path: root/arch/mips/lib/iomap.c
2014-11-24MIPS: iomap: Use __mem_{read,write}{b,w,l} for MMIOMarkos Chandras
Using the __raw_{read,write}{b,w,l} functions to perform repeatable MMIO could result in problems if the host bus does not match the endianness of the PCI/ISA. This problem is visible on big-endian SEAD3 configurations after commit 2925f6c0c7af32720dcbadc586463aeceb6baa22 "net: smc911x: use io{read,write}*_rep accessors". This effectively moves away from using the __mem_* variants to __raw_* ones and causes a kernel bug as follows: Call Trace: CPU 0 Unable to handle kernel paging request at virtual address 00000000, epc == 00000000, ra == 8012b3b0 Oops[#1]: Cpu 0 $ 0 : 00000000 00000065 00000000 00000004 $ 4 : 00000000 00000000 9a82dd60 00000000 $ 8 : 00000000 00000000 a00ae278 00000007 $12 : 0000000e 00000011 804c4228 ffff9411 $16 : 00000100 00000000 80560000 807fc6d0 $20 : 807fc8d0 807fcad0 807fbec0 00000100 $24 : 00009150 80109be0 $28 : 9a82c000 9a82dd28 00000001 8012b3b0 Hi : 00000000 Lo : 00000000 epc : 00000000 (null) Not tainted ra : 8012b3b0 call_timer_fn.isra.39+0x24/0x84 Status: 10009503 KERNEL EXL IE Cause : 00800808 BadVA : 00000000 PrId : 00019c20 (MIPS M14Kc) Modules linked in: Process swapper (pid: 1, threadinfo=9a82c000, task=9a82ba18, tls=00000000) Stack : 00000040 00000000 00000007 8056732c 80580000 00000001 9a82dd60 00200200 80560000 8012b598 8056732c 80580000 00000001 00000000 9a82dd60 9a82dd60 00000000 807fbd44 807fbd40 805664e0 0000000a 80800000 00000004 80125924 0000fda0 000007f0 80000000 00000001 80800000 007f0000 00200140 80166338 00000000 8100fda0 0000fda0 000007f0 80000000 00000001 80800000 007f0000 ... Call Trace: [<8012b598>] run_timer_softirq+0x188/0x1f4 [<80125924>] __do_softirq+0xc4/0x18c [<80166338>] handle_percpu_irq+0x54/0x84 [<80125aa4>] do_softirq+0x68/0x70 [<80103b50>] do_IRQ+0x18/0x28 [<80125d1c>] irq_exit+0x94/0xc0 [<80125aa4>] do_softirq+0x68/0x70 [<80102130>] ret_from_irq+0x0/0x4 [<80102130>] ret_from_irq+0x0/0x4 [<80125d1c>] irq_exit+0x94/0xc0 [<803165b0>] __bzero+0xd4/0x164 [<80346d0c>] mem32_serial_out+0x0/0x1c [<8010d4ac>] free_init_pages+0x98/0xfc [<80180a08>] free_hot_cold_page+0x2c/0x1c4 [<80180bd8>] __free_pages+0x38/0x98 [<8010d4a0>] free_init_pages+0x8c/0xfc [<8010d4ac>] free_init_pages+0x98/0xfc [<8049fb04>] kernel_init+0x28/0x15c [<80147484>] schedule_tail+0x1c/0x60 [<8049fadc>] kernel_init+0x0/0x15c [<80102178>] ret_from_kernel_thread+0x14/0x1c [<8040a06f>] skb_pad+0xe7/0x13c Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: Steve Glendinning <steve.glendinning@shawell.net> Cc: Ben Boeckel <mathstuf@gmail.com> Cc: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Cc: David S. Miller <davem@davemloft.net> Cc: netdev@vger.kernel.org Cc: Jeffrey Deans <Jeffrey.Deans@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/6672/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-18[MIPS] Iomap implementation.Ralf Baechle
This implementation has support for the concept of one separate ioport address space by PCI domain. A pointer to the virtual address where the port space of a domain has been mapped has been added to struct pci_controller and systems should be fixed to fill in this value. For single domain systems this will be the same value as passed to set_io_port_base(). Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-28[MIPS] Fix build error on processors that don's support copy-on-write.Ralf Baechle
2006-01-10Update Yoichi Yuasa's email address.Ralf Baechle
