path: root/arch/parisc/kernel/firmware.c
2012-03-28Disintegrate asm/system.h for PA-RISCDavid Howells
Disintegrate asm/system.h for PA-RISC. Signed-off-by: David Howells <dhowells@redhat.com> cc: linux-parisc@vger.kernel.org
2011-01-15parisc : Remove broken line wrapping handling pdc_iodc_print()Guy Martin
Remove the broken line wrapping handling in pdc_iodc_print(). It is broken in 3 ways : - It doesn't keep track of the current screen position, it just assumes that the new buffer will be printed at the begining of the screen. - It doesn't take in account that non printable characters won't increase the current position on the screen. - And last but not least, it triggers a kernel panic if a backspace is the first char in the provided buffer : Backtrace: [<0000000040128ec4>] pdc_console_write+0x44/0x78 [<0000000040128f18>] pdc_console_tty_write+0x20/0x38 [<000000004032f1ac>] n_tty_write+0x2a4/0x550 [<000000004032b158>] tty_write+0x1e0/0x2d8 [<00000000401bb420>] vfs_write+0xb8/0x188 [<00000000401bb630>] sys_write+0x68/0xb8 [<0000000040104eb8>] syscall_exit+0x0/0x14 Most terminals handle the line wrapping just fine. I've confirmed that it works correctly on a C8000 with both vga and serial output. Signed-off-by: Guy Martin <gmsoft@tuxicoman.be> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-04parisc: pass through '\t' to early (iodc) consoleKyle McMartin
The firmware handles '\t' internally, so stop trying to emulate it (which, incidentally, had a bug in it.) Fixes a really weird hang at bootup in rcu_bootup_announce, which, as far as I can tell, is the first printk in the core kernel to use a tab as the first character. Cc: stable@kernel.org Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31parisc: expose 32/64-bit capabilities in cpuinfoColin Watson
It'd be rather useful for debian-installer if we could get hold of accurate firmware information on whether only 32-bit kernels are supported, only 64-bit kernels, or both; this would allow us to present an accurate menu of kernel packages if more than one is available, rather than the user having to guess. This patch attempts to expose it in cpuinfo. I adjusted pdc_model_capabilities to cope with a potential PDC_INVALID_ARG return as the firmware manual instructs, by assuming 32-bit only. This may be the wrong place for it. I made up user-visible capability names by total fiat and for the moment ignored the other bits that may appear in the capabilities word. I have no PA-RISC machine myself to test on, and no PA experience either, so I rather hope that somebody will kind-heartedly take this and fix it up if needed. I ran it past Dann Frazier on IRC and he said "looks good to me", but I think without testing. Also, this is against the Ubuntu 2.6.28 kernel tree since that's what I had handy and I was a bit tight on disk space to slurp down another tree. Sorry if it's skewed in any relevant way; I'll be happy to adjust if necessary. Thanks in advance! Signed-off-by: Colin Watson <cjwatson@canonical.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: fix section mismatch warningsHelge Deller
Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-10parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlockedKyle McMartin
These functions are called only when bringing up the monarch cpu, so it is safe to call them without taking the pdc spinlock. In the future, this may become relevant for lockdep, since these functions were taking spinlocks before start_kernel called the lockdep initializers.
2008-10-10parisc: move pdc_result to real2.SKyle McMartin
2008-03-15[PARISC] pdc_console: fix bizarre panic on bootKyle McMartin
Commit 721fdf34167580ff98263c74cead8871d76936e6 introduced a subtle bug by accidently removing the "static" from iodc_dbuf. This resulted in, what appeared to be, a trap without *current set to a task. Probably the result of a trap in real mode while calling firmware. Also do other misc clean ups. Since the only input from firmware is non blocking, share iodc_dbuf between input and output, and spinlock the only callers. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-12-06[PARISC] print more than one character at a time for pdc consoleKyle McMartin
There's really no reason not to print more than one character at a time to the PDC console... Booting is measurably speedier, and now I don't have to watch individual characters get drawn. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-05-22[PARISC] spelling fixes: arch/parisc/Simon Arlott
Spelling fixes in arch/parisc/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2007-02-17[PARISC] use CONFIG_64BIT instead of __LP64__Helge Deller
- additionally update my copyright timestamps Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-07[PARISC] Make firmware calls irqsafe-ish...Kyle McMartin
There's no reason why we shouldn't be using _irqsave instead of _irq for any of these calls. fwiw, this fixes the "start_kernel(): bug: interrupts were enabled early" message displayed on bootup recently. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Matthew Wilcox <matthew@wil.cx>
2006-10-01[PATCH] proper flags type of spin_lock_irqsave()Alexey Dobriyan
Convert various spin_lock_irqsave() callers to correctly use `unsigned long'. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Cc: "Luck, Tony" <tony.luck@intel.com> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PARISC] OS_ID_LINUX == 0x0006Kyle McMartin
We were assigned an OS_ID of 0x0006. Consistently use OS_ID_LINUX instead of using the magic number. Also update the OS_ID_ defines in asm/pdc.h to reflect this. Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] Ensure Space ID hashing is turned offKyle McMartin
Check PDC_CACHE to see if spaceid hashing is turned on, and fail to boot if that is the case. However, some old machines do not implement the PDC_CACHE_RET_SPID firmware call, so continue to boot if the call fails because of PDC_BAD_OPTION (but fail in all other error returns). Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-27[PARISC] PDC_CHASSIS is implemented on all machinesThibaut Varene
This patch removes a limitation of the original code, so that CHASSIS codes can be sent to all machines. On machines with a LCD panel, this code displays "INI" during bootup, "RUN" when the system is booted and running, "FLT" when a panic occurs, etc. This part of the code can be enabled/disabled through CONFIG_PDC_CHASSIS This patch also adds minimalistic support for Chassis warnings, through a proc entry '/proc/chassis', which will reflect the warnings status (PSU or fans failure when they happen, NVRAM battery level and temperature thresholds overflows). This part of the code can be enabled/disabled through CONFIG_PDC_CHASSIS_WARN Signed-off-by: Thibaut VARENE <varenet@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Add __read_mostly section for pariscHelge Deller
Flag a whole bunch of things as __read_mostly on parisc. Also flag a few branches as unlikely() and cleanup a bit of code. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Document history of PDC_NARROW as it is now obsoleteGrant Grundler
Document history of PDC_NARROW a bit as it will still show up in an older kernel's .config file. Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
