path: root/arch/mips/lantiq/clk.c
2011-12-07MIPS: Fix up inconsistency in panic() string argument.Ralf Baechle
Panic() invokes printk() to add a \n internally, so panic arguments should not themselves end in \n. Panic invocations in arch/mips and elsewhere are inconsistently sometimes terminating in \n, sometimes not. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-11-14MIPS: lantiq: use export.h in favour of module.hJohn Crispin
The code located at arch/mips/lantiq/ included module.h to be able to use the EXPORT_SYMBOL* macros. These can now be directly included using export.h. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2937/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-20MIPS: Lantiq: Add missing clk_enable and clk_disable functions.John Crispin
Signed-of-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2465/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-05-19MIPS: Lantiq: Add initial support for Lantiq SoCsJohn Crispin
Add initial support for Mips based SoCs made by Lantiq. This series will add support for the XWAY family. The series allows booting a minimal system using a initramfs or NOR. Missing drivers and support for Amazon and GPON family will be provided in a later series. [Ralf: Remove some cargo cult programming and fixed formatting.] Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Ralph Hempel <ralph.hempel@lantiq.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2252/ Patchwork: https://patchwork.linux-mips.org/patch/2371/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
