path: root/arch/mips/cobalt/setup.c
2010-01-12MIPS: Cobalt use strlcat() for the command line argumentsYoichi Yuasa
Tested with CoLo v1.22 Signed-off-by: Yoichi Yuasa <yuasa@linux-mips.org> Patchwork: http://patchwork.linux-mips.org/patch/807/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2008-07-20[MIPS] Cobalt: Fix I/O port resource rangeYoichi Yuasa
LCD and buttons don't use I/O port space. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-22[MIPS] time: Add GT641xx timer0 clockevent driverYoichi Yuasa
And make use of it for Cobalt. A few others such as the Malta could make use of it as well. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Cobalt: Remove cobalt_machine_power_off()Yoichi Yuasa
It's same as cobalt_machine_halt(). Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] i8253 PIT clocksource and clockevent driversRalf Baechle
Derived from the i386 variant with a few x86 complexities chopped off. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] ARC: Get rid of mips_machgroupRalf Baechle
This has not been any serious user of this ill conceived thing since the original invention in like '95. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-10-11[MIPS] Add GT641xx IRQ routines.Yoichi Yuasa
2007-05-11[MIPS] Rework cobalt_board_idYoichi Yuasa
This patch has reworked cobalt_board_id. The cobalt_board_id is read from PCI config register. It should be in PCI routine. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-05-11[MIPS] Use platform_device for Cobalt UARTYoichi Yuasa
2007-04-27[MIPS] Cobalt: Split PCI codes from setup.cYoichi Yuasa
It's removed #ifdef CONFIG_PCI/#endif from cobalt setup.c . Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-04-27[MIPS] Cobalt: clean up include filesYoichi Yuasa
2007-03-04[MIPS] Cobalt: update reserved resourcesYoichi Yuasa
This patch has removed unused timer resource. Moreover, the name of reserved resources ware changed. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-03-04[MIPS] Fix and cleanup the mess that a dozen prom_printf variants are.Ralf Baechle
early_printk is a so much saner thing. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-20[MIPS] Cobalt: Fix UART I/O typeYoichi Yuasa
The Cobalt UART is actually connected to memory resource area. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-06[MIPS] prom_free_prom_memory cleanupAtsushi Nemoto
Current prom_free_prom_memory() implementations are almost same as free_init_pages(), or no-op. Make free_init_pages() extern (again) and make prom_free_prom_memory() use it. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-11-30[MIPS] Rewrite GALILEO_INL/GALILEO_OUTL to GT_READ/GT_WRITEYoichi Yuasa
This patch has rewritten GALILEO_INL/GALILEO_OUTL using GT_READ/GT_WRITE. This patch tested on Cobalt Qube2. Signed-off-by: Yoichi Yuasa <yoichi_yuasa@tripeaks.co.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-08[MIPS] Cobalt: Time runs too quicklyScott Ashcroft
A kernel built with HZ==250 runs about 4 four times too quickly on a Cobalt RaQ2. Signed-off-by: Scott Ashcroft <scott.ashcroft@talk21.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-10-01[SERIAL] Remove wrong asm/serial.h inclusionsRussell King
asm/serial.h is supposed to contain the definitions for the architecture specific 8250 ports for the 8250 driver. It may also define BASE_BAUD, but this is the base baud for the architecture specific ports _only_. Therefore, nothing other than the 8250 driver should be including this header file. In order to move towards this goal, here is a patch which removes some of the more obvious incorrect includes of the file. Acked-by: Paul Fulghum <paulkf@microgate.com> Acked-by: Tony Luck <tony.luck@intel.com> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-07-13[MIPS] Replace board_timer_setup function pointer by plat_timer_setup.Ralf Baechle
Signed-off-by: Ralf Baechle <ralf@linux-mips.org> ---
2006-06-19[MIPS] Cleanup memory managment initialization.Ralf Baechle
Historically plat_mem_setup did the entire platform initialization. This was rather impractical because it meant plat_mem_setup had to get away without any kind of memory allocator. To keep old code from breaking plat_setup was just renamed to plat_setup and a second platform initialization hook for anything else was introduced. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-06-19[MIPS] C99-ify struct resource initialization.Ralf Baechle
2006-03-21[MIPS] Add early console for Cobalt.Peter Horton
Signed-off-by: Peter Horton <pdh@colonel-panic.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2006-02-08Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2006-02-07[MIPS] Rename include/asm-mips/cobalt to include/asm-mips/mach-cobalt.Ralf Baechle
2006-02-07[MIPS] Rename _machine_power_off to pm_power_off so the kernel builds again.Ralf Baechle
2006-02-05[SERIAL] uart_port flags member should use UPF_*Russell King
Convert usage of ASYNC_* to UPF_*. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Resurrect Cobalt support for 2.6.Ralf Baechle
2005-10-29Get rid of early_init. There's more need to make this form ofRalf Baechle
initialization actually useful and as is certainly unmergable with upstream. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
