path: root/arch/parisc/kernel
2005-11-17[PARISC] Remove unused variable in signal.cGrant Grundler
Remove unused variable "struct siginfo si" in signal.c Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] remove drm compat ioctls handlersChristoph Hellwig
Remove drm compat_ioctl handlers. The drm drivers have proper compat_ioctl methods these days. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] move PA perf driver over to ->compat_ioctlChristoph Hellwig
Move PA perf driver over to ->compat_ioctl. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Fix some compile problems in ptrace.cMatthew Wilcox
Fix some compile problems: - ret wasn't being initialised in all code paths - I'm pretty sure 'goto out' should have been 'goto out_tsk' Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Improve the error message when we get a clashing mod pathMatthew Wilcox
Improve the error message when we get a clashing mod path, and actually display the IODC data and path for the conflicting device. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Return PDC_OK when alloc_pa_dev fails to enumerate all devicesMatthew Wilcox
Return PDC_OK when device registration fails so that we enumerate all subsequent devices, even when we get two devices with the same hardware path (which should never happen, but does with at least one revision of rp8400 firmware). Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Document some register usages in assembly filesCarlos O'Donell
Document clobbers and args in entry.S and syscall.S. entry.S: Add comment to indicate that cr27 may recycle and EDEADLOCK detection is not 100% correct. Since this is only enabled when using ENABLE_LWS_DEBUG, the user is warned by the comment. Signed-off-by: Carlos O'Donell <carlos@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Make redirecting irq messages less noisyRyan Bradetich
Make the "redirecting irq" message to not display on the console by setting the severity to KERN_DEBUG. The console was basically unusable. Signed-off-by: Ryan Bradetich <rbrad@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] irq_affinityp[] only available for SMP buildsGrant Grundler
irq_affinityp[] only available for SMP builds, make code that uses it conditional on CONFIG_SMP. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Add IRQ affinitiesJames Bottomley
This really only adds them for the machines I can check SMP on, which is CPU interrupts and IOSAPIC (so not any of the GSC based machines). With this patch, irqbalanced can be used to maintain irq balancing. Unfortunately, irqbalanced is a bit x86 centric, so it doesn't do an incredibly good job, but it does work. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Fix uniprocessor build by dummying smp_send_all_nop()Kyle McMartin
Since irq.c uses smp_send_all_nop, we must define it for UP builds as well. Make it a static inline so it gets optimized away. This forces irq.c to include <asm/smp.h> though. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Fix our interrupts not to use smp_call_functionJames Bottomley
Fix our interrupts not to use smp_call_function On K and D class smp, the generic code calls this under an irq spinlock, which causes the WARN_ON() message in smp_call_function() (and is also illegal because it could deadlock). The fix is to use a new scheme based on the IPI_NOP. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Disable nesting of interruptsGrant Grundler
Disable nesting of interrupts - still has holes The offending sequence starts out like this: 1) take external interrupt 2) set_eiem() to only allow TIMER_IRQ; local interrupts still disabled 3) read the EIRR to get a "list" of pending interrupts 4) clear EIRR of pending interrupts we intend to handle 5) call __do_IRQ() to handle IRQ. 6) handle_IRQ_event() enables local interrupts (I-Bit) 7) take a timer interrupt 8) read EIRR to get a new list of pending interrupts 9) clear EIRR of pending interrupts we just read 10) handle pending interrupts found in (8) 11) set_eiem(cpu_eiem) and return [ TROUBLE! all enabled CPU IRQs are unmasked. } 12) handle remaining interrupts pending from (3) e.g. call __do_IRQ() -> handle_IRQ_event()..etc [ TROUBLE! call to handle_IRQ_event() can now enable *any* IRQ. } 13) set_eiem(cpu_eiem) and return The problem is we now get into ugly race conditions with Timer and IPI interrupts at this point. I'm not exactly sure what happens when things go wrong (perhaps nest calls to IPI or timer interrupt?). But I'm certain it's not good. This sequence will break sooner if (10) would accidentally leave interrupts enabled. I'm pretty sure the right answer is now to make cpu_eiem a per CPU variable since all external interrupts on parisc are per CPU. This means we will NOT need to send an IPI to every CPU in the system when enabling or disabling an IRQ since only one CPU needs to change it's EIEM. Thanks to James Bottomley for (once again) pointing out the problem. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Make sure timer and IPI execute with interrupts disabledJames Bottomley
Fix a longstanding smp bug The problem is that both the timer and ipi interrupts are being called with interrupts enabled, which isn't what anyone is expecting. The IPI issue has just started to show up by causing a BUG_ON in the slab debugging code. The timer issue never shows up because there's an eiem work around in our irq.c The fix is to label both these as SA_INTERRUPT which causes the generic irq code not to enable interrupts. I also suspect the smp_call_function timeouts we're seeing might be connected with the fact that we disable IPIs when handling any other type of interrupt. I've put a WARN_ON in the code for executing smp_call_function() with IPIs disabled. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] changing CONFIG_LOCALVERSION rebuilds too much, for no good reasonOlaf Hering
This patch removes almost all inclusions of linux/version.h. The 3 #defines are unused in most of the touched files. A few drivers use the simple KERNEL_VERSION(a,b,c) macro, which is unfortunatly in linux/version.h. There are also lots of #ifdef for long obsolete kernels, this was not touched. In a few places, the linux/version.h include was move to where the LINUX_VERSION_CODE was used. quilt vi `find * -type f -name "*.[ch]"|xargs grep -El '(UTS_RELEASE|LINUX_VERSION_CODE|KERNEL_VERSION|linux/version.h)'|grep -Ev '(/(boot|coda|drm)/|~$)'` search pattern: /UTS_RELEASE\|LINUX_VERSION_CODE\|KERNEL_VERSION\|linux\/\(utsname\|version\).h Signed-off-by: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] consolidate sys_ptrace()Christoph Hellwig
The sys_ptrace boilerplate code (everything outside the big switch statement for the arch-specific requests) is shared by most architectures. This patch moves it to kernel/ptrace.c and leaves the arch-specific code as arch_ptrace. Some architectures have a too different ptrace so we have to exclude them. They continue to keep their implementations. For sh64 I had to add a sh64_ptrace wrapper because it does some initialization on the first call. For um I removed an ifdefed SUBARCH_PTRACE_SPECIAL block, but SUBARCH_PTRACE_SPECIAL isn't defined anywhere in the tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Paul Mackerras <paulus@samba.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-By: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] jiffies_64 cleanupThomas Gleixner
Define jiffies_64 in kernel/timer.c rather than having 24 duplicated defines in each architecture. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] adjust parisc sys_ptrace prototypeChristoph Hellwig
Make the pid argument a long as on every other arcihtecture. Despite pid_t beeing a 32bit type even on 64bit parisc this is not an ABI change due to the parisc calling conventions. And even if it did it wouldn't matter too much because 64bit userspace on parisc is in an embrionic stage. Acked-by: Matthew Wilcox <matthew@wil.cx> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] TIOC* compat ioctl handlingChristoph Hellwig
TIOCSTART and TIOCSTOP are defined in asm/ioctls.h and asm/termios.h by various architectures but not actually implemented anywhere but in the IRIX compatibility layer, so remove their COMPATIBLE_IOCTL from parisc, ppc64 and sparc64. Move the TIOCSLTC COMPATIBLE_IOCTL to common code, guided by an ifdef to only show up on architectures that support it (same as the code handling it in tty_ioctl.c), aswell as it's brother TIOCGLTC that wasn't handled so far. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: parisc pte atomicityHugh Dickins
There's a worrying function translation_exists in parisc cacheflush.h, unaffected by split ptlock since flush_dcache_page is using it on some other mm, without any relevant lock. Oh well, make it a slightly more robust by factoring the pfn check within it. And it looked liable to confuse a camouflaged swap or file entry with a good pte: fix that too. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: init_mm without ptlockHugh Dickins
First step in pushing down the page_table_lock. init_mm.page_table_lock has been used throughout the architectures (usually for ioremap): not to serialize kernel address space allocation (that's usually vmlist_lock), but because pud_alloc,pmd_alloc,pte_alloc_kernel expect caller holds it. Reverse that: don't lock or unlock init_mm.page_table_lock in any of the architectures; instead rely on pud_alloc,pmd_alloc,pte_alloc_kernel to take and drop it when allocating a new one, to check lest a racing task already did. Similarly no page_table_lock in vmalloc's map_vm_area. Some temporary ugliness in __pud_alloc and __pmd_alloc: since they also handle user mms, which are converted only by a later patch, for now they have to lock differently according to whether or not it's init_mm. If sources get muddled, there's a danger that an arch source taking init_mm.page_table_lock will be mixed with common source also taking it (or neither take it). So break the rules and make another change, which should break the build for such a mismatch: remove the redundant mm arg from pte_alloc_kernel (ppc64 scrapped its distinct ioremap_mm in 2.6.13). Exceptions: arm26 used pte_alloc_kernel on user mm, now pte_alloc_map; ia64 used pte_alloc_map on init_mm, now pte_alloc_kernel; parisc had bad args to pmd_alloc and pte_alloc_kernel in unused USE_HPPA_IOREMAP code; ppc64 map_io_page forgot to unlock on failure; ppc mmu_mapin_ram and ppc64 im_free took page_table_lock for no good reason. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28Auto-update from upstreamKyle McMartin
2005-10-28[PATCH] gfp_t: dma-mapping (parisc)Al Viro
2005-10-21[PARISC] Properly specify section alignment for real2.SGrant Grundler
.align applies to the current section - ie section directives come first. Thanks to Joel Soete for catching this. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Explicitly specify sr4 when flushing kernel spaceMatthew Wilcox
Specify sr4 when flushing kernel space (we could equally well use sr5-7, but must not use sr0). Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Properly specify index field to I/D cache flush opsGrant Grundler
replace use of "0" with "%r0" since PA 1.1 I/D flush ops only take a general register and not an immediate value for the index field. This just forces the code to always be PA 1.1 "clean". From: Joel Soete <soete.joel@tiscali.be> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix copy_user_page_asm to NOT access past end of pageGrant Grundler
2.6.12-rc2-pa3 fix copy_user_page_asm to NOT access past end of page. My bad. /o\ Lamont confirmed that instructions following a conditional branch are *alway* executed regardless if the branch is taken or not. Unless they are nullified (which was missing in this case). He also noted: Conditional branches nullify on forward taken branch, and on non-taken backward branch. Note that .+4 is a backwards branch. This makes alot more sense than the giberish in the PA20 arch book. Compiles and boots on both 64-bit (a500) and 32-bit (j6k). Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Remove the spurious do_softirq calls from entry.SJames Bottomley
remove the spurious do_softirq calls from entry.S With these in we were calling do_softirq twice; plus the calls in entry.S took no account of nesting. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix the alloc_slabmgmt panicJames Bottomley
Fix the alloc_slabmgmt panic Hopefully this should also fix a lot of other intermittent kernel bugs. The problem has been around since 2.6.9-rc2-pa6 when we allowed floating point registers to be used in kernel code. The essence of the problem is that gcc prefers to use floating point for integer divides and multiples. Further, it can rely on the values in the no clobber fp regs being correct across a function call. Unfortunately, our task switch function only saves the integer no clobber registers, not the fp ones, so if gcc makes a function call to any function in the kernel which could sleep, the values it is relying on in any no clobber floating point register may be lost. In the case of alloc_slabmgmt, the value of the page offset is being stored in %fr12 across a call to kmem_getpages(), which sleeps if no pages are available. Thus, the offset can be trashed and the slab code can end up with a completely bogus address leading to corruption. Kudos to Randolph who came up with the program to trip this problem at will and thus allowed it to be tracked and fixed. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Implement 5 argument clone.Carlos O'Donell
* arch/parisc/kernel/process.c (sys_clone): Use 5 args, and process CLONE_PARENT_SETTID, CLONE_CHILD_SETTID, CLONE_CHILD_CLEARTID. (copy_thread): First cut at CLONE_SETTLS. Signed-off-by: Carlos O'Donell <carlos@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Document history of PDC_NARROW as it is now obsoleteGrant Grundler
Document history of PDC_NARROW a bit as it will still show up in an older kernel's .config file. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] kfree cleanups to ioctl32.cJesper Juhl
2.6.12-rc2-pa2 kfree cleanups from Jesper Juhl Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Cleanup whitespace and handle proc_mkdir() failures in pci-dma.cGrant Grundler
1) cleanup whitespace and handle proc_mkdir() failures. From: Christophe Lucas <clucas@rotomalug.org> 2) rename "dino" entry to "pcxl_dma"...also seems like it's in the wrong location. 3) don't dump resource bitmap in /proc/pcxl_dma output 4) fixup compiler warning Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] More informative error message in pcibios_link_hba_resourcesGrant Grundler
Generate a more informative message when a resource does not have a parent. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Update pdc console from parisc treeMatthew Wilcox
Get rid of some unnecessary includes Remove a layer of macro indirection around pdc_console_device Delete pdc_console_die() as it is unused Avoid double-printing on panic by clearing CON_PRINTBUFFER rather than setting con_start to be log_end Make con_start and log_end static again Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Prevent signal loops if we have a problem setting up a frameRandolph Chung
2.6.13-rc6-pa2 use force_sigsegv() if we have a problem setting up a frame. This is required to prevent SIGSEGV loops. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Add printing of fpregs state to stack dumpThibaut Varene
We're using fp regs now in the kernel, so we want to print them on stack dump Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Add sync required after fdc to enforce insn orderingGrant Grundler
PA20 arch book (page 7-52 and 7-55) indicate a "sync" is required after the FDC "to enforce instruction ordering". And we want to make sure FIC is executed after FDC has retired. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Replace uses of __LP64__ with CONFIG_64BITGrant Grundler
2.6.12-rc4-pa3 s/__LP64__/CONFIG_64BIT/ and fixup config.h usage Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Use work queue in LED/LCD driver instead of tasklet.Grant Grundler
2.6.12-rc1-pa6 use work queue in LED/LCD driver instead of tasklet. Main advantage is it allows use of msleep() in the led_LCD_driver to "atomically" perform two MMIO writes (CMD, then DATA). Lead to nice cleanup of the main led_work_func() and led_LCD_driver(). Kudos to David for being persistent. From: David Pye <dmp@davidmpye.dyndns.org> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Add new ioprio_{set,get} syscallsJens Axboe
add syscall entries for ioprio_set/get as per Jens Axboe. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Fix parisc_setup_cache_timing to choose a better flush thresholdStuart Brady
update comment about CAFL_STRIDE Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Fixed a bug in parisc_setup_cache_timing() which caused it to calculate a poor value for parisc_cache_flush_threshold. Thanks to Joel Soete for spotting the bug. Thanks to James Bottomley for pointing out the clean way to fix this. Signed-off-by: Stuart Brady <sdb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Add ability for prctl to change unaligned trap behaviourKyle McMartin
Add support for changing unaligned trap behaviour on a per-thread basis. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Replace some calls to bl with b,l or bv to use longer offsetsRandolph Chung
convert some bl calls to b,l or bv to use longer offsets Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Take into account nullified insn and lock functions for profilingRandolph Chung
export profile_pc() symbol - oprofile needs it when built as a module. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Take into account nullified insn and lock functions for profiling This is needed at the end of functions; it is typical that the return branch nullifies the next insn, which is in the next function. This causes profiling data to show up against the "wrong" function. We also count lock times against the locker. This is consistent with other architectures. Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Make sure use of RFI conforms to PA 2.0 and 1.1 arch docsGrant Grundler
2.6.12-rc4-pa3 : first pass at making sure use of RFI conforms to PA 2.0 arch pages F-4 and F-5, PA 1.1 Arch page 3-19 and 3-20. The discussion revolves around all the rules for clearing PSW Q-bit. The hard part is meeting all the rules for "relied upon translation". .align directive is used to guarantee the critical sequence ends more than 8 instructions (32 bytes) from the end of page. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device tree to use struct device klistsMatthew Wilcox
Fix parse_tree_node. much more needs to be done to fix this file. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Make drivers.c compile based on a patch from Pat Mochel. From: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Fix drivers.c to create new device tree nodes when no match is found. Signed-off-by: Richard Hirst <rhirst@parisc-linux.org> Do a proper depth-first search returning parents before children, using the new klist infrastructure. Signed-off-by: Richard Hirst <rhirst@parisc-linux.org> Fixed parisc_device traversal so that pdc_stable works again Fixed check_dev so it doesn't dereference a parisc_device until it has verified the bus type Signed-off-by: Randolph Chung <tausq@parisc-linux.org> Convert pa_dev->hpa from an unsigned long to a struct resource. Use insert_resource() instead of request_mem_region(). Request resources at bus walk time instead of driver probe time. Don't release the resources as we don't have any hotplug parisc_device support yet. Add parisc_pathname() to conveniently get the textual representation of the hwpath used in sysfs. Inline the remnants of claim_device() into its caller. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> I noticed that some of the STI regions weren't showing up in iomem. Reading the STI spec indicated that all STI devices occupy at least 32MB. So check for STI HPAs and give them 32MB instead of 4kB. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
