path: root/arch/mips/pci/fixup-sb1250.c
2014-01-24mips: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/6320/
2013-01-03MIPS: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-07-19MIPS: PCI: Move fixups from __init to __devinit.Sebastian Andrzej Siewior
Fixups are executed once the pci-device is found which is during boot process so __init seems fine as long as the platform does not support hotplug. However it is possible to remove the PCI bus at run time and have it rediscovered again via "echo 1 > /sys/bus/pci/rescan" and this will call the fixups again. [ralf@linux-mips.org: Made piixirqmap[] in malta_piix_func0_fixup() __initdata.] Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Eleminate filenames from commentsRalf Baechle
They tend to get not updated when files are moved around or copied and lack any obvious use. While at it zap some only too obvious comments and as per Shinya's suggestion, add a copyright header to extable.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03[MIPS] BCM1250: TRDY timeout tweaks for Broadcom SiByte systemsMaciej W. Rozycki
It was obesrved that at least one older PCI card predating the requirement for the TRDY signal to respond within 16 clock ticks actually does not meet this rule nor even the power-on defaults of the PCI bridges found in development systems built around the Broadcom SiByte SOCs. Here is a patch that bumps up the timeout to the highest finite value supported by these chips, which is 255 clock ticks. The bridges affected are the SiByte SOC itself and the SP1011. This change does not effectively affect systems only having PCI option cards installed that meet the TRDY requirement of the current PCI spec. The rule was introduced with PCI 2.1, so any older card may make the system affected. If this is the case, performance of the system will suffer in return for the card working at all. If this is a concern, then the solution is not to use such cards. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
