Boot log says:
pci 0000:00:0a.3: no compatible bridge window for [io 0x1000-0x103f]
pci 0000:00:0a.3: no compatible bridge window for [io 0x1100-0x110f]
The io resource starting point on Malta was modified by c5de50dada (MIPS:
Malta: Change start address to avoid conflicts.) to avoid conflicts with
ACPI and SMB devices. In fact, that was not needed (and now causing
southbridge ACPI missing) since 166c637075 (PCI: add pci_create_root_bus()
that accepts resource list) and 7c090e5bfa (mips/PCI: convert to
pci_scan_root_bus() for correct root bus resources) had already done the
correct fix.
This patch actually reverts the change made by c5de50dada. And with this
fix, log says:
pci 0000:00:0a.3: quirk: [io 0x1000-0x103f] claimed by PIIX4 ACPI
pci 0000:00:0a.3: quirk: [io 0x1100-0x110f] claimed by PIIX4 SMB
These things may not be used but as part of platform resources are better
off to be included.
Cc: Steven J. Hill <Steven.Hill@imgtec.com>
Signed-off-by: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Signed-off-by: John Crispin <blogic@openwrt.org>
Patchwork: http://patchwork.linux-mips.org/patch/6037/
