path: root/arch/mips/kernel/branch.c
2015-07-09MIPS: Fix branch emulation for BLTC and BGEC instructionsMarkos Chandras
Commits f1b44067c19258b7614e3cd09dfe8d8e12ff5895 ("MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructions") and commit a8ff66f52d3f17b5ae793955270675c197f73d6c ("MIPS: Emulate the new MIPS R6 B{L,G}E{Z,}{AL,}C instructions") added support for emulating various branch compact instructions. However, it missed the case for those which use the old BLEZL and BGTZL opcodes leading to random crashes when the R6 emulator is disabled. We fix this by ensuring that the 'rt' field is not zero which is always true for these branch compact instructions. Fixes: f1b44067c192 ("MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructions") Fixes: a8ff66f52d3f ("MIPS: Emulate the new MIPS R6 B{L,G}E{Z,}{AL,}C instructions") Cc: <stable@vger.kernel.org> # 4.0+ Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Cc: linux-mips@linux-mips.org Cc: Markos Chandras <markos.chandras@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/10582/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-04-01MIPS: LLVMLinux: Fix a 'cast to type not present in union' error.Toma Tabacu
Remove a cast to the 'mips16e_instruction' union inside an if condition and instead do an assignment to a local 'union mips16e_instruction' variable's 'full' member before the if statement and use this variable in the if condition. This is the error message reported by clang: arch/mips/kernel/branch.c:38:8: error: cast to union type from type 'unsigned short' not present in union if (((union mips16e_instruction)inst).ri.opcode ^ ~~~~ The changed code can be compiled successfully by both gcc and clang. Signed-off-by: Toma Tabacu <toma.tabacu@imgtec.com> Signed-off-by: Daniel Sanders <daniel.sanders@imgtec.com> Cc: Andreas Herrmann <andreas.herrmann@caviumnetworks.com> Cc: David Daney <david.daney@cavium.com> Cc: Manuel Lauss <manuel.lauss@gmail.com> Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/9312/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-02-17MIPS: kernel: mips-r2-to-r6-emul: Add R2 emulator for MIPS R6Leonid Yegoshin
MIPS R6 removed quite a few R2 instructions. However, there is plenty of <R6 userland code so we add an in-kernel emulator so we can still be able to execute all R2 userland out there. The emulator comes with a handy debugfs under /mips/ directory (r2-emul-stats) to provide some basic statistics of the instructions that are being emulated. Below are some statistics from booting a minimal buildroot image: Instruction Total BDslot ------------------------------ movs 236969 0 hilo 56686 0 muls 55279 0 divs 10941 0 dsps 0 0 bops 1 0 traps 0 0 fpus 0 0 loads 214981 17 stores 103364 0 llsc 56898 0 dsemul 150418 0 jr 370158 bltzl 43 bgezl 1594 bltzll 0 bgezll 0 bltzal 39 bgezal 39 beql 14503 bnel 138741 blezl 0 bgtzl 3988 Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 BNEZC and JIALC instructionsMarkos Chandras
MIPS R6 uses the <R6 sdc2 opcode for the new BNEZC and JIALC instructions Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 BEQZC and JIC instructionsMarkos Chandras
MIPS R6 uses the <R6 ldc2 opcode for the new BEQZC and JIC instructions Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 BALC instructionMarkos Chandras
MIPS R6 uses the <R6 swc2 opcode for the new BALC instructions. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 BNVC, BNEC and BNEZLAC instructionsMarkos Chandras
MIPS R6 uses the <R6 DADDI opcode for the new BNVC, BNEC and BNEZLAC instructions. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 BOVC, BEQC and BEQZALC instructionsMarkos Chandras
MIPS R6 uses the <R6 ADDI opcode for the new BOVC, BEQC and BEQZALC instructions. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 branch compact (BC) instructionMarkos Chandras
MIPS R6 uses the <R6 LWC2 opcode for the new BC instruction. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 B{L,G}T{Z,}{AL,}C instructionsMarkos Chandras
MIPS R6 added the following four instructions which share the BGTZ and BGTZL opcode: BLTZALC: Compact branch-and-link if GPR rt is < to zero BGTZALC: Compact branch-and-link if GPR rt is > to zero BLTZL : Compact branch if GPR rt is < to zero BGTZL : Compact branch if GPR rt is > to zero BLTC : Compact branch if GPR rs is less than GPR rt BLTUC : Similar to BLTC but unsigned Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the new MIPS R6 B{L,G}Ε{Z,}{AL,}C instructionsMarkos Chandras
MIPS R6 added the following four instructions which share the BLEZ and BLEZL opcodes: BLEZALC: Compact branch-and-link if GPR rt is <= to zero BGEZALC: Compact branch-and-link if GPR rt is >= to zero BLEZC : Compact branch if GPR rt is <= to zero BGEZC : Compact branch if GPR rt is >= to zero BGEC : Compact branch if GPR rs is less than or equal to GPR rt BGEUC : Similar to BGEC but unsigned. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: Emulate the BC1{EQ,NE}Z FPU instructionsMarkos Chandras
MIPS R6 introduced the following two branch instructions for COP1: BC1EQZ: Branch if Cop1 (FPR) Register Bit 0 is Equal to Zero BC1NEZ: Branch if Cop1 (FPR) Register Bit 0 is Not Equal to Zero Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: kernel: branch: Do not emulate the branch likelies on MIPS R6Markos Chandras
MIPS R6 removed the BLTZL, BGEZL, BLTZAL, BGEZAL, BEQL, BNEL, BLEZL, BGTZL branch likely instructions so we must not try to emulate them on MIPS R6 if the R2-to-R6 emulator is not present. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2015-02-17MIPS: kernel: Prepare the JR instruction for emulation on MIPS R6Markos Chandras
The MIPS R6 JR instruction is an alias to the JALR one, so it may need emulation for non-R6 userlands. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com>
2014-11-07MIPS: Fix build with binutils 2.24.51+Manuel Lauss
Starting with version 2.24.51.20140728 MIPS binutils complain loudly about mixing soft-float and hard-float object files, leading to this build failure since GCC is invoked with "-msoft-float" on MIPS: {standard input}: Warning: .gnu_attribute 4,3 requires `softfloat' LD arch/mips/alchemy/common/built-in.o mipsel-softfloat-linux-gnu-ld: Warning: arch/mips/alchemy/common/built-in.o uses -msoft-float (set by arch/mips/alchemy/common/prom.o), arch/mips/alchemy/common/sleeper.o uses -mhard-float To fix this, we detect if GAS is new enough to support "-msoft-float" command option, and if it does, we can let GCC pass it to GAS; but then we also need to sprinkle the files which make use of floating point registers with the necessary ".set hardfloat" directives. Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Cc: Linux-MIPS <linux-mips@linux-mips.org> Cc: Matthew Fortune <Matthew.Fortune@imgtec.com> Cc: Markos Chandras <Markos.Chandras@imgtec.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/8355/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-06-04Merge branch '3.15-fixes' into mips-for-linux-nextRalf Baechle
2014-05-30MIPS: OCTEON: Enable use of FPUDavid Daney
Some versions of the assembler will not assemble CFC1 for OCTEON, so override the ISA for these. Add r4k_fpu.o to handle low level FPU initialization. Modify octeon_switch.S to save the FPU registers. And include r4k_switch.S to pick up more FPU support. Get rid of "#define cpu_has_fpu 0" Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Andreas Herrmann <andreas.herrmann@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: James Hogan <james.hogan@imgtec.com> Cc: kvm@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/7006/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-23MIPS: Sort out mm_isBranchInstr.Ralf Baechle
mm_isBranchInstr() did reside in the math emu code even though it logically is separate and also is used outside the math emu code. In addition GCC 4.9.0 leaves the following unnnecessarily bloated function body for a non-microMIPS configuration: <mm_isBranchInstr>: 105c: afa50004 sw a1,4(sp) 1060: afa60008 sw a2,8(sp) 1064: afa7000c sw a3,12(sp) 1068: 03e00008 jr ra 106c: 00001021 move v0,zero which stores arguments that are never going to be used on the stack frame. Move mm_isBranchInstr() from cp1emu.c to branch.c, then split mm_isBranchInstr() into a __mm_isBranchInstr() core and a mm_isBranchInstr() wrapper inline function which only invokes __mm_isBranchInstr() on microMIPS configurations. This shaves off 112 bytes off the kernel and improves code flow a bit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2014-05-23MIPS: Fix branch emulation of branch likely instructions.Ralf Baechle
Two issues: o For beql_op, beql_op, bne_op, bnel_op, blez_op, blezl_op, bgtz_op and bgtzl_op the wrong field was being checked for the instruction opcode. o For blez_op / blezl_op and bgtz_op / bgtzl_op the test was testing for the wrong opcode. This bug got introduced by d8d4e3ae0b5c179c0bfd3f0af5b352d13bea9cfa [MIPS Kprobes: Refactor branch emulation]. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Acked-by: Victor Kamensky <kamensky@cisco.com>
2013-07-01MIPS: Cleanup indentation and whitespaceTony Wu
Signed-off-by: Tony Wu <tung7970@gmail.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/5536/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2013-05-09MIPS: MIPS16e: Support handling of delay slots.Steven J. Hill
Add logic needed to properly calculate exceptions for delay slots when in MIPS16e mode. Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
2013-05-09MIPS: microMIPS: Support handling of delay slots.Leonid Yegoshin
Add logic needed to properly calculate exceptions for delay slots when in microMIPS mode. Signed-off-by: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com> Signed-off-by: Steven J. Hill <Steven.Hill@imgtec.com>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS Kprobes: Refactor branch emulationManeesh Soni
This patch refactors MIPS branch emulation code so as to allow skipping delay slot instruction in case of branch likely instructions when branch is not taken. This is useful for keeping the code common for use cases like kprobes where one would like to handle the branch instructions keeping the delay slot instuction also in picture for branch likely instructions. Also allow emulation when instruction to be decoded is not at pt_regs->cp0_epc as in case of kprobes where pt_regs->cp0_epc points to the breakpoint instruction. The patch also exports the function for modules. Signed-off-by: Maneesh Soni <manesoni@cisco.com> Signed-off-by: Victor Kamensky <kamensky@cisco.com> Cc: David Daney <david.daney@cavium.com> Cc: ananth@in.ibm.com Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2913/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-10-18MIPS: Sanitize restart logicsAl Viro
Put the original syscall number into ->regs[0] when we leave syscall with error. Use it in restart logics. Everything else will have it 0 since we pass through SAVE_SOME on all the ways in. Note that in places like bad_stack and inllegal_syscall we leave it 0 - it's not restartable. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-kernel@vger.kernel.org Cc: linux-arch@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/1698/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-11MIPS: Compute branch returns for Cavium OCTEON specific branch instructions.David Daney
For Cavium OCTEON, compute the return epc value for OCTEON specific branch instructions. Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-07-13[MIPS] Add some __user tagsAtsushi Nemoto
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] Unify mips_fpu_soft_struct and mips_fpu_hard_structs.Atsushi Nemoto
The struct mips_fpu_soft_struct and mips_fpu_hard_struct are completely same now and the kernel fpu emulator assumes that. This patch unifies them to mips_fpu_struct and get rid of mips_fpu_union. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-04-27[MIPS] Fix branch emulation for floating-point exceptions.Ralf Baechle
In the branch emulation for floating-point exceptions, __compute_return_epc must determine for bc1f et al which condition code bit to test. This is based on bits <4:2> of the rt field. The switch statement to distinguish bc1f et al needs to use only the two low bits of rt, but the old code tests on the whole rt field. This patch masks off the proper bits. Signed-off-by: Win Treese <treese@acm.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2005-10-29Support the MIPS32 / MIPS64 DSP ASE.Ralf Baechle
2005-10-29__compute_return_epc() uses CFC1 instruction which might result in aRalf Baechle
coprocessor unusable exception since the process can lose its fpu context by preemption. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
