path: root/arch/mips/nxp/pnx8550/common/prom.c
2010-08-05MIPS: PNX8550: Move code one directory level up.Ralf Baechle
It was sharing the nxp directory but no code with pnx833x and will fit better into the new platform makefile scheme, if moved. Also after the pnx833x code has been moved up, the pnx8550 Code was the last users of the nxp dir. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: PNX8550: Remove unnecessary export prom_getcmdline()Yoichi Yuasa
Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/886/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Move arch/mips/philips to arch/mips/nxpDaniel Laird
Signed-off-by: daniel.j.laird <daniel.j.laird@nxp.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
