those instructions were reordered, there could be an issue in iommu_unmap_sg(). The second is making sure we terminate the list on the failure case of iommu_map_sg(). If a driver does not look at the failure return code, it could pass a ill-formed SG list to iommu_unmap_sg(). Signed-off-by: Jake Moilanen <moilanen@austin.ibm.com> Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-14powerpc: Move most remaining ppc64 files over to arch/powerpcPaul Mackerras
Also deletes files in arch/ppc64 that are no longer used now that we don't compile with ARCH=ppc64 any more. Signed-off-by: Paul Mackerras <paulus@samba.org>
