When building a 32-bit kernel for RBTX4927 with gcc version 4.1.2 20061115
(prerelease) (Ubuntu 4.1.1-21), I get:
arch/mips/lib/delay.c:24:5: warning: "__SIZEOF_LONG__" is not defined
As a consequence, __delay() always uses the 64-bit "dsubu" instruction.
Replace the check for "__SIZEOF_LONG__ == 4" by "BITS_PER_LONG == 32" to
fix this.
Introduced by commit 5210edcd527773c227465ad18e416a894966324f [MIPS: Make
__{,n,u}delay declarations match definitions and generic delay.h"]
Patchwork: https://patchwork.linux-mips.org/patch/4678/
Acked-by: David Daney <david.daney@cavium.com>
At some recent point arch/mips/include/asm/delay.h has started being
included into csrc-octeon.c where the __?delay() functions are defined.
This causes a compile failure due to conflicting declarations and
definitions of the functions.
It turns out that the generic definitions in arch/mips/lib/delay.c also
conflict.
Proposed fix: Declare the functions to take unsigned long parameters
just like asm-generic (and x86) does. Update __delay to agree
(__ndelay and __udelay need no change).
Bonus: Get rid of 'inline' from __delay() definition, as it is globally
visible, and the compiler should be making this decision itself (it does
in fact inline the function without being told to).
Signed-off-by: David Daney <david.daney@cavium.com>
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/4354/
This may lead to warnings like:
BUG: using smp_processor_id() in preemptible [00000000] code: reboot/1989
caller is __udelay+0x14/0x70
Call Trace:
[<ffffffff8110ad28>] dump_stack+0x8/0x34
[<ffffffff812dde04>] debug_smp_processor_id+0xf4/0x110
[<ffffffff812d90bc>] __udelay+0x14/0x70
[<ffffffff81378274>] md_notify_reboot+0x12c/0x148
[<ffffffff81161054>] notifier_call_chain+0x64/0xc8
[<ffffffff811614dc>] __blocking_notifier_call_chain+0x64/0xc0
[<ffffffff8115566c>] kernel_restart_prepare+0x1c/0x38
[<ffffffff811556cc>] kernel_restart+0x14/0x50
[<ffffffff8115581c>] SyS_reboot+0x10c/0x1f0
[<ffffffff81103684>] handle_sysn32+0x44/0x84
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Outlining fixes the issue were on certain CPUs such as the R10000 family
the delay loop would need an extra cycle if it overlaps a cacheline
boundary.
The rewrite also fixes build errors with GCC 4.4 which was changed in
way incompatible with the kernel's inline assembly.
Relying on pure C for computation of the delay value removes the need for
explicit. The price we pay is a slight slowdown of the computation - to
be fixed on another day.
