path: root/arch/powerpc/kernel/ftrace.c
2009-02-10powerpc/ftrace: Fix math to calculate offset in TOCSteven Rostedt
Impact: fix dynamic ftrace with large modules in PPC64 The math to calculate the offset into the TOC that is taken from reading the trampoline is incorrect. The bottom half of the offset is a signed extended short. The current code was using an OR to create the offset when it should have been using an addition. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-11-28powerpc: ftrace, use create_branchSteven Rostedt
Impact: clean up Paul Mackerras pointed out that the code to determine if the branch can reach the destination is incorrect. Michael Ellerman suggested to pull out the code from create_branch and use that. Simply using create_branch is probably the best. Reported-by: Michael Ellerman <michael@ellerman.id.au> Reported-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-28powerpc: ftrace, added missing icache flushSteven Rostedt
Impact: fix to PowerPC code modification After modifying code it is essential to flush the icache. This patch adds the missing flush. Reported-by: Paul Mackerras <paulus@samba.org> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-28powerpc: ftrace, fix cast aliasing and add code verificationSteven Rostedt
Impact: clean up and robustness addition This patch addresses the comments made by Paul Mackerras. It removes the type casting between unsigned int and unsigned char pointers, and replaces them with a use of all unsigned int. Verification that the jump is indeed made to a trampoline has also been added. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-20powerpc/ppc32: ftrace, dynamic ftrace to handle modulesSteven Rostedt
Impact: add ability to trace modules on 32 bit PowerPC This patch performs the necessary trampoline calls to handle modules with dynamic ftrace on 32 bit PowerPC. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-20powerpc/ppc64: ftrace, handle module trampolines for dyn ftraceSteven Rostedt
Impact: Allow 64 bit PowerPC to trace modules with dynamic ftrace This adds code to handle the PPC64 module trampolines, and allows for PPC64 to use dynamic ftrace. Thanks to Paul Mackerras for these updates: - fix the mod and rec->arch.mod NULL checks. - fix to is_bl_op compare. Thanks to Milton Miller for: - finding the nasty race with using two nops, and recommending instead that I use a branch 8 forward. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-20powerpc: ftrace, use probe_kernel API to modify codeSteven Rostedt
Impact: use cleaner probe_kernel API over assembly Using probe_kernel_read/write interface is a much cleaner approach than the current assembly version. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-11-20powerpc: ftrace, convert to new dynamic ftrace arch APISteven Rostedt
Impact: update to PowerPC ftrace arch API This patch converts PowerPC to use the new dynamic ftrace arch API. Thanks to Paul Mackennas for pointing out the mistakes of my original test_24bit_addr function. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2008-10-23ftrace, powerpc, sparc64, x86: remove notrace from arch ftrace fileSteven Rostedt
The entire file of ftrace.c in the arch code needs to be marked as notrace. It is much cleaner to do this from the Makefile with CFLAGS_REMOVE_ftrace.o. [ powerpc already had this in its Makefile. ] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23ftrace: remove mcount setSteven Rostedt
The arch dependent function ftrace_mcount_set was only used by the daemon start up code. This patch removes it. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-23ftrace: store mcount address in rec->ipAbhishek Sagar
Record the address of the mcount call-site. Currently all archs except sparc64 record the address of the instruction following the mcount call-site. Some general cleanups are entailed. Storing mcount addresses in rec->ip enables looking them up in the kprobe hash table later on to check if they're kprobe'd. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: davem@davemloft.net Cc: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-10ftrace: remove ftrace_ip_converted()Abhishek Sagar
Remove the unneeded function ftrace_ip_converted(). Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-26ftrace: powerpc clean upsSteven Rostedt
This patch cleans up the ftrace code in PowerPC based on the comments from Michael Ellerman. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Michael Ellerman <michael@ellerman.id.au> Cc: proski@gnu.org Cc: a.p.zijlstra@chello.nl Cc: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <srostedt@redhat.com> Cc: linuxppc-dev@ozlabs.org Cc: Soeren Sandmann Pedersen <sandmann@redhat.com> Cc: paulus@samba.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-05-23ftrace: support for PowerPCSteven Rostedt
This patch adds full support for ftrace for PowerPC (both 64 and 32 bit). This includes dynamic tracing and function filtering. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
