path: root/arch/mips/kernel/vmlinux.lds.S
2011-01-25percpu: align percpu readmostly subsection to cachelineTejun Heo
Currently percpu readmostly subsection may share cachelines with other percpu subsections which may result in unnecessary cacheline bounce and performance degradation. This patch adds @cacheline parameter to PERCPU() and PERCPU_VADDR() linker macros, makes each arch linker scripts specify its cacheline size and use it to align percpu subsections. This is based on Shaohua's x86 only patch. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Shaohua Li <shaohua.li@intel.com>
2011-01-18MIPS: Add generic support for multiple machines within a single kernelGabor Juhos
This patch adds a generic solution to support multiple machines based on a given SoC within a single kernel image. It is implemented already for several other architectures but MIPS has no generic support for that yet. [Ralf: This competes with DT but DT is a much more complex solution and this code has been used by OpenWRT for a long time so for now DT is a bad reason to stop the merge but longer term this should be migrated to DT.] Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: kaloz@openwrt.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1814/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Tracing: Add IRQENTRY_EXIT section for MIPSWu Zhangjin
This patch add a new section for MIPS to record the block of the hardirq handling for function graph tracer(print_graph_irq) via adding the __irq_entry annotation to the the entrypoints of the hardirqs(the block with irq_enter()...irq_exit()). Thanks goes to Steven & Frederic Weisbecker for their feedbacks. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Patchwork: http://patchwork.linux-mips.org/patch/676/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-25mips: fix build of vmlinux.ldsManuel Lauss
Commit 51b563fc93c8cb5bff1d67a0a71c374e4a4ea049 ("arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0") removed a few CPPFLAGS with vital include paths necessary to build vmlinux.lds on MIPS, and moved the calculation of the 'jiffies' symbol directly to vmlinux.lds.S but forgot to change make ifdef/... to cpp macros. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> [sam: moved assignment of CPPFLAGS arch/mips/kernel/Makefile] Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Acked-by: Dmitri Vorobiev <dmitri.vorobiev@movial.com>
2009-09-20arm, cris, mips, sparc, powerpc, um, xtensa: fix build with bash 4.0Sam Ravnborg
Albin Tonnerre <albin.tonnerre@free-electrons.com> reported: Bash 4 filters out variables which contain a dot in them. This happends to be the case of CPPFLAGS_vmlinux.lds. This is rather unfortunate, as it now causes build failures when using SHELL=/bin/bash to compile, or when bash happens to be used by make (eg when it's /bin/sh) Remove the common definition of CPPFLAGS_vmlinux.lds by pushing relevant stuff to either Makefile.build or the arch specific kernel/Makefile where we build the linker script. This is also nice cleanup as we move the information out where it is used. Notes for the different architectures touched: arm - we use an already exported symbol cris - we use a config symbol aleady available [Not build tested] mips - the jiffies complexity has moved to vmlinux.lds.S where we need it. Added a few variables to CPPFLAGS - they are only used by the linker script. [Not build tested] powerpc - removed assignment that is not needed [not build tested] sparc - simplified it using $(BITS) um - introduced a few new exported variables to deal with this xtensa - added options to CPP invocation [not build tested] Cc: Albin Tonnerre <albin.tonnerre@free-electrons.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2009-09-17MIPS: Clean up linker script using new linker script macros.Nelson Elhage
This patch results in fewer output sections and in some data being reordered, but should have no functional impact. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: Use PAGE_SIZE in assembly instead of _PAGE_SIZE.Nelson Elhage
Now that PAGE_SIZE is available to assembly directly, there is no need to separately expose it as _PAGE_SIZE through asm-offsets. In addition, remove _PAGE_SHIFT from asm-offsets, since it was never needed, and is not used anywhere. Signed-off-by: Nelson Elhage <nelhage@ksplice.com> Signed-off-by: Tim Abbott <tabbott@ksplice.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-07-09linker script: unify usage of discard definitionTejun Heo
Discarded sections in different archs share some commonality but have considerable differences. This led to linker script for each arch implementing its own /DISCARD/ definition, which makes maintaining tedious and adding new entries error-prone. This patch makes all linker scripts to move discard definitions to the end of the linker script and use the common DISCARDS macro. As ld uses the first matching section definition, archs can include default discarded sections by including them earlier in the linker script. ia64 is notable because it first throws away some ia64 specific subsections and then include the rest of the sections into the final image, so those sections must be discarded before the inclusion. defconfig compile tested for x86, x86-64, powerpc, powerpc64, ia64, alpha, sparc, sparc64 and s390. Michal Simek tested microblaze. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Paul Mundt <lethal@linux-sh.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Tested-by: Michal Simek <monstr@monstr.eu> Cc: linux-arch@vger.kernel.org Cc: Michal Simek <monstr@monstr.eu> Cc: microblaze-uclinux@itee.uq.edu.au Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Tony Luck <tony.luck@intel.com>
2009-06-24linker script: throw away .discard sectionTejun Heo
x86 throws away .discard section but no other archs do. Also, .discard is not thrown away while linking modules. Make every arch and module linking throw it away. This will be used to define dummy variables for percpu declarations and definitions. This patch is based on Ivan Kokshaysky's alpha percpu patch. [ Impact: always throw away everything in .discard ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Richard Henderson <rth@twiddle.net> Cc: Russell King <linux@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Bryan Wu <cooloney@kernel.org> Cc: Mikael Starvik <starvik@axis.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: David Howells <dhowells@redhat.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Michal Simek <monstr@monstr.eu> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Chris Zankel <chris@zankel.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Ingo Molnar <mingo@elte.hu>
2008-10-15MIPS: Align .data.cacheline_aligned based on CONFIG_MIPS_L1_CACHE_SHIFTDavid Daney
Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-09-21[MIPS] vmlinux.lds.S: handle .text.*Atsushi Nemoto
The -ffunction-sections puts each text in .text.function_name section. Without this patch, most functions are placed outside _text..._etext area and it breaks show_stacktrace(), etc. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-28all archs: consolidate init and exit sections in vmlinux.lds.hSam Ravnborg
This patch consolidate all definitions of .init.text, .init.data and .exit.text, .exit.data section definitions in the generic vmlinux.lds.h. This is a preparational patch - alone it does not buy us much good. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-10-29[MIPS] vmlinux.ld.S: correctly indent .data sectionFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-16[MIPS] vmlinux.lds.S: Handle KPROBES_TEXT.Ralf Baechle
2007-10-16[MIPS] vmlinux.lds.S: Fix handling of .notes in final link.Ralf Baechle
2007-10-16[MIPS] vmlinux.lds.S: Remove duplicate comment.Ralf Baechle
2007-10-11[MIPS] Introduce a consistent style for vmlinux.lds.Sam Ravnborg
This style will be consitent with all other arch's - soon. In addition: - Moved a few labels inside brackets for the sections they specify to prevent that linker alignmnet made them point before the section start Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-01[MIPS] vmlinux.lds.S: Handle note sectionsMaciej W. Rozycki
Store any note sections after the exception tables like the other architectures do. This is required for .note.gnu.build-id emitted from binutils 2.18 onwards if nothing else. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] Do not discard extra debugging sections.Daniel Jacobowitz
Leaving these sections is useful to some tools that look at the image, and none of them are loaded into memory. The .mdebug.abi64 section, in particular, lets GDB recognize vmlinux.32 as an N64 program instead of guessing that it is O32. Signed-off-by: Daniel Jacobowitz <dan@codesourcery.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-19define new percpu interface for shared dataFenghua Yu
per cpu data section contains two types of data. One set which is exclusively accessed by the local cpu and the other set which is per cpu, but also shared by remote cpus. In the current kernel, these two sets are not clearely separated out. This can potentially cause the same data cacheline shared between the two sets of data, which will result in unnecessary bouncing of the cacheline between cpus. One way to fix the problem is to cacheline align the remotely accessed per cpu data, both at the beginning and at the end. Because of the padding at both ends, this will likely cause some memory wastage and also the interface to achieve this is not clean. This patch: Moves the remotely accessed per cpu data (which is currently marked as ____cacheline_aligned_in_smp) into a different section, where all the data elements are cacheline aligned. And as such, this differentiates the local only data and remotely accessed data cleanly. Signed-off-by: Fenghua Yu <fenghua.yu@intel.com> Acked-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Christoph Lameter <clameter@sgi.com> Cc: <linux-arch@vger.kernel.org> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-19all-archs: consolidate .data section definition in asm-genericSam Ravnborg
With this consolidation we can now modify the .data section definition in one spot for all archs. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-19all-archs: consolidate .text section definition in asm-genericSam Ravnborg
Move definition of .text section to asm-generic. Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2007-05-02[PATCH] x86: Allow percpu variables to be page-alignedJeremy Fitzhardinge
Let's allow page-alignment in general for per-cpu data (wanted by Xen, and Ingo suggested KVM as well). Because larger alignments can use more room, we increase the max per-cpu memory to 64k rather than 32k: it's getting a little tight. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2007-02-11[PATCH] disable init/initramfs.c: architecturesJean-Paul Saman
Update all arch/*/kernel/vmlinux.lds.S to not include space for initramfs when CONFIG_BLK_DEV_INITRAMFS is not selected. This saves another 4 kbytes on most platfoms (some reserve PAGE_SIZE for initramfs). Signed-off-by: Jean-Paul Saman <jean-paul.saman@nxp.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-12[MIPS] Discard .exit.text and .exit.data at runtime.Ralf Baechle
While the recent cset 86384d544157db23879064cde36061cdcafc6794 did improve things it didn't resolve all the problems. So bite the bullet and discard .exit.text and .exit.data at runtime. Which of course sucks because it bloats binaries with code that will never ever be used but it's the only thing that will work reliable as demonstrated by the function sd_major() in drivers/scsi/sd.c. Gcc may compile sd_major() using a jump table which it will put into .rodata. If it also inlines sd_major's function body into exit_sd() which gcc > 3.4.x does. If CONFIG_BLK_DEV_SD has been set to y we would like ld to discard exit_sd's code at link time. However sd_major happens to contain a switch statement which gcc will compile using a jump table in .rodata on the architectures I checked. So, when ld later discards .exit.text only the jump table in .rodata with its stale references to the discard .exit.text will be left which any no antique ld will honor with a link error. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-12-10[MIPS] Discard .exit.text at linktime.Ralf Baechle
This fixes fairly unobvious breakage of various drivers. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-01[MIPS] 16K & 64K page size fixesRalf Baechle
Derived from Peter Watkins <treestem@gmail.com>'s work. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-27[PATCH] vmlinux.lds: consolidate initcall sectionsAndrew Morton
Add a vmlinux.lds.h helper macro for defining the eight-level initcall table, teach all the architectures to use it. This is a prerequisite for a patch which performs initcall synchronisation for multithreaded-probing. Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> [ Added AVR32 as well ] Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-01[MIPS] Use generic STABS_DEBUG macro.Atsushi Nemoto
2006-06-01[MIPS] Use generic DWARF_DEBUGAtsushi Nemoto
When debugging a kernel compiled by gcc 4.1 with gdb 6.4, gdb could not show filename, linenumber, etc. It seems fixed if I used generic DWARF_DEBUG macro. Although gcc 3.x seems work without this change, it would be better to use the generic macro unless there were something MIPS specific. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-03-09[MIPS] Discard .exit.text at runtime.Ralf Baechle
At times gcc will place bits of __exit functions into .rodata. If compiled into the kernle itself we used to discard .exit.text - but not the bits left in .rodata. While harmless this did at times result in a large number of warnings. So until gcc fixes this, discard .exit.text at runtime. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-07[MIPS] Fix linker script to work for non-4K page size.Ralf Baechle
Very much to my surprise Fuxin Zhang reports this is all it takes to get the kernel to work for page sizes larger than 4kB. This also paves the way for support for the R6000 and R8000 which don't support 4kB page size. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Get rid of the the remains of 2.4-style ramdisk support.Ralf Baechle
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
