path: root/arch/mips/kernel/proc.c
2013-03-13MIPS: Fix inconsistent formatting inside /proc/cpuinfoJohn Crispin
There is a missing " " inside /proc/cpuinfo. The bad commit was: commit a96102be700f87283f168942cd09a2b30f86f324 Author: Steven J. Hill <sjhill@mips.com> Date: Fri Dec 7 04:31:36 2012 +0000 MIPS: Add printing of ISA version in cpuinfo. Signed-off-by: John Crispin <blogic@openwrt.org> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/4988/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-02-21Merge branch 'mips-next-3.9' of ↵Ralf Baechle
git://git.linux-mips.org/pub/scm/john/linux-john into mips-for-linux-next
2013-02-19MIPS: Probe for and report hardware virtualization support.David Daney
The presence of the MIPS Virtualization Application-Specific Extension is indicated by CP0_Config3[23]. Probe for this and report it in /proc/cpuinfo. Signed-off-by: David Daney <david.daney@cavium.com> Patchwork: http://patchwork.linux-mips.org/patch/4904/ Signed-off-by: John Crispin <blogic@openwrt.org>
2013-02-17MIPS: Add support for the M14KEc core.Steven J. Hill
Signed-off-by: Steven J. Hill <sjhill@mips.com> Patchwork: http://patchwork.linux-mips.org/patch/4682/ Signed-off-by: John Crispin <blogic@openwrt.org>
2013-02-15MIPS: Add printing of ISA version in cpuinfo.Steven J. Hill
Display the MIPS ISA version release in the /proc/cpuinfo file. [ralf@linux-mips.org: Add support for MIPS I ... IV legacy architecture revisions. Also differenciate between MIPS32 and MIPS64 versions instead of lumping them together as just r1 and r2. Note to application programmers: this indicates the CPU's ISA level It does not imply the current execution environment does support it. For example an O32 application seeing "mips64r2" would still be restricted by by the execution environment to 32-bit - but the kernel could run mips64r2 code. The same for a 32-bit kernel running on a 64-bit processor. This field doesn't include ASEs or optional architecture modules nor other detailed flags such as the availability of an FPU.] Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Patchwork: http://patchwork.linux-mips.org/patch/4714/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-11MIPS: proc: Cleanup printing of ASEs.Ralf Baechle
The number of %s was just getting ridiculous. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-10-11MIPS: Add detection of DSP ASE Revision 2.Steven J. Hill
[ralf@linux-mips.org: This patch really only detects the ASE and passes its existence on to userland via /proc/cpuinfo. The DSP ASE Rev 2. adds new resources but no resources that would need management by the kernel.] Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/4165/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-05-15MIPS: Code formatting fixes.Steven J. Hill
Signed-off-by: Steven J. Hill <sjhill@mips.com> Cc: linux-mips@linux-mips.org Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2012-03-29remove references to cpu_*_map in arch/Rusty Russell
This has been obsolescent for a while; time for the final push. In adjacent context, replaced old cpus_* with cpumask_*. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: David S. Miller <davem@davemloft.net> (arch/sparc) Acked-by: Chris Metcalf <cmetcalf@tilera.com> (arch/tile) Cc: user-mode-linux-devel@lists.sourceforge.net Cc: Russell King <linux@arm.linux.org.uk> Cc: linux-arm-kernel@lists.infradead.org Cc: Richard Kuo <rkuo@codeaurora.org> Cc: linux-hexagon@vger.kernel.org Cc: Ralf Baechle <ralf@linux-mips.org> Cc: linux-mips@linux-mips.org Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Helge Deller <deller@gmx.de> Cc: sparclinux@vger.kernel.org
2011-01-18MIPS: Probe for presence of KScratch registers.David Daney
Probe c0_config4 for KScratch registers and report them in /proc/cpuinfo. Signed-off-by: David Daney <ddaney@caviumnetworks.com> To: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1877/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-01-18MIPS: Add generic support for multiple machines within a single kernelGabor Juhos
This patch adds a generic solution to support multiple machines based on a given SoC within a single kernel image. It is implemented already for several other architectures but MIPS has no generic support for that yet. [Ralf: This competes with DT but DT is a much more complex solution and this code has been used by OpenWRT for a long time so for now DT is a bad reason to stop the merge but longer term this should be migrated to DT.] Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: linux-mips@linux-mips.org Cc: kaloz@openwrt.org Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Cc: Cliff Holden <Cliff.Holden@Atheros.com> Patchwork: https://patchwork.linux-mips.org/patch/1814/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-08-03MIPS: Eleminate filenames from commentsRalf Baechle
They tend to get not updated when files are moved around or copied and lack any obvious use. While at it zap some only too obvious comments and as per Shinya's suggestion, add a copyright header to extable.c. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Acked-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com>
2009-06-08MIPS: Outline udelay and fix a few issues.Ralf Baechle
Outlining fixes the issue were on certain CPUs such as the R10000 family the delay loop would need an extra cycle if it overlaps a cacheline boundary. The rewrite also fixes build errors with GCC 4.4 which was changed in way incompatible with the kernel's inline assembly. Relying on pure C for computation of the delay value removes the need for explicit. The price we pay is a slight slowdown of the computation - to be fixed on another day. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-15MIPS: show_cpuinfo prints the type of the calling CPUJohannes Dickgreber
It should print the type of the Nth processor. Signed-off-by: Johannes Dickgreber <tanzy@gmx.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Probe watch registers and report configuration.David Daney
Probe for watch register characteristics, and report them in /proc/cpuinfo. Signed-off-by: David Daney <ddaney@avtrex.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS]: constify function pointer tablesJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-01-29[MIPS] MT: Scheduler support for SMTRalf Baechle
2007-11-15[MIPS] Fix shadow register support.Ralf Baechle
Shadow register support would not possibly have worked on multicore systems. The support code for it was also depending not on MIPS R2 but VSMP or SMTC kernels even though it makes perfect sense with UP kernels. SR sets are a scarce resource and the expected usage pattern is that users actually hardcode the register set numbers in their code. So fix the allocator by ditching it. Move the remaining CPU probe bits into the generic CPU probe. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Make facility to convert CPU types to strings generally available.Ralf Baechle
So far /proc/cpuinfo has been the only user but human readable processor name are more useful than that for proc. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add support for BCM47XX CPUs.Aurelien Jarno
Note that the BCM4710 does not support the wait instruction, this is not a mistake in the code. It originally comes from the OpenWrt patches. Cc: Michael Buesch <mb@bu3sch.de> Cc: Felix Fietkau <nbd@openwrt.org> Cc: Florian Schirmer <jolt@tuxbox.org> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] define Hit_Invalidate_I to Index_Invalidate_I for loongson2Fuxin Zhang
Signed-off-by: Fuxin Zhang <zhangfx@lemote.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-10[MIPS] Remove unused watchpoint support and arch/mips/lib-{32,64}Atsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] Whitespace cleanups.Ralf Baechle
2006-10-09[MIPS] Make sure cpu_has_fpu is used only in atomic contextAtsushi Nemoto
Make sure cpu_has_fpu (which uses smp_processor_id()) is used only in atomic context. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Show actual CPU information in /proc/cpuinfoKarl-Johan Karlsson
Currently, /proc/cpuinfo contains several copies of the information for whatever processor we happen to be scheduled on. This patch makes it contain the proper information for each CPU, which is particularly useful on mixed R12k/R10k IP27 machines. Signed-off-by: Karl-Johan Karlsson <creideiki@lysator.liu.se> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Treat R14000 like R10000.Kumba
Signed-off-by: Joshua Kinard <kumba@gentoo.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-01[MIPS] Fix detection and handling of the 74K processor.Chris Dearman
Nothing exciting; Linux just didn't know it yet so this is most adding a value to a case statement. Signed-off-by: Chris Dearman <chris@mips.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-03-21[MIPS] Separate CPU entries in /proc/cpuinfo with a blank line.Martin Michlmayr
Put in a blank line between CPU entries in /proc/cpuinfo, just like most other architectures (i386, ia64, x86_64) do. Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2005-10-29Add support for SB1A CPU.Andrew Isaacson
Signed-Off-By: Andy Isaacson <adi@broadcom.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Display presence of SmartMIPS, DSP and MT ASEs in /proc/cpuinfo.Ralf Baechle
2005-10-29Philips PNX8550 support: MIPS32-like core with 2 Trimedias on it.Pete Popov
2005-10-29Detect the 34K.Ralf Baechle
2005-10-29Cleanup decoding of MIPSxx config registers.Ralf Baechle
2005-10-29ISOify.Ralf Baechle
2005-10-29Base Au1200 2.6 support.Pete Popov
2005-10-29On multiprocessor systems the BogoMIPS for each CPU was reported wasRalf Baechle
the value for the last CPU having calibrated it's delay loop. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
