path: root/arch/powerpc/include/asm/io.h
2016-09-09powerpc: Add simple cache inhibited MMIO accessorsSuresh Warrier
Add simple cache inhibited accessors for memory mapped I/O. Unlike the accessors built from the DEF_MMIO_* macros, these don't include any hardware memory barriers, callers need to manage memory barriers on their own. These can only be called in hypervisor real mode. Signed-off-by: Suresh Warrier <warrier@linux.vnet.ibm.com> [paulus@ozlabs.org - added line to comment] Signed-off-by: Paul Mackerras <paulus@ozlabs.org>
2016-03-01powerpc: Fix misspellings in comments.Adam Buchbinder
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-12-17powerpc: Add __raw_rm_writeq() functionAlistair Popple
Move __raw_rm_writeq() from platforms/powernv/pci-ioda.c to include/asm/io.h so that it can be used by other code. Signed-off-by: Alistair Popple <alistair@popple.id.au> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2015-07-29arch/*/io.h: Add ioremap_uc() to all architecturesLuis R. Rodriguez
This adds ioremap_uc() only for architectures that do not include asm-generic.h/io.h as that already provides a default definition for them for both cases where you have CONFIG_MMU and you do not, and because of this, the number of architectures this patch address is less than the architectures that the ioremap_wt() patch addressed, "arch/*/io.h: Add ioremap_wt() to all architectures"). In order to reduce the number of architectures we have to modify by adding new architecture IO APIs we'll have to review the architectures in this patch, see why they can't add asm-generic.h/io.h or issues that would be created by doing so and then spread a consistent inclusion of this header towards the end of their own header. For instance arch/metag includes the asm-generic/io.h *before* the ioremap*() definitions, this should be the other way around but only once we have guard wrappers for the non-MMU case also for asm-generic/io.h. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com> Cc: Abhilash Kesavan <a.kesavan@samsung.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Borislav Petkov <bp@suse.de> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: David Howells <dhowells@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Guenter Roeck <linux@roeck-us.net> Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Hans-Christian Egtvedt <egtvedt@samfundet.no> Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com> Cc: Kyle McMartin <kyle@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rob Herring <robh@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Will Deacon <will.deacon@arm.com> Cc: linux-am33-list@redhat.com Cc: linux-arch@vger.kernel.org Cc: linux-m68k@lists.linux-m68k.org Cc: linux-sh@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/r/20150728181713.GB30479@wotan.suse.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-12-11Merge tag 'powerpc-3.19-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux Pull powerpc updates from Michael Ellerman: "Some nice cleanups like removing bootmem, and removal of __get_cpu_var(). There is one patch to mm/gup.c. This is the generic GUP implementation, but is only used by us and arm(64). We have an ack from Steve Capper, and although we didn't get an ack from Andrew he told us to take the patch through the powerpc tree. There's one cxl patch. This is in drivers/misc, but Greg said he was happy for us to manage fixes for it. There is an infrastructure patch to support an IPMI driver for OPAL. There is also an RTC driver for OPAL. We weren't able to get any response from the RTC maintainer, Alessandro Zummo, so in the end we just merged the driver. The usual batch of Freescale updates from Scott" * tag 'powerpc-3.19-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mpe/linux: (101 commits) powerpc/powernv: Return to cpu offline loop when finished in KVM guest powerpc/book3s: Fix partial invalidation of TLBs in MCE code. powerpc/mm: don't do tlbie for updatepp request with NO HPTE fault powerpc/xmon: Cleanup the breakpoint flags powerpc/xmon: Enable HW instruction breakpoint on POWER8 powerpc/mm/thp: Use tlbiel if possible powerpc/mm/thp: Remove code duplication powerpc/mm/hugetlb: Sanity check gigantic hugepage count powerpc/oprofile: Disable pagefaults during user stack read powerpc/mm: Check for matching hpte without taking hpte lock powerpc: Drop useless warning in eeh_init() powerpc/powernv: Cleanup unused MCE definitions/declarations. powerpc/eeh: Dump PHB diag-data early powerpc/eeh: Recover EEH error on ownership change for BCM5719 powerpc/eeh: Set EEH_PE_RESET on PE reset powerpc/eeh: Refactor eeh_reset_pe() powerpc: Remove more traces of bootmem powerpc/pseries: Initialise nvram_pstore_info's buf_lock cxl: Name interrupts in /proc/interrupt cxl: Return error to PSL if IRQ demultiplexing fails & print clearer warning ...
2014-11-10powerpc: Remove unused devm_ioremap_prot()Kyle McMartin
Added in 2008, but has never had any in-tree users, and no other architectures provide it. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-10-20powerpc: io: implement dummy relaxed accessor macros for writesWill Deacon
write{b,w,l,q}_relaxed are implemented by some architectures in order to permit memory-mapped I/O accesses with weaker barrier semantics than the non-relaxed variants. This patch adds dummy macros for the write accessors to powerpc, in the same vein as the dummy definitions for the relaxed read accessors. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Will Deacon <will.deacon@arm.com>
2013-12-05powerpc: Add real mode cache inhibited IO accessorsMichael Ellerman
These accessors allow us to do cache inhibited accesses when in real mode. They should only be used in real mode. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-11powerpc: Enable /dev/port when isa_io_special is setBenjamin Herrenschmidt
isa_io_special is set when the platform provides a "special" implementation of inX/outX via some FW interface for example. Such a platform doesn't need an ISA bridge on PCI, and so /dev/port should be made available even if one isn't present. This makes the LPC bus IOs accessible via /dev/port on PowerNV Power8 Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-10-11powerpc: Support endian agnostic MMIOIan Munsie
This patch maps the MMIO functions for 32bit PowerPC to their appropriate instructions depending on CPU endianness. The macros used to create the corresponding inline functions are also renamed by this patch. Previously they had BE or LE in their names which was misleading - they had nothing to do with endianness, but actually created different instruction forms so their new names reflect the instruction form they are creating (D-Form and X-Form). Little endian 64bit PowerPC is not supported, so the lack of mappings (and corresponding breakage) for that case is intentional to bring the attention of anyone doing a 64bit little endian port. 64bit big endian is unaffected. [ Added 64 bit versions - Anton ] Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc/powernv: Add PIO accessors for Power8 LPC busBenjamin Herrenschmidt
This uses the hooks provided by CONFIG_PPC_INDIRECT_PIO to implement a set of hooks for IO port access to use the LPC bus via OPAL calls for the first 64K of IO space Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-08-14powerpc: Better split CONFIG_PPC_INDIRECT_PIO and CONFIG_PPC_INDIRECT_MMIOBenjamin Herrenschmidt
Remove the generic PPC_INDIRECT_IO and ensure we only add overhead to the right accessors. IE. If only CONFIG_PPC_INDIRECT_PIO is set, we don't add overhead to all MMIO accessors. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2013-04-18powerpc: remove PReP platformPaul Bolle
PPC_PREP is marked as BROKEN since v2.6.15. Remove all PReP specific code now. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
2012-07-11powerpc: Disable /dev/port interface on systems without an ISA bridgeHaren Myneni
Some power systems do not have legacy ISA devices. So, /dev/port is not a valid interface on these systems. User level tools such as kbdrate is trying to access the device using this interface which is causing the system crash. This patch will fix this issue by not creating this interface on these powerpc systems. Signed-off-by: Haren Myneni <haren@us.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-19powerpc: Remove ioremap_flagsAnton Blanchard
We have a confusing number of ioremap functions. Make things just a bit simpler by merging ioremap_flags and ioremap_prot. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-05-19powerpc: Add ioremap_wcAnton Blanchard
Add ioremap_wc so drivers can request write combining on kernel mappings. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-04-27powerpc/pci: Split IO vs MMIO indirect access hooksMichael Ellerman
The goal is to avoid adding overhead to MMIO when only PIO is needed Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2009-03-11powerpc: Wire up /proc/vmallocinfo to our ioremap()Benjamin Herrenschmidt
This adds the necessary bits and pieces to powerpc implementation of ioremap to benefit from caller tracking in /proc/vmallocinfo, at least for ioremap's done after mem init as the older ones aren't tracked. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2008-12-16powerpc: Remove dead BIO_VMERGE_BOUNDARY definitionFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY definition is meaningless now (For POWER, BIO_VMERGE_BOUNDARY has been meaningless for a long time since POWER disables the virtual merge feature). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2008-09-24POWERPC: Allow 32-bit hashed pgtable code to support 36-bit physicalBecky Bruce
This rearranges a bit of code, and adds support for 36-bit physical addressing for configs that use a hashed page table. The 36b physical support is not enabled by default on any config - it must be explicitly enabled via the config system. This patch *only* expands the page table code to accomodate large physical addresses on 32-bit systems and enables the PHYS_64BIT config option for 86xx. It does *not* allow you to boot a board with more than about 3.5GB of RAM - for that, SWIOTLB support is also required (and coming soon). Signed-off-by: Becky Bruce <becky.bruce@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
