path: root/arch/powerpc/include/asm
2015-06-26Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge second patchbomb from Andrew Morton: - most of the rest of MM - lots of misc things - procfs updates - printk feature work - updates to get_maintainer, MAINTAINERS, checkpatch - lib/ updates * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (96 commits) exit,stats: /* obey this comment */ coredump: add __printf attribute to cn_*printf functions coredump: use from_kuid/kgid when formatting corename fs/reiserfs: remove unneeded cast NILFS2: support NFSv2 export fs/befs/btree.c: remove unneeded initializations fs/minix: remove unneeded cast init/do_mounts.c: add create_dev() failure log kasan: remove duplicate definition of the macro KASAN_FREE_PAGE fs/efs: femove unneeded cast checkpatch: emit "NOTE: <types>" message only once after multiple files checkpatch: emit an error when there's a diff in a changelog checkpatch: validate MODULE_LICENSE content checkpatch: add multi-line handling for PREFER_ETHER_ADDR_COPY checkpatch: suggest using eth_zero_addr() and eth_broadcast_addr() checkpatch: fix processing of MEMSET issues checkpatch: suggest using ether_addr_equal*() checkpatch: avoid NOT_UNIFIED_DIFF errors on cover-letter.patch files checkpatch: remove local from codespell path checkpatch: add --showfile to allow input via pipe to show filenames ...
2015-06-25mm/hugetlb: remove arch_prepare/release_hugepage from arch headersDominik Dingel
Nobody used these hooks so they were removed from common code, and can now be removed from the architectures. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-25Merge branch 'for-4.2/sg' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull asm/scatterlist.h removal from Jens Axboe: "We don't have any specific arch scatterlist anymore, since parisc finally switched over. Kill the include" * 'for-4.2/sg' of git://git.kernel.dk/linux-block: remove scatterlist.h generation from arch Kbuild files remove <asm/scatterlist.h>
2015-06-24Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge first patchbomb from Andrew Morton: - a few misc things - ocfs2 udpates - kernel/watchdog.c feature work (took ages to get right) - most of MM. A few tricky bits are held up and probably won't make 4.2. * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (91 commits) mm: kmemleak_alloc_percpu() should follow the gfp from per_alloc() mm, thp: respect MPOL_PREFERRED policy with non-local node tmpfs: truncate prealloc blocks past i_size mm/memory hotplug: print the last vmemmap region at the end of hot add memory mm/mmap.c: optimization of do_mmap_pgoff function mm: kmemleak: optimise kmemleak_lock acquiring during kmemleak_scan mm: kmemleak: avoid deadlock on the kmemleak object insertion error path mm: kmemleak: do not acquire scan_mutex in kmemleak_do_cleanup() mm: kmemleak: fix delete_object_*() race when called on the same memory block mm: kmemleak: allow safe memory scanning during kmemleak disabling memcg: convert mem_cgroup->under_oom from atomic_t to int memcg: remove unused mem_cgroup->oom_wakeups frontswap: allow multiple backends x86, mirror: x86 enabling - find mirrored memory ranges mm/memblock: allocate boot time data structures from mirrored memory mm/memblock: add extra "flags" to memblock to allow selection of memory based on attribute mm: do not ignore mapping_gfp_mask in page cache allocation paths mm/cma.c: fix typos in comments mm/oom_kill.c: print points as unsigned int mm/hugetlb: handle races in alloc_huge_page and hugetlb_reserve_pages ...
2015-06-24Merge tag 'edac_for_4.2_2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC updates from Borislav Petkov: - New APM X-Gene SoC EDAC driver (Loc Ho) - AMD error injection module improvements (Aravind Gopalakrishnan) - Altera Arria 10 support (Thor Thayer) - misc fixes and cleanups all over the place * tag 'edac_for_4.2_2' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: (28 commits) EDAC: Update Documentation/edac.txt EDAC: Fix typos in Documentation/edac.txt EDAC, mce_amd_inj: Set MISCV on injection EDAC, mce_amd_inj: Move bit preparations before the injection EDAC, mce_amd_inj: Cleanup and simplify README EDAC, altera: Do not allow suspend when EDAC is enabled EDAC, mce_amd_inj: Make inj_type static arm: socfpga: dts: Add Arria10 SDRAM EDAC DTS support EDAC, altera: Add Arria10 EDAC support EDAC, altera: Refactor for Altera CycloneV SoC EDAC, altera: Generalize driver to use DT Memory size EDAC, mce_amd_inj: Add README file EDAC, mce_amd_inj: Add individual permissions field to dfs_node EDAC, mce_amd_inj: Modify flags attribute to use string arguments EDAC, mce_amd_inj: Read out number of MCE banks from the hardware EDAC, mce_amd_inj: Use MCE_INJECT_GET macro for bank node too EDAC, xgene: Fix cpuid abuse EDAC, mpc85xx: Extend error address to 64 bit EDAC, mpc8xxx: Adapt for FSL SoC EDAC, edac_stub: Drop arch-specific include ...
2015-06-24mm: clarify that the function operates on hugepage pteAneesh Kumar K.V
We have confusing functions to clear pmd, pmd_clear_* and pmd_clear. Add _huge_ to pmdp_clear functions so that we are clear that they operate on hugepage pte. We don't bother about other functions like pmdp_set_wrprotect, pmdp_clear_flush_young, because they operate on PTE bits and hence indicate they are operating on hugepage ptes Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24powerpc/mm: use generic version of pmdp_clear_flush()Aneesh Kumar K.V
Also move the pmd_trans_huge check to generic code. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/thp: split out pmd collapse flush into separate functionsAneesh Kumar K.V
Architectures like ppc64 [1] need to do special things while clearing pmd before a collapse. For them this operation is largely different from a normal hugepage pte clear. Hence add a separate function to clear pmd before collapse. After this patch pmdp_* functions operate only on hugepage pte, and not on regular pmd_t values pointing to page table. [1] ppc64 needs to invalidate all the normal page pte mappings we already have inserted in the hardware hash page table. But before doing that we need to make sure there are no parallel hash page table insert going on. So we need to do a kick_all_cpus_sync() before flushing the older hash table entries. By moving this to a separate function we capture these details and mention how it is different from a hugepage pte clear. This patch is a cleanup and only does code movement for clarity. There should not be any change in functionality. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm/hugetlb: reduce arch dependent code about hugetlb_prefault_arch_hookZhang Zhen
Currently we have many duplicates in definitions of hugetlb_prefault_arch_hook. In all architectures this function is empty. Signed-off-by: Zhang Zhen <zhenzhang.zhang@huawei.com> Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24powerpc/mm: tracking vDSO remapLaurent Dufour
Some processes (CRIU) are moving the vDSO area using the mremap system call. As a consequence the kernel reference to the vDSO base address is no more valid and the signal return frame built once the vDSO has been moved is not pointing to the new sigreturn address. This patch handles vDSO remapping and unmapping. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Reviewed-by: Ingo Molnar <mingo@kernel.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24mm: new mm hook frameworkLaurent Dufour
CRIU is recreating the process memory layout by remapping the checkpointee memory area on top of the current process (criu). This includes remapping the vDSO to the place it has at checkpoint time. However some architectures like powerpc are keeping a reference to the vDSO base address to build the signal return stack frame by calling the vDSO sigreturn service. So once the vDSO has been moved, this reference is no more valid and the signal frame built later are not usable. This patch serie is introducing a new mm hook framework, and a new arch_remap hook which is called when mremap is done and the mm lock still hold. The next patch is adding the vDSO remap and unmap tracking to the powerpc architecture. This patch (of 3): This patch introduces a new set of header file to manage mm hooks: - per architecture empty header file (arch/x/include/asm/mm-arch-hooks.h) - a generic header (include/linux/mm-arch-hooks.h) The architecture which need to overwrite a hook as to redefine it in its header file, while architecture which doesn't need have nothing to do. The default hooks are defined in the generic header and are used in the case the architecture is not defining it. In a next step, mm hooks defined in include/asm-generic/mm_hooks.h should be moved here. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com> Cc: Hugh Dickins <hughd@google.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Pavel Emelyanov <xemul@parallels.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-24Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull first batch of KVM updates from Paolo Bonzini: "The bulk of the changes here is for x86. And for once it's not for silicon that no one owns: these are really new features for everyone. Details: - ARM: several features are in progress but missed the 4.2 deadline. So here is just a smattering of bug fixes, plus enabling the VFIO integration. - s390: Some fixes/refactorings/optimizations, plus support for 2GB pages. - x86: * host and guest support for marking kvmclock as a stable scheduler clock. * support for write combining. * support for system management mode, needed for secure boot in guests. * a bunch of cleanups required for the above * support for virtualized performance counters on AMD * legacy PCI device assignment is deprecated and defaults to "n" in Kconfig; VFIO replaces it On top of this there are also bug fixes and eager FPU context loading for FPU-heavy guests. - Common code: Support for multiple address spaces; for now it is used only for x86 SMM but the s390 folks also have plans" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (124 commits) KVM: s390: clear floating interrupt bitmap and parameters KVM: x86/vPMU: Enable PMU handling for AMD PERFCTRn and EVNTSELn MSRs KVM: x86/vPMU: Implement AMD vPMU code for KVM KVM: x86/vPMU: Define kvm_pmu_ops to support vPMU function dispatch KVM: x86/vPMU: introduce kvm_pmu_msr_idx_to_pmc KVM: x86/vPMU: reorder PMU functions KVM: x86/vPMU: whitespace and stylistic adjustments in PMU code KVM: x86/vPMU: use the new macros to go between PMC, PMU and VCPU KVM: x86/vPMU: introduce pmu.h header KVM: x86/vPMU: rename a few PMU functions KVM: MTRR: do not map huge page for non-consistent range KVM: MTRR: simplify kvm_mtrr_get_guest_memory_type KVM: MTRR: introduce mtrr_for_each_mem_type KVM: MTRR: introduce fixed_mtrr_addr_* functions KVM: MTRR: sort variable MTRRs KVM: MTRR: introduce var_mtrr_range KVM: MTRR: introduce fixed_mtrr_segment table KVM: MTRR: improve kvm_mtrr_get_guest_memory_type KVM: MTRR: do not split 64 bits MSR content KVM: MTRR: clean up mtrr default type ...
2015-06-24Merge tag 'powerpc-4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: - disable the 32-bit vdso when building LE, so we can build with a 64-bit only toolchain. - EEH fixes from Gavin & Richard. - enable the sys_kcmp syscall from Laurent. - sysfs control for fastsleep workaround from Shreyas. - expose OPAL events as an irq chip by Alistair. - MSI ops moved to pci_controller_ops by Daniel. - fix for kernel to userspace backtraces for perf from Anton. - merge pseries and pseries_le defconfigs from Cyril. - CXL in-kernel API from Mikey. - OPAL prd driver from Jeremy. - fix for DSCR handling & tests from Anshuman. - Powernv flash mtd driver from Cyril. - dynamic DMA Window support on powernv from Alexey. - LLVM clang fixes & workarounds from Anton. - reworked version of the patch to abort syscalls when transactional. - fix the swap encoding to support 4TB, from Aneesh. - various fixes as usual. - Freescale updates from Scott: Highlights include more 8xx optimizations, an e6500 hugetlb optimization, QMan device tree nodes, t1024/t1023 support, and various fixes and cleanup. * tag 'powerpc-4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (180 commits) cxl: Fix typo in debug print cxl: Add CXL_KERNEL_API config option powerpc/powernv: Fix wrong IOMMU table in pnv_ioda_setup_bus_dma() powerpc/mm: Change the swap encoding in pte. powerpc/mm: PTE_RPN_MAX is not used, remove the same powerpc/tm: Abort syscalls in active transactions powerpc/iommu/ioda2: Enable compile with IOV=on and IOMMU_API=off powerpc/include: Add opal-prd to installed uapi headers powerpc/powernv: fix construction of opal PRD messages powerpc/powernv: Increase opal-irqchip initcall priority powerpc: Make doorbell check preemption safe powerpc/powernv: pnv_init_idle_states() should only run on powernv macintosh/nvram: Remove as unused powerpc: Don't use gcc specific options on clang powerpc: Don't use -mno-strict-align on clang powerpc: Only use -mtraceback=no, -mno-string and -msoft-float if toolchain supports it powerpc: Only use -mabi=altivec if toolchain supports it powerpc: Fix duplicate const clang warning in user access code vfio: powerpc/spapr: Support Dynamic DMA windows vfio: powerpc/spapr: Register memory and define IOMMU v2 ...
2015-06-23Merge tag 'pci-v4.2-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "PCI changes for the v4.2 merge window: Enumeration - Move pci_ari_enabled() to global header (Alex Williamson) - Account for ARI in _PRT lookups (Alex Williamson) - Remove unused pci_scan_bus_parented() (Yijing Wang) Resource management - Use host bridge _CRS info on systems with >32 bit addressing (Bjorn Helgaas) - Use host bridge _CRS info on Foxconn K8M890-8237A (Bjorn Helgaas) - Fix pci_address_to_pio() conversion of CPU address to I/O port (Zhichang Yuan) - Add pci_bus_addr_t (Yinghai Lu) PCI device hotplug - Wait for pciehp command completion where necessary (Alex Williamson) - Drop pointless ACPI-based "slot detection" check (Rafael J. Wysocki) - Check ignore_hotplug for all downstream devices (Rafael J. Wysocki) - Propagate the "ignore hotplug" setting to parent (Rafael J. Wysocki) - Inline pciehp "handle event" functions into the ISR (Bjorn Helgaas) - Clean up pciehp debug logging (Bjorn Helgaas) Power management - Remove redundant PCIe port type checking (Yijing Wang) - Add dev->has_secondary_link to track downstream PCIe links (Yijing Wang) - Use dev->has_secondary_link to find downstream links for ASPM (Yijing Wang) - Drop __pci_disable_link_state() useless "force" parameter (Bjorn Helgaas) - Simplify Clock Power Management setting (Bjorn Helgaas) Virtualization - Add ACS quirks for Intel 9-series PCH root ports (Alex Williamson) - Add function 1 DMA alias quirk for Marvell 9120 (Sakari Ailus) MSI - Disable MSI at enumeration even if kernel doesn't support MSI (Michael S. Tsirkin) - Remove unused pci_msi_off() (Bjorn Helgaas) - Rename msi_set_enable(), msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Export pci_msi_set_enable(), pci_msix_clear_and_set_ctrl() (Michael S. Tsirkin) - Drop pci_msi_off() calls during probe (Michael S. Tsirkin) APM X-Gene host bridge driver - Add APM X-Gene v1 PCIe MSI/MSIX termination driver (Duc Dang) - Add APM X-Gene PCIe MSI DTS nodes (Duc Dang) - Disable Configuration Request Retry Status for v1 silicon (Duc Dang) - Allow config access to Root Port even when link is down (Duc Dang) Broadcom iProc host bridge driver - Allow override of device tree IRQ mapping function (Hauke Mehrtens) - Add BCMA PCIe driver (Hauke Mehrtens) - Directly add PCI resources (Hauke Mehrtens) - Free resource list after registration (Hauke Mehrtens) Freescale i.MX6 host bridge driver - Add speed change timeout message (Troy Kisky) - Rename imx6_pcie_start_link() to imx6_pcie_establish_link() (Bjorn Helgaas) Freescale Layerscape host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) - Factor out ls_pcie_establish_link() (Bjorn Helgaas) Marvell MVEBU host bridge driver - Remove mvebu_pcie_scan_bus() (Yijing Wang) NVIDIA Tegra host bridge driver - Remove tegra_pcie_scan_bus() (Yijing Wang) Synopsys DesignWare host bridge driver - Consolidate outbound iATU programming functions (Jisheng Zhang) - Use iATU0 for cfg and IO, iATU1 for MEM (Jisheng Zhang) - Add support for x8 links (Zhou Wang) - Wait for link to come up with consistent style (Bjorn Helgaas) - Use pci_scan_root_bus() for simplicity (Yijing Wang) TI DRA7xx host bridge driver - Use dw_pcie_link_up() consistently (Bjorn Helgaas) Miscellaneous - Include <linux/pci.h>, not <asm/pci.h> (Bjorn Helgaas) - Remove unnecessary #includes of <asm/pci.h> (Bjorn Helgaas) - Remove unused pcibios_select_root() (again) (Bjorn Helgaas) - Remove unused pci_dma_burst_advice() (Bjorn Helgaas) - xen/pcifront: Don't use deprecated function pci_scan_bus_parented() (Arnd Bergmann)" * tag 'pci-v4.2-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (58 commits) PCI: pciehp: Inline the "handle event" functions into the ISR PCI: pciehp: Rename queue_interrupt_event() to pciehp_queue_interrupt_event() PCI: pciehp: Make queue_interrupt_event() void PCI: xgene: Allow config access to Root Port even when link is down PCI: xgene: Disable Configuration Request Retry Status for v1 silicon PCI: pciehp: Clean up debug logging x86/PCI: Use host bridge _CRS info on systems with >32 bit addressing PCI: imx6: Add #define PCIE_RC_LCSR PCI: imx6: Use "u32", not "uint32_t" PCI: Remove unused pci_scan_bus_parented() xen/pcifront: Don't use deprecated function pci_scan_bus_parented() PCI: imx6: Add speed change timeout message PCI/ASPM: Simplify Clock Power Management setting PCI: designware: Wait for link to come up with consistent style PCI: layerscape: Factor out ls_pcie_establish_link() PCI: layerscape: Use dw_pcie_link_up() consistently PCI: dra7xx: Use dw_pcie_link_up() consistently x86/PCI: Use host bridge _CRS info on Foxconn K8M890-8237A PCI: pciehp: Wait for hotplug command completion where necessary PCI: Remove unused pci_dma_burst_advice() ...
2015-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: "Here is the crypto update for 4.2: API: - Convert RNG interface to new style. - New AEAD interface with one SG list for AD and plain/cipher text. All external AEAD users have been converted. - New asymmetric key interface (akcipher). Algorithms: - Chacha20, Poly1305 and RFC7539 support. - New RSA implementation. - Jitter RNG. - DRBG is now seeded with both /dev/random and Jitter RNG. If kernel pool isn't ready then DRBG will be reseeded when it is. - DRBG is now the default crypto API RNG, replacing krng. - 842 compression (previously part of powerpc nx driver). Drivers: - Accelerated SHA-512 for arm64. - New Marvell CESA driver that supports DMA and more algorithms. - Updated powerpc nx 842 support. - Added support for SEC1 hardware to talitos" * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (292 commits) crypto: marvell/cesa - remove COMPILE_TEST dependency crypto: algif_aead - Temporarily disable all AEAD algorithms crypto: af_alg - Forbid the use internal algorithms crypto: echainiv - Only hold RNG during initialisation crypto: seqiv - Add compatibility support without RNG crypto: eseqiv - Offer normal cipher functionality without RNG crypto: chainiv - Offer normal cipher functionality without RNG crypto: user - Add CRYPTO_MSG_DELRNG crypto: user - Move cryptouser.h to uapi crypto: rng - Do not free default RNG when it becomes unused crypto: skcipher - Allow givencrypt to be NULL crypto: sahara - propagate the error on clk_disable_unprepare() failure crypto: rsa - fix invalid select for AKCIPHER crypto: picoxcell - Update to the current clk API crypto: nx - Check for bogus firmware properties crypto: marvell/cesa - add DT bindings documentation crypto: marvell/cesa - add support for Kirkwood and Dove SoCs crypto: marvell/cesa - add support for Orion SoCs crypto: marvell/cesa - add allhwsupport module parameter crypto: marvell/cesa - add support for all armada SoCs ...
2015-06-22Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes are: - lockless wakeup support for futexes and IPC message queues (Davidlohr Bueso, Peter Zijlstra) - Replace spinlocks with atomics in thread_group_cputimer(), to improve scalability (Jason Low) - NUMA balancing improvements (Rik van Riel) - SCHED_DEADLINE improvements (Wanpeng Li) - clean up and reorganize preemption helpers (Frederic Weisbecker) - decouple page fault disabling machinery from the preemption counter, to improve debuggability and robustness (David Hildenbrand) - SCHED_DEADLINE documentation updates (Luca Abeni) - topology CPU masks cleanups (Bartosz Golaszewski) - /proc/sched_debug improvements (Srikar Dronamraju)" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (79 commits) sched/deadline: Remove needless parameter in dl_runtime_exceeded() sched: Remove superfluous resetting of the p->dl_throttled flag sched/deadline: Drop duplicate init_sched_dl_class() declaration sched/deadline: Reduce rq lock contention by eliminating locking of non-feasible target sched/deadline: Make init_sched_dl_class() __init sched/deadline: Optimize pull_dl_task() sched/preempt: Add static_key() to preempt_notifiers sched/preempt: Fix preempt notifiers documentation about hlist_del() within unsafe iteration sched/stop_machine: Fix deadlock between multiple stop_two_cpus() sched/debug: Add sum_sleep_runtime to /proc/<pid>/sched sched/debug: Replace vruntime with wait_sum in /proc/sched_debug sched/debug: Properly format runnable tasks in /proc/sched_debug sched/numa: Only consider less busy nodes as numa balancing destinations Revert 095bebf61a46 ("sched/numa: Do not move past the balance point if unbalanced") sched/fair: Prevent throttling in early pick_next_task_fair() preempt: Reorganize the notrace definitions a bit preempt: Use preempt_schedule_context() as the official tracing preemption point sched: Make preempt_schedule_context() function-tracing safe x86: Remove cpu_sibling_mask() and cpu_core_mask() x86: Replace cpu_**_mask() with topology_**_cpumask() ...
2015-06-22Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes are: - 'qspinlock' support, enabled on x86: queued spinlocks - these are now the spinlock variant used by x86 as they outperform ticket spinlocks in every category. (Waiman Long) - 'pvqspinlock' support on x86: paravirtualized variant of queued spinlocks. (Waiman Long, Peter Zijlstra) - 'qrwlock' support, enabled on x86: queued rwlocks. Similar to queued spinlocks, they are now the variant used by x86: CONFIG_ARCH_USE_QUEUED_SPINLOCKS=y CONFIG_QUEUED_SPINLOCKS=y CONFIG_ARCH_USE_QUEUED_RWLOCKS=y CONFIG_QUEUED_RWLOCKS=y - various lockdep fixlets - various locking primitives cleanups, further WRITE_ONCE() propagation" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) locking/lockdep: Remove hard coded array size dependency locking/qrwlock: Don't contend with readers when setting _QW_WAITING lockdep: Do not break user-visible string locking/arch: Rename set_mb() to smp_store_mb() locking/arch: Add WRITE_ONCE() to set_mb() rtmutex: Warn if trylock is called from hard/softirq context arch: Remove __ARCH_HAVE_CMPXCHG locking/rtmutex: Drop usage of __HAVE_ARCH_CMPXCHG locking/qrwlock: Rename QUEUE_RWLOCK to QUEUED_RWLOCKS locking/pvqspinlock: Rename QUEUED_SPINLOCK to QUEUED_SPINLOCKS locking/pvqspinlock: Replace xchg() by the more descriptive set_mb() locking/pvqspinlock, x86: Enable PV qspinlock for Xen locking/pvqspinlock, x86: Enable PV qspinlock for KVM locking/pvqspinlock, x86: Implement the paravirt qspinlock call patching locking/pvqspinlock: Implement simple paravirt support for the qspinlock locking/qspinlock: Revert to test-and-set on hypervisors locking/qspinlock: Use a simple write to grab the lock locking/qspinlock: Optimize for smaller NR_CPUS locking/qspinlock: Extract out code snippets for the next patch locking/qspinlock: Add pending bit ...
2015-06-19Merge branch 'mvebu/drivers' of ↵Herbert Xu
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Merge the mvebu/drivers branch of the arm-soc tree which contains just a single patch bfa1ce5f38938cc9e6c7f2d1011f88eba2b9e2b2 ("bus: mvebu-mbus: add mv_mbus_dram_info_nooverlap()") that happens to be a prerequisite of the new marvell/cesa crypto driver.
2015-06-19Merge branch 'next' of ↵Michael Ellerman
git://git.kernel.org/pub/scm/linux/kernel/git/scottwood/linux into next Freescale updates from Scott: "Highlights include more 8xx optimizations, an e6500 hugetlb optimization, QMan device tree nodes, t1024/t1023 support, and various fixes and cleanup."
2015-06-19powerpc/mm: Change the swap encoding in pte.Aneesh Kumar K.V
Current swap encoding in pte can't support large pfns above 4TB. Change the swap encoding such that we put the swap type in the PTE bits. Also add build checks to make sure we don't overlap with HPTEFLAGS. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-19powerpc/mm: PTE_RPN_MAX is not used, remove the sameAneesh Kumar K.V
Remove the unused #define Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-19powerpc/tm: Abort syscalls in active transactionsSam bobroff
This patch changes the syscall handler to doom (tabort) active transactions when a syscall is made and return very early without performing the syscall and keeping side effects to a minimum (no CPU accounting or system call tracing is performed). Also included is a new HWCAP2 bit, PPC_FEATURE2_HTM_NOSC, to indicate this behaviour to userspace. Currently, the system call instruction automatically suspends an active transaction which causes side effects to persist when an active transaction fails. This does change the kernel's behaviour, but in a way that was documented as unsupported. It doesn't reduce functionality as syscalls will still be performed after tsuspend; it just requires that the transaction be explicitly suspended. It also provides a consistent interface and makes the behaviour of user code substantially the same across powerpc and platforms that do not support suspended transactions (e.g. x86 and s390). Performance measurements using http://ozlabs.org/~anton/junkcode/null_syscall.c indicate the cost of a normal (non-aborted) system call increases by about 0.25%. Signed-off-by: Sam Bobroff <sam.bobroff@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc: Fix duplicate const clang warning in user access codeAnton Blanchard
We see a large number of duplicate const errors in the user access code when building with llvm/clang: include/linux/pagemap.h:576:8: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier] ret = __get_user(c, uaddr); The problem is we are doing const __typeof__(*(ptr)), which will hit the warning if ptr is marked const. Removing const does not seem to have any effect on GCC code generation. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11vfio: powerpc/spapr: Support Dynamic DMA windowsAlexey Kardashevskiy
This adds create/remove window ioctls to create and remove DMA windows. sPAPR defines a Dynamic DMA windows capability which allows para-virtualized guests to create additional DMA windows on a PCI bus. The existing linux kernels use this new window to map the entire guest memory and switch to the direct DMA operations saving time on map/unmap requests which would normally happen in a big amounts. This adds 2 ioctl handlers - VFIO_IOMMU_SPAPR_TCE_CREATE and VFIO_IOMMU_SPAPR_TCE_REMOVE - to create and remove windows. Up to 2 windows are supported now by the hardware and by this driver. This changes VFIO_IOMMU_SPAPR_TCE_GET_INFO handler to return additional information such as a number of supported windows and maximum number levels of TCE tables. DDW is added as a capability, not as a SPAPR TCE IOMMU v2 unique feature as we still want to support v2 on platforms which cannot do DDW for the sake of TCE acceleration in KVM (coming soon). Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11vfio: powerpc/spapr: Register memory and define IOMMU v2Alexey Kardashevskiy
The existing implementation accounts the whole DMA window in the locked_vm counter. This is going to be worse with multiple containers and huge DMA windows. Also, real-time accounting would requite additional tracking of accounted pages due to the page size difference - IOMMU uses 4K pages and system uses 4K or 64K pages. Another issue is that actual pages pinning/unpinning happens on every DMA map/unmap request. This does not affect the performance much now as we spend way too much time now on switching context between guest/userspace/host but this will start to matter when we add in-kernel DMA map/unmap acceleration. This introduces a new IOMMU type for SPAPR - VFIO_SPAPR_TCE_v2_IOMMU. New IOMMU deprecates VFIO_IOMMU_ENABLE/VFIO_IOMMU_DISABLE and introduces 2 new ioctls to register/unregister DMA memory - VFIO_IOMMU_SPAPR_REGISTER_MEMORY and VFIO_IOMMU_SPAPR_UNREGISTER_MEMORY - which receive user space address and size of a memory region which needs to be pinned/unpinned and counted in locked_vm. New IOMMU splits physical pages pinning and TCE table update into 2 different operations. It requires: 1) guest pages to be registered first 2) consequent map/unmap requests to work only with pre-registered memory. For the default single window case this means that the entire guest (instead of 2GB) needs to be pinned before using VFIO. When a huge DMA window is added, no additional pinning will be required, otherwise it would be guest RAM + 2GB. The new memory registration ioctls are not supported by VFIO_SPAPR_TCE_IOMMU. Dynamic DMA window and in-kernel acceleration will require memory to be preregistered in order to work. The accounting is done per the user process. This advertises v2 SPAPR TCE IOMMU and restricts what the userspace can do with v1 or v2 IOMMUs. In order to support memory pre-registration, we need a way to track the use of every registered memory region and only allow unregistration if a region is not in use anymore. So we need a way to tell from what region the just cleared TCE was from. This adds a userspace view of the TCE table into iommu_table struct. It contains userspace address, one per TCE entry. The table is only allocated when the ownership over an IOMMU group is taken which means it is only used from outside of the powernv code (such as VFIO). As v2 IOMMU supports IODA2 and pre-IODA2 IOMMUs (which do not support DDW API), this creates a default DMA window for IODA2 for consistency. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/mmu: Add userspace-to-physical addresses translation cacheAlexey Kardashevskiy
We are adding support for DMA memory pre-registration to be used in conjunction with VFIO. The idea is that the userspace which is going to run a guest may want to pre-register a user space memory region so it all gets pinned once and never goes away. Having this done, a hypervisor will not have to pin/unpin pages on every DMA map/unmap request. This is going to help with multiple pinning of the same memory. Another use of it is in-kernel real mode (mmu off) acceleration of DMA requests where real time translation of guest physical to host physical addresses is non-trivial and may fail as linux ptes may be temporarily invalid. Also, having cached host physical addresses (compared to just pinning at the start and then walking the page table again on every H_PUT_TCE), we can be sure that the addresses which we put into TCE table are the ones we already pinned. This adds a list of memory regions to mm_context_t. Each region consists of a header and a list of physical addresses. This adds API to: 1. register/unregister memory regions; 2. do final cleanup (which puts all pre-registered pages); 3. do userspace to physical address translation; 4. manage usage counters; multiple registration of the same memory is allowed (once per container). This implements 2 counters per registered memory region: - @mapped: incremented on every DMA mapping; decremented on unmapping; initialized to 1 when a region is just registered; once it becomes zero, no more mappings allowe; - @used: incremented on every "register" ioctl; decremented on "unregister"; unregistration is allowed for DMA mapped regions unless it is the very last reference. For the very last reference this checks that the region is still mapped and returns -EBUSY so the userspace gets to know that memory is still pinned and unregistration needs to be retried; @used remains 1. Host physical addresses are stored in vmalloc'ed array. In order to access these in the real mode (mmu off), there is a real_vmalloc_addr() helper. In-kernel acceleration patchset will move it from KVM to MMU code. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/iommu/ioda2: Add get_table_size() to calculate the size of future tableAlexey Kardashevskiy
This adds a way for the IOMMU user to know how much a new table will use so it can be accounted in the locked_vm limit before allocation happens. This stores the allocated table size in pnv_pci_ioda2_get_table_size() so the locked_vm counter can be updated correctly when a table is being disposed. This defines an iommu_table_group_ops callback to let VFIO know how much memory will be locked if a table is created. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11vfio: powerpc/spapr: powerpc/powernv/ioda: Define and implement DMA windows APIAlexey Kardashevskiy
This extends iommu_table_group_ops by a set of callbacks to support dynamic DMA windows management. create_table() creates a TCE table with specific parameters. it receives iommu_table_group to know nodeid in order to allocate TCE table memory closer to the PHB. The exact format of allocated multi-level table might be also specific to the PHB model (not the case now though). This callback calculated the DMA window offset on a PCI bus from @num and stores it in a just created table. set_window() sets the window at specified TVT index + @num on PHB. unset_window() unsets the window from specified TVT. This adds a free() callback to iommu_table_ops to free the memory (potentially a tree of tables) allocated for the TCE table. create_table() and free() are supposed to be called once per VFIO container and set_window()/unset_window() are supposed to be called for every group in a container. This adds IOMMU capabilities to iommu_table_group such as default 32bit window parameters and others. This makes use of new values in vfio_iommu_spapr_tce. IODA1/P5IOC2 do not support DDW so they do not advertise pagemasks to the userspace. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/powernv: Implement multilevel TCE tablesAlexey Kardashevskiy
TCE tables might get too big in case of 4K IOMMU pages and DDW enabled on huge guests (hundreds of GB of RAM) so the kernel might be unable to allocate contiguous chunk of physical memory to store the TCE table. To address this, POWER8 CPU (actually, IODA2) supports multi-level TCE tables, up to 5 levels which splits the table into a tree of smaller subtables. This adds multi-level TCE tables support to pnv_pci_ioda2_table_alloc_pages() and pnv_pci_ioda2_table_free_pages() helpers. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/iommu/powernv: Release replaced TCEAlexey Kardashevskiy
At the moment writing new TCE value to the IOMMU table fails with EBUSY if there is a valid entry already. However PAPR specification allows the guest to write new TCE value without clearing it first. Another problem this patch is addressing is the use of pool locks for external IOMMU users such as VFIO. The pool locks are to protect DMA page allocator rather than entries and since the host kernel does not control what pages are in use, there is no point in pool locks and exchange()+put_page(oldtce) is sufficient to avoid possible races. This adds an exchange() callback to iommu_table_ops which does the same thing as set() plus it returns replaced TCE and DMA direction so the caller can release the pages afterwards. The exchange() receives a physical address unlike set() which receives linear mapping address; and returns a physical address as the clear() does. This implements exchange() for P5IOC2/IODA/IODA2. This adds a requirement for a platform to have exchange() implemented in order to support VFIO. This replaces iommu_tce_build() and iommu_clear_tce() with a single iommu_tce_xchg(). This makes sure that TCE permission bits are not set in TCE passed to IOMMU API as those are to be calculated by platform code from DMA direction. This moves SetPageDirty() to the IOMMU code to make it work for both VFIO ioctl interface in in-kernel TCE acceleration (when it becomes available later). Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11vfio: powerpc/spapr/iommu/powernv/ioda2: Rework IOMMU ownership controlAlexey Kardashevskiy
This adds tce_iommu_take_ownership() and tce_iommu_release_ownership which call in a loop iommu_take_ownership()/iommu_release_ownership() for every table on the group. As there is just one now, no change in behaviour is expected. At the moment the iommu_table struct has a set_bypass() which enables/ disables DMA bypass on IODA2 PHB. This is exposed to POWERPC IOMMU code which calls this callback when external IOMMU users such as VFIO are about to get over a PHB. The set_bypass() callback is not really an iommu_table function but IOMMU/PE function. This introduces a iommu_table_group_ops struct and adds take_ownership()/release_ownership() callbacks to it which are called when an external user takes/releases control over the IOMMU. This replaces set_bypass() with ownership callbacks as it is not necessarily just bypass enabling, it can be something else/more so let's give it more generic name. The callbacks is implemented for IODA2 only. Other platforms (P5IOC2, IODA1) will use the old iommu_take_ownership/iommu_release_ownership API. The following patches will replace iommu_take_ownership/ iommu_release_ownership calls in IODA2 with full IOMMU table release/ create. As we here and touching bypass control, this removes pnv_pci_ioda2_setup_bypass_pe() as it does not do much more compared to pnv_pci_ioda2_set_bypass. This moves tce_bypass_base initialization to pnv_pci_ioda2_setup_dma_pe. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/spapr: vfio: Switch from iommu_table to new iommu_table_groupAlexey Kardashevskiy
So far one TCE table could only be used by one IOMMU group. However IODA2 hardware allows programming the same TCE table address to multiple PE allowing sharing tables. This replaces a single pointer to a group in a iommu_table struct with a linked list of groups which provides the way of invalidating TCE cache for every PE when an actual TCE table is updated. This adds pnv_pci_link_table_and_group() and pnv_pci_unlink_table_and_group() helpers to manage the list. However without VFIO, it is still going to be a single IOMMU group per iommu_table. This changes iommu_add_device() to add a device to a first group from the group list of a table as it is only called from the platform init code or PCI bus notifier and at these moments there is only one group per table. This does not change TCE invalidation code to loop through all attached groups in order to simplify this patch and because it is not really needed in most cases. IODA2 is fixed in a later patch. This should cause no behavioural change. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/spapr: vfio: Replace iommu_table with iommu_table_groupAlexey Kardashevskiy
Modern IBM POWERPC systems support multiple (currently two) TCE tables per IOMMU group (a.k.a. PE). This adds a iommu_table_group container for TCE tables. Right now just one table is supported. This defines iommu_table_group struct which stores pointers to iommu_group and iommu_table(s). This replaces iommu_table with iommu_table_group where iommu_table was used to identify a group: - iommu_register_group(); - iommudata of generic iommu_group; This removes @data from iommu_table as it_table_group provides same access to pnv_ioda_pe. For IODA, instead of embedding iommu_table, the new iommu_table_group keeps pointers to those. The iommu_table structs are allocated dynamically. For P5IOC2, both iommu_table_group and iommu_table are embedded into PE struct. As there is no EEH and SRIOV support for P5IOC2, iommu_free_table() should not be called on iommu_table struct pointers so we can keep it embedded in pnv_phb::p5ioc2. For pSeries, this replaces multiple calls of kzalloc_node() with a new iommu_pseries_alloc_group() helper and stores the table group struct pointer into the pci_dn struct. For release, a iommu_table_free_group() helper is added. This moves iommu_table struct allocation from SR-IOV code to the generic DMA initialization code in pnv_pci_ioda_setup_dma_pe and pnv_pci_ioda2_setup_dma_pe as this is where DMA is actually initialized. This change is here because those lines had to be changed anyway. This should cause no behavioural change. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/iommu: Move tce_xxx callbacks from ppc_md to iommu_tableAlexey Kardashevskiy
This adds a iommu_table_ops struct and puts pointer to it into the iommu_table struct. This moves tce_build/tce_free/tce_get/tce_flush callbacks from ppc_md to the new struct where they really belong to. This adds the requirement for @it_ops to be initialized before calling iommu_init_table() to make sure that we do not leave any IOMMU table with iommu_table_ops uninitialized. This is not a parameter of iommu_init_table() though as there will be cases when iommu_init_table() will not be called on TCE tables, for example - VFIO. This does s/tce_build/set/, s/tce_free/clear/ and removes "tce_" redundant prefixes. This removes tce_xxx_rm handlers from ppc_md but does not add them to iommu_table_ops as this will be done later if we decide to support TCE hypercalls in real mode. This removes _vm callbacks as only virtual mode is supported by now so this also removes @rm parameter. For pSeries, this always uses tce_buildmulti_pSeriesLP/ tce_buildmulti_pSeriesLP. This changes multi callback to fall back to tce_build_pSeriesLP/tce_free_pSeriesLP if FW_FEATURE_MULTITCE is not present. The reason for this is we still have to support "multitce=off" boot parameter in disable_multitce() and we do not want to walk through all IOMMU tables in the system and replace "multi" callbacks with single ones. For powernv, this defines _ops per PHB type which are P5IOC2/IODA1/IODA2. This makes the callbacks for them public. Later patches will extend callbacks for IODA1/2. No change in behaviour is expected. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/powernv: Do not set "read" flag if direction==DMA_NONEAlexey Kardashevskiy
Normally a bitmap from the iommu_table is used to track what TCE entry is in use. Since we are going to use iommu_table without its locks and do xchg() instead, it becomes essential not to put bits which are not implied in the direction flag as the old TCE value (more precisely - the permission bits) will be used to decide whether to put the page or not. This adds iommu_direction_to_tce_perm() (its counterpart is there already) and uses it for powernv's pnv_tce_build(). Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11vfio: powerpc/spapr: Move page pinning from arch code to VFIO IOMMU driverAlexey Kardashevskiy
This moves page pinning (get_user_pages_fast()/put_page()) code out of the platform IOMMU code and puts it to VFIO IOMMU driver where it belongs to as the platform code does not deal with page pinning. This makes iommu_take_ownership()/iommu_release_ownership() deal with the IOMMU table bitmap only. This removes page unpinning from iommu_take_ownership() as the actual TCE table might contain garbage and doing put_page() on it is undefined behaviour. Besides the last part, the rest of the patch is mechanical. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> [aw: for the vfio related changes] Acked-by: Alex Williamson <alex.williamson@redhat.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-11powerpc/iommu/powernv: Get rid of set_iommu_table_base_and_groupAlexey Kardashevskiy
The set_iommu_table_base_and_group() name suggests that the function sets table base and add a device to an IOMMU group. The actual purpose for table base setting is to put some reference into a device so later iommu_add_device() can get the IOMMU group reference and the device to the group. At the moment a group cannot be explicitly passed to iommu_add_device() as we want it to work from the bus notifier, we can fix it later and remove confusing calls of set_iommu_table_base(). This replaces set_iommu_table_base_and_group() with a couple of set_iommu_table_base() + iommu_add_device() which makes reading the code easier. This adds few comments why set_iommu_table_base() and iommu_add_device() are called where they are called. For IODA1/2, this essentially removes iommu_add_device() call from the pnv_pci_ioda_dma_dev_setup() as it will always fail at this particular place: - for physical PE, the device is already attached by iommu_add_device() in pnv_pci_ioda_setup_dma_pe(); - for virtual PE, the sysfs entries are not ready to create all symlinks so actual adding is happening in tce_iommu_bus_notifier. Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru> Reviewed-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Reviewed-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-10powerpc/mm: Add trace point for tracking hash pte faultAneesh Kumar K.V
This enables us to understand how many hash fault we are taking when running benchmarks. For ex: -bash-4.2# ./perf stat -e powerpc:hash_fault -e page-faults /tmp/ebizzy.ppc64 -S 30 -P -n 1000 ... Performance counter stats for '/tmp/ebizzy.ppc64 -S 30 -P -n 1000': 1,10,04,075 powerpc:hash_fault 1,10,03,429 page-faults 30.865978991 seconds time elapsed NOTE: The impact of the tracepoint was not noticeable when running test. It was within the run-time variance of the test. For ex: without-patch: -------------- Performance counter stats for './a.out 3000 300': 643 page-faults # 0.089 M/sec 7.236562 task-clock (msec) # 0.928 CPUs utilized 2,179,213 stalled-cycles-frontend # 0.00% frontend cycles idle 17,174,367 stalled-cycles-backend # 0.00% backend cycles idle 0 context-switches # 0.000 K/sec 0.007794658 seconds time elapsed And with-patch: --------------- Performance counter stats for './a.out 3000 300': 643 page-faults # 0.089 M/sec 7.233746 task-clock (msec) # 0.921 CPUs utilized 0 context-switches # 0.000 K/sec 0.007854876 seconds time elapsed Performance counter stats for './a.out 3000 300': 643 page-faults # 0.087 M/sec 649 powerpc:hash_fault # 0.087 M/sec 7.430376 task-clock (msec) # 0.938 CPUs utilized 2,347,174 stalled-cycles-frontend # 0.00% frontend cycles idle 17,524,282 stalled-cycles-backend # 0.00% backend cycles idle 0 context-switches # 0.000 K/sec 0.007920284 seconds time elapsed Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-08PCI: Remove unused pci_dma_burst_advice()Bjorn Helgaas
pci_dma_burst_advice() was added by e24c2d963a60 ("[PATCH] PCI: DMA bursting advice") but apparently never used. Remove it. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Michal Simek <monstr@monstr.eu> # microblaze CC: David S. Miller <davem@davemloft.net>
2015-06-07powerpc/dscr: Add some in-code documentationAnshuman Khandual
This patch adds some in-code documentation to the DSCR related code to make it more readable without having any functional change to it. Signed-off-by: Anshuman Khandual <khandual@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-05KVM: implement multiple address spacesPaolo Bonzini
Only two ioctls have to be modified; the address space id is placed in the higher 16 bits of their slot id argument. As of this patch, no architecture defines more than one address space; x86 will be the first. Reviewed-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com>
2015-06-05powerpc/powernv: Add opal-prd channelJeremy Kerr
This change adds a char device to access the "PRD" (processor runtime diagnostics) channel to OPAL firmware. Includes contributions from Vaidyanathan Srinivasan, Neelesh Gupta & Vishal Kulkarni. Signed-off-by: Neelesh Gupta <neelegup@linux.vnet.ibm.com> Signed-off-by: Jeremy Kerr <jk@ozlabs.org> Acked-by: Stewart Smith <stewart@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03cxl: Move include file cxl.h -> cxl-base.hMichael Neuling
This moves the current include file from cxl.h -> cxl-base.h. This current include file is used only to pass information between the base driver that needs to be built into the kernel and the cxl module. This is to make way for a new include/misc/cxl.h which will contain just the kernel API for other driver to use Signed-off-by: Michael Neuling <mikey@neuling.org> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03powerpc/pci: Add pcibios_disable_device() hookMichael Neuling
This adds a hook into the powerpc pci code for pci_disable_device() calls. The generic code already provides a weak pcibios_disable_device() symbol, so we just need to provide our own in powerpc and it'll get picked up. This is passed directly to the phb controller ops, provided one exists. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03powerpc/pci: Add shutdown hook to pci_controller_opsMichael Neuling
Currently pnv_pci_shutdown() calls the PHB shutdown code for all PHBs in the system. It dereferences the private_data assuming it's a powernv PHB, which won't be the case when we have different PHB in the systems (like when we add vPHBs for CXL). This moves the shutdown hook to the pci_controller_ops and fixes the call site to use that instead. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03powerpc: Add cxl context to device archdataMichael Neuling
Add cxl context pointer to archdata. We'll want to create one of these for cxl PCI devices. Put them here until we can get a pci_dev specific private data. This location was suggested by benh. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-03powerpc/pci: Add release_device() hook to phb opsMichael Neuling
Add release_device() hook to phb ops so we can clean up for specific phbs. Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-06-02powerpc/8xx: Implementation of PAGE_EXECLEROY Christophe
This patch implements PAGE_EXEC capability on the 8xx. All pages PP exec bits are set to 000, which means Execute for Supervisor and no Execute for User. Then we use the APG to say whether accesses are according to Page rules, "all Supervisor" rules (Exec for all) and "all User" rules (Exec for noone) Therefore, we define 4 APG groups. msb is _PAGE_EXEC, lsb is _PAGE_USER. MI_AP is initialised as follows: GP0 (00) => Not User, no exec => 11 (all accesses performed as user) GP1 (01) => User but no exec => 11 (all accesses performed as user) GP2 (10) => Not User, exec => 01 (rights according to page definition) GP3 (11) => User, exec => 00 (all accesses performed as supervisor) Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> [scottwood: comments: s/exec/data/ on data side, and s/pages/pages'/] Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-06-02powerpc/8xx: Handle PAGE_USER via APG bitsLEROY Christophe
Use of APG for handling PAGE_USER. All pages PP exec bits are set to either 000 or 011, which means respectively RW for Supervisor and no access for User, or RO for Supervisor and no access for user. Then we use the APG to say whether accesses are according to Page rules or "all Supervisor" rules (Access to all) Therefore, we define 2 APG groups corresponding to _PAGE_USER. Mx_AP are initialised as follows: GP0 => No user => 01 (all accesses performed according to page definition) GP1 => User => 00 (all accesses performed as supervisor according to page definition) This removes the special 8xx handling in pte_update() Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Scott Wood <scottwood@freescale.com>
2015-06-02powerpc/8xx: mark _PAGE_SHARED all types of kernel pagesLEROY Christophe
All kernel pages have to be marked as shared in order to not perform CASID verification. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Scott Wood <scottwood@freescale.com>
