Currently there are several dts that don't specify address or size
cells for the muram. This causes dtc to use default values, one of
which is an address-cells of two, and this breaks the parsing of the
muram ranges, which is assuming an address-cells of one. For example:
Warning (reg_format): "reg" property in
/qe@e0100000/muram@10000/data-only@0 has invalid length
(8 bytes) (#address-cells == 2, #size-cells == 1)
Explicitly setting the address and size cells gets it parsed properly
and gets rid of the four dtc warnings.
Also fixed a few minor indent problems as well.
Add the dts files for the MPC838xE Reference Development Board (RDB).
The board is a mini-ITX reference board with 256M DDR2, 8M flash,
32M NAND, USB, PCI, gigabit ethernet, SATA, and serial.
the difference among the three files is the 8377 has two, the 8378
none, and the 8379 has four sata controllers.
partially based on the 8379 mds device trees.
Signed-off-by: Joe D'Abbraccio <ljd015@freescale.com>
Add the dts for the MPC8315E Reference Development Board (RDB).
The board is a mini-ITX reference board with 128M DDR2, 8M flash,
Signed-off-by: Jerry Huang <Chang-Ming.Huang@freescale.com>
Also:
- rename "fsl_spi" to "fsl,spi";
- add and use cell-index property, if found;
- split probing code out of fsl_spi_init, thus we can call
it for legacy device_type probing and new "compatible" probing.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
device_type property is bogus, thus use proper compatible.
Also change compatible property to "fsl,ucc-mdio".
Now we're searching for "fsl,qe", "fsl,qe-muram", "fsl,qe-muram-data"
and "fsl,qe-ic".
Unfortunately it's still impossible to remove device_type = "qe"
from the existing device trees because older u-boots are looking for it.
* "simple-bus" covers all our needs for of_platform_bus_probe()
* make device tree name just 'soc' not 'soc85..'
Move mpc834x_mds device tree source forward to dts-v1 format. Nothing
too complex in this one, so it boils down to just adding a bunch of 0x
in the right places and converting clock speeds to decimal.
This adds the device tree source for the Wind River SBC834x board.
It is based on the MPC834x_MDS DTS, with the biggest difference being
the lack of BCSR and the PCI2 that the MDS gets via the PIB. That,
and this file is also dts-v1 format.
This adds a v1 device tree source for the Wind River SBC8548 board.
The biggest difference between this and the MPC8548CDS reference
platform is the absence of the CDS's Arcadia peripherals and physical
access to the PCI#2 bus.
This adds a v1 device tree source for the Wind River SBC8560 board. The
biggest difference between this and the MPC8560ADS reference platform
dts is the use of an external 16550 compatible UART instead of the CPM2.
The bd info struct changes if we have CPM2 enabled in u-boot.
Add the ability to find a device node by just what its compatible with.
This is useful in cases that we don't have a prop to find the node with.
logical/bitand typo
Signed-off-by: Roel Kluin <12o3l@tiscali.nl>
Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com>
Add the cuboot wrapper for the PIKA Warp board
Signed-off-by: Sean MacLennan <smaclennan@pikatech.com>
Add the device tree for the PIKA Warp board
This patch extends the Ebony and Walnut platform code to instantiate
the existing ds1742 RTC class driver for the DS1743 RTC/NVRAM chip
found on both those boards. The patch uses a helper function to scan
the device tree and instantiate the appropriate platform_device based
on it, so it should be easy to extend for other boards which have mmio
mapped RTC chips.
Along with this, the device tree binding for the ds1743 chips is
tweaked, based on the existing DS1385 OF binding found at:
http://playground.sun.com/1275/proposals/Closed/Remanded/Accepted/346-it.txt
Although that document covers the NVRAM portion of the chip, whereas
here we're interested in the RTC portion, so it's not entirely clear
if that's a good model.
This implements only RTC class driver support - that is /dev/rtc0, not
/dev/rtc, and the low-level get/set time callbacks remain
unimplemented. That means in order to get at the clock you will
either need a modified version of hwclock which will look at
/dev/rtc0, or you'll need to configure udev to symlink rtc0 to rtc.
Signed-off-by: David Gibson <david@gibson.dropbear.id.au>
The patch adds the Haleakala dts. The Haleakala is a stripped down
version of the Kilauea (405EX) with only one EMAC and only one PCIe
interface.
master.kernel.org:/pub/scm/linux/kernel/git/galak/powerpc into for-2.6.25
Use cuImage bootwrapper until U-Boot port is completed.
Derived heavily from Linkstation port.
Acked-by: Andy Wilcox <andy@protium.com>
Based on the Kurobox DTS files.
Add local bus, flash, and MTD partition nodes to mpc8641_hpcn.dts
Also add compatible field for the soc node, so that it will be picked up
by of_platform_bus_probe().
Signed-off-by: Wade Farnsworth <wfarnsworth@mvista.com>
Add NAND to device tree, and call of_platform_bus_probe().
This board is also resold by Freescale under the names
"QUICCStart MPC8248 Evaluation System" and "CWH-PPC-8248N-VE".
Update the MPC8610 HPCD files to support the audio driver. Update
booting-without-of.txt with information on the SSI device.
Add support for UART serial ports using a Freescale QUICCEngine. Update
booting-without-of.txt to define new properties for a QE UART node. Update
the MPC8323E-MDS device tree to add UCC5 as a UART. Update the QE library
to support slow UCC devices and modules.
...thus use fixed-link to register proper "Fixed PHY"
Signed-off-by: Vitaly Bordug <vitb@kernel.crashing.org>
This patch adds localbus and pata nodes to use CF IDE interface
on MPC8349E-mITX boards.
Patch also adds code to probe localbus.
Remove device_type = "usb" for 83xx SoC USB controller
Signed-off-by: Li Yang <leoli@freescale.com>
The ULI based boards had the interrupt maps for USB on the ULI incorrectly
set.
Also, the MPC8572DS was missing the interrupt-map-mask for the 3rd PCIe
controller.
Add the ability to set the mac address given the alias for the device.
Removes the need for having a linux,network-index property.
Fix typo in arch/powerpc/boot/flatdevtree_env.h.
There is no Documentation/networking/ixgbe.txt.
README.cycladesZ is now in Documentation/.
wavelan.p.h is now in drivers/net/wireless/.
HFS.txt is now Documentation/filesystems/hfs.txt.
OSS-files are now in sound/oss/.
Signed-off-by: Johann Felix Soden <johfel@users.sourceforge.net>
This patch adds support for 'mpc5200-simple-platform' compatible
boards which do not need a platform specific setup. Such boards
are supported assuming the following:
- GPIO pins are configured by the firmware,
- CDM configuration (clocking) is setup correctly by firmware,
- if the 'fsl,has-wdt' property is present in one of the
gpt nodes, then it is safe to use such gpt to reset the board,
- PCI is supported if enabled in the kernel configuration
and if there is a PCI bus node defined in the device tree.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
Add device tree source file for Promess Motion-PRO board.
Add device tree source file for CM5200 board.
Add device tree source file for TQ Components TQM5200 board.
Update .gitignore as needed by dtc addition.
Signed-off-by: Jochen Friedrich <jochen@scram.de>
Acked-by: David Gibson <david@gibson.dropbear.id.au>
git://git.secretlab.ca/git/linux-2.6-virtex into for-2.6.25
generator.
Missed this one in the boot loader before.
Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
