path: root/arch/mips/include/asm/kprobes.h
2018-04-13MIPS: kprobes: flush_insn_slot should flush only if probe initialisedMarcin Nowakowski
[ Upstream commit 698b851073ddf5a894910d63ca04605e0473414e ] When ftrace is used with kprobes, it is possible for a kprobe to contain an invalid location (ie. only initialised to 0 and not to a specific location in the code). Trying to perform a cache flush on such location leads to a crash r4k_flush_icache_range(). Fixes: c1bf207d6ee1 ("MIPS: kprobe: Add support.") Signed-off-by: Marcin Nowakowski <marcin.nowakowski@imgtec.com> Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/16296/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-02-01MIPS: Whitespace cleanup.Ralf Baechle
Having received another series of whitespace patches I decided to do this once and for all rather than dealing with this kind of patches trickling in forever. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2011-12-07MIPS Kprobes: Support branch instructions probingManeesh Soni
This patch provides support for kprobes on branch instructions. The branch instruction at the probed address is actually emulated and not executed out-of-line like other normal instructions. Instead the delay-slot instruction is copied and single stepped out of line. At the time of probe hit, the original branch instruction is evaluated and the target cp0_epc is computed similar to compute_retrun_epc(). It is also checked if the delay slot instruction can be skipped, which is true if there is a NOP in delay slot or branch is taken in case of branch likely instructions. Once the delay slot instruction is single stepped the normal execution resume with the cp0_epc updated the earlier computed cp0_epc as per the branch instructions. Signed-off-by: Maneesh Soni <manesoni@cisco.com> Signed-off-by: Victor Kamensky <kamensky@cisco.com> Cc: David Daney <david.daney@cavium.com> Cc: ananth@in.ibm.com Cc: linux-kernel@vger.kernel.org Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/2914/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2010-08-05MIPS: kprobe: Add support.David Daney
This patch is based on previous work by Sony and Himanshu Chauhan. I have done some cleanup and implemented JProbes and KRETPROBES. The KRETPROBES part is pretty much copied verbatim from powerpc. A possible future enhance might be to factor out the common code. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: Himanshu Chauhan <hschauhan@nulltrace.org> To: linux-mips@linux-mips.org To: ananth@in.ibm.com, To: anil.s.keshavamurthy@intel.com To: davem@davemloft.net To: masami.hiramatsu.pt@hitachi.com Cc: linux-kernel@vger.kernel.org Patchwork: https://patchwork.linux-mips.org/patch/1525/ Patchwork: https://patchwork.linux-mips.org/patch/1530/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
