path: root/arch/mips/mm/init.c
2013-07-03mm/MIPS: prepare for removing num_physpages and simplify mem_init()Jiang Liu
Prepare for removing num_physpages and simplify mem_init(). Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <david.daney@cavium.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jiri Kosina <jkosina@suse.cz> Cc: John Crispin <blogic@openwrt.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: concentrate modification of totalram_pages into the mm coreJiang Liu
Concentrate code to modify totalram_pages into the mm core, so the arch memory initialized code doesn't need to take care of it. With these changes applied, only following functions from mm core modify global variable totalram_pages: free_bootmem_late(), free_all_bootmem(), free_all_bootmem_node(), adjust_managed_page_count(). With this patch applied, it will be much more easier for us to keep totalram_pages and zone->managed_pages in consistence. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Acked-by: David Howells <dhowells@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03mm: change signature of free_reserved_area() to fix building warningsJiang Liu
Change signature of free_reserved_area() according to Russell King's suggestion to fix following build warnings: arch/arm/mm/init.c: In function 'mem_init': arch/arm/mm/init.c:603:2: warning: passing argument 1 of 'free_reserved_area' makes integer from pointer without a cast [enabled by default] free_reserved_area(__va(PHYS_PFN_OFFSET), swapper_pg_dir, 0, NULL); ^ In file included from include/linux/mman.h:4:0, from arch/arm/mm/init.c:15: include/linux/mm.h:1301:22: note: expected 'long unsigned int' but argument is of type 'void *' extern unsigned long free_reserved_area(unsigned long start, unsigned long end, mm/page_alloc.c: In function 'free_reserved_area': >> mm/page_alloc.c:5134:3: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast [enabled by default] In file included from arch/mips/include/asm/page.h:49:0, from include/linux/mmzone.h:20, from include/linux/gfp.h:4, from include/linux/mm.h:8, from mm/page_alloc.c:18: arch/mips/include/asm/io.h:119:29: note: expected 'const volatile void *' but argument is of type 'long unsigned int' mm/page_alloc.c: In function 'free_area_init_nodes': mm/page_alloc.c:5030:34: warning: array subscript is below array bounds [-Warray-bounds] Also address some minor code review comments. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Reported-by: Arnd Bergmann <arnd@arndb.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: "Michael S. Tsirkin" <mst@redhat.com> Cc: <sworddragon2@aol.com> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: David Howells <dhowells@redhat.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Jianguo Wu <wujianguo@huawei.com> Cc: Joonsoo Kim <js1304@gmail.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Michel Lespinasse <walken@google.com> Cc: Minchan Kim <minchan@kernel.org> Cc: Rik van Riel <riel@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Tang Chen <tangchen@cn.fujitsu.com> Cc: Tejun Heo <tj@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Wen Congyang <wency@cn.fujitsu.com> Cc: Will Deacon <will.deacon@arm.com> Cc: Yasuaki Ishimatsu <isimatu.yasuaki@jp.fujitsu.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-29mm/MIPS: use free_highmem_page() to free highmem pages into buddy systemJiang Liu
Use helper function free_highmem_page() to free highmem pages into the buddy system. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Daney <david.daney@cavium.com> Cc: Cong Wang <amwang@redhat.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm/MIPS: use common help functions to free reserved pagesJiang Liu
Use common help functions to free reserved pages. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29proc: Split kcore bits from linux/procfs.h into linux/kcore.hDavid Howells
Split kcore bits from linux/procfs.h into linux/kcore.h. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org cc: sparclinux@vger.kernel.org cc: x86@kernel.org cc: linux-mm@kvack.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-11MIPS: Align swapper_pg_dir to 64K for better TLB Refill code.David Daney
We can save an instruction in the TLB Refill path for kernel mappings by aligning swapper_pg_dir on a 64K boundary. The address of swapper_pg_dir can be generated with a single LUI instead of LUI/{D}ADDUI. The alignment of __init_end is bumped up to 64K so there are no holes between it and swapper_pg_dir, which is placed at the very beginning of .bss. The alignment of invalid_pmd_table and invalid_pte_table can be relaxed to PAGE_SIZE. We do this by using __page_aligned_bss, which has the added benefit of eliminating alignment holes in .bss. Signed-off-by: David Daney <david.daney@cavium.com> Cc: linux-mips@linux-mips.org Cc: linux-arch@vger.kernel.org, Cc: linux-kernel@vger.kernel.org Acked-by: Arnd Bergmann <arnd@arndb.de> Patchwork: https://patchwork.linux-mips.org/patch/4220/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-20mips: remove the second argument of k[un]map_atomic()Cong Wang
Signed-off-by: Cong Wang <amwang@redhat.com>
2011-12-07MIPS: Handle initmem in systems with kernel not in add_memory_region() memDavid Daney
This patch addresses a couple of related problems: 1) The kernel may reside in physical memory outside of the ranges set by plat_mem_setup(). If this is the case, init mem cannot be reused as it resides outside of the range of pages that the kernel memory allocators control. 2) initrd images might be loaded in physical memory outside of the ranges set by plat_mem_setup(). The memory likewise cannot be reused. The patch doesn't handle this specific case, but the infrastructure is useful for future patches that do. The crux of the problem is that there are memory regions that need be memory_present(), but that cannot be free_bootmem() at the time of arch_mem_init(). We create a new type of memory (BOOT_MEM_INIT_RAM) for use with add_memory_region(). Then arch_mem_init() adds the init mem with this type if the init mem is not already covered by existing ranges. When memory is being freed into the bootmem allocator, we skip the BOOT_MEM_INIT_RAM ranges so they are not clobbered, but we do signal them as memory_present(). This way when they are later freed, the necessary memory manager structures have initialized and the Sparse allocater is prevented from crashing. The Octeon specific code that handled this case is removed, because the new general purpose code handles the case. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1988/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: Limit fixrange_init() to the FIXMAP regionKevin Cernekee
fixrange_init() allocates page tables for all addresses higher than FIXADDR_TOP. On processors that override the default FIXADDR_TOP address of 0xfffe_0000, this can consume up to 4 pages (1 page per 4MB) for pgd's that are never used. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1980/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-25MIPS: pfn_valid() is broken on low memory HIGHMEM systemsKevin Cernekee
pfn_valid() compares the PFN to max_mapnr: __pfn >= min_low_pfn && __pfn < max_mapnr; On HIGHMEM kernels, highend_pfn is used to set the value of max_mapnr. Unfortunately, highend_pfn is left at zero if the system does not actually have enough RAM to reach into the HIGHMEM range. This causes pfn_valid() to always return false, and when debug checks are enabled the kernel will fail catastrophically: Memory: 22432k/32768k available (2249k kernel code, 10336k reserved, 653k data, 1352k init, 0k highmem) NR_IRQS:128 kfree_debugcheck: out of range ptr 81c02900h. Kernel bug detected[#1]: Cpu 0 $ 0 : 00000000 10008400 00000034 00000000 $ 4 : 8003e160 802a0000 8003e160 00000000 $ 8 : 00000000 0000003e 00000747 00000747 ... On such a configuration, max_low_pfn should be used to set max_mapnr. This was seen on 2.6.34. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> To: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1992/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-14MIPS: Fix GCC-4.6 'set but not used' warning in arch/mips/mm/init.cDavid Daney
Under some combinations of CONFIG_*, lastpfn in page_is_ram is 'set but not used'. Mark it as __maybe_unused to quiet the warning/error. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2033/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-28Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, mm: Unify kernel_physical_mapping_init() API x86, mm: Allow highmem user page tables to be disabled at boot time x86: Do not reserve brk for DMI if it's not going to be used x86: Convert tlbstate_lock to raw_spinlock x86: Use the generic page_is_ram() x86: Remove BIOS data range from e820 Move page_is_ram() declaration to mm.h Generic page_is_ram: use __weak resources: introduce generic page_is_ram()
2010-02-27MIPS: Implement Read Inhibit/eXecute InhibitDavid Daney
The SmartMIPS ASE specifies how Read Inhibit (RI) and eXecute Inhibit (XI) bits in the page tables work. The upper two bits of EntryLo{0,1} are RI and XI when the feature is enabled in the PageGrain register. SmartMIPS only covers 32-bit systems. Cavium Octeon+ extends this to 64-bit systems by continuing to place the RI and XI bits in the top of EntryLo even when EntryLo is 64-bits wide. Because we need to carry the RI and XI bits in the PTE, the layout of the PTE is changed. There is a two instruction overhead in the TLB refill hot path to get the EntryLo bits into the proper position. Also the TLB load exception has to probe the TLB to check if RI or XI caused the exception. Also of note is that the layout of the PTE bits is done at compile and runtime rather than statically. In the 32-bit case this allows for the same number of PFN bits as before the patch as the _PAGE_HUGE is not supported in 32-bit kernels (we have _PAGE_NO_EXEC and _PAGE_NO_READ instead of _PAGE_READ and _PAGE_HUGE). The patch is tested on Cavium Octeon+, but should also work on 32-bit systems with the Smart-MIPS ASE. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/952/ Patchwork: http://patchwork.linux-mips.org/patch/956/ Patchwork: http://patchwork.linux-mips.org/patch/962/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-27MIPS: Two-level pagetables for 64-bit kernels with 64KB pages.David Daney
For 64-bit kernels with 64KB pages and two level page tables, there are 42 bits worth of virtual address space This is larger than the 40 bits of virtual address space obtained with the default 4KB Page size and three levels, so there are no draw backs for using two level tables with this configuration. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/761/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-02-17Merge branch 'linus' into x86/mmThomas Gleixner
x86/mm is on 32-rc4 and missing the spinlock namespace changes which are needed for further commits into this topic. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-02-01resources: introduce generic page_is_ram()Wu Fengguang
It's based on walk_system_ram_range(), for archs that don't have their own page_is_ram(). The static verions in MIPS and SCORE are also made global. v4: prefer plain 1 instead of PAGE_IS_RAM (H. Peter Anvin) v3: add comment (KAMEZAWA Hiroyuki) "AFAIK, this "System RAM" information has been used for kdump to grab valid memory area and seems good for the kernel itself." v2: add PAGE_IS_RAM macro (Américo Wang) Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Cc: Américo Wang <xiyou.wangcong@gmail.com> Cc: linux-mips@linux-mips.org Cc: Yinghai Lu <yinghai@kernel.org> Acked-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> LKML-Reference: <20100122081619.GA6431@localhost> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2010-01-11mm: make totalhigh_pages unsigned longAndreas Fenkart
Makes it consistent with the extern declaration, used when CONFIG_HIGHMEM is set Removes redundant casts in printout messages Signed-off-by: Andreas Fenkart <andreas.fenkart@streamunlimited.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Chen Liqin <liqin.chen@sunplusct.com> Cc: Lennox Wu <lennox.wu@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-17MIPS: Put PGD in C0_CONTEXT for 64-bit R2 processors.David Daney
Processors that support the mips64r2 ISA can in four instructions convert a shifted PGD pointer stored in the upper bits of c0_context into a usable pointer. By doing this we save a memory load and associated potential cache miss in the TLB exception handlers. Since the upper bits of c0_context were holding the CPU number, we move this to the upper bits of c0_xcontext which doesn't have enough bits to hold the PGD pointer, but has plenty for the CPU number. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-11-02MIPS: Fix machine check exception in kmap_coherent()Kevin Cernekee
On an SMP system with cache aliases, the following sequence of events may happen: 1) copy_user_highpage() runs on CPU0, invoking kmap_coherent() to create a temporary mapping in the fixmap region 2) copy_page() starts on CPU0 3) CPU1 sends CPU0 an IPI asking CPU0 to run local_r4k_flush_cache_page() 4) CPU0 takes the interrupt, interrupting copy_page() 5) local_r4k_flush_cache_page() on CPU0 calls kmap_coherent() again 6) The second invocation of kmap_coherent() on CPU0 tries to use the same fixmap virtual address that was being used by copy_user_highpage() 7) CPU0 throws a machine check exception for the TLB address conflict Fixed by creating an extra set of fixmap entries for use in interrupt handlers. This prevents fixmap VA conflicts between copy_user_highpage() running in user context, and local_r4k_flush_cache_page() invoked from an SMP IPI. Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-23kcore: use registerd physmem informationKAMEZAWA Hiroyuki
For /proc/kcore, each arch registers its memory range by kclist_add(). In usual, - range of physical memory - range of vmalloc area - text, etc... are registered but "range of physical memory" has some troubles. It doesn't updated at memory hotplug and it tend to include unnecessary memory holes. Now, /proc/iomem (kernel/resource.c) includes required physical memory range information and it's properly updated at memory hotplug. Then, it's good to avoid using its own code(duplicating information) and to rebuild kclist for physical memory based on /proc/iomem. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: register vmalloc area in generic wayKAMEZAWA Hiroyuki
For /proc/kcore, vmalloc areas are registered per arch. But, all of them registers same range of [VMALLOC_START...VMALLOC_END) This patch unifies them. By this. archs which have no kclist_add() hooks can see vmalloc area correctly. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23kcore: add kclist typesKAMEZAWA Hiroyuki
Presently, kclist_add() only eats start address and size as its arguments. Considering to make kclist dynamically reconfigulable, it's necessary to know which kclists are for System RAM and which are not. This patch add kclist types as KCORE_RAM KCORE_VMALLOC KCORE_TEXT KCORE_OTHER This "type" is used in a patch following this for detecting KCORE_RAM. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-22arches: drop superfluous casts in nr_free_pages() callersGeert Uytterhoeven
Commit 96177299416dbccb73b54e6b344260154a445375 ("Drop free_pages()") modified nr_free_pages() to return 'unsigned long' instead of 'unsigned int'. This made the casts to 'unsigned long' in most callers superfluous, so remove them. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Ingo Molnar <mingo@elte.hu> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Mikael Starvik <starvik@axis.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Chris Zankel <zankel@tensilica.com> Cc: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-17MIPS: Shrink the size of tlb handlerWu Fei
By combining swapper_pg_dir and module_pg_dir, several if conditions can be eliminated from the tlb exception handler. The reason they can be combined is that, the effective virtual address of vmalloc returned is at the bottom, and of module_alloc returned is at the top. It also fixes the bug in vmalloc(), which happens when its return address is not covered by the first pgd. Signed-off-by: Wu Fei <at.wufei@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-05-14MIPS: Fix highmem.Ralf Baechle
Commit 351336929ccf222ae38ff0cb7a8dd5fd5c6236a0 (kernel.org) rsp. b3594a089f1c17ff919f8f78505c3f20e1f6f8ce (linux-mips.org): > From: Chris Dearman <chris@mips.com> > Date: Wed, 19 Sep 2007 00:58:24 +0100 > Subject: [PATCH] [MIPS] Allow setting of the cache attribute at run time. > > Slightly tacky, but there is a precedent in the sparc archirecture code. introduces the variable _page_cachable_default, which defaults to zero and. is used to create the prototype PTE for __kmap_atomic in arch/mips/mm/init.c:kmap_init before initialization in arch/mips/mm/c-r4k.c:coherency_setup, so the default value of 0 will be used as the CCA of kmap atomic pages which on many processors is not a defined CCA value and may result in writes to kmap_atomic pages getting corrupted. Debugged by Jon Fraser (jfraser@broadcom.com). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-03-30MIPS: Use BUG_ON() where possible.Ralf Baechle
Based on original patch by Stoyan Gaydarov <stoyboyker@gmail.com> which missed a few places. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-16[MIPS] Export empty_zero_page for sake of the ext4 module.Ralf Baechle
2008-04-28[MIPS] unexport copy_from_user_page()Dmitri Vorobiev
No users for the copy_from_user_page() routine exist outside of the core kernel code. Therefore, EXPORT_SYMBOL(copy_from_user_page) is useless, and this patch removes it. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport copy_to_user_page()Dmitri Vorobiev
The copy_to_user_page() function is called only in the core kernel code. Therefore, there is no need to export it. This patch removes EXPORT_SYMBOL(copy_to_user_page). Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] unexport copy_user_highpage()Dmitri Vorobiev
The copy_user_highpage() routine has no users outside of the core kernel code, so exporting this symbol is pointless. This patch removes EXPORT_SYMBOL(copy_user_highpage). Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] All MIPS32 processors support64-bit physical addresses.Chris Dearman
Still, only the 4K may actually implement it. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-19[MIPS] Fix buggy invocations of kmap_coherent()Ralf Baechle
kmap_coherent will only work correctly if the page it is called on is not marked dirty. If it's dirty the kernel address of the page should be used instead of a temporary mapping. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-26[MIPS] 64-bit Sibyte kernels need DMA32.Ralf Baechle
Sibyte SOCs only have 32-bit PCI. Due to the sparse use of the address space only the first 1GB of memory is mapped at physical addresses below 1GB. If a system has more than 1GB of memory 32-bit DMA will not be able to reach all of it. For now this patch is good enough to keep Sibyte users happy but it seems eventually something like swiotlb will be needed for Sibyte. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-11-15[MIPS] Convert reference to mem_map to pfn_to_page().Ralf Baechle
This was crashing the combination of highmem and sparsemem. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] Fix aliasing bug in copy_user_highpage, take 2.Ralf Baechle
Turns out b868868ae0f7272228c95cc760338ffe35bb739d wasn't quite right. When called for a page that isn't marked dirty it would artificially create an alias instead of doing the obvious thing and access the page via KSEG0. The same issue also exists in copy_to_user_page and copy_from_user_page which was causing the machine to die under rare circumstances for example when running ps if the BUG_ON() assertion added by the earlier fix was getting triggered. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-11[MIPS] Fix aliasing bug in copy_user_highpage.Ralf Baechle
Copy_user_highpage was written assuming it was only being called for breaking COW pages in which case the source page isn't cached as in marked cachable under it kernel virtual address. If it is called anyway the aliasing avoidance strategy implemented by kmap_coherent will fail. Avoid the use of kmap_coherent for pages marked dirty and to avoid another instance of this sort of bug, place a BUG_ON in kmap_coherent. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Gcc 3.3 build fixes.Ralf Baechle
Work around gcc 3.3's unability to evaluate that certain expressions indeed are constant. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-24[MIPS] Mark prom_free_prom_memory as __init_refokAtsushi Nemoto
> WARNING: vmlinux.o(.text+0xbf20): Section mismatch: reference to > .init.text:prom_free_prom_memory (between 'free_initmem' and 'copy_from_user_page') prom_free_prom_memory() is called _before_ freeing init sections, so it is false positive. __init_refok can be used for such cases. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] Remove LIMITED_DMA supportFranck Bui-Huu
This code was needed only by Jaguar ATX. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Remove unused argument from kunmap_coherent().Ralf Baechle
2007-04-27[MIPS] Select ZONE_DMA only if GENERIC_ISA_DMA selectedAtsushi Nemoto
2007-03-24[MIPS] Implement flush_anon_page().Ralf Baechle
2007-03-24[MIPS] SPARSEMEM: The first pfn of zone should be min_low_pfn, not 0.Atsushi Nemoto
