path: root/arch/mips/bcm63xx/setup.c
2009-11-02MIPS: BCM63xx: Fix soft-reset lockup on BCM6345Florian Fainelli
This patch fixes a lockup on BCM6345 where setting the PLL soft reset bit will also lock the other blocks including UART. Instead of setting only the PLL soft reset bit in the software reset register, set this bit but do not touch the others. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2009-09-17MIPS: BCM63xx: Add support for the Broadcom BCM63xx family of SOCs.Maxime Bizon
Signed-off-by: Maxime Bizon <mbizon@freebox.fr> Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
