path: root/arch/mips/sibyte/swarm/setup.c
2018-10-31mm: remove include/linux/bootmem.hMike Rapoport
Move remaining definitions and declarations from include/linux/bootmem.h into include/linux/memblock.h and remove the redundant header. The includes were replaced with the semantic patch below and then semi-automated removal of duplicated '#include <linux/memblock.h> @@ @@ - #include <linux/bootmem.h> + #include <linux/memblock.h> [sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au [sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h] Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au [sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal] Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com> Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Zankel <chris@zankel.net> Cc: "David S. Miller" <davem@davemloft.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Greentime Hu <green.hu@gmail.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Guan Xuetao <gxt@pku.edu.cn> Cc: Ingo Molnar <mingo@redhat.com> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Jonas Bonn <jonas@southpole.se> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Ley Foon Tan <lftan@altera.com> Cc: Mark Salter <msalter@redhat.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Michal Simek <monstr@monstr.eu> Cc: Palmer Dabbelt <palmer@sifive.com> Cc: Paul Burton <paul.burton@mips.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Richard Weinberger <richard@nod.at> Cc: Rich Felker <dalias@libc.org> Cc: Russell King <linux@armlinux.org.uk> Cc: Serge Semin <fancer.lancer@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tony Luck <tony.luck@intel.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-05-14MIPS: Convert update_persistent_clock() to update_persistent_clock64()Baolin Wang
Since struct timespec is not y2038 safe on 32bit machines, this patch converts update_persistent_clock() to update_persistent_clock64() using struct timespec64. The rtc_mips_set_time() and rtc_mips_set_mmss() interfaces were using 'unsigned long' type that is not y2038 safe on 32bit machines, moreover there is only one platform implementing rtc_mips_set_time() and two platforms implementing rtc_mips_set_mmss(), so we can just make them each implement update_persistent_clock64() directly, to get that helper out of the common mips code by removing rtc_mips_set_time() and rtc_mips_set_mmss() interfaces. Signed-off-by: Baolin Wang <baolin.wang@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Huacai Chen <chenhc@lemote.com> Cc: Paul Burton <paul.burton@mips.com> Cc: linux-mips@linux-mips.org Signed-off-by: James Hogan <jhogan@kernel.org>
2018-05-14MIPS: Convert read_persistent_clock() to read_persistent_clock64()Baolin Wang
Since struct timespec is not y2038 safe on 32bit machines, this patch converts read_persistent_clock() to read_persistent_clock64() using struct timespec64, as well as converting mktime() to mktime64(). Signed-off-by: Baolin Wang <baolin.wang@linaro.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Huacai Chen <chenhc@lemote.com> Cc: Paul Burton <paul.burton@mips.com> Cc: linux-mips@linux-mips.org Signed-off-by: James Hogan <jhogan@kernel.org>
2014-11-24MIPS: Remove useless parenthesesRalf Baechle
Based on the spatch @@ expression e; @@ - return (e); + return e; with heavy hand editing because some of the changes are either whitespace or identation only or result in excessivly long lines. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-11-26MIPS: Remove panic_timeout settingsRalf Baechle
Now that we have a CONFIG_PANIC_TIMEOUT=x setting, remove the mips settings. The default is 0, which means don't reboot on panic. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Shinya Kuribayashi <skuribay@pobox.com> Signed-off-by: Jason Baron <jbaron@akamai.com> Cc: benh@kernel.crashing.org Cc: paulus@samba.org Cc: mpe@ellerman.id.au Cc: felipe.contreras@gmail.com Cc: linux-mips@linux-mips.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/d19dc75fca343ec5d9ada75a1400f57330021976.1385418410.git.jbaron@akamai.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2010-12-16MIPS: Swarm: Fix typo in symbol name: RTC_M4LT81 -> RTC_M41T81Ralf Baechle
2010-04-30MIPS: Fixup screen_info struct initializationsSebastian Andrzej Siewior
|arch/mips/sibyte/swarm/setup.c:153: | warning: large integer implicitly truncated to unsigned type The field was changed in d9b26352 aka ("x86, setup: Store the boot cursor state"). This patch changes the values back they way they were before this extra field got introduced. While here, the other two boards are also converted to C99 initializer. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1137/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-30MIPS: Sibyte: Fix compilation error.Mark Mason
Build error introduced by d4f587c67fc39e0030ddd718675e252e208da4d7. Signed-off-by: Mark Mason <mmason@upwardaccess.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-15timekeeping: Increase granularity of read_persistent_clock()Martin Schwidefsky
The persistent clock of some architectures (e.g. s390) have a better granularity than seconds. To reduce the delta between the host clock and the guest clock in a virtualized system change the read_persistent_clock function to return a struct timespec. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: John Stultz <johnstul@us.ibm.com> Cc: Daniel Walker <dwalker@fifo99.com> LKML-Reference: <20090814134811.013873340@de.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-06-17MIPS: Sibyte: Remove standalone kernel supportImre Kaloz
CFE is the only supported and used bootloader on the SiByte boards, the standalone kernel support has been never used outside Broadcom. Remove it and make the kernel use CFE by default. Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: Sibyte: Remove simulator optionImre Kaloz
This patch removes the SiByte simulation Kconfig option, which only modified a printk. Signed-off-by: Imre Kaloz <kaloz@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-19[MIPS] Sibyte: Finish conversion to modern time APIs.Ralf Baechle
2007-10-11[MIPS] Deforest the function pointer jungle in the time code.Ralf Baechle
Hard to follow who is pointing what to where and why so it's simply getting in the way of the time code renovation. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-24[MIPS] SB1250: Fix bugs/warnings by creative use of volatile.Ralf Baechle
2006-12-04[MIPS] SWARM: Fix a typo in #error directivesMaciej W. Rozycki
This is a fix for a typo repeated several times in #error directives for invalid SiByte configurations. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-10[PATCH] tty: Remove include of screen_info.h from tty.hJon Smirl
screen_info.h doesn't have anything to do with the tty layer and shouldn't be included by tty.h. This patches removes the include and modifies all users to directly include screen_info.h. struct screen_info is mainly used to communicate with the console drivers in drivers/video/console. Note that this patch touches every arch and I have no way of testing it. If there is a mistake the worst thing that will happen is a compile error. [akpm@osdl.org: fix arm build] [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] Fix bcm1480 compileThiemo Seufer
Fix compilation for bcm1480, a hpt is only available on sb1250/bcm112x. Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-27[PATCH] mips: fixed collision of rtc function nameYoichi Yuasa
Fix the collision of rtc function name. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-18[MIPS] Sibyte: Fix race in sb1250_gettimeoffset().Ralf Baechle
From Dave Johnson <djohnson+linuxmips@sw.starentnetworks.com>: sb1250_gettimeoffset() simply reads the current cpu 0 timer remaining value, however once this counter reaches 0 and the interrupt is raised, it immediately resets and begins to count down again. If sb1250_gettimeoffset() is called on cpu 1 via do_gettimeofday() after the timer has reset but prior to cpu 0 processing the interrupt and taking write_seqlock() in timer_interrupt() it will return a full value (or close to it) causing time to jump backwards 1ms. Once cpu 0 handles the interrupt and timer_interrupt() gets far enough along it will jump forward 1ms. Fix this problem by implementing mips_hpt_*() on sb1250 using a spare timer unrelated to the existing periodic interrupt timers. It runs at 1Mhz with a full 23bit counter. This eliminated the custom do_gettimeoffset() for sb1250 and allowed use of the generic fixed_rate_gettimeoffset() using mips_hpt_*() and timerhi/timerlo. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Add support for BCM1480 family of chips.Andrew Isaacson
- Kconfig and Makefile changes - arch/mips/sibyte/bcm1480/ - changes to sibyte common code to support 1480 Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29No need to explicitly call __read_64bit_c0_split; __read_64bit_c0_registerRalf Baechle
will do that itself iff needed. Fix format string. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
