If we want to stop the tick further idle, we need to be
able to account the cputime without using the tick.
Virtual based cputime accounting solves that problem by
hooking into kernel/user boundaries.
However implementing CONFIG_VIRT_CPU_ACCOUNTING require
low level hooks and involves more overhead. But we already
have a generic context tracking subsystem that is required
for RCU needs by archs which plan to shut down the tick
outside idle.
This patch implements a generic virtual based cputime
accounting that relies on these generic kernel/user hooks.
There are some upsides of doing this:
- This requires no arch code to implement CONFIG_VIRT_CPU_ACCOUNTING
if context tracking is already built (already necessary for RCU in full
tickless mode).
- We can rely on the generic context tracking subsystem to dynamically
(de)activate the hooks, so that we can switch anytime between virtual
and tick based accounting. This way we don't have the overhead
of the virtual accounting when the tick is running periodically.
And one downside:
- There is probably more overhead than a native virtual based cputime
accounting. But this relies on hooks that are already set anyway.
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
On ia64 and powerpc, vtime context switch only consists
in flushing system and user pending time, plus a few
arch housekeeping.
Consolidate that into a generic implementation. s390 is
a special case because pending user and system time accounting
there is hard to dissociate. So it's keeping its own implementation.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (185 commits)
powerpc: fix compile error with 85xx/p1010rdb.c
powerpc: fix compile error with 85xx/p1023_rds.c
powerpc/fsl: add MSI support for the Freescale hypervisor
arch/powerpc/sysdev/fsl_rmu.c: introduce missing kfree
powerpc/fsl: Add support for Integrated Flash Controller
powerpc/fsl: update compatiable on fsl 16550 uart nodes
powerpc/85xx: fix PCI and localbus properties in p1022ds.dts
powerpc/85xx: re-enable ePAPR byte channel driver in corenet32_smp_defconfig
powerpc/fsl: Update defconfigs to enable some standard FSL HW features
powerpc: Add TBI PHY node to first MDIO bus
sbc834x: put full compat string in board match check
powerpc/fsl-pci: Allow 64-bit PCIe devices to DMA to any memory address
powerpc: Fix unpaired probe_hcall_entry and probe_hcall_exit
offb: Fix setting of the pseudo-palette for >8bpp
offb: Add palette hack for qemu "standard vga" framebuffer
offb: Fix bug in calculating requested vram size
powerpc/boot: Change the WARN to INFO for boot wrapper overlap message
powerpc/44x: Fix build error on currituck platform
powerpc/boot: Change the load address for the wrapper to fit the kernel
powerpc/44x: Enable CRASH_DUMP for 440x
Fix up a trivial conflict in arch/powerpc/include/asm/cputime.h due to
the additional sparse-checking code for cputime_t.
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
sched/tracing: Add a new tracepoint for sleeptime
sched: Disable scheduler warnings during oopses
sched: Fix cgroup movement of waking process
sched: Fix cgroup movement of newly created process
sched: Fix cgroup movement of forking process
sched: Remove cfs bandwidth period check in tg_set_cfs_period()
sched: Fix load-balance lock-breaking
sched: Replace all_pinned with a generic flags field
sched: Only queue remote wakeups when crossing cache boundaries
sched: Add missing rcu_dereference() around ->real_parent usage
[S390] fix cputime overflow in uptime_proc_show
[S390] cputime: add sparse checking and cleanup
sched: Mark parent and real_parent as __rcu
sched, nohz: Fix missing RCU read lock
sched, nohz: Set the NOHZ_BALANCE_KICK flag for idle load balancer
sched, nohz: Fix the idle cpu check in nohz_idle_balance
sched: Use jump_labels for sched_feat
sched/accounting: Fix parameter passing in task_group_account_field
sched/accounting: Fix user/system tick double accounting
sched/accounting: Re-use scheduler statistics for the root cgroup
Fix up conflicts in
- arch/ia64/include/asm/cputime.h, include/asm-generic/cputime.h
usecs_to_cputime64() vs the sparse cleanups
- kernel/sched/fair.c, kernel/time/tick-sched.c
scheduler changes in multiple branches
Commit 2a95ea6c0d129b4 ("procfs: do not overflow get_{idle,iowait}_time
for nohz") did not take into account that one some architectures jiffies
and cputime use different units.
This causes get_idle_time() to return numbers in the wrong units, making
the idle time fields in /proc/stat wrong.
Instead of converting the usec value returned by
get_cpu_{idle,iowait}_time_us to units of jiffies, use the new function
usecs_to_cputime64 to convert it to the correct unit of cputime64_t.
Signed-off-by: Andreas Schwab <schwab@linux-m68k.org>
Acked-by: Michal Hocko <mhocko@suse.cz>
Cc: "Artem S. Tashkinov" <t.artem@mailcity.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Commit d57af9b (taskstats: use real microsecond granularity for CPU times)
renamed msecs_to_cputime to usecs_to_cputime, but failed to update all
numbers on the way. This causes nonsensical cpu idle/iowait values to be
displayed in /proc/stat (the only user of usecs_to_cputime so far).
This also renames __cputime_msec_factor to __cputime_usec_factor, adapting
its value and using it directly in cputime_to_usecs instead of doing two
multiplications.
Acked-by: Anton Blanchard <anton@samba.org>
Make cputime_t and cputime64_t nocast to enable sparse checking to
detect incorrect use of cputime. Drop the cputime macros for simple
scalar operations. The conversion macros are still needed.
The taskstats interface uses microsecond granularity for the user and
system time values. The conversion from cputime to the taskstats values
uses the cputime_to_msecs primitive which effectively limits the
granularity to milliseconds. Add the cputime_to_usecs primitive for
architectures that have better, more precise CPU time values. Remove
cputime_to_msecs primitive because there are no more users left.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Cc: Luck Tony <tony.luck@intel.com>
Cc: Shailabh Nagar <nagar1234@in.ibm.com>
Cc: Shailabh Nagar <nagar@us.ibm.com>
The cputime code has a few places that do per_cpu(, smp_processor_id()).
Replace them with __get_cpu_var().
For powerpc with CONFIG_VIRT_CPU_ACCOUNTING
jiffies_to_cputime(1) is not compile time constant and run time
calculations are quite expensive. To optimize we use
precomputed value. For all other architectures is is
preprocessor definition.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1248862529-6063-5-git-send-email-sgruszka@redhat.com>
from include/asm-powerpc. This is the result of a
mkdir arch/powerpc/include/asm
git mv include/asm-powerpc/* arch/powerpc/include/asm
Followed by a few documentation/comment fixups and a couple of places
where <asm-powepc/...> was being used explicitly. Of the latter only
one was outside the arch code and it is a driver only built for powerpc.
