path: root/arch/mips/include/asm/stackframe.h
2010-04-30MIPS: Loongson-2F: Use CONFIG_CPU_JUMP_WORKAROUNDS to control workarounds.Wu Zhangjin
Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips <linux-mips@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/1106/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-04-12MIPS: Loongson-2F: Flush the branch target history in BTB and RASWu Zhangjin
As per chapter 15 "Errata: Issue of Out-of-order in loongson"[1] to work around the Loongson 2F erratum we need to do: "When switching from user mode to kernel mode, you should flush the branch target history such as BTB and RAS." [1] Chinese version: http://www.loongson.cn/uploadfile/file/200808211 [2] English version of chapter 15: http://groups.google.com.hk/group/loongson-dev/msg/e0d2e220958f10a6?dmode=source Signed-off-by: Wu Zhangjin <wuzhangjin@gmail.com> Cc: linux-mips@linux-mips.org Cc: Shinya Kuribayashi <shinya.kuribayashi@necel.com> Patchwork: http://patchwork.linux-mips.org/patch/1066/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Put PGD in C0_CONTEXT for 64-bit R2 processors.David Daney
Processors that support the mips64r2 ISA can in four instructions convert a shifted PGD pointer stored in the upper bits of c0_context into a usable pointer. By doing this we save a memory load and associated potential cache miss in the TLB exception handlers. Since the upper bits of c0_context were holding the CPU number, we move this to the upper bits of c0_xcontext which doesn't have enough bits to hold the PGD pointer, but has plenty for the CPU number. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-12-17MIPS: Reorder operations in stackframe.h for better schedulingDavid Daney
Reorder PT ops to avoid pipeline stalls. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-01-11MIPS: Cavium OCTEON multiplier state preservation.David Daney
For OCTEON, implement a save and restore of the multiplier state across context switches. Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-10-11MIPS: Move headfiles to new location below arch/mips/includeRalf Baechle
