path: root/arch/mips/kernel/scall32-o32.S
2006-04-19[MIPS] FPU affinity for MT ASE.Ralf Baechle
2006-04-19[MIPS] Wire up sync_file_range(2).Ralf Baechle
2006-04-19[MIPS] Wire splice syscall.Ralf Baechle
2006-02-24[PATCH] flags parameter for linkatUlrich Drepper
I'm currently at the POSIX meeting and one thing covered was the incompatibility of Linux's link() with the POSIX definition. The name. Linux does not follow symlinks, POSIX requires it does. Even if somebody thinks this is a good default behavior we cannot change this because it would break the ABI. But the fact remains that some application might want this behavior. We have one chance to help implementing this without breaking the behavior. For this we could use the new linkat interface which would need a new flags parameter. If the new parameter is AT_SYMLINK_FOLLOW the new behavior could be invoked. I do not want to introduce such a patch now. But we could add the parameter now, just don't use it. The patch below would do this. Can we get this late patch applied before the release more or less fixes the syscall API? Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-13[PATCH] MIPS 32bit machines need fstatat64 support.Yoichi Yuasa
As noted by Jan Dittmer <jdi@l4x.org> Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08[MIPS] Wire up new syscalls.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2005-12-01[MIPS] Fix register handling in syscalls when debugging.Ralf Baechle
2005-12-01[MIPS] Fix return path of sysmips(MIPS_ATOMIC_SET, ...)Ralf Baechle
The way we were doing things does no longer work on 2.6. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Sys_lookup_dcookie arguments occupy 4 argument slots.Ralf Baechle
2005-10-29Add inotify syscalls for MIPS.Ralf Baechle
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29NPTL, round one.Ralf Baechle
2005-10-29sys_futex has 6 arguments.Thiemo Seufer
Signed-off-by: Thiemo Seufer <ths@networkno.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Waitid(2) now has 5 arguments.Ralf Baechle
2005-09-09kbuild: mips use generic asm-offsets.h supportSam Ravnborg
Removed obsolete stuff from arch makefile. mips had a special rule for generating asm-offsets.h so preserved it using an architecture specific hook in top-level Kbuild file. Renamed .h file to asm-offsets.h Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
