path: root/arch/parisc/kernel/process.c
2005-11-09[PATCH] sched: resched and cpu_idle reworkNick Piggin
Make some changes to the NEED_RESCHED and POLLING_NRFLAG to reduce confusion, and make their semantics rigid. Improves efficiency of resched_task and some cpu_idle routines. * In resched_task: - TIF_NEED_RESCHED is only cleared with the task's runqueue lock held, and as we hold it during resched_task, then there is no need for an atomic test and set there. The only other time this should be set is when the task's quantum expires, in the timer interrupt - this is protected against because the rq lock is irq-safe. - If TIF_NEED_RESCHED is set, then we don't need to do anything. It won't get unset until the task get's schedule()d off. - If we are running on the same CPU as the task we resched, then set TIF_NEED_RESCHED and no further action is required. - If we are running on another CPU, and TIF_POLLING_NRFLAG is *not* set after TIF_NEED_RESCHED has been set, then we need to send an IPI. Using these rules, we are able to remove the test and set operation in resched_task, and make clear the previously vague semantics of POLLING_NRFLAG. * In idle routines: - Enter cpu_idle with preempt disabled. When the need_resched() condition becomes true, explicitly call schedule(). This makes things a bit clearer (IMO), but haven't updated all architectures yet. - Many do a test and clear of TIF_NEED_RESCHED for some reason. According to the resched_task rules, this isn't needed (and actually breaks the assumption that TIF_NEED_RESCHED is only cleared with the runqueue lock held). So remove that. Generally one less locked memory op when switching to the idle thread. - Many idle routines clear TIF_POLLING_NRFLAG, and only set it in the inner most polling idle loops. The above resched_task semantics allow it to be set until before the last time need_resched() is checked before going into a halt requiring interrupt wakeup. Many idle routines simply never enter such a halt, and so POLLING_NRFLAG can be always left set, completely eliminating resched IPIs when rescheduling the idle task. POLLING_NRFLAG width can be increased, to reduce the chance of resched IPIs. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Con Kolivas <kernel@kolivas.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] sched: disable preempt in idle tasksNick Piggin
Run idle threads with preempt disabled. Also corrected a bugs in arm26's cpu_idle (make it actually call schedule()). How did it ever work before? Might fix the CPU hotplugging hang which Nigel Cunningham noted. We think the bug hits if the idle thread is preempted after checking need_resched() and before going to sleep, then the CPU offlined. After calling stop_machine_run, the CPU eventually returns from preemption and into the idle thread and goes to sleep. The CPU will continue executing previous idle and have no chance to call play_dead. By disabling preemption until we are ready to explicitly schedule, this bug is fixed and the idle threads generally become more robust. From: alexs <ashepard@u.washington.edu> PPC build fix From: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> MIPS build fix Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Yoichi Yuasa <yuasa@hh.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-21[PARISC] Implement 5 argument clone.Carlos O'Donell
* arch/parisc/kernel/process.c (sys_clone): Use 5 args, and process CLONE_PARENT_SETTID, CLONE_CHILD_SETTID, CLONE_CHILD_CLEARTID. (copy_thread): First cut at CLONE_SETTLS. Signed-off-by: Carlos O'Donell <carlos@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09kbuild: m68k,parisc,ppc,ppc64,s390,xtensa use generic asm-offsets.h supportSam Ravnborg
Delete obsoleted parts form arch makefiles and rename to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-07-26[PATCH] Don't export machine_restart, machine_halt, or machine_power_off.Eric W. Biederman
machine_restart, machine_halt and machine_power_off are machine specific hooks deep into the reboot logic, that modules have no business messing with. Usually code should be calling kernel_restart, kernel_halt, kernel_power_off, or emergency_restart. So don't export machine_restart, machine_halt, and machine_power_off so we can catch buggy users. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
