path: root/arch/mips/sgi-ip27/ip27-irq.c
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2012-01-11Merge branch 'next/generic' into mips-for-linux-nextRalf Baechle
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Fix up inconsistency in panic() string argument.Ralf Baechle
Panic() invokes printk() to add a \n internally, so panic arguments should not themselves end in \n. Panic invocations in arch/mips and elsewhere are inconsistently sometimes terminating in \n, sometimes not. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-10-20MIPS: IP27: Sort out section mismatch.Ralf Baechle
WARNING: vmlinux.o(.text+0x3059f8): Section mismatch in reference from the function pcibios_plat_dev_init() to the function .devinit.text:request_bridge_irq() The function pcibios_plat_dev_init() references the function __devinit request_bridge_irq(). This is often because pcibios_plat_dev_init lacks a __devinit annotation or the annotation of request_bridge_irq is wrong. Fixing this one leads to: WARNING: vmlinux.o(.text+0x1790): Section mismatch in reference from the function request_bridge_irq() to the function .devinit.text:register_bridge_irq() The function request_bridge_irq() references the function __devinit register_bridge_irq(). This is often because request_bridge_irq lacks a __devinit annotation or the annotation of register_bridge_irq is wrong. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: IP27: Convert to new irq_chip functionsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2203/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-18[MIPS] IP27: Convert to clock_event_device.Ralf Baechle
This separates the tick timer stuff from the generic MIPS time.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP27: intr_sconnect_level: don't disable interrupts.Ralf Baechle
There is no reason to. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP27: startup_bridge_irq: connect interrupt.Ralf Baechle
shutdown_bridge_irq disconnects the irq so we need to connect the irq or requesting the same irq a send time will fail. This used to make things like ifconfig eth0 down; ifconfig eth0 up fail on IP27. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] IP27: shutdown_bridge_irq: don't free irq.Ralf Baechle
2007-02-06[MIPS] use name instead of typename for each irq_chipAtsushi Nemoto
The "typename" field was obsoleted by the "name" field. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-06[MIPS] Compile __do_IRQ() when really neededFranck Bui-Huu
__do_IRQ() is needed only by irq handlers that can't use default handlers defined in kernel/irq/chip.c. For others platforms there's no need to compile this function since it won't be used. For those platforms this patch defines GENERIC_HARDIRQS_NO__DO_IRQ symbol which is used exactly for this purpose. Futhermore for platforms which do not use __do_IRQ(), end() method which is part of the 'irq_chip' structure is not used. This patch simply removes this method in this case. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] use generic_handle_irq, handle_level_irq, handle_percpu_irqAtsushi Nemoto
Further incorporation of generic irq framework. Replacing __do_IRQ() by proper flow handler would make the irq handling path a bit simpler and faster. * use generic_handle_irq() instead of __do_IRQ(). * use handle_level_irq for obvious level-type irq chips. * use handle_percpu_irq for irqs marked as IRQ_PER_CPU. * setup .eoi routine for irq chips possibly used with handle_percpu_irq. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] IRQ cleanupsAtsushi Nemoto
This is a big irq cleanup patch. * Use set_irq_chip() to register irq_chip. * Initialize .mask, .unmask, .mask_ack field. Functions for these method are already exist in most case. * Do not initialize .startup, .shutdown, .enable, .disable fields if default routines provided by irq_chip_set_defaults() were suitable. * Remove redundant irq_desc initializations. * Remove unnecessary local_irq_save/local_irq_restore, spin_lock. With this cleanup, it would be easy to switch to slightly lightwait irq flow handlers (handle_level_irq(), etc.) instead of __do_IRQ(). Though whole this patch is quite large, changes in each irq_chip are not quite simple. Please review and test on your platform. Thanks. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-06[MIPS] Make irq number allocator generally available for fixing EV64120.Ralf Baechle
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-07-13[MIPS] Eleminate interrupt migration helper use.Ralf Baechle
> #define hw_interrupt_type irq_chip > typedef struct irq_chip hw_irq_controller; > #define no_irq_type no_irq_chip > typedef struct irq_desc irq_desc_t; Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] IP27: Don't destroy interrupt routing information on shutdown irq.Ralf Baechle
This fixes the "not syncing: Could not identify cpu/level ..." panic when a PCI irq is requested the second time. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-02[PATCH] irq-flags: MIPS: Use the new IRQF_ constantsThomas Gleixner
Use the new IRQF_ constants and remove the SA_INTERRUPT define Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-19[MIPS] IP27: Fix collision with hardcoded interrupt number.Ralf Baechle
2006-04-19[MIPS] Rewrite all the assembler interrupt handlers to C.Ralf Baechle
Saves like 1,600 lines of code, is way easier to debug, compilers frequently do a better job than the cut and paste type of handlers many boards had. And finally having all the stuff done in a single place also means alot of bug potencial for the MT ASE is gone. The only surviving handler in assembler is the DECstation one; I hope Maciej will rewrite it. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-23[PATCH] more for_each_cpu() conversionsAndrew Morton
When we stop allocating percpu memory for not-possible CPUs we must not touch the percpu data for not-possible CPUs at all. The correct way of doing this is to test cpu_possible() or to use for_each_cpu(). This patch is a kernel-wide sweep of all instances of NR_CPUS. I found very few instances of this bug, if any. But the patch converts lots of open-coded test to use the preferred helper macros. Cc: Mikael Starvik <starvik@axis.com> Cc: David Howells <dhowells@redhat.com> Acked-by: Kyle McMartin <kyle@parisc-linux.org> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: William Lee Irwin III <wli@holomorphy.com> Cc: Andi Kleen <ak@muc.de> Cc: Christian Zankel <chris@zankel.net> Cc: Philippe Elie <phil.el@wanadoo.fr> Cc: Nathan Scott <nathans@sgi.com> Cc: Jens Axboe <axboe@suse.de> Cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Use pr_debug instead of homegrown debug print macros.Ralf Baechle
2005-10-29Arrested for multiple offences of header file inclusion.Ralf Baechle
2005-10-29HUB interrupts are allocated per node, not per slice. Make manipulationRalf Baechle
of the interrupt mask register atomic by disabling interrupts. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
