path: root/arch/mips/lantiq/xway/gptu.c
2017-02-14MIPS: Audit and remove any unnecessary uses of module.hPaul Gortmaker
Historically a lot of these existed because we did not have a distinction between what was modular code and what was providing support to modules via EXPORT_SYMBOL and friends. That changed when we forked out support for the latter into the export.h file. This means we should be able to reduce the usage of module.h in code that is obj-y Makefile or bool Kconfig. In the case of some code where it is modular, we can extend that to also include files that are building basic support functionality but not related to loading or registering the final module; such files also have no need whatsoever for module.h The advantage in removing such instances is that module.h itself sources about 15 other headers; adding significantly to what we feed cpp, and it can obscure what headers we are effectively using. Since module.h might have been the implicit source for init.h (for __init) and for export.h (for EXPORT_SYMBOL) we consider each instance for the presence of either and replace/add as needed. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. Build coverage of all the mips defconfigs revealed the module.h header was masking a couple of implicit include instances, so we add the appropriate headers there. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: David Daney <david.daney@cavium.com> Cc: John Crispin <john@phrozen.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: "Steven J. Hill" <steven.hill@cavium.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/15131/ [james.hogan@imgtec.com: Preserve sort order where it already exists] Signed-off-by: James Hogan <james.hogan@imgtec.com>
2016-05-13MIPS: Change my email addressJohn Crispin
The old address is no longer valid. Use the my new one instead. Signed-off-by: John Crispin <john@phrozen.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/13201/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-10-20mips: lantiq: xway: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-05-18Merge branch 'devm_no_resource_check' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull devm usage cleanup from Wolfram Sang: "Lately, I have been experimenting how to improve the devm interface to make writing device drivers easier and less error prone while also getting rid of its subtle issues. I think it has more potential but still needs work and definately conistency, especiall in its usage. The first thing I come up with is a low hanging fruit regarding devm_ioremap_resouce(). This function already checks if the passed resource is valid and gives an error message if not. So, we can remove similar checks from the drivers and get rid of a bit of code and a number of inconsistent error strings. This series only removes the unneeded check iff devm_ioremap_resource follows platform_get_resource directly. The previous version tried to shuffle code if needed, too, what lead to an embarrasing bug. It turned out to me that shuffling code for all cases found will make the automated script too complex, so I am unsure if an automated cleanup is the proper tool for this case. Removing the easy stuff seems worthwhile to me, though. Despite various architectures and platform dependencies, I managed to compile test 45 out of 57 modified files locally using heuristics and defconfigs." Pulled because: 296 deletions, 0 additions. * 'devm_no_resource_check' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: (33 commits) sound/soc/kirkwood: don't check resource with devm_ioremap_resource sound/soc/fsl: don't check resource with devm_ioremap_resource arch/mips/lantiq/xway: don't check resource with devm_ioremap_resource arch/arm/plat-samsung: don't check resource with devm_ioremap_resource arch/arm/mach-tegra: don't check resource with devm_ioremap_resource drivers/watchdog: don't check resource with devm_ioremap_resource drivers/w1/masters: don't check resource with devm_ioremap_resource drivers/video/omap2/dss: don't check resource with devm_ioremap_resource drivers/video/omap2: don't check resource with devm_ioremap_resource drivers/usb/phy: don't check resource with devm_ioremap_resource drivers/usb/host: don't check resource with devm_ioremap_resource drivers/usb/gadget: don't check resource with devm_ioremap_resource drivers/usb/chipidea: don't check resource with devm_ioremap_resource drivers/thermal: don't check resource with devm_ioremap_resource drivers/staging/nvec: don't check resource with devm_ioremap_resource drivers/staging/dwc2: don't check resource with devm_ioremap_resource drivers/spi: don't check resource with devm_ioremap_resource drivers/rtc: don't check resource with devm_ioremap_resource drivers/pwm: don't check resource with devm_ioremap_resource drivers/pinctrl: don't check resource with devm_ioremap_resource ...
2013-05-18arch/mips/lantiq/xway: don't check resource with devm_ioremap_resourceWolfram Sang
devm_ioremap_resource does sanity checks on the given resource. No need to duplicate this in the driver. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: John Crispin <blogic@openwrt.org>
2013-05-17MIPS: Xway: Fix clk leakLibo Chen
When gptu_r32 fails, we should put clk before returning. Signed-off-by: Libo Chen <libo.chen@huawei.com> Acked-by: John Crispin <blogic@openwrt.org> Cc: grant.likely@linaro.org Cc: rob.herring@calxeda.com, Cc: linux-mips@linux-mips.org Cc: LKML linux-kernel@vger.kernel.org Cc: Andrew Morton akpm@linux-foundation.org Cc: Li Zefan lizefan@huawei.com Patchwork: https://patchwork.linux-mips.org/patch/5247/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-01-25MIPS: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03MIPS: drivers: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-23MIPS: lantiq: adds support for gptu timersJohn Crispin
Lantiq socs have a General Purpose Timer Unit (GPTU). This driver allows us to initialize the timers. The voice firmware needs these timers as a reference. Signed-off-by: John Crispin <blogic@openwrt.org> Patchwork: http://patchwork.linux-mips.org/patch/4236/
