path: root/arch/mips/momentum/ocelot_3/prom.c
2007-07-10[MIPS] Delete Ocelot 3 support.Ralf Baechle
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-06[MIPS] Ocelot 3: Fix MAC address detection after platform_device conversion.Ralf Baechle
2005-10-29 prom_free_prom_memory() returns unsigned longArthur Othieno
Some boards declare prom_free_prom_memory as a void function but the caller free_initmem() expects a return value. Fix those up and return 0 instead, just like everyone else does. Signed-off-by: Arthur Othieno <a.othieno@bluewin.ch> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: clean up 32/64-bit configurationRalf Baechle
Start cleaning 32-bit vs. 64-bit configuration. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
