path: root/arch/mips
2009-09-17MIPS: Loongson: Change naming methodsWu Zhangjin
To make source code of loongson sharable to the machines(such as gdium) made by the other companies, we rename arch/mips/lemote to arch/mips/loongson, asm/mach-lemote to asm/mach-loongson, and rename lm2e to the name of the machine: fuloong-2e. accordingly, FULONG are renamed to FULOONG2E to make it distinguishable to the future FULOONG2F. and also, some other relative tuning is needed. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Add oprofile supportWu Zhangjin
This kernel support is needed by the user-space tool:oprofile to profile linux kernel or applications via loongson2 performance counters. you can enable this driver via CONFIG_OPROFILE = y or m. On Loongson2 there are two performance counters, each one can count 16 events respectively. when anyone of the performance counter overflows, an interrupt will be generated and is routed to the IRQ MIPS_CPU_IRQ_BASE + 6. Signed-off-by: Yanhua <yanh@lemote.com> Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: RTC: Enable legacy RTC driver on fulongWu Zhangjin
RTC_LIB is selected by MIPS by default, and therefore, the legacy RTC driver is disabled. but fortunately, RTC_LIB not works on fulong, so, enabling the legcy RTC driver is needed, otherwise, the tools like hwclock will not work. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: PCI: Clean up pcimap setupWu Zhangjin
Fixup the wrong original comment of pcimap, and make the source code more understandable. and also, some new extra consideration is added in. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: clean up the coding styleWu Zhangjin
With the help of script/checkpatch.pl, i have cleaned up the coding style. 1. remove un-needed header files and tune some comments. 2. remove some un-needed { } add a new header file loongson.h: 3. move some common header files to loongson.h 4. move some common extern declartions to loongson.h and this new header file is needed for future loongson2f support. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Split the implementation of prom and setup partsWu Zhangjin
This patch split the old initilization and setup implementation to several file, one file one logic function. the other main changes include: 1. as the script/checkpatch.pl suggests, use strict_strtol instead of simple_strtol in arch/mips/lemote/lm2e/cmdline.c 2. use the existed macros in asm/mips-boards/bonito64.h as the arguments of set_io_port_base() and remove the un-needed ones in asm/mach-lemote/pci.h Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: PCI: use existing mips_io_port_baseWu Zhangjin
mips_io_port_base is initialized via set_io_port_base() in arch/mips/lemote/lm2e/setup.c, we can use it directly here. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: pm: clean up the reboot supportWu Zhangjin
Several magic numbers have been replaced by relative macros, which will be more readable and understandable. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: pm: Remove redundant source codeWu Zhangjin
The implmentation of loongson2e_power_off and loongson2e_halt is almostly the same, just preserve one of them. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Add new early_printk implmentationWu Zhangjin
This patch is based on the implementation in the lm2e-fixes branch of Philippe's git://git.linux-cisco.org/linux-mips.git and the malta-specific early_printk implementation. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Remove out-of-date board-specific kgdb source codeWu Zhangjin
Since the re-implementation of kgdb by commit 8854700115ecf8aa6f087aa915b7b6cf18090d39 the platform-specific version has become superfluous, remove it. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Loongson: Remove existing early_printk implementationWu Zhangjin
Removes the existing implementation of early_printk for fulong. The old implementation was based on the outdated board-specific dbg_io.c. Since commit 8d60a903d986ffa26c41f0092320a3b9da20bfaf dbg_io.c is not longer needed; it will be removed by the next patch, and a new implementation of early_printk will be added later. Signed-off-by: Wu Zhangjin <wuzj@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: IP22, IP28: Build with -WerrorRalf Baechle
2009-09-17MIPS: FW: Build with -WerrorRalf Baechle
2009-09-17MIPS: Fulong: Convert reset initialization to initcall.Ralf Baechle
2009-09-17MIPS: Malta: Convert reset initialization to initcall.Ralf Baechle
2009-09-17MIPS: Get rid of duplicate cpu_idle() prototype.Ralf Baechle
Since 2.6.11-rc1 there is a prototype in <linux/smp.h>. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: TXx9: Fix error handling.Julia Lawall
Error handling code following a kzalloc should free the allocated data. Error handling code following an ioremap should iounmap the allocated data. The semantic match that finds the first problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @r exists@ local idexpression x; statement S; expression E; identifier f,f1,l; position p1,p2; expression *ptr != NULL; @@ x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...); ... if (x == NULL) S <... when != x when != if (...) { <+...x...+> } ( x->f1 = E | (x->f1 == NULL || ...) | f(...,x->f1,...) ) ...> ( return \(0\|<+...x...+>\|ptr\); | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: TXx9: Disable PM capability of TX493[89] internal etherAtsushi Nemoto
Some TC35815 variants (i.e. TX493[89] internal ether) report existance of PM registers though they are not supported. Disable PM features by clearing pdev->pm_cap. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: make page.h constants available to assembly.Nelson Elhage
page.h includes ifndef __ASSEMBLY__ guards, but PAGE_SIZE and some other constants are defined using "1UL", which the assembler does not support. Use the _AC macro from const.h to make them available to assembly (and linker scripts). Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Alchemy: add gpio_request/gpio_free stubs for CONFIG_GPIOLIB=nManuel Lauss
Some drivers use gpio_request/gpio_free regardless of whether gpiolib is actually built; add stubs to work around the ensuing compile failures. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Tested-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Lasat: Fix compilationAlexey Dobriyan
Header needed for current_cpu_data which expands to smp_processor_id(). However, linux/smp.h can't be included into asm/cpu-info.h due to horrible circular dependencies, so plug it here. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Octeon: Check all CCAs in cvmx_write_csr.David Daney
The current code only checks CCA of 0 when deciding if a dummy read is needed. Since the kernel can (and does) use other CCAs we need to mask out the CCA bits from the address. Since the address constant now fits in 16 bits, there is an added benefit that smaller code is generated. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Fix potencial build error in <asm/delay.h>Ralf Baechle
<asm/delay.h> will break if HZ isn't defined. In 2.6.26 and later we're usually lucky ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-16Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (75 commits) PCI hotplug: clean up acpi_run_hpp() PCI hotplug: acpiphp: use generic pci_configure_slot() PCI hotplug: shpchp: use generic pci_configure_slot() PCI hotplug: pciehp: use generic pci_configure_slot() PCI hotplug: add pci_configure_slot() PCI hotplug: clean up acpi_get_hp_params_from_firmware() interface PCI hotplug: acpiphp: don't cache hotplug_params in acpiphp_bridge PCI hotplug: acpiphp: remove superfluous _HPP/_HPX evaluation PCI: Clear saved_state after the state has been restored PCI PM: Return error codes from pci_pm_resume() PCI: use dev_printk in quirk messages PCI / PCIe portdrv: Fix pcie_portdrv_slot_reset() PCI Hotplug: convert acpi_pci_detect_ejectable() to take an acpi_handle PCI Hotplug: acpiphp: find bridges the easy way PCI: pcie portdrv: remove unused variable PCI / ACPI PM: Propagate wake-up enable for devices w/o ACPI support ACPI PM: Replace wakeup.prepared with reference counter PCI PM: Introduce device flag wakeup_prepared PCI / ACPI PM: Rework some debug messages PCI PM: Simplify PCI wake-up code ... Fixed up conflict in arch/powerpc/kernel/pci_64.c due to OF device tree scanning having been moved and merged for the 32- and 64-bit cases. The 'needs_freset' initialization added in 6e19314cc ("PCI/powerpc: support PCIe fundamental reset") is now in arch/powerpc/kernel/pci_of_scan.c.
2009-09-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (46 commits) powerpc64: convert to dynamic percpu allocator sparc64: use embedding percpu first chunk allocator percpu: kill lpage first chunk allocator x86,percpu: use embedding for 64bit NUMA and page for 32bit NUMA percpu: update embedding first chunk allocator to handle sparse units percpu: use group information to allocate vmap areas sparsely vmalloc: implement pcpu_get_vm_areas() vmalloc: separate out insert_vmalloc_vm() percpu: add chunk->base_addr percpu: add pcpu_unit_offsets[] percpu: introduce pcpu_alloc_info and pcpu_group_info percpu: move pcpu_lpage_build_unit_map() and pcpul_lpage_dump_cfg() upward percpu: add @align to pcpu_fc_alloc_fn_t percpu: make @dyn_size mandatory for pcpu_setup_first_chunk() percpu: drop @static_size from first chunk allocators percpu: generalize first chunk allocator selection percpu: build first chunk allocators selectively percpu: rename 4k first chunk allocator to page percpu: improve boot messages percpu: fix pcpu_reclaim() locking ... Fix trivial conflict as by Tejun Heo in kernel/sched.c
2009-09-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1623 commits) netxen: update copyright netxen: fix tx timeout recovery netxen: fix file firmware leak netxen: improve pci memory access netxen: change firmware write size tg3: Fix return ring size breakage netxen: build fix for INET=n cdc-phonet: autoconfigure Phonet address Phonet: back-end for autoconfigured addresses Phonet: fix netlink address dump error handling ipv6: Add IFA_F_DADFAILED flag net: Add DEVTYPE support for Ethernet based devices mv643xx_eth.c: remove unused txq_set_wrr() ucc_geth: Fix hangs after switching from full to half duplex ucc_geth: Rearrange some code to avoid forward declarations phy/marvell: Make non-aneg speed/duplex forcing work for 88E1111 PHYs drivers/net/phy: introduce missing kfree drivers/net/wan: introduce missing kfree net: force bridge module(s) to be GPL Subject: [PATCH] appletalk: Fix skb leak when ipddp interface is not loaded ... Fixed up trivial conflicts: - arch/x86/include/asm/socket.h converted to <asm-generic/socket.h> in the x86 tree. The generic header has the same new #define's, so that works out fine. - drivers/net/tun.c fix conflict between 89f56d1e9 ("tun: reuse struct sock fields") that switched over to using 'tun->socket.sk' instead of the redundantly available (and thus removed) 'tun->sk', and 2b980dbd ("lsm: Add hooks to the TUN driver") which added a new 'tun->sk' use. Noted in 'next' by Stephen Rothwell.
2009-09-09PCI: remove pcibios_scan_all_fns()Alex Chiang
This was #define'd as 0 on all platforms, so let's get rid of it. This change makes pci_scan_slot() slightly easier to read. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Reviewed-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-09KEYS: Add missing linux/tracehook.h #inclusionsDavid Howells
Add #inclusions of linux/tracehook.h to those arch files that had the tracehook call for TIF_NOTIFY_RESUME added when support for that flag was added to that arch. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Add a keyctl to install a process's session keyring on its parent [try #6]David Howells
Add a keyctl to install a process's session keyring onto its parent. This replaces the parent's session keyring. Because the COW credential code does not permit one process to change another process's credentials directly, the change is deferred until userspace next starts executing again. Normally this will be after a wait*() syscall. To support this, three new security hooks have been provided: cred_alloc_blank() to allocate unset security creds, cred_transfer() to fill in the blank security creds and key_session_to_parent() - which asks the LSM if the process may replace its parent's session keyring. The replacement may only happen if the process has the same ownership details as its parent, and the process has LINK permission on the session keyring, and the session keyring is owned by the process, and the LSM permits it. Note that this requires alteration to each architecture's notify_resume path. This has been done for all arches barring blackfin, m68k* and xtensa, all of which need assembly alteration to support TIF_NOTIFY_RESUME. This allows the replacement to be performed at the point the parent process resumes userspace execution. This allows the userspace AFS pioctl emulation to fully emulate newpag() and the VIOCSETTOK and VIOCSETTOK2 pioctls, all of which require the ability to alter the parent process's PAG membership. However, since kAFS doesn't use PAGs per se, but rather dumps the keys into the session keyring, the session keyring of the parent must be replaced if, for example, VIOCSETTOK is passed the newpag flag. This can be tested with the following program: #include <stdio.h> #include <stdlib.h> #include <keyutils.h> #define KEYCTL_SESSION_TO_PARENT 18 #define OSERROR(X, S) do { if ((long)(X) == -1) { perror(S); exit(1); } } while(0) int main(int argc, char **argv) { key_serial_t keyring, key; long ret; keyring = keyctl_join_session_keyring(argv[1]); OSERROR(keyring, "keyctl_join_session_keyring"); key = add_key("user", "a", "b", 1, keyring); OSERROR(key, "add_key"); ret = keyctl(KEYCTL_SESSION_TO_PARENT); OSERROR(ret, "KEYCTL_SESSION_TO_PARENT"); return 0; } Compiled and linked with -lkeyutils, you should see something like: [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 355907932 --alswrv 4043 -1 \_ keyring: _uid.4043 [dhowells@andromeda ~]$ /tmp/newpag [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: _ses 1055658746 --alswrv 4043 4043 \_ user: a [dhowells@andromeda ~]$ /tmp/newpag hello [dhowells@andromeda ~]$ keyctl show Session Keyring -3 --alswrv 4043 4043 keyring: hello 340417692 --alswrv 4043 4043 \_ user: a Where the test program creates a new session keyring, sticks a user key named 'a' into it and then installs it on its parent. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-02KEYS: Extend TIF_NOTIFY_RESUME to (almost) all architectures [try #6]David Howells
Implement TIF_NOTIFY_RESUME for most of those architectures in which isn't yet available, and, whilst we're at it, have it call the appropriate tracehook. After this patch, blackfin, m68k* and xtensa still lack support and need alteration of assembly code to make it work. Resume notification can then be used (by a later patch) to install a new session keyring on the parent of a process. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> cc: linux-arch@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2009-08-17Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: MIPS: Fix HPAGE_SIZE redefinition
2009-08-17MIPS: Fix HPAGE_SIZE redefinitionAtsushi Nemoto
This patch fixes warnings like this: CC fs/proc/meminfo.o In file included from /work/linux/include/linux/mmzone.h:20, from /work/linux/include/linux/gfp.h:4, from /work/linux/include/linux/mm.h:8, from /work/linux/fs/proc/meminfo.c:5: /work/linux/arch/mips/include/asm/page.h:36:1: warning: "HPAGE_SIZE" redefined In file included from /work/linux/fs/proc/meminfo.c:2: /work/linux/include/linux/hugetlb.h:107:1: warning: this is the location of the previous definition Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Acked-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-14Merge branch 'percpu-for-linus' into percpu-for-nextTejun Heo
Conflicts: arch/sparc/kernel/smp_64.c arch/x86/kernel/cpu/perf_counter.c arch/x86/kernel/setup_percpu.c drivers/cpufreq/cpufreq_ondemand.c mm/percpu.c Conflicts in core and arch percpu codes are mostly from commit ed78e1e078dd44249f88b1dd8c76dafb39567161 which substituted many num_possible_cpus() with nr_cpu_ids. As for-next branch has moved all the first chunk allocators into mm/percpu.c, the changes are moved from arch code to mm/percpu.c. Signed-off-by: Tejun Heo <tj@kernel.org>
2009-08-12Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: arch/microblaze/include/asm/socket.h
2009-08-05net: implement a SO_DOMAIN getsockoptionJan Engelhardt
This sockopt goes in line with SO_TYPE and SO_PROTOCOL. It makes it possible for userspace programs to pass around file descriptors — I am referring to arguments-to-functions, but it may even work for the fd passing over UNIX sockets — without needing to also pass the auxiliary information (PF_INET6/IPPROTO_TCP). Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05net: implement a SO_PROTOCOL getsockoptionJan Engelhardt
Similar to SO_TYPE returning the socket type, SO_PROTOCOL allows to retrieve the protocol used with a given socket. I am not quite sure why we have that-many copies of socket.h, and why the values are not the same on all arches either, but for where hex numbers dominate, I use 0x1029 for SO_PROTOCOL as that seems to be the next free unused number across a bunch of operating systems, or so Google results make me want to believe. SO_PROTOCOL for others just uses the next free Linux number, 38. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-05ar7: add fixed PHY support for the two on-board cpmacFlorian Fainelli
This patch adds fixed PHY support for the two on-chip cpmac Ethernet adapters. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-08-03MIPS: Wire up accept4 syscall.Ralf Baechle
2009-08-03MIPS: VPE: Delete unused function get_tc_unused().Ralf Baechle
2009-08-03MIPS: VPE: Fix bogus indentation.Ralf Baechle
2009-08-03MIPS: VPE: Make various functions static.Ralf Baechle
None of these is used outside the VPE loader. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: VPE: Free relocation chain on error.Ralf Baechle
This may happen if a bad sequence of relocations is being encountered. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: VPE: Fix compiler warning.Raghu Gandham
Signed-off-by: Raghu Gandham <raghu@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Module: Make error messages unique.Ralf Baechle
There were three different errors resulting in a "dangerous relocation" message. Add the relocation type to the messgages to make them more useful. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Octeon: Run IPI code with interrupts disabled.David Daney
In mm/slab.c the function do_ccupdate_local requires that interrupts be disabled. If they are not, we panic with CONFIG_DEBUG_SLAB. So we disable interrupts while processing IPIs. Also these are not shared irqs, so get rid of the IRQF_SHARED flag. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Jazz: Fix read buffer overflowRoel Kluin
Check whether index is within bounds before testing the element. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Use DIV_ROUND_CLOSESTJulia Lawall
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d but is perhaps more readable. The semantic patch that makes this change is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @haskernel@ @@ #include <linux/kernel.h> @depends on haskernel@ expression x,__divisor; @@ - (((x) + ((__divisor) / 2)) / (__divisor)) + DIV_ROUND_CLOSEST(x,__divisor) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: MTX-1: Request button GPIO before setting its directionFlorian Fainelli
This patch fixes the following warning at boot time: WARNING: at drivers/gpio/gpiolib.c:83 0x8021d5e0() autorequest GPIO-207 Modules linked in: Call Trace:[<8011e0ec>] 0x8011e0ec [<80110a28>] 0x80110a28 [<80110a28>] 0x80110a28 [..snip..] The current code does not request the GPIO and attempts to set its direction, which is a violation of the GPIO API. This patch also unhardcode the GPIO we request and use the one we defined in the button driver. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: AR7: Override CFLAGS with -WerrorFlorian Fainelli
Now that we have removed all warnings from the ar7 board code we can use -Werror like on other MIPS boards. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
