path: root/arch/mips/kernel/smtc.c
2012-07-23MIPS: SMTC: Support for Multi-threaded FPUsSteven J. Hill
Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/3603/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-19MIPS: SMTC: delay irq enable to ->smp_finish()Yong Zhang
To prepare for smoothing set_cpu_[active|online]() mess up Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Cc: Sergei Shtylyov <sshtylyov@mvista.com> Cc: David Daney <david.daney@cavium.com> Acked-by: David Daney <david.daney@cavium.com> Patchwork: https://patchwork.linux-mips.org/patch/3847/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-07-19MIPS: SMTC: Spelling and grammar corrections.Ralf Baechle
Extractd from Steven J. Hill's https://patchwork.linux-mips.org/patch/3603/. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-29remove references to cpu_*_map in arch/Rusty Russell
This has been obsolescent for a while; time for the final push. In adjacent context, replaced old cpus_* with cpumask_*. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc) Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile) Cc: user-mode-linux-devel@lists.sourceforge.net Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: sparclinux@vger.kernel.org
2012-03-28Disintegrate asm/system.h for MIPSDavid Howells
Disintegrate asm/system.h for MIPS. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> cc: linux-mips@linux-mips.org
2012-01-11Merge branch 'next/generic' into mips-for-linux-nextRalf Baechle
2011-12-07MIPS: irq: Remove IRQF_DISABLEDYong Zhang
Since commit [e58aa3d2: genirq: Run irq handlers with interrupts disabled], We run all interrupt handlers with interrupts disabled and we even check and yell when an interrupt handler returns with interrupts enabled (see commit [b738a50a: genirq: Warn when handler enables interrupts]). So now this flag is a NOOP and can be removed. [ralf@linux-mips.org: Fixed up conflicts in arch/mips/alchemy/common/dbdma.c, arch/mips/cavium-octeon/smp.c and arch/mips/kernel/perf_event.c.] Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> To: linux-kernel@vger.kernel.org Cc: tglx@linutronix.de linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2835/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS: Fix up inconsistency in panic() string argument.Ralf Baechle
Panic() invokes printk() to add a \n internally, so panic arguments should not themselves end in \n. Panic invocations in arch/mips and elsewhere are inconsistently sometimes terminating in \n, sometimes not. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-14sched: Provide scheduler_ipi() callback in response to smp_send_reschedule()Peter Zijlstra
For future rework of try_to_wake_up() we'd like to push part of that function onto the CPU the task is actually going to run on. In order to do so we need a generic callback from the existing scheduler IPI. This patch introduces such a generic callback: scheduler_ipi() and implements it as a NOP. BenH notes: PowerPC might use this IPI on offline CPUs under rare conditions! Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Acked-by: Chris Metcalf <cmetcalf@tilera.com> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.744338123@chello.nl
2011-03-29MIPS: Convert the irq functions to the new namesThomas Gleixner
Scripted with coccinelle. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25MIPS: SMTC: Cleanup the hook mess and use irq_dataThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2194/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-03-25MIPS: SMTC: Use irq_data in smtc_forward_irq()Thomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2193/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-07Fix IRQ flag handling namingDavid Howells
Fix the IRQ flag handling naming. In linux/irqflags.h under one configuration, it maps: local_irq_enable() -> raw_local_irq_enable() local_irq_disable() -> raw_local_irq_disable() local_irq_save() -> raw_local_irq_save() ... and under the other configuration, it maps: raw_local_irq_enable() -> local_irq_enable() raw_local_irq_disable() -> local_irq_disable() raw_local_irq_save() -> local_irq_save() ... This is quite confusing. There should be one set of names expected of the arch, and this should be wrapped to give another set of names that are expected by users of this facility. Change this to have the arch provide: flags = arch_local_save_flags() flags = arch_local_irq_save() arch_local_irq_restore(flags) arch_local_irq_disable() arch_local_irq_enable() arch_irqs_disabled_flags(flags) arch_irqs_disabled() arch_safe_halt() Then linux/irqflags.h wraps these to provide: raw_local_save_flags(flags) raw_local_irq_save(flags) raw_local_irq_restore(flags) raw_local_irq_disable() raw_local_irq_enable() raw_irqs_disabled_flags(flags) raw_irqs_disabled() raw_safe_halt() with type checking on the flags 'arguments', and then wraps those to provide: local_save_flags(flags) local_irq_save(flags) local_irq_restore(flags) local_irq_disable() local_irq_enable() irqs_disabled_flags(flags) irqs_disabled() safe_halt() with tracing included if enabled. The arch functions can now all be inline functions rather than some of them having to be macros. Signed-off-by: David Howells <dhowells@redhat.com> [X86, FRV, MN10300] Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> [Tile] Signed-off-by: Michal Simek <monstr@monstr.eu> [Microblaze] Tested-by: Catalin Marinas <catalin.marinas@arm.com> [ARM] Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> [AVR] Acked-by: Tony Luck <tony.luck@intel.com> [IA-64] Acked-by: Hirokazu Takata <takata@linux-m32r.org> [M32R] Acked-by: Greg Ungerer <gerg@uclinux.org> [M68K/M68KNOMMU] Acked-by: Ralf Baechle <ralf@linux-mips.org> [MIPS] Acked-by: Kyle McMartin <kyle@mcmartin.ca> [PA-RISC] Acked-by: Paul Mackerras <paulus@samba.org> [PowerPC] Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> [S390] Acked-by: Chen Liqin <liqin.chen@sunplusct.com> [Score] Acked-by: Matt Fleming <matt@console-pimps.org> [SH] Acked-by: David S. Miller <davem@davemloft.net> [Sparc] Acked-by: Chris Zankel <chris@zankel.net> [Xtensa] Reviewed-by: Richard Henderson <rth@twiddle.net> [Alpha] Reviewed-by: Yoshinori Sato <ysato@users.sourceforge.jp> [H8300] Cc: starvik@axis.com [CRIS] Cc: jesper.nilsson@axis.com [CRIS] Cc: linux-cris-kernel@axis.com
2010-08-05MIPS: SMTC: Use %p to format pointersKulikov Vasiliy
While at it, drop 0x prefix. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> To: kernel-janitors@vger.kernel.org Cc: Chris Dearman <chris@mips.com> Cc: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: André Goddard Rosa <andre.goddard@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1458/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Initialize an atomic_t properly with ATOMIC_INIT(0).Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> To: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/1008/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-12-17MIPS: Tracing: Add IRQENTRY_EXIT section for MIPSWu Zhangjin
This patch add a new section for MIPS to record the block of the hardirq handling for function graph tracer(print_graph_irq) via adding the __irq_entry annotation to the the entrypoints of the hardirqs(the block with irq_enter()...irq_exit()). Thanks goes to Steven & Frederic Weisbecker for their feedbacks. Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Nicholas Mc Guire <der.herr@hofr.at> Cc: zhangfx@lemote.com Cc: Wu Zhangjin <wuzhangjin@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Reviewed-by: Frederic Weisbecker <fweisbec@gmail.com> Patchwork: http://patchwork.linux-mips.org/patch/676/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-02MIPS: SMTC: Avoid queing multiple reschedule IPIsJaidev Patwardhan
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-30MIPS: SMTC: Remove duplicate structure field initializationJulia Lawall
The definition of the irq_ipi structure has two initializations of the flags field. This combines them. [Ralf: The issue was originally introduced by commit be4894196d79455f420dd7bb78be7dc73bec115c (linux-mips.org) rsp. 033890b084adfa367c544864451d7730552ce8bf (kernel.org). The original intention of the code was to initialize .flags with both flags ored together. The broken C code as actually implemented will be compiled by an equally broken gcc to use only the last initialization, that is IRQF_PERCPU which means this turned into an SMTC bug for 2.6.23 and newer.] The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier I, s, fld; position p0,p; expression E; @@ struct I s =@p0 { ... .fld@p = E, ...}; @s@ identifier I, s, r.fld; position r.p0,p; expression E; @@ struct I s =@p0 { ... .fld@p = E, ...}; @script:python@ p0 << r.p0; fld << r.fld; ps << s.p; pr << r.p; @@ if int(ps[0].line)!=int(pr[0].line) or int(ps[0].column)!=int(pr[0].column): cocci.print_main(fld,p0) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-24cpumask: Use accessors for cpu_*_mask: mipsRusty Russell
Use the accessors rather than frobbing bits directly (the new versions are const). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com>
2009-09-17MIPS: Remove useless zero initializations.Ralf Baechle
2009-08-03MIPS: SMTC: Move cross VPE writes to after a TC is assigned to VPE.Kurt Martin
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Raghu Gandham <raghu@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-24MIPS: Build fix - include <linux/smp.h> into all smp_processor_id() users.Ralf Baechle
Some of the were relying into smp.h being dragged in by another header which of course is fragile. <asm/cpu-info.h> uses smp_processor_id() only in macros and including smp.h there leads to an include loop, so don't change cpu-info.h. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-06-17MIPS: SMTC: Fix formatting difference to linux-mips.org codeRalf Baechle
2009-01-15irq: update all arches for new irq_desc, fixMike Travis
Impact: fix build errors Since the SPARSE IRQS changes redefined how the kstat irqs are organized, arch's must use the new accessor function: kstat_incr_irqs_this_cpu(irq, DESC); If CONFIG_SPARSE_IRQS is set, then DESC is a pointer to the irq_desc which has a pointer to the kstat_irqs. If not, then the .irqs field of struct kernel_stat is used instead. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-12irq: update all arches for new irq_descMike Travis
Impact: cleanup, update to new cpumask API Irq_desc.affinity and irq_desc.pending_mask are now cpumask_var_t's so access to them should be using the new cpumask API. Signed-off-by: Mike Travis <travis@sgi.com>
2008-12-13cpumask: centralize cpu_online_map and cpu_possible_mapRusty Russell
Impact: cleanup Each SMP arch defines these themselves. Move them to a central location. Twists: 1) Some archs (m32, parisc, s390) set possible_map to all 1, so we add a CONFIG_INIT_ALL_POSSIBLE for this rather than break them. 2) mips and sparc32 '#define cpu_possible_map phys_cpu_present_map'. Those archs simply have phys_cpu_present_map replaced everywhere. 3) Alpha defined cpu_possible_map to cpu_present_map; this is tricky so I just manipulate them both in sync. 4) IA64, cris and m32r have gratuitous 'extern cpumask_t cpu_possible_map' declarations. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Tested-by: Tony Luck <tony.luck@intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Mike Travis <travis@sgi.com> Cc: ink@jurassic.park.msu.ru Cc: rmk@arm.linux.org.uk Cc: starvik@axis.com Cc: tony.luck@intel.com Cc: takata@linux-m32r.org Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: paulus@samba.org Cc: schwidefsky@de.ibm.com Cc: lethal@linux-sh.org Cc: wli@holomorphy.com Cc: davem@davemloft.net Cc: jdike@addtoit.com Cc: mingo@redhat.com
2008-10-03[MIPS] SMTC: Fix SMTC dyntick support.Kevin D. Kissell
Rework of SMTC support to make it work with the new clock event system, allowing "tickless" operation, and to make it compatible with the use of the "wait_irqoff" idle loop. The new clocking scheme means that the previously optional IPI instant replay mechanism is now required, and has been made more robust. Signed-off-by: Kevin D. Kissell <kevink@paralogos.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-03[MIPS] SMTC: Close tiny holes in the SMTC IPI replay system.Kevin D. Kissell
2008-10-03[MIPS] Build fix: Fix irq flags typeRalf Baechle
Though from a hardware perspective it would be sensible to use only a 32-bit unsigned int type Linux defines interrupt flags to be stored in an unsigned long and nothing else. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-06-26mips: convert to generic helpers for IPI function callsJens Axboe
This converts mips to use the new helpers for smp_call_function() and friends, and adds support for smp_call_function_single(). Not tested, but it compiles. mips shares the same IPI for smp_call_function() and smp_call_function_single(), since not all mips platforms have enough available IPIs to support seperate setups. Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-28[MIPS] Add support for MIPS CMP platform.Ralf Baechle
Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-04-28[MIPS] Remove TLB sanitation codeChris Dearman
It is not being used by Malta and shouldn't be needed for MIPSsim. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-02-03arch/mips/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-29[MIPS] SMP: Call platform methods via ops structure.Ralf Baechle
2007-10-29[MIPS] SMTC: Allow control over TC assignment to vpe0.Kevin D. Kissell
Modify the SMTC initialization code to allow boot-time specification not only of how many VPEs and TCs to use, but also how many TCs out of the allowed pool are to be bound to VPE 0. The new boot option is "vpe0tcs=N", where N is an integer. Using it in combination with the existing options allows arbitrary assignments across the 2 VPEs of a 34K. e.g. "maxtcs=3 vpe0tcs=1" forces VPE0 to have 1 TC, while VPE1 has 2, and "maxtcs=4 vpe0tcs=3" forces VPE0 to have 3 TCs, while VPE1 gets 1. If no vpe0tcs option is specified, the traditional algorithm of evenly dividing TCs between available VPEs, with the odd "slop" going to VPE0, is retained. The reason for doing this is to allow a finer balancing of TCs which can handle I/O interrupts on Malta (those on VPE 0) and those which cannot. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Kill num_online_cpus() loops.Ralf Baechle
2007-10-11[MIPS] checkfiles: Fix "need space after that ','" errors.Ralf Baechle
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-10-11[MIPS] Dyntick support for SMTC:Ralf Baechle
The kernel currently only supports broadcasting of the timer interrupt from a single timer, not multicasting into two multicast groups of processors. So the implemented mechanism for SMTC works by broadcasting the cp0 compare interrupt on VPE 0 and ignoring it on any additional VPEs. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Implement clockevents for R4000-style cp0 count/compare interruptRalf Baechle
2007-10-11[MIPS] Consolidate all variants of MIPS cp0 timer interrupt handlers.Ralf Baechle
2007-10-11[MIPS] SMTC: Microoptimize atomic_postincrement for non-weak consistency.Ralf Baechle
2007-10-11[MIPS] IRQ Affinity Support for SMTC on Malta PlatformKevin D. Kissell
Signed-off-by: Kevin D. Kissell <kevink@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-09-24[MIPS] SMTC: Make ack_bad_irq() safe with no IM backstop.Ralf Baechle
Issue reported and original patch by Kevin Kissel, cleaner (imho) implementation by me. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-08-27[MIPS] SMTC: Move MIPS_CPU_IPI_IRQ definition into header.Ralf Baechle
2007-07-31[MIPS] SMTC: Fix modpost warning.Ralf Baechle
WARNING: vmlinux.o(.text+0xcf54): Section mismatch: reference to .init.text:smp_bootstrap (between 'smtc_boot_secondary' and 'ipi_interrupt') Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-31[MIPS] MT: Enable coexistence of AP/SP with VSMP and SMTC.Ralf Baechle
