path: root/arch/mips/kernel/signal32.c
2009-02-27MIPS: CVE-2009-0029: Enable syscall wrappers.Ralf Baechle
Thanks to David Daney helping with debugging and testing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: David Daney <ddaney@caviumnetworks.com>
2008-10-11MIPS: Use compat_sys_ptraceThomas Bogendoerfer
This replaces mips's sys_ptrace32 with a compat_arch_ptrace and enables the new generic definition of compat_sys_ptrace instead. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Fix "no space between function name and open parenthesis" warnings.Ralf Baechle
2007-07-31[MIPS] remove some duplicate includesJesper Juhl
This patch removes some duplicate includes from arch/mips/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-06-26[MIPS] use compat_siginfo in rt_sigframe_n32Pavel Kiryukhin
Signed-off-by: Pavel Kiryukhin <vksavl@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-20[MIPS] Retry {save,restore}_fp_context if failed in atomic context.Atsushi Nemoto
The save_fp_context()/restore_fp_context() might sleep on accessing user stack and therefore might lose FPU ownership in middle of them. If these function failed due to "in_atomic" test in do_page_fault, touch the sigcontext area in non-atomic context and retry these save/restore operation. This is a replacement of a (broken) fix which was titled "Allow CpU exception in kernel partially". Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-20[MIPS] Disallow CpU exception in kernel again.Atsushi Nemoto
The commit 4d40bff7110e9e1a97ff8c01bdd6350e9867cc10 ("Allow CpU exception in kernel partially") was broken. The commit was to fix theoretical problem but broke usual case. Revert it for now. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-17[MIPS] FPU ownership management & preemption fixesAtsushi Nemoto
2007-03-17[MIPS] Check FCSR for pending interrupts, alternative versionAtsushi Nemoto
Commit 6d6671066a311703bca1b91645bb1e04cc983387 is incomplete and misses non-r4k CPUs. This patch reverts the commit and fixes in other way. o Do FCSR checking in caller of restore_fp_context. o Send SIGFPE if the signal handler set any FPU exception bits. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[MIPS] sigset_32 has been made redundand by compat_sigset_t.Ralf Baechle
2007-02-18[MIPS] signals: Share even more code.Ralf Baechle
native and compat do_signal and handle_signal are identical and can easily be unified. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-18[MIPS] Fix sigset_t endianess swapping issues in 32-bit compat code.Atsushi Nemoto
access_ok in compat-signal.h is wrong (checking destination instead of source) and redundant (already checked before calling this function). Also sf_mask in struct sigframe32 should be compat_sigset_t type. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] Fix sigset_t endianess swapping issues in 32-bit compat code.Ralf Baechle
2007-02-13[MIPS] signals: make common _BLOCKABLE macroFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] signal: Fix warnings in o32 compat code.Ralf Baechle
2007-02-10[MIPS] signal: do not use save_static_function() anymoreFranck Bui-Huu
This macro was used to save static registers before calling sys_sigsuspend() and sys_sigreturn(). For the sys_sigreturn() case, there's no point to save them since they have been already saved by setup_sigcontext() before calling the signal handler. For the sys_sigsuspend() case, I don't see any reasons... Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-10[MIPS] signal32: no need to save c0_status register in setup_sigcontext32()Franck Bui-Huu
All the information in the MIPS c0_status register is priviledged. Nothing that would constitute part of the thread context. The one flag one could possibly argument about might be c0_status.fr but none of the ABIs or tools or application software can make use of it. So for consistency with restore_sigcontext32(), which does not restore c0_status register, this patch remove the saving part. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-10[MIPS] signal32: reduce {setup,restore}_sigcontext32 sizesFranck Bui-Huu
This trivial changes should decrease a lot the size of these 2 functions. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-10[MIPS] signal: factorize debug codeFranck Bui-Huu
2007-02-10[MIPS] signal32: remove duplicate codeFranck Bui-Huu
There's no point for signal32.c to redefine get_sigframe(). It should use the one define in signal.c instead. The same stands for install_sigtramp(). Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-10[MIPS] signal: clean up sigframe structureFranck Bui-Huu
This patch makes 'struct sigframe' declaration avalaible for all signals code. It allows signal32 to not have its own declaration. This patch also removes all ICACHE_REFILLS_WORKAROUND_WAR tests in structure declaration and hopefully make them more readable. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Avoid double signal restarting.Ralf Baechle
In entry.S resume_userspace ... jal do_notify_resume form a loop through which the kernel will iterate as long as work is pending. If we iterate through this loop more than once with no signal pending for at least one but the last iteration we will take do the syscall restarting multiple times resulting in a syscall return prior to the the syscall instruction in userspace. This may happen when debugging a multithreaded program. Debugging and original fix by Maciej; extended to other ABIs by me. Signed-off-by: Maciej W. Rozycki <macro@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-09-27[MIPS] Add missing returns in signal code.Ralf Baechle
2006-09-27[MIPS] Don't call try_to_freeze in do_signal & co.Ralf Baechle
2006-03-21[MIPS] War on whitespace: cleanup initial spaces followed by tabs.Ralf Baechle
2006-03-21[MIPS] Signal cleanupAtsushi Nemoto
Move function prototypes to asm/signal.h to detect trivial errors and add some __user tags to get rid of sparse warnings. Generated code should not be changed. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] Reformat all of signal32.c with tabs instead of space for consistencyMartin Michlmayr
Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-21[MIPS] Reformat _sys32_rt_sigsuspend with tabs instead of space for consistency.Ralf Baechle
2006-02-21[MIPS] Make do_signal32 return void.Martin Michlmayr
do_signal has been changed to return void since the "return value is ignored everywhere". Convert do_signal32 accordingly. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-21[MIPS] Add support for TIF_RESTORE_SIGMASK for signal32Martin Michlmayr
Following the recent implementation of TIF_RESTORE_SIGMASK in arch/mips/kernel/signal.c, 64-bit kernels with 32-bit user-land compatibility oops when starting init. signal32.c needs to be converted to use TIF_RESTORE_SIGMASK too. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-14[MIPS] Fix typo in _sys32_rt_sigreturn and _sysn32_rt_sigreturn.Atsushi Nemoto
2006-02-08[MIPS] Add support for TIF_RESTORE_SIGMASK.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-02-07[MIPS] Fix minor sparse warningsAtsushi Nemoto
2006-02-07[MIPS] Sparse: Add some __user tags to signal functions.Atsushi Nemoto
2006-01-10MIPS: DSP: Put DSPcontrol register into the right place in the signal frame.Ralf Baechle
2005-12-01[MIPS] Avoid duplicate do_syscall_trace calls on return from sigreturn.Ralf Baechle
2005-11-07Fix return type of setup_frame variantsAtsushi Nemoto
Since 2.6.13-rc1 setup_frame and its variants return int. But some bits were missed in the conversion. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Setup_frame is now returning a success value.Ralf Baechle
2005-10-29Redo RM9000 workaround which along with other DSP ASE changes wasRalf Baechle
causing some headache for debuggers knowing about signal frames. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29We pass a kernel pointer to do_sigaltstack in sys32_sigaltstack, soRalf Baechle
we need to do the set_fs(KERNEL_DS) thing around this call. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Use compat_sigval_t in struct compat_siginfo.Ralf Baechle
2005-10-29Gcc 4.0 fixes.Ralf Baechle
2005-10-29Update to match the native siginfo structure and code.Ralf Baechle
2005-10-29Implement 32-bit compatibility for waitid(2).Ralf Baechle
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-29[PATCH] convert signal handling of NODEFER to act like other Unix boxes.Steven Rostedt
It has been reported that the way Linux handles NODEFER for signals is not consistent with the way other Unix boxes handle it. I've written a program to test the behavior of how this flag affects signals and had several reports from people who ran this on various Unix boxes, confirming that Linux seems to be unique on the way this is handled. The way NODEFER affects signals on other Unix boxes is as follows: 1) If NODEFER is set, other signals in sa_mask are still blocked. 2) If NODEFER is set and the signal is in sa_mask, then the signal is still blocked. (Note: this is the behavior of all tested but Linux _and_ NetBSD 2.0 *). The way NODEFER affects signals on Linux: 1) If NODEFER is set, other signals are _not_ blocked regardless of sa_mask (Even NetBSD doesn't do this). 2) If NODEFER is set and the signal is in sa_mask, then the signal being handled is not blocked. The patch converts signal handling in all current Linux architectures to the way most Unix boxes work. Unix boxes that were tested: DU4, AIX 5.2, Irix 6.5, NetBSD 2.0, SFU 3.5 on WinXP, AIX 5.3, Mac OSX, and of course Linux 2.6.13-rcX. * NetBSD was the only other Unix to behave like Linux on point #2. The main concern was brought up by point #1 which even NetBSD isn't like Linux. So with this patch, we leave NetBSD as the lonely one that behaves differently here with #2. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] try_to_freeze() call fixesNigel Cunningham
Here are fixes for four try_to_freeze calls that are still (incorrectly) using a parameter after the recent try_to_freeze() changes. Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
