path: root/arch/mips/mips-boards/generic
2006-10-31[MIPS] Flags must be unsigned long.Ralf Baechle
2006-10-21[MIPS] Cleanup remaining references to mips_counter_frequency.Ralf Baechle
Noticed by Samium Gromoff but his patch got stale in flight ... Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-09[MIPS] Cleanup unnecessary <asm/ptrace.h> inclusions.Ralf Baechle
2006-10-08[MIPS] Complete fixes after removal of pt_regs argument to int handlers.Ralf Baechle
2006-09-27[MIPS] Atlas: update interrupt handlingMaciej W. Rozycki
The following change updates the Atlas interrupt handling to match that of Malta. Tested with a 5Kc and a 34Kf successfully. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Patch to arch/mips/mips-boards/generic/time.cKevin D. Kissell
In hooking up the perf counter overflow interrupt to the experimental deprecated-real-soon-now /proc/perf interface last night, I had to revisit arch/mips/mips-boards/generic/time.c, and discovered that when the 2.6.9-based SMTC prototype was merged with the more recent tree, it was missed that arch/mips/kernel/time.c had changed so that even in SMP kernels, timer_interrupt() calls local_timer_interrupt(), so there is no longer a need to invoke it directly from mips_timer_interrupt() in those cases where timer_interrupt() has been called. So I got rid of that, and added the invocation of perf_irq() if Cause.PCI is set, more-or-less following the same logic as in the non-SMTC case, with the modifications that (a) a runtime check for Release 2 isn't done, because it's redundant in SMTC), and (b) we check for a clock interrupt regardless of the value returned by the perf counter service - I don't understand why we'd want to control that with perf_irq(), but maybe one of you knows the story. I also got rid of the stupid warning about the unused variable when compiled for SMTC (another artifact of the merge). The result hasn't been beaten to death, but boots, seems stable, and supports extended precision event counting. Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Atlas, Malta, SEAD: Don't disable interrupts in mips_time_init().Ralf Baechle
By the time it's called from time_init interrupts are still disabled. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-07-13[MIPS] Malta: Fix build of certain configs.Ralf Baechle
2006-06-19[MIPS] Malta: Handle byteswapping hardare bug in big endian mode.Elizabeth Oldham
The SOC-it system controller running in big endian mode might forget byteswapping when DMAing to the last word of physical memory. Fixed by ignoring the last page of memory. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-27[MIPS] 24K LV: Add core card id.Chris Dearman
2006-04-19[MIPS] kgdb: Let gcc compute the array size itself.Ralf Baechle
This is the same method as used in the serial driver. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-04-19[MIPS] Fix the crime against humanity that mipsIRQ.S is.Ralf Baechle
2006-04-19[MIPS] Fixup damage done by 22a9835c350782a5c3257343713932af3ac92ee0.Ralf Baechle
2006-04-19[MIPS] Replace redundant declarations of _end by <asm/sections.h>.Ralf Baechle
2006-04-19[MIPS] Rewrite spurious_interrupt from assembler to C.Ralf Baechle
2006-03-27[PATCH] unify PFN_* macrosDave Hansen
Just about every architecture defines some macros to do operations on pfns. They're all virtually identical. This patch consolidates all of them. One minor glitch is that at least i386 uses them in a very skeletal header file. To keep away from #include dependency hell, I stuck the new definitions in a new, isolated header. Of all of the implementations, sh64 is the only one that varied by a bit. It used some masks to ensure that any sign-extension got ripped away before the arithmetic is done. This has been posted to that sh64 maintainers and the development list. Compiles on x86, x86_64, ia64 and ppc64. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] remove set_page_count() outside mm/Nick Piggin
set_page_count usage outside mm/ is limited to setting the refcount to 1. Remove set_page_count from outside mm/, and replace those users with init_page_count() and set_page_refcounted(). This allows more debug checking, and tighter control on how code is allowed to play around with page->_count. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2006-02-07[MIPS] Rename _machine_power_off to pm_power_off so the kernel builds again.Ralf Baechle
2006-01-10MIPS: Oprofile: Fixup the loose ends in the plumbing.Ralf Baechle
2006-01-10MIPS: MIPS boards: Get rid of useless SMP/non-SMP casing.Ralf Baechle
2005-10-29Virtual SMP support for the 34K.Ralf Baechle
2005-10-29Support for CoreFPGA-3.Ralf Baechle
2005-10-29More AP / SP bits for the 34K, the Malta bits and things. Still wantsRalf Baechle
a little polishing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Fixes for system controllers for Atlas/Malta core cards.Maciej W. Rozycki
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
