commit 0d808df06a44200f52262b6eb72bcb6042f5a7c5 upstream.
When switching from/to a guest that has a transaction in progress,
we need to save/restore the checkpointed register state. Although
XER is part of the CPU state that gets checkpointed, the code that
does this saving and restoring doesn't save/restore XER.
This fixes it by saving and restoring the XER. To allow userspace
to read/write the checkpointed XER value, we also add a new ONE_REG
specifier.
The visible effect of this bug is that the guest may see its XER
value being corrupted when it uses transactions.
Fixes: e4e38121507a ("KVM: PPC: Book3S HV: Add transactional memory support")
Fixes: 0a8eccefcb34 ("KVM: PPC: Book3S HV: Add missing code for transaction reclaim on guest exit")
Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
Reviewed-by: Thomas Huth <thuth@redhat.com>
This patch enables support for Performance monitor registers related
ELF core note NT_PPC_PMU based ptrace requests through
PTRACE_GETREGSET, PTRACE_SETREGSET calls. This is achieved
through adding one new register sets REGSET_PMU in powerpc
corresponding to the ELF core note sections added in this
regard. It also implements the get, set and active functions
for this new register sets added.
Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com>
Signed-off-by: Simon Guo <wei.guo.simon@gmail.com>
This patch enables support for EBB state registers related
ELF core note NT_PPC_EBB based ptrace requests through
through adding one new register sets REGSET_EBB in powerpc
This patch enables support for TM SPR state related ELF core
note NT_PPC_TM_SPR based ptrace requests through PTRACE_GETREGSET,
PTRACE_SETREGSET calls. This is achieved through adding a register
set REGSET_TM_SPR in powerpc corresponding to the ELF core note
section added. It implements the get, set and active functions for
this new register set added.
This patch enables support for TM checkpointed VSX register
set ELF core note NT_PPC_CVSX based ptrace requests through
through adding a register set REGSET_CVSX in powerpc
corresponding to the ELF core note section added. It
implements the get, set and active functions for this new
register set added.
This patch enables support for TM checkpointed VMX register
set ELF core note NT_PPC_CVMX based ptrace requests through
through adding a register set REGSET_CVMX in powerpc
register set added.
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- Support for Power ISA 3.0 (Power9) Radix Tree MMU from Aneesh Kumar K.V
- Live patching support for ppc64le (also merged via livepatching.git)
Various cleanups & minor fixes from:
- Aaro Koskinen, Alexey Kardashevskiy, Andrew Donnellan, Aneesh Kumar K.V,
Chris Smart, Daniel Axtens, Frederic Barrat, Gavin Shan, Ian Munsie,
Lennart Sorensen, Madhavan Srinivasan, Mahesh Salgaonkar, Markus Elfring,
Michael Ellerman, Oliver O'Halloran, Paul Gortmaker, Paul Mackerras,
Rashmica Gupta, Russell Currey, Suraj Jitindar Singh, Thiago Jung
Bauermann, Valentin Rothberg, Vipin K Parashar.
General:
- Update LMB associativity index during DLPAR add/remove from Nathan
Fontenot
- Fix branching to OOL handlers in relocatable kernel from Hari Bathini
- Add support for userspace Power9 copy/paste from Chris Smart
- Always use STRICT_MM_TYPECHECKS from Michael Ellerman
- Add mask of possible MMU features from Michael Ellerman
PCI:
- Enable pass through of NVLink to guests from Alexey Kardashevskiy
- Cleanups in preparation for powernv PCI hotplug from Gavin Shan
- Don't report error in eeh_pe_reset_and_recover() from Gavin Shan
- Restore initial state in eeh_pe_reset_and_recover() from Gavin Shan
- Revert "powerpc/eeh: Fix crash in eeh_add_device_early() on Cell"
from Guilherme G Piccoli
- Remove the dependency on EEH struct in DDW mechanism from Guilherme
G Piccoli
selftests:
- Test cp_abort during context switch from Chris Smart
- Add several tests for transactional memory support from Rashmica
Gupta
perf:
- Add support for sampling interrupt register state from Anju T
- Add support for unwinding perf-stackdump from Chandan Kumar
cxl:
- Configure the PSL for two CAPI ports on POWER8NVL from Philippe
Bergheaud
- Allow initialization on timebase sync failures from Frederic Barrat
- Increase timeout for detection of AFU mmio hang from Frederic
Barrat
- Handle num_of_processes larger than can fit in the SPA from Ian
Munsie
- Ensure PSL interrupt is configured for contexts with no AFU IRQs
from Ian Munsie
- Add kernel API to allow a context to operate with relocate disabled
from Ian Munsie
- Check periodically the coherent platform function's state from
Christophe Lombard
Freescale:
- Updates from Scott: "Contains 86xx fixes, minor device tree fixes,
an erratum workaround, and a kconfig dependency fix."
* tag 'powerpc-4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (192 commits)
powerpc/86xx: Fix PCI interrupt map definition
powerpc/86xx: Move pci1 definition to the include file
powerpc/fsl: Fix build of the dtb embedded kernel images
powerpc/fsl: Fix rcpm compatible string
powerpc/fsl: Remove FSL_SOC dependency from FSL_LBC
powerpc/fsl-pci: Add a workaround for PCI 5 errata
powerpc/fsl: Fix SPI compatible on t208xrdb and t1040rdb
powerpc/powernv/npu: Add PE to PHB's list
powerpc/powernv: Fix insufficient memory allocation
powerpc/iommu: Remove the dependency on EEH struct in DDW mechanism
powerpc/eeh: Drop unnecessary label in eeh_pe_change_owner()
powerpc/eeh: Ignore handlers in eeh_pe_reset_and_recover()
powerpc/eeh: Restore initial state in eeh_pe_reset_and_recover()
powerpc/eeh: Don't report error in eeh_pe_reset_and_recover()
Revert "powerpc/powernv: Exclude root bus in pnv_pci_reset_secondary_bus()"
powerpc/powernv/npu: Enable NVLink pass through
powerpc/powernv/npu: Rework TCE Kill handling
powerpc/powernv/npu: Add set/unset window helpers
powerpc/powernv/ioda2: Export debug helper pe_level_printk()
Wire up preadv2/pwritev2 in the same way as preadv/pwritev. Fixes two
build warnings on ppc64.
mpe: Lightly tested with fio (slightly hacked to add the syscall
wrappers):
fio-4217 [009] .... 1304.635300: sys_preadv2(fd: 3, vec:
10025821de0, vlen: 1, pos_l: 6253000, pos_h: 0, flags: 1)
fio-4217 [009] .... 1304.635474: sys_preadv2 -> 0x1000
Signed-off-by: Rui Salvaterra <rsalvaterra@gmail.com>
The enum definition assigns an 'id' to each register in "struct pt_regs"
of arch/powerpc. The order of these values in the enum definition are
based on the order of members in pt_regs.
Signed-off-by: Anju T <anju@linux.vnet.ibm.com>
[mpe: Rename LNK to LINK, use _UAPI_ASM for include guards]
The REAL_LE feature entry in the ibm_pa_feature struct is missing an MMU
feature value, meaning all the remaining elements initialise the wrong
values.
This means instead of checking for byte 5, bit 0, we check for byte 0,
bit 0, and then we incorrectly set the CPU feature bit as well as MMU
feature bit 1 and CPU user feature bits 0 and 2 (5).
Checking byte 0 bit 0 (IBM numbering), means we're looking at the
"Memory Management Unit (MMU)" feature - ie. does the CPU have an MMU.
In practice that bit is set on all platforms which have the property.
This means we set CPU_FTR_REAL_LE always. In practice that seems not to
matter because all the modern cpus which have this property also
implement REAL_LE, and we've never needed to disable it.
We're also incorrectly setting MMU feature bit 1, which is:
#define MMU_FTR_TYPE_8xx 0x00000002
Luckily the only place that looks for MMU_FTR_TYPE_8xx is in Book3E
code, which can't run on the same cpus as scan_features(). So this also
doesn't matter in practice.
Finally in the CPU user feature mask, we're setting bits 0 and 2. Bit 2
is not currently used, and bit 0 is:
#define PPC_FEATURE_PPC_LE 0x00000001
Which says the CPU supports the old style "PPC Little Endian" mode.
Again this should be harmless in practice as no 64-bit CPUs implement
that mode.
Fix the code by adding the missing initialisation of the MMU feature.
Also add a comment marking CPU user feature bit 2 (0x4) as reserved. It
would be unsafe to start using it as old kernels incorrectly set it.
Fixes: 44ae3ab3358e ("powerpc: Free up some CPU feature bits by moving out MMU-related features")
Cc: stable@vger.kernel.org
[mpe: Flesh out changelog, add comment reserving 0x4]
"This was delayed a day or two by some build-breakage on old toolchains
which we've now fixed.
There's two PCI commits both acked by Bjorn.
There's one commit to mm/hugepage.c which is (co)authored by Kirill.
Highlights:
- Restructure Linux PTE on Book3S/64 to Radix format from Paul
Mackerras
- Book3s 64 MMU cleanup in preparation for Radix MMU from Aneesh
Kumar K.V
- Add POWER9 cputable entry from Michael Neuling
- FPU/Altivec/VSX save/restore optimisations from Cyril Bur
- Add support for new ftrace ABI on ppc64le from Torsten Duwe
- Adam Buchbinder, Andrew Donnellan, Balbir Singh, Christophe Leroy,
Cyril Bur, Luis Henriques, Madhavan Srinivasan, Pan Xinhui, Russell
Currey, Sukadev Bhattiprolu, Suraj Jitindar Singh.
General:
- atomics: Allow architectures to define their own __atomic_op_*
helpers from Boqun Feng
- Implement atomic{, 64}_*_return_* variants and acquire/release/
relaxed variants for (cmp)xchg from Boqun Feng
- Add powernv_defconfig from Jeremy Kerr
- Fix BUG_ON() reporting in real mode from Balbir Singh
- Add xmon command to dump OPAL msglog from Andrew Donnellan
- Add xmon command to dump process/task similar to ps(1) from Douglas
Miller
- Clean up memory hotplug failure paths from David Gibson
pci/eeh:
- Redesign SR-IOV on PowerNV to give absolute isolation between VFs
from Wei Yang.
- EEH Support for SRIOV VFs from Wei Yang and Gavin Shan.
- PCI/IOV: Rename and export virtfn_{add, remove} from Wei Yang
- PCI: Add pcibios_bus_add_device() weak function from Wei Yang
- MAINTAINERS: Update EEH details and maintainership from Russell
Currey
cxl:
- Support added to the CXL driver for running on both bare-metal and
hypervisor systems, from Christophe Lombard and Frederic Barrat.
- Ignore probes for virtual afu pci devices from Vaibhav Jain
perf:
- Export Power8 generic and cache events to sysfs from Sukadev
Bhattiprolu
- hv-24x7: Fix usage with chip events, display change in counter
values, display domain indices in sysfs, eliminate domain suffix in
event names, from Sukadev Bhattiprolu
Freescale:
- Updates from Scott: "Highlights include 8xx optimizations, 32-bit
checksum optimizations, 86xx consolidation, e5500/e6500 cpu
hotplug, more fman and other dt bits, and minor fixes/cleanup"
* tag 'powerpc-4.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (179 commits)
powerpc: Fix unrecoverable SLB miss during restore_math()
powerpc/8xx: Fix do_mtspr_cpu6() build on older compilers
powerpc/rcpm: Fix build break when SMP=n
powerpc/book3e-64: Use hardcoded mttmr opcode
powerpc/fsl/dts: Add "jedec,spi-nor" flash compatible
powerpc/T104xRDB: add tdm riser card node to device tree
powerpc32: PAGE_EXEC required for inittext
powerpc/mpc85xx: Add pcsphy nodes to FManV3 device tree
powerpc/mpc85xx: Add MDIO bus muxing support to the board device tree(s)
powerpc/86xx: Introduce and use common dtsi
powerpc/86xx: Update device tree
powerpc/86xx: Move dts files to fsl directory
powerpc/86xx: Switch to kconfig fragments approach
powerpc/86xx: Update defconfigs
powerpc/86xx: Consolidate common platform code
powerpc32: Remove one insn in mulhdu
powerpc32: small optimisation in flush_icache_range()
powerpc: Simplify test in __dma_sync()
powerpc32: move xxxxx_dcache_range() functions inline
powerpc32: Remove clear_pages() and define clear_page() inline
Pull networking updates from David Miller:
"Highlights:
1) Support more Realtek wireless chips, from Jes Sorenson.
2) New BPF types for per-cpu hash and arrap maps, from Alexei
Starovoitov.
3) Make several TCP sysctls per-namespace, from Nikolay Borisov.
4) Allow the use of SO_REUSEPORT in order to do per-thread processing
of incoming TCP/UDP connections. The muxing can be done using a
BPF program which hashes the incoming packet. From Craig Gallek.
5) Add a multiplexer for TCP streams, to provide a messaged based
interface. BPF programs can be used to determine the message
boundaries. From Tom Herbert.
6) Add 802.1AE MACSEC support, from Sabrina Dubroca.
7) Avoid factorial complexity when taking down an inetdev interface
with lots of configured addresses. We were doing things like
traversing the entire address less for each address removed, and
flushing the entire netfilter conntrack table for every address as
well.
8) Add and use SKB bulk free infrastructure, from Jesper Brouer.
9) Allow offloading u32 classifiers to hardware, and implement for
ixgbe, from John Fastabend.
10) Allow configuring IRQ coalescing parameters on a per-queue basis,
from Kan Liang.
11) Extend ethtool so that larger link mode masks can be supported.
From David Decotigny.
12) Introduce devlink, which can be used to configure port link types
(ethernet vs Infiniband, etc.), port splitting, and switch device
level attributes as a whole. From Jiri Pirko.
13) Hardware offload support for flower classifiers, from Amir Vadai.
14) Add "Local Checksum Offload". Basically, for a tunneled packet
the checksum of the outer header is 'constant' (because with the
checksum field filled into the inner protocol header, the payload
of the outer frame checksums to 'zero'), and we can take advantage
of that in various ways. From Edward Cree"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1548 commits)
bonding: fix bond_get_stats()
net: bcmgenet: fix dma api length mismatch
net/mlx4_core: Fix backward compatibility on VFs
phy: mdio-thunder: Fix some Kconfig typos
lan78xx: add ndo_get_stats64
lan78xx: handle statistics counter rollover
RDS: TCP: Remove unused constant
RDS: TCP: Add sysctl tunables for sndbuf/rcvbuf on rds-tcp socket
net: smc911x: convert pxa dma to dmaengine
team: remove duplicate set of flag IFF_MULTICAST
bonding: remove duplicate set of flag IFF_MULTICAST
net: fix a comment typo
ethernet: micrel: fix some error codes
ip_tunnels, bpf: define IP_TUNNEL_OPTS_MAX and use it
bpf, dst: add and use dst_tclassid helper
bpf: make skb->tc_classid also readable
net: mvneta: bm: clarify dependencies
cls_bpf: reset class and reuse major in da
ldmvsw: Checkpatch sunvnet.c and sunvnet_common.c
ldmvsw: Add ldmvsw.c driver code
The existing KVM_CREATE_SPAPR_TCE only supports 32bit windows which is not
enough for directly mapped windows as the guest can get more than 4GB.
This adds KVM_CREATE_SPAPR_TCE_64 ioctl and advertises it
via KVM_CAP_SPAPR_TCE_64 capability. The table size is checked against
the locked memory limit.
Since 64bit windows are to support Dynamic DMA windows (DDW), let's add
@bus_offset and @page_shift which are also required by DDW.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
This patch add the SO_CNX_ADVICE socket option (setsockopt only). The
purpose is to allow an application to give feedback to the kernel about
the quality of the network path for a connected socket. The value
argument indicates the type of quality report. For this initial patch
the only supported advice is a value of 1 which indicates "bad path,
please reroute"-- the action taken by the kernel is to call
dst_negative_advice which will attempt to choose a different ECMP route,
reset the TX hash for flow label and UDP source port in encapsulation,
etc.
This facility should be useful for connected UDP sockets where only the
application can provide any feedback about path quality. It could also
be useful for TCP applications that have additional knowledge about the
path outside of the normal TCP control loop.
Signed-off-by: Tom Herbert <tom@herbertland.com>
Test runs on a ppc64 BE guest succeeded using modified fstests.
Also tested on ppc64 LE using a home made test - mpe.
Signed-off-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
"Core:
- Ground work for the new Power9 MMU from Aneesh Kumar K.V
- Optimise FP/VMX/VSX context switching from Anton Blanchard
Misc:
- Various cleanups from Krzysztof Kozlowski, John Ogness, Rashmica
Gupta, Russell Currey, Gavin Shan, Daniel Axtens, Michael Neuling,
Andrew Donnellan
- Allow wrapper to work on non-english system from Laurent Vivier
- Add rN aliases to the pt_regs_offset table from Rashmica Gupta
- Fix module autoload for rackmeter & axonram drivers from Luis de
Bethencourt
- Include KVM guest test in all interrupt vectors from Paul Mackerras
- Fix DSCR inheritance over fork() from Anton Blanchard
- Make value-returning atomics & {cmp}xchg* & their atomic_ versions
fully ordered from Boqun Feng
- Print MSR TM bits in oops messages from Michael Neuling
- Add TM signal return & invalid stack selftests from Michael Neuling
- Limit EPOW reset event warnings from Vipin K Parashar
- Remove the Cell QPACE code from Rashmica Gupta
- Append linux_banner to exception information in xmon from Rashmica
Gupta
- Add selftest to check if VSRs are corrupted from Rashmica Gupta
- Remove broken GregorianDay() from Daniel Axtens
- Import Anton's context_switch2 benchmark into selftests from
Michael Ellerman
- Add selftest script to test HMI functionality from Daniel Axtens
- Remove obsolete OPAL v2 support from Stewart Smith
- Make enter_rtas() private from Michael Ellerman
- PPR exception cleanups from Michael Ellerman
- Add page soft dirty tracking from Laurent Dufour
- Add support for Nvlink NPUs from Alistair Popple
- Add support for kexec on 476fpe from Alistair Popple
- Enable kernel CPU dlpar from sysfs from Nathan Fontenot
- Copy only required pieces of the mm_context_t to the paca from
Michael Neuling
- Add a kmsg_dumper that flushes OPAL console output on panic from
Russell Currey
- Implement save_stack_trace_regs() to enable kprobe stack tracing
from Steven Rostedt
- Add HWCAP bits for Power9 from Michael Ellerman
- Fix _PAGE_PTE breaking swapoff from Aneesh Kumar K.V
- Fix _PAGE_SWP_SOFT_DIRTY breaking swapoff from Hugh Dickins
- scripts/recordmcount.pl: support data in text section on powerpc
from Ulrich Weigand
- Handle R_PPC64_ENTRY relocations in modules from Ulrich Weigand
cxl:
- cxl: Fix possible idr warning when contexts are released from
Vaibhav Jain
- cxl: use correct operator when writing pcie config space values
- cxl: Fix DSI misses when the context owning task exits from Vaibhav
Jain
- cxl: fix build for GCC 4.6.x from Brian Norris
- cxl: use -Werror only with CONFIG_PPC_WERROR from Brian Norris
- cxl: Enable PCI device ID for future IBM CXL adapter from Uma
Krishnan
Freescale:
- Freescale updates from Scott: Highlights include moving QE code out
of arch/powerpc (to be shared with arm), device tree updates, and
minor fixes"
* tag 'powerpc-4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (149 commits)
powerpc/module: Handle R_PPC64_ENTRY relocations
powerpc/powernv: Fix OPAL_CONSOLE_FLUSH prototype and usages
powerpc/mm: fix _PAGE_SWP_SOFT_DIRTY breaking swapoff
powerpc/mm: Fix _PAGE_PTE breaking swapoff
powerpc: Add HWCAP bits for Power9
powerpc/powernv: Reserve PE#0 on NPU
powerpc/powernv: Change NPU PE# assignment
powerpc/powernv: Fix update of NVLink DMA mask
powerpc/powernv: Remove misleading comment in pci.c
powerpc: Implement save_stack_trace_regs() to enable kprobe stack tracing
powerpc: Fix build break due to paca mm_context_t changes
MAINTAINERS: Update Scott Wood's e-mail address
powerpc/powernv: Fix minor off-by-one error in opal_mce_check_early_recovery()
powerpc: Fix style of self-test config prompts
powerpc/powernv: Only delay opal_rtc_read() retry when necessary
GCC 6 will include changes to generated code with -mcmodel=large,
which is used to build kernel modules on powerpc64le. This was
necessary because the large model is supposed to allow arbitrary
sizes and locations of the code and data sections, but the ELFv2
global entry point prolog still made the unconditional assumption
that the TOC associated with any particular function can be found
within 2 GB of the function entry point:
func:
addis r2,r12,(.TOC.-func)@ha
addi r2,r2,(.TOC.-func)@l
.localentry func, .-func
To remove this assumption, GCC will now generate instead this global
entry point prolog sequence when using -mcmodel=large:
.quad .TOC.-func
func:
.reloc ., R_PPC64_ENTRY
ld r2, -8(r12)
add r2, r2, r12
The new .reloc triggers an optimization in the linker that will
replace this new prolog with the original code (see above) if the
linker determines that the distance between .TOC. and func is in
range after all.
Since this new relocation is now present in module object files,
the kernel module loader is required to handle them too. This
patch adds support for the new relocation and implements the
same optimization done by the GNU linker.
Signed-off-by: Ulrich Weigand <ulrich.weigand@de.ibm.com>
In order to support Power9 we need two new HWCAP bits. We are merging
these ahead of the cputable entry so that glibc can start referring to
them.
Expose socket options for setting a classic or extended BPF program
for use when selecting sockets in an SO_REUSEPORT group. These options
can be used on the first socket to belong to a group before bind or
on any socket in the group after bind.
This change includes refactoring of the existing sk_filter code to
allow reuse of the existing BPF filter validation checks.
Signed-off-by: Craig Gallek <kraig@google.com>
Acked-by: Alexei Starovoitov <ast@kernel.org>
This partially reverts commit a34236155afb1cc41945e58388ac988431bcb0b8.
While reviewing the glibc patch to exploit the individual IPC calls,
Arnd & Andreas noticed that we were still requiring userspace to pass
IPC_64 in order to get the new style IPC API.
With a bit of cleanup in the kernel we can drop that requirement, and
instead only provide the new style API, which will simplify things for
userspace.
Rather than try and sneak that patch into 4.4, instead we will drop the
individual IPC calls for powerpc, and merge them again in 4.5 once the
cleanup patch has gone in.
Because we've already added sys_mlock2() as syscall #378, we don't do a
full revert of the IPC calls. Instead we drop the __NR #defines, and
send those now undefined syscall numbers to sys_ni_syscall(). This
leaves a gap in the syscall numbers, but we'll reuse them when we merge
the individual IPC calls.
The selftest passes on 64-bit LE and 32-bit BE.
- Kconfig: remove BE-only platforms from LE kernel build from Boqun
Feng
- Refresh ps3_defconfig from Geoff Levand
- Emit GNU & SysV hashes for the vdso from Michael Ellerman
- Define an enum for the bolted SLB indexes from Anshuman Khandual
- Use a local to avoid multiple calls to get_slb_shadow() from Michael
Ellerman
- Add gettimeofday() benchmark from Michael Neuling
- Avoid link stack corruption in __get_datapage() from Michael Neuling
- Add virt_to_pfn and use this instead of opencoding from Aneesh Kumar
K.V
- Add ppc64le_defconfig from Michael Ellerman
- pseries: extract of_helpers module from Andy Shevchenko
- Correct string length in pseries_of_derive_parent() from Nathan
Fontenot
- Free the MSI bitmap if it was slab allocated from Denis Kirjanov
- Shorten irq_chip name for the SIU from Christophe Leroy
- Wait 1s for secondaries to enter OPAL during kexec from Samuel
Mendoza-Jonas
- Fix _ALIGN_* errors due to type difference, from Aneesh Kumar K.V
- powerpc/pseries/hvcserver: don't memset pi_buff if it is null from
Colin Ian King
- Disable hugepd for 64K page size, from Aneesh Kumar K.V
- Differentiate between hugetlb and THP during page walk from Aneesh
Kumar K.V
- Make PCI non-optional for pseries from Michael Ellerman
- Individual System V IPC system calls from Sam bobroff
- Add selftest of unmuxed IPC calls from Michael Ellerman
- discard .exit.data at runtime from Stephen Rothwell
- Delete old orphaned PrPMC 280/2800 DTS and boot file, from Paul
Gortmaker
- Use of_get_next_parent to simplify code from Christophe Jaillet
- Paginate some xmon output from Sam bobroff
- Add some more elements to the xmon PACA dump from Michael Ellerman
- Allow the tm-syscall selftest to build with old headers from Michael
Ellerman
- Run EBB selftests only on POWER8 from Denis Kirjanov
- Drop CONFIG_TUNE_CELL in favour of CONFIG_CELL_CPU from Michael
Ellerman
- Avoid reference to potentially freed memory in prom.c from Christophe
Jaillet
- Quieten boot wrapper output with run_cmd from Geoff Levand
- EEH fixes and cleanups from Gavin Shan
- Fix recursive fenced PHB on Broadcom shiner adapter from Gavin Shan
- Use of_get_next_parent() in of_get_ibm_chip_id() from Michael
Ellerman
- Fix section mismatch warning in msi_bitmap_alloc() from Denis
Kirjanov
- Fix ps3-lpm white space from Rudhresh Kumar J
- Fix ps3-vuart null dereference from Colin King
- nvram: Add missing kfree in error path from Christophe Jaillet
- nvram: Fix function name in some errors messages, from Christophe
Jaillet
- drivers/macintosh: adb: fix misleading Kconfig help text from Aaro
Koskinen
- agp/uninorth: fix a memleak in create_gatt_table from Denis Kirjanov
- cxl: Free virtual PHB when removing from Andrew Donnellan
- scripts/kconfig/Makefile: Allow KBUILD_DEFCONFIG to be a target from
Michael Ellerman
- scripts/kconfig/Makefile: Fix KBUILD_DEFCONFIG check when building
with O= from Michael Ellerman
- Freescale updates from Scott: Highlights include 64-bit book3e
kexec/kdump support, a rework of the qoriq clock driver, device tree
changes including qoriq fman nodes, support for a new 85xx board, and
some fixes.
- MPC5xxx updates from Anatolij: Highlights include a driver for
MPC512x LocalPlus Bus FIFO with its device tree binding
documentation, mpc512x device tree updates and some minor fixes.
* tag 'powerpc-4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (106 commits)
powerpc/msi: Fix section mismatch warning in msi_bitmap_alloc()
powerpc/prom: Use of_get_next_parent() in of_get_ibm_chip_id()
powerpc/pseries: Correct string length in pseries_of_derive_parent()
powerpc/e6500: hw tablewalk: make sure we invalidate and write to the same tlb entry
powerpc/mpc85xx: Add FSL QorIQ DPAA FMan support to the SoC device tree(s)
powerpc/mpc85xx: Create dts components for the FSL QorIQ DPAA FMan
powerpc/fsl: Add #clock-cells and clockgen label to clockgen nodes
powerpc: handle error case in cpm_muram_alloc()
powerpc: mpic: use IRQCHIP_SKIP_SET_WAKE instead of redundant mpic_irq_set_wake
powerpc/book3e-64: Enable kexec
powerpc/book3e-64/kexec: Set "r4 = 0" when entering spinloop
powerpc/booke: Only use VIRT_PHYS_OFFSET on booke32
powerpc/book3e-64/kexec: Enable SMP release
powerpc/book3e-64/kexec: create an identity TLB mapping
powerpc/book3e-64: Don't limit paca to 256 MiB
powerpc/book3e/kdump: Enable crash_kexec_wait_realmode
powerpc/book3e: support CONFIG_RELOCATABLE
powerpc/booke64: Fix args to copy_and_flush
powerpc/book3e-64: rename interrupt_end_book3e with __end_interrupts
powerpc/e6500: kexec: Handle hardware threads
The previous patch introduced a flag that specified pages in a VMA should
be placed on the unevictable LRU, but they should not be made present when
the area is created. This patch adds the ability to set this state via
the new mlock system calls.
We add MLOCK_ONFAULT for mlock2 and MCL_ONFAULT for mlockall.
MLOCK_ONFAULT will set the VM_LOCKONFAULT modifier for VM_LOCKED.
MCL_ONFAULT should be used as a modifier to the two other mlockall flags.
When used with MCL_CURRENT, all current mappings will be marked with
VM_LOCKED | VM_LOCKONFAULT. When used with MCL_FUTURE, the mm->def_flags
will be marked with VM_LOCKED | VM_LOCKONFAULT. When used with both
MCL_CURRENT and MCL_FUTURE, all current mappings and mm->def_flags will be
Prior to this patch, mlockall() will unconditionally clear the
mm->def_flags any time it is called without MCL_FUTURE. This behavior is
maintained after adding MCL_ONFAULT. If a call to mlockall(MCL_FUTURE) is
followed by mlockall(MCL_CURRENT), the mm->def_flags will be cleared and
new VMAs will be unlocked. This remains true with or without MCL_ONFAULT
in either mlockall() invocation.
munlock() will unconditionally clear both vma flags. munlockall()
unconditionally clears for VMA flags on all VMAs and in the mm->def_flags
field.
Signed-off-by: Eric B Munson <emunson@akamai.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Shuah Khan <shuahkh@osg.samsung.com>
This patch provides individual system call numbers for the following
System V IPC system calls, on PowerPC, so that they do not need to be
multiplexed:
* semop, semget, semctl, semtimedop
* msgsnd, msgrcv, msgget, msgctl
* shmat, shmdt, shmget, shmctl
Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com>
The selftest passes on 64-bit LE & BE, and 32-bit.
The selftest passes on 64-bit LE and BE.
This adds include/uapi/asm/eeh.h to kbuild so that the header
file will be exported automatically with below command. The
header file was added by commit ed3e81ff2016 ("powerpc/eeh: Move PE
state constants around")
make INSTALL_HDR_PATH=/tmp/headers \
SRCARCH=powerpc headers_install
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
Currently on powerpc we have our own #define for the highest (negative)
errno value, called _LAST_ERRNO. This is defined to be 516, for reasons
which are not clear.
The generic code, and x86, use MAX_ERRNO, which is defined to be 4095.
In particular seccomp uses MAX_ERRNO to restrict the value that a
seccomp filter can return.
Currently with the mismatch between _LAST_ERRNO and MAX_ERRNO, a seccomp
tracer wanting to return 600, expecting it to be seen as an error, would
instead find on powerpc that userspace sees a successful syscall with a
return value of 600.
To avoid this inconsistency, switch powerpc to use MAX_ERRNO.
We are somewhat confident that generic syscalls that can return a
non-error value above negative MAX_ERRNO have already been updated to
use force_successful_syscall_return().
I have also checked all the powerpc specific syscalls, and believe that
none of them expect to return a non-error value between -MAX_ERRNO and
-516. So this change should be safe ...
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Commit ce48b2100785 "powerpc: Add VSX context save/restore, ptrace and
signal support" expanded the 'vmx_reserve' array element to contain 101
double words, but the comment block above was not updated.
Also reorder the constants in the array size declaration to reflect the
logic mentioned in the comment block above. This change helps in
explaining how the HW registers are represented in the array. But no
functional change.
[mpe: Reworded change log and added whitespace around +'s]
This patch changes the syscall handler to doom (tabort) active
transactions when a syscall is made and return very early without
performing the syscall and keeping side effects to a minimum (no CPU
accounting or system call tracing is performed). Also included is a
new HWCAP2 bit, PPC_FEATURE2_HTM_NOSC, to indicate this
behaviour to userspace.
Currently, the system call instruction automatically suspends an
active transaction which causes side effects to persist when an active
transaction fails.
This does change the kernel's behaviour, but in a way that was
documented as unsupported. It doesn't reduce functionality as
syscalls will still be performed after tsuspend; it just requires that
the transaction be explicitly suspended. It also provides a
consistent interface and makes the behaviour of user code
substantially the same across powerpc and platforms that do not
support suspended transactions (e.g. x86 and s390).
Performance measurements using
http://ozlabs.org/~anton/junkcode/null_syscall.c indicate the cost of
a normal (non-aborted) system call increases by about 0.25%.
We'll want to build the opal-prd daemon with the prd headers, so include
this in the uapi headers list.
Signed-off-by: Jeremy Kerr <jk@ozlabs.org>
This change adds a char device to access the "PRD" (processor runtime
diagnostics) channel to OPAL firmware.
Includes contributions from Vaidyanathan Srinivasan, Neelesh Gupta &
Vishal Kulkarni.
Signed-off-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com>
Acked-by: Stewart Smith <stewart@linux.vnet.ibm.com>
The patch defines PCI error types and functions in uapi/asm/eeh.h
and exports function eeh_pe_inject_err(), which will be called by
VFIO driver to inject the specified PCI error to the indicated
PE for testing purpose.
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
There are two equivalent sets of PE state constants, defined in
arch/powerpc/include/asm/eeh.h and include/uapi/linux/vfio.h.
Though the names are different, their corresponding values are
exactly same. The former is used by EEH core and the latter is
used by userspace.
The patch moves those constants from arch/powerpc/include/asm/eeh.h
to arch/powerpc/include/uapi/asm/eeh.h, which are expected to be
used by userspace from now on. We can't delete those constants in
vfio.h as it's uncertain that those constants have been or will be
used by userspace.
Suggested-by: David Gibson <david@gibson.dropbear.id.au>
This reverts commit feba40362b11341bee6d8ed58d54b896abbd9f84.
Although the principle of this change is good, the implementation has a
few issues.
Firstly we can sometimes fail to abort a syscall because r12 may have
been clobbered by C code if we went down the virtual CPU accounting
path, or if syscall tracing was enabled.
Secondly we have decided that it is safer to abort the syscall even
earlier in the syscall entry path, so that we avoid the syscall tracing
path when we are transactional.
So that we have time to thoroughly test those changes we have decided to
revert this for this merge window and will merge the fixed version in
the next window.
NB. Rather than reverting the selftest we just drop tm-syscall from
TEST_PROGS so that it's not run by default.
Fixes: feba40362b11 ("powerpc/tm: Abort syscalls in active transactions")
Merge third patchbomb from Andrew Morton:
- various misc things
- a couple of lib/ optimisations
- provide DIV_ROUND_CLOSEST_ULL()
- checkpatch updates
- rtc tree
- befs, nilfs2, hfs, hfsplus, fatfs, adfs, affs, bfs
- ptrace fixes
- fork() fixes
- seccomp cleanups
- more mmap_sem hold time reductions from Davidlohr
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (138 commits)
proc: show locks in /proc/pid/fdinfo/X
docs: add missing and new /proc/PID/status file entries, fix typos
drivers/rtc/rtc-at91rm9200.c: make IO endian agnostic
Documentation/spi/spidev_test.c: fix warning
drivers/rtc/rtc-s5m.c: allow usage on device type different than main MFD type
.gitignore: ignore *.tar
MAINTAINERS: add Mediatek SoC mailing list
tomoyo: reduce mmap_sem hold for mm->exe_file
powerpc/oprofile: reduce mmap_sem hold for exe_file
oprofile: reduce mmap_sem hold for mm->exe_file
mips: ip32: add platform data hooks to use DS1685 driver
lib/Kconfig: fix up HAVE_ARCH_BITREVERSE help text
x86: switch to using asm-generic for seccomp.h
sparc: switch to using asm-generic for seccomp.h
powerpc: switch to using asm-generic for seccomp.h
parisc: switch to using asm-generic for seccomp.h
mips: switch to using asm-generic for seccomp.h
microblaze: use asm-generic for seccomp.h
arm: use asm-generic for seccomp.h
seccomp: allow COMPAT sigreturn overrides
Switch to using the newly created asm-generic/seccomp.h for the seccomp
strict mode syscall definitions. The obsolete sigreturn in COMPAT mode is
retained as an override. Remaining definitions are identical, though they
incorrectly appeared in uapi, which has been corrected.
Cc: Michael Ellerman <mpe@ellerman.id.au>
transactions when a syscall is made and return immediately without
performing the syscall.
transaction fails.
documented as unsupported. It doesn't reduce functionality because
syscalls will still be performed after tsuspend. It also provides a
indicate the cost of a system call increases by about 0.5%.
Acked-By: Michael Neuling <mikey@neuling.org>
We currently have a "special" syscall for switching endianness. This is
syscall number 0x1ebe, which is handled explicitly in the 64-bit syscall
exception entry.
That has a few problems, firstly the syscall number is outside of the
usual range, which confuses various tools. For example strace doesn't
recognise the syscall at all.
Secondly it's handled explicitly as a special case in the syscall
exception entry, which is complicated enough without it.
As a first step toward removing the special syscall, we need to add a
regular syscall that implements the same functionality.
The logic is simple, it simply toggles the MSR_LE bit in the userspace
MSR. This is the same as the special syscall, with the caveat that the
special syscall clobbers fewer registers.
This version clobbers r9-r12, XER, CTR, and CR0-1,5-7.
As our various loops (copy, string, crypto etc) get more complicated,
we want to share implementations between userspace (eg glibc) and
the kernel. We also want to write userspace test harnesses to put
in tools/testing/selftest.
One gratuitous difference between userspace and the kernel is the
VMX register definitions - the kernel uses vrX whereas both gcc and
glibc use vX.
Change the kernel to match userspace.
Wire up sys_execveat(). This passes the selftests for the system call.
Check success of execveat(3, '../execveat', 0)... [OK]
Check success of execveat(5, 'execveat', 0)... [OK]
Check success of execveat(6, 'execveat', 0)... [OK]
Check success of execveat(-100, '/home/pranith/linux/...ftests/exec/execveat', 0)... [OK]
Check success of execveat(99, '/home/pranith/linux/...ftests/exec/execveat', 0)... [OK]
Check success of execveat(8, '', 4096)... [OK]
Check success of execveat(17, '', 4096)... [OK]
Check success of execveat(9, '', 4096)... [OK]
Check success of execveat(14, '', 4096)... [OK]
Check success of execveat(15, '', 4096)... [OK]
Check failure of execveat(8, '', 0) with ENOENT... [OK]
Check failure of execveat(8, '(null)', 4096) with EFAULT... [OK]
Check success of execveat(5, 'execveat.symlink', 0)... [OK]
Check success of execveat(6, 'execveat.symlink', 0)... [OK]
Check success of execveat(-100, '/home/pranith/linux/...xec/execveat.symlink', 0)... [OK]
Check success of execveat(10, '', 4096)... [OK]
Check success of execveat(10, '', 4352)... [OK]
Check failure of execveat(5, 'execveat.symlink', 256) with ELOOP... [OK]
Check failure of execveat(6, 'execveat.symlink', 256) with ELOOP... [OK]
Check failure of execveat(-100, '/home/pranith/linux/tools/testing/selftests/exec/execveat.symlink', 256) with ELOOP... [OK]
Check success of execveat(3, '../script', 0)... [OK]
Check success of execveat(5, 'script', 0)... [OK]
Check success of execveat(6, 'script', 0)... [OK]
Check success of execveat(-100, '/home/pranith/linux/...elftests/exec/script', 0)... [OK]
Check success of execveat(13, '', 4096)... [OK]
Check success of execveat(13, '', 4352)... [OK]
Check failure of execveat(18, '', 4096) with ENOENT... [OK]
Check failure of execveat(7, 'script', 0) with ENOENT... [OK]
Check success of execveat(16, '', 4096)... [OK]
Check success of execveat(4, '../script', 0)... [OK]
Check success of execveat(4, 'script', 0)... [OK]
Check failure of execveat(4, 'script', 0) with ENOENT... [OK]
Check failure of execveat(5, 'execveat', 65535) with EINVAL... [OK]
Check failure of execveat(5, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(6, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(-100, 'no-such-file', 0) with ENOENT... [OK]
Check failure of execveat(5, '', 4096) with EACCES... [OK]
Check failure of execveat(5, 'Makefile', 0) with EACCES... [OK]
Check failure of execveat(11, '', 4096) with EACCES... [OK]
Check failure of execveat(12, '', 4096) with EACCES... [OK]
Check failure of execveat(99, '', 4096) with EBADF... [OK]
Check failure of execveat(99, 'execveat', 0) with EBADF... [OK]
Check failure of execveat(8, 'execveat', 0) with ENOTDIR... [OK]
Invoke copy of 'execveat' via filename of length 4093:
Check success of execveat(19, '', 4096)... [OK]
Check success of execveat(5, 'xxxxxxxxxxxxxxxxxxxx...yyyyyyyyyyyyyyyyyyyy', 0)... [OK]
Invoke copy of 'script' via filename of length 4093:
Check success of execveat(20, '', 4096)... [OK]
/bin/sh: 0: Can't open /dev/fd/5/xxxxxxx(... a long line of x's and y's, 0)... [OK]
Tested on a 32-bit powerpc system.
Signed-off-by: Pranith Kumar <bobby.prani@gmail.com>
introduce new setsockopt() command:
setsockopt(sock, SOL_SOCKET, SO_ATTACH_BPF, &prog_fd, sizeof(prog_fd))
where prog_fd was received from syscall bpf(BPF_PROG_LOAD, attr, ...)
and attr->prog_type == BPF_PROG_TYPE_SOCKET_FILTER
setsockopt() calls bpf_prog_get() which increments refcnt of the program,
so it doesn't get unloaded while socket is using the program.
The same eBPF program can be attached to multiple sockets.
User task exit automatically closes socket which calls sk_filter_uncharge()
which decrements refcnt of eBPF program
Signed-off-by: Alexei Starovoitov <ast@plumgrid.com>
Alternative to RPS/RFS is to use hardware support for multiple
queues.
Then split a set of million of sockets into worker threads, each
one using epoll() to manage events on its own socket pool.
Ideally, we want one thread per RX/TX queue/cpu, but we have no way to
know after accept() or connect() on which queue/cpu a socket is managed.
We normally use one cpu per RX queue (IRQ smp_affinity being properly
set), so remembering on socket structure which cpu delivered last packet
is enough to solve the problem.
After accept(), connect(), or even file descriptor passing around
processes, applications can use :
int cpu;
socklen_t len = sizeof(cpu);
getsockopt(fd, SOL_SOCKET, SO_INCOMING_CPU, &cpu, &len);
And use this information to put the socket into the right silo
for optimal performance, as all networking stack should run
on the appropriate cpu, without need to send IPI (RPS/RFS).
This patch wires up the new syscall sys_bpf() on powerpc.
Passes the tests in samples/bpf:
#0 add+sub+mul OK
#1 unreachable OK
#2 unreachable2 OK
#3 out of range jump OK
#4 out of range jump2 OK
#5 test1 ld_imm64 OK
#6 test2 ld_imm64 OK
#7 test3 ld_imm64 OK
#8 test4 ld_imm64 OK
#9 test5 ld_imm64 OK
#10 no bpf_exit OK
#11 loop (back-edge) OK
#12 loop2 (back-edge) OK
#13 conditional loop OK
#14 read uninitialized register OK
#15 read invalid register OK
#16 program doesn't init R0 before exit OK
#17 stack out of bounds OK
#18 invalid call insn1 OK
#19 invalid call insn2 OK
#20 invalid function call OK
#21 uninitialized stack1 OK
#22 uninitialized stack2 OK
#23 check valid spill/fill OK
#24 check corrupted spill/fill OK
#25 invalid src register in STX OK
#26 invalid dst register in STX OK
#27 invalid dst register in ST OK
#28 invalid src register in LDX OK
#29 invalid dst register in LDX OK
#30 junk insn OK
#31 junk insn2 OK
#32 junk insn3 OK
#33 junk insn4 OK
#34 junk insn5 OK
#35 misaligned read from stack OK
#36 invalid map_fd for function call OK
#37 don't check return value before access OK
#38 access memory with incorrect alignment OK
#39 sometimes access memory with incorrect alignment OK
#40 jump test 1 OK
#41 jump test 2 OK
#42 jump test 3 OK
#43 jump test 4 OK
[mpe: test using samples/bpf]
Pull KVM updates from Paolo Bonzini:
"Fixes and features for 3.18.
Apart from the usual cleanups, here is the summary of new features:
- s390 moves closer towards host large page support
- PowerPC has improved support for debugging (both inside the guest
and via gdbstub) and support for e6500 processors
- ARM/ARM64 support read-only memory (which is necessary to put
firmware in emulated NOR flash)
- x86 has the usual emulator fixes and nested virtualization
improvements (including improved Windows support on Intel and
Jailhouse hypervisor support on AMD), adaptive PLE which helps
overcommitting of huge guests. Also included are some patches that
make KVM more friendly to memory hot-unplug, and fixes for rare
caching bugs.
Two patches have trivial mm/ parts that were acked by Rik and Andrew.
Note: I will soon switch to a subkey for signing purposes"
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (157 commits)
kvm: do not handle APIC access page if in-kernel irqchip is not in use
KVM: s390: count vcpu wakeups in stat.halt_wakeup
KVM: s390/facilities: allow TOD-CLOCK steering facility bit
KVM: PPC: BOOK3S: HV: CMA: Reserve cma region only in hypervisor mode
arm/arm64: KVM: Report correct FSC for unsupported fault types
arm/arm64: KVM: Fix VTTBR_BADDR_MASK and pgd alloc
kvm: Fix kvm_get_page_retry_io __gup retval check
arm/arm64: KVM: Fix set_clear_sgi_pend_reg offset
kvm: x86: Unpin and remove kvm_arch->apic_access_page
kvm: vmx: Implement set_apic_access_page_addr
kvm: x86: Add request bit to reload APIC access page address
kvm: Add arch specific mmu notifier for page invalidation
kvm: Rename make_all_cpus_request() to kvm_make_all_cpus_request() and make it non-static
kvm: Fix page ageing bugs
kvm/x86/mmu: Pass gfn and level to rmapp callback.
x86: kvm: use alternatives for VMCALL vs. VMMCALL if kernel text is read-only
kvm: x86: use macros to compute bank MSRs
KVM: x86: Remove debug assertion of non-PAE reserved bits
kvm: don't take vcpu mutex for obviously invalid vcpu ioctls
kvm: Faults which trigger IO release the mmap_sem
Move ONE_REG AltiVec support to powerpc generic layer.
Signed-off-by: Mihai Caraman <mihai.caraman@freescale.com>
Signed-off-by: Bharat Bhushan <Bharat.Bhushan@freescale.com>
This patch wires up three new syscalls for powerpc. The three
new syscalls are seccomp, getrandom and memfd_create.
Reviewed-by: David Herrmann <dh.herrmann@gmail.com>
Unfortunately, the LPCR got defined as a 32-bit register in the
one_reg interface. This is unfortunate because KVM allows userspace
to control the DPFD (default prefetch depth) field, which is in the
upper 32 bits. The result is that DPFD always get set to 0, which
reduces performance in the guest.
We can't just change KVM_REG_PPC_LPCR to be a 64-bit register ID,
since that would break existing userspace binaries. Instead we define
a new KVM_REG_PPC_LPCR_64 id which is 64-bit. Userspace can still use
the old KVM_REG_PPC_LPCR id, but it now only modifies those fields in
the bottom 32 bits that userspace can modify (ILE, TC and AIL).
If userspace uses the new KVM_REG_PPC_LPCR_64 id, it can modify DPFD
as well.
