common/au1000/irq.c was missing a mips_timer_interrupt() prototype,
whereas in common/au1000/time.c the actual mips_timer_interrupt()
implementation was missing an irq_exit() invocation, causing a
preempt_count() leak.
Signed-off-by: Herbert Valerio Riedel <hvr@hvrlab.org>
Saves like 1,600 lines of code, is way easier to debug, compilers
frequently do a better job than the cut and paste type of handlers many
boards had. And finally having all the stuff done in a single place
also means alot of bug potencial for the MT ASE is gone.
The only surviving handler in assembler is the DECstation one; I hope
Maciej will rewrite it.
previously been initialized statically in kernel/irq/handle.c.
timer tick. Prior to this patch, if IDE IRQ probing occured, then the
TOY_MATCH2 interrupt would be permanently disabled, and no system timer
tick occurs. This patch corrects this situation by correctly registering
the TOY_MATCH2 interrupt so that IDE IRQ probing doesn't have adverse
side effects.
initializers.
infrastructure for it.
Let it rip!
