path: root/arch/nios2/kernel/traps.c
2018-04-25signal/nios2: Use force_sig_fault where appropriateEric W. Biederman
Filling in struct siginfo before calling force_sig_info a tedious and error prone process, where once in a great while the wrong fields are filled out, and siginfo has been inconsistently cleared. Simplify this process by using the helper force_sig_fault. Which takes as a parameters all of the information it needs, ensures all of the fiddly bits of filling in struct siginfo are done properly and then calls force_sig_info. In short about a 5 line reduction in code for every time force_sig_info is called, which makes the calling function clearer. Cc: Ley Foon Tan <lftan@altera.com> Cc: nios2-dev@lists.rocketboards.org Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2018-04-25signal: Ensure every siginfo we send has all bits initializedEric W. Biederman
Call clear_siginfo to ensure every stack allocated siginfo is properly initialized before being passed to the signal sending functions. Note: It is not safe to depend on C initializers to initialize struct siginfo on the stack because C is allowed to skip holes when initializing a structure. The initialization of struct siginfo in tracehook_report_syscall_exit was moved from the helper user_single_step_siginfo into tracehook_report_syscall_exit itself, to make it clear that the local variable siginfo gets fully initialized. In a few cases the scope of struct siginfo has been reduced to make it clear that siginfo siginfo is not used on other paths in the function in which it is declared. Instances of using memset to initialize siginfo have been replaced with calls clear_siginfo for clarity. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/debug.h> We are going to split <linux/sched/debug.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/debug.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the files that are going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-20nios2: rework trap handlerLey Foon Tan
Redefine trap handler as below: 0 N/A reserved for system calls 1 SIGUSR1 user-defined signal 1 2 SIGUSR2 user-defined signal 2 3 SIGILL illegal instruction 4..29 reserved (but implemented to raise SIGILL instead of being undefined) 30 SIGTRAP KGDB 31 SIGTRAP trace/breakpoint trap Signed-off-by: Ley Foon Tan <lftan@altera.com>
2014-12-08nios2: Traps exception handlingLey Foon Tan
This patch contains traps exception handling. Signed-off-by: Ley Foon Tan <lftan@altera.com>
