path: root/arch/mips/cavium-octeon/dma-octeon.c
2009-01-11MIPS: Add Cavium OCTEON processor support files to arch/mips/cavium-octeon.David Daney
These are the rest of the new files needed to add OCTEON processor support to the Linux kernel. Other than Makefile and Kconfig which should be obvious, we have: csrc-octeon.c -- Clock source driver for OCTEON. dma-octeon.c -- Helper functions for mapping DMA memory. flash_setup.c -- Register on-board flash with the MTD subsystem. octeon-irq.c -- OCTEON interrupt controller managment. octeon-memcpy.S -- Optimized memcpy() implementation. serial.c -- Register 8250 platform driver and early console. setup.c -- Early architecture initialization. smp.c -- OCTEON SMP support. octeon_switch.S -- Scheduler context switch for OCTEON. c-octeon.c -- OCTEON cache controller support. cex-oct.S -- OCTEON cache exception handler. asm/mach-cavium-octeon/*.h -- Architecture include files. Signed-off-by: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org> create mode 100644 arch/mips/cavium-octeon/Kconfig create mode 100644 arch/mips/cavium-octeon/Makefile create mode 100644 arch/mips/cavium-octeon/csrc-octeon.c create mode 100644 arch/mips/cavium-octeon/dma-octeon.c create mode 100644 arch/mips/cavium-octeon/flash_setup.c create mode 100644 arch/mips/cavium-octeon/octeon-irq.c create mode 100644 arch/mips/cavium-octeon/octeon-memcpy.S create mode 100644 arch/mips/cavium-octeon/serial.c create mode 100644 arch/mips/cavium-octeon/setup.c create mode 100644 arch/mips/cavium-octeon/smp.c create mode 100644 arch/mips/include/asm/mach-cavium-octeon/cpu-feature-overrides.h create mode 100644 arch/mips/include/asm/mach-cavium-octeon/dma-coherence.h create mode 100644 arch/mips/include/asm/mach-cavium-octeon/irq.h create mode 100644 arch/mips/include/asm/mach-cavium-octeon/kernel-entry-init.h create mode 100644 arch/mips/include/asm/mach-cavium-octeon/war.h create mode 100644 arch/mips/include/asm/octeon/octeon.h create mode 100644 arch/mips/kernel/octeon_switch.S create mode 100644 arch/mips/mm/c-octeon.c create mode 100644 arch/mips/mm/cex-oct.S
