path: root/arch/powerpc/boot/stdio.c
2014-04-28powerpc/boot: Fix do_div for 64bit wrapperCédric Le Goater
When the boot wrapper is compiled in 64bit, there is no need to use __div64_32. Signed-off-by: Cédric Le Goater <clg@fr.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2007-06-28[POWERPC] Add u64 printf to bootwrapperGeoff Levand
Add support for the 'll' (long long) printf qualifier in the powerpc zImage bootwrapper. This is useful for bootwrapper debugging on 64 bit platforms. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-10-18[POWERPC] More bootwrapper reorganizationMark A. Greer
More reorganization of the bootwrapper: - Add dtb section to zImage - ft_init now called by platform_init - Pack a flat dt before calling kernel - Remove size parameter from free - printf only calls console_ops.write it its not NULL - Some cleanup Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-09-20[POWERPC] Start arch/powerpc/boot code reorganizationMark A. Greer
This abstracts the operations used in the bootwrapper, and defines the operations needed for the bootwrapper to run on an OF platform. The operations have been divided up into platform ops (platform_ops), firmware ops (fw_ops), device tree ops (dt_ops), and console ops (console_ops). The proper operations will be hooked up at runtime to provide the functionality that you need. Signed-off-by: Mark A. Greer <mgreer@mvista.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-01-14powerpc: Make COFF zImages for old 32-bit powermacsPaul Mackerras
This adds code to build zImage.coff and/or zImage.initrd.coff when CONFIG_PPC32 and CONFIG_PPC_PMAC are defined. It also restructures the OF client code and adds some workarounds for OF quirks on the older machines. Signed-off-by: Paul Mackerras <paulus@samba.org>
