This patch addresses a couple of related problems:
1) The kernel may reside in physical memory outside of the ranges set
by plat_mem_setup(). If this is the case, init mem cannot be
reused as it resides outside of the range of pages that the kernel
memory allocators control.
2) initrd images might be loaded in physical memory outside of the
ranges set by plat_mem_setup(). The memory likewise cannot be
reused. The patch doesn't handle this specific case, but the
infrastructure is useful for future patches that do.
The crux of the problem is that there are memory regions that need be
memory_present(), but that cannot be free_bootmem() at the time of
arch_mem_init(). We create a new type of memory (BOOT_MEM_INIT_RAM)
for use with add_memory_region(). Then arch_mem_init() adds the init
mem with this type if the init mem is not already covered by existing
ranges.
When memory is being freed into the bootmem allocator, we skip the
BOOT_MEM_INIT_RAM ranges so they are not clobbered, but we do signal
them as memory_present(). This way when they are later freed, the
necessary memory manager structures have initialized and the Sparse
allocater is prevented from crashing.
The Octeon specific code that handled this case is removed, because
the new general purpose code handles the case.
Signed-off-by: David Daney <ddaney@caviumnetworks.com>
To: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1988/
Panic() invokes printk() to add a \n internally, so panic arguments should
not themselves end in \n. Panic invocations in arch/mips and elsewhere
are inconsistently sometimes terminating in \n, sometimes not.
Octeon uses different interrupt irq for timer and performance counters.
Set CvmCtl[IPPCI] to correct irq value very early.
Signed-off-by: Chandrakala Chavva <cchavva@caviumnetworks.com>
Cc: Chandrakala Chavva <cchavva@caviumnetworks.com>
Patchwork: https://patchwork.linux-mips.org/patch/2085/
This includes conversion to new style irq_chip functions, and
correctly enabling/disabling per-CPU interrupts.
The hardware interrupt bit to irq number mapping is now done with a
flexible map, instead of by bit twiddling the irq number.
[ tglx: Adjusted to new irq_cpu_on/offline callbacks and
__irq_set_affinity_lock ]
Cc: linux-mips@linux-mips.org
Cc: ralf@linux-mips.org
LKML-Reference: <1301081931-11240-5-git-send-email-ddaney@caviumnetworks.com>
The CN63XXP1 needs a couple of workarounds to ensure memory is not written
in unexpected ways.
All PREF with hints in the range 0-4,6-24 are replaced with PREF 28. We
pass a flag to the assembler to cover compiler generated code, and patch
uasm for the dynamically generated code.
The write buffer threshold is reduced to 4.
Patchwork: http://patchwork.linux-mips.org/patch/1672/
Starting with cn63xx Octeon I/O blocks are clocked at a different rate
than the CPU. Add a new function octeon_get_io_clock_rate() that
yields the I/O clock rate.
Also rearrange octeon_get_clock_rate() to get the value from the saved
sysinfo structure.
Patchwork: http://patchwork.linux-mips.org/patch/1671/
We can run with any simulator clock rate. Get rid of the code
overriding it to 6MHz.
Patchwork: http://patchwork.linux-mips.org/patch/1669/
We reserve the 3.75GB - 4GB region of PCIe address space for device to
device transfers, making the corresponding physical memory under
direct mapping unavailable for DMA.
To allow for PCIe DMA to all physical memory we map this chunk of
physical memory with BAR1. Because of the resulting discontinuity in
the mapping function, we remove a page of memory at each end of the
range so multi-page DMA buffers can never be allocated that span the
range.
Patchwork: https://patchwork.linux-mips.org/patch/1535/
The forthcoming watchdog driver will use it.
To: wim@iguana.be
Patchwork: https://patchwork.linux-mips.org/patch/1499/
Power throttling make deterministic delay loops impossible.
Re-implement delays using the cycle counter. This also allows us to
get rid of the code that calculates loops per jiffy.
Patchwork: https://patchwork.linux-mips.org/patch/1317/
CONFIG_GDB_CONSOLE doesn't exist in Kconfig, therefore removing all
references for it from the source code.
Signed-off-by: Christoph Egger <siccegge@cs.fau.de>
To: David Daney <ddaney@caviumnetworks.com>
To: Yang Shi <yang.shi@windriver.com>
To: Herbert Xu <herbert@gondor.apana.org.au>
To: Tejun Heo <tj@kernel.org>
To: linux-kernel@vger.kernel.org
Cc: vamos@i4.informatik.uni-erlangen.de
Patchwork: https://patchwork.linux-mips.org/patch/1368/
Acked-by: David Daney <ddaney@caviumnetworks.com>
For the simulator, fake a slow clock to get fast output.
In prom_putchar we have to mask the value so the simulator doesn't
ASSERT when printing non-ASCII characters.
Patchwork: http://patchwork.linux-mips.org/patch/1255/
Get rid of early_serial_setup, we use CONFIG_EARLY_PRINTK instead.
Patchwork: http://patchwork.linux-mips.org/patch/1254/
octeon_reserve32_memory is defined In Octeon's setup.c, so remove the
redundant extern declaration of this variable.
Signed-off-by: Yang Shi <yang.shi@windriver.com>
To: f.fainelli@gmail.com
Patchwork: http://patchwork.linux-mips.org/patch/1022/
Patchwork: http://patchwork.linux-mips.org/patch/1029/
The config option CAVIUM_RESERVE32_USE_WIRED_TLB is not supported.
Remove the dead code controlled by it.
Patchwork: http://patchwork.linux-mips.org/patch/1028/
There is a bunch of platform device registration in
arch/mips/cavium-octeon/setup.c. We move it to its own file in
preparation for adding more platform devices.
Add a platform device for the Octeon Random Number Generator (RNG).
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Some of the were relying into smp.h being dragged in by another header
which of course is fragile. <asm/cpu-info.h> uses smp_processor_id()
only in macros and including smp.h there leads to an include loop, so
don't change cpu-info.h.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
These are the rest of the new files needed to add OCTEON processor
support to the Linux kernel. Other than Makefile and Kconfig which
should be obvious, we have:
csrc-octeon.c -- Clock source driver for OCTEON.
dma-octeon.c -- Helper functions for mapping DMA memory.
flash_setup.c -- Register on-board flash with the MTD subsystem.
octeon-irq.c -- OCTEON interrupt controller managment.
octeon-memcpy.S -- Optimized memcpy() implementation.
serial.c -- Register 8250 platform driver and early console.
setup.c -- Early architecture initialization.
smp.c -- OCTEON SMP support.
octeon_switch.S -- Scheduler context switch for OCTEON.
c-octeon.c -- OCTEON cache controller support.
cex-oct.S -- OCTEON cache exception handler.
asm/mach-cavium-octeon/*.h -- Architecture include files.
Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com>
create mode 100644 arch/mips/cavium-octeon/Kconfig
create mode 100644 arch/mips/cavium-octeon/Makefile
create mode 100644 arch/mips/cavium-octeon/csrc-octeon.c
create mode 100644 arch/mips/cavium-octeon/dma-octeon.c
create mode 100644 arch/mips/cavium-octeon/flash_setup.c
create mode 100644 arch/mips/cavium-octeon/octeon-irq.c
create mode 100644 arch/mips/cavium-octeon/octeon-memcpy.S
create mode 100644 arch/mips/cavium-octeon/serial.c
create mode 100644 arch/mips/cavium-octeon/setup.c
create mode 100644 arch/mips/cavium-octeon/smp.c
create mode 100644 arch/mips/include/asm/mach-cavium-octeon/cpu-feature-overrides.h
create mode 100644 arch/mips/include/asm/mach-cavium-octeon/dma-coherence.h
create mode 100644 arch/mips/include/asm/mach-cavium-octeon/irq.h
create mode 100644 arch/mips/include/asm/mach-cavium-octeon/kernel-entry-init.h
create mode 100644 arch/mips/include/asm/mach-cavium-octeon/war.h
create mode 100644 arch/mips/include/asm/octeon/octeon.h
create mode 100644 arch/mips/kernel/octeon_switch.S
create mode 100644 arch/mips/mm/c-octeon.c
create mode 100644 arch/mips/mm/cex-oct.S
