path: root/arch/mips/kernel/gdb-stub.c
2007-02-06[MIPS] Whitespace cleanups.Ralf Baechle
2006-04-19[MIPS] MT: Improved multithreading support.Ralf Baechle
2006-02-01[PATCH] mips: gdb-stub.c: fix parse error before ; tokenAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29Define and initialize kdb_lock using DEFINE_SPINLOCK.Ralf Baechle
Convert kgdb_cpulock into a raw_spinlock_t. SPIN_LOCK_UNLOCKED is deprecated and it's replacement DEFINE_SPINLOCK is not suitable for arrays of spinlocks. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Make kgdb_wait static.Ralf Baechle
Nothing outside gdb-stub.c uses kgdb_wait, so change it's definition to static. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Prevent gcc from optimizing a few functions away completly.Ralf Baechle
2005-10-29Fix build with SMP disabled and preemption enabled.Ralf Baechle
2005-09-05[PATCH] mips: nuke trailing whitespaceRalf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
