path: root/arch/parisc/kernel/sys_parisc.c
2010-03-12improve sys_newuname() for compat architecturesChristoph Hellwig
On an architecture that supports 32-bit compat we need to override the reported machine in uname with the 32-bit value. Instead of doing this separately in every architecture introduce a COMPAT_UTS_MACHINE define in <asm/compat.h> and apply it directly in sys_newuname(). Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: James Morris <jmorris@namei.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Unify sys_mmap*Al Viro
New helper - sys_mmap_pgoff(); switch syscalls to using it. Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07get_unmapped_area handles MAP_FIXED on pariscBenjamin Herrenschmidt
Handle MAP_FIXED in parisc arch_get_unmapped_area(), just return the address. We might want to also check for possible cache aliasing issues now that we get called in that case (like ARM or MIPS), leave a comment for the maintainers to pick up. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-05[PA-RISC] Fix parisc_newuname()Matthew Wilcox
The utsname virtualisation broke parisc_newuname compilation. Rewrite the implementation to call sys_newuname() like sparc64 does. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org>
2006-10-04[PARISC] Allow overriding personality with sys_personalityKyle McMartin
And now suddenly, linux32 works on parisc... Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-04-21[PARISC] Add new entries to the syscall tableKyle McMartin
Most are easy, but sync_file_range needed special handling when entering through the 32-bit syscall table. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-05-01[PATCH] consolidate sys_shmatStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
