Support the Ingenic JZ4780 SoC using the existing code under
arch/mips/jz4740 now that it has been generalised sufficiently.
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Ian Campbell <ijc+devicetree@hellion.org.uk>
Cc: Kumar Gala <galak@codeaurora.org>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Mark Rutland <mark.rutland@arm.com>
Cc: Pawel Moll <pawel.moll@arm.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: devicetree@vger.kernel.org
Cc: linux-mips@linux-mips.org
Cc: Joshua Kinard <kumba@gentoo.org>
Cc: Leonid Yegoshin <Leonid.Yegoshin@imgtec.com>
Cc: Deng-Cheng Zhu <dengcheng.zhu@imgtec.com>
Cc: Markos Chandras <markos.chandras@imgtec.com>
Cc: Andreas Herrmann <andreas.herrmann@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/10164/
For interrupts numbered after those of the interrupt controller, define
their numbers based upon the number of interrupts provided by the SoC
interrupt controller. This is in preparation for supporting newer
Ingenic SoCs which provide more interrupts.
Cc: Jason Cooper <jason@lakedaemon.net>
Patchwork: https://patchwork.linux-mips.org/patch/10143/
Declare the JZ4740 interrupt controller for probe via DT using the
standard irqchip_init function, and make use of that function to probe
the controller by adding the appropriate node to the JZ4740 dtsi.
Cc: Brian Norris <computersforpeace@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/10135/
In preparation for moving the JZ4740 interrupt controller driver to
drivers/irqchip, move arch_init_irq into setup.c such that everything
remaining in irq.c is related to said JZ4740 interrupt controller.
Patchwork: https://patchwork.linux-mips.org/patch/10136/
Having received another series of whitespace patches I decided to do this
once and for all rather than dealing with this kind of patches trickling
in forever.
Signed-off-by: Antony Pavlov <antonynpavlov@gmail.com>
Patchwork: https://patchwork.linux-mips.org/patch/3459/
Add support for IRQ handling on a JZ4740 SoC.
Patchwork: https://patchwork.linux-mips.org/patch/1465/
