path: root/arch/powerpc/include/asm/cpm.h
2009-11-11powerpc/qe&cpm: Implement static inline stubs for non-QE/CPM buildsAnton Vorontsov
This is needed to avoid ugly #ifdefs in drivers. Also update fsl_qe_udc driver so that now it doesn't define its own versions that cause build breakage when the generic stubs are used. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-11powerpc/cpm: Move CPMFCR_* defines into cpm.hAnton Vorontsov
The bits are generic to CPM devices, so let's move them to the common header file, so drivers won't need to privately reintroduce another bunch of the same bits (as we can't include cpm2.h header together with cpm1.h). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-11-11powerpc/qe&cpm2: Avoid redefinitions in CPM2 and QE headersAnton Vorontsov
struct mcc defined in both immap_qe.h and immap_cpm2.h, so they will conflic when included in a single file. The mcc struct is easy to deal with, since it isn't used in any driver (yet), so let's just rename QE version to qe_mcc. The ucb_ctlr is a bit trickier, since it is used by fsl_qe_udc driver, and the driver supports both CPM and QE UDCs, plus the QE version is used to form a bigger immap struct. I don't want to touch too much of USB code in this series, so for now let's just copy most generic version into the common cpm.h header, later we'll create cpm_usb.h where we'll place common USB structs that are used by QE/CPM UDC and QE Host drivers (FHCI). And as for the structs in qe.h and cpm2.h, just prefix them with qe_ and cpm_. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2008-08-04powerpc: Move include files to arch/powerpc/include/asmStephen Rothwell
from include/asm-powerpc. This is the result of a mkdir arch/powerpc/include/asm git mv include/asm-powerpc/* arch/powerpc/include/asm Followed by a few documentation/comment fixups and a couple of places where <asm-powepc/...> was being used explicitly. Of the latter only one was outside the arch code and it is a driver only built for powerpc. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
