path: root/arch/m68k
2011-07-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/math-emu: Remove unnecessary code m68k/math-emu: Remove commented out old code m68k: Kill warning in setup_arch() when compiling for Sun3 m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_ sparc: iounmap() and *_free_coherent() - Use lookup_resource() m68k/atari: Reserve some ST-RAM early on for device buffer use m68k/amiga: Chip RAM - Use lookup_resource() resources: Add lookup_resource() sparc: _sparc_find_resource() should check for exact matches m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDR m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one error m68k/amiga: Chip RAM - Change chipavail to an atomic_t m68k/amiga: Chip RAM - Always allocate from the start of memory m68k/amiga: Chip RAM - Convert from printk() to pr_*() m68k/amiga: Chip RAM - Use tabs for indentation
2011-07-30m68k/math-emu: Remove unnecessary codeGreg Dietsche
Remove unnecessary code that matches this coccinelle pattern if (...) return ret; return ret; Signed-off-by: Greg Dietsche <Gregory.Dietsche@cuw.edu> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/math-emu: Remove commented out old codeGeert Uytterhoeven
It's been unused for ages, and contains bugs (e.g. incorrect shifts in lsl64()). Reported-by: Jonathan Elchison <jelchison@gmail.com> Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k: Kill warning in setup_arch() when compiling for Sun3Geert Uytterhoeven
arch/m68k/kernel/setup_mm.c: In function ‘setup_arch’: arch/m68k/kernel/setup_mm.c:219: warning: unused variable ‘i’ Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/atari: Prefix GPIO_{IN,OUT} with CODEC_Geert Uytterhoeven
These defines are way to generic, and cause conflicts: drivers/net/wireless/rtlwifi/rtl8192c/../rtl8192ce/reg.h:369:1: warning: "GPIO_IN" redefined drivers/net/wireless/rtlwifi/rtl8192c/../rtl8192ce/reg.h:370:1: warning: "GPIO_OUT" redefined drivers/net/wireless/rtlwifi/rtl8192se/reg.h:252:1: warning: "GPIO_IN" redefined drivers/net/wireless/rtlwifi/rtl8192se/reg.h:253:1: warning: "GPIO_OUT" redefined Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/atari: Reserve some ST-RAM early on for device buffer useMichael Schmitz
Based on an original patch from Michael Schmitz: Because mem_init() is now called before device init, devices that rely on ST-RAM may find all ST-RAM already allocated to other users by the time device init happens. In particular, a large initrd RAM disk may use up enough of ST-RAM to cause atari_stram_alloc() to resort to __get_dma_pages() allocation. In the current state of Atari memory management, all of RAM is marked DMA capable, so __get_dma_pages() may well return RAM that is not in actual fact DMA capable. Using this for frame buffer or SCSI DMA buffer causes subtle failure. The ST-RAM allocator has been changed to allocate memory from a pool of reserved ST-RAM of configurable size, set aside on ST-RAM init (i.e. before mem_init()). As long as this pool is not exhausted, allocation of real ST-RAM can be guaranteed. Other changes: - Replace the custom allocator in the ST-RAM pool by the existing allocator in the resource subsystem, - Remove mem_init_done and its hook, as memory init is now done before device init, - Remove /proc/stram, as ST-RAM usage now shows up under /proc/iomem, e.g. 005f2000-006f1fff : ST-RAM Pool 005f2000-0063dfff : atafb 0063e000-00641fff : ataflop 00642000-00642fff : SCSI Signed-off-by: Michael Schmitz <schmitz@debian.org> [Andreas Schwab <schwab@linux-m68k.org>: Use memparse()] [Geert: Use the resource subsystem instead of a custom allocator] Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Use lookup_resource()Geert Uytterhoeven
Replace a custom implementation (which doesn't lock the resource tree) by a call to lookup_resource() Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Offset resource end by CHIP_PHYSADDRGeert Uytterhoeven
Technically, the end of Chip RAM should be offset by CHIP_PHYSADDR (which is zero). Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Use resource_size() to fix off-by-one errorGeert Uytterhoeven
2011-07-30m68k/amiga: Chip RAM - Change chipavail to an atomic_tGeert Uytterhoeven
While the core resource handling code is safe, our global counter must still be protected against concurrent modifications. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Always allocate from the start of memoryGeert Uytterhoeven
As of commit 5df1abdbd37af2ae317a1c5b5944173284dc55d6 ('m68k/amiga: Fix "debug=mem"'), "debug=mem" no longer uses amiga_chip_alloc_res(), so we can remove the hack to prefer memory at the safe end. This allows to simplify the code and make amiga_chip_alloc() just call amiga_chip_alloc_res() internally. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Convert from printk() to pr_*()Geert Uytterhoeven
and fix a few formattings: - resource sizes are now resource_size_t, use %pR to make it future proof, - use %lu for unsigned long. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-30m68k/amiga: Chip RAM - Use tabs for indentationGeert Uytterhoeven
2011-07-26atomic: cleanup asm-generic atomic*.h inclusionArun Sharma
After changing all consumers of atomics to include <linux/atomic.h>, we ran into some compile time errors due to this dependency chain: linux/atomic.h -> asm/atomic.h -> asm-generic/atomic-long.h where atomic-long.h could use funcs defined later in linux/atomic.h without a prototype. This patches moves the code that includes asm-generic/atomic*.h to linux/atomic.h. Archs that need <asm-generic/atomic64.h> need to select CONFIG_GENERIC_ATOMIC64 from now on (some of them used to include it unconditionally). Compile tested on i386 and x86_64 with allnoconfig. Signed-off-by: Arun Sharma <asharma@fb.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: move atomic_add_unless to generic codeArun Sharma
This is in preparation for more generic atomic primitives based on __atomic_add_unless. Signed-off-by: Arun Sharma <asharma@fb.com> Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26h8300/m68k/xtensa: __FD_ISSET should return 0/1Andrew Morton
Harmonise these return values with other architectures. In some cases this affects all compilers and in other cases non-gcc compilers only. Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Chris Zankel <chris@zankel.net> Cc: Ulrich Drepper <drepper@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ptrace: unify show_regs() prototypeMike Frysinger
[ poleg@redhat.com: no need to declare show_regs() in ptrace.h, sched.h does this ] Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68k: Revive reporting of spurious interrupts m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.h m68k: fix some atomic operation asm address modes for ColdFire m68k: use CPU_HAS_NO_BITFIELDS for signal functions m68k: merge and clean up delay.h files m68knommu: correctly use trap_init m68knommu: merge ColdFire 5206 and 5206e platform code m68k: merge mmu and non-mmu bitops.h m68k: merge MMU and non MMU versions of system.h m68k: merge MMU and non-MMU versions of asm/hardirq.h m68k: merge the non-mmu and mmu versions of module.c m68knommu: Fix printk() format in free_initrd_mem() m68knommu: Make empty_zero_page "void *", like on m68k
2011-07-25m68k, exec: remove redundant set_fs(USER_DS)Mathias Krause
The address limit is already set in flush_old_exec() so those calls to set_fs(USER_DS) are redundant. Signed-off-by: Mathias Krause <minipli@googlemail.com> Cc: Greg Ungerer <gerg@uclinux.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25m68k: Revive reporting of spurious interruptsGeert Uytterhoeven
commit 2502b667ea835ee16685c74b2a0d89ba8afe117a ("Change the m68knommu irq handling to use the generic irq framework.") removed the reporting of spurious interrupts on nommu (68328 and 68360). Bring it back in a generic way, using "atomic_t irq_err_count", as that's what most of the other architectures are using. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: Move forward declaration of do_IRQ() from machdep.h to irq.hGeert Uytterhoeven
It is not machine-specific, but common irq infrastructure. Also add the missing asmlinkage, to match its definition. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: fix some atomic operation asm address modes for ColdFireGreg Ungerer
The ColdFire processors have a much more limited set of addressing modes that can be used for most instructions. A number of the atomic operations have already been fixed to limit the addressing modes used with add and sub instructions when building for ColdFire. But we missed a few. Fix the remaining atomic operations to be clean for ColdFire processors. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: use CPU_HAS_NO_BITFIELDS for signal functionsGreg Ungerer
When reworking bitops.h to be clean for all processor types we introduced a CONFIG_CPU_HAS_NO_BITFIELDS define to signal whether this processor type supported the bit field instructions. The ARCH_SIG_BITOPS functions for m68k use these instruction types. We should base the use of these functions (or the generic versions) on the CONFIG_CPU_HAS_NO_BITFIELDS define. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge and clean up delay.h filesGreg Ungerer
The real difference between the mmu and non-mmu varients of the delay.h files has nothing to do with having an mmu or not. It is processor family differences that means slightly different code. Merge the delay_mm.h and delay_no.h files back into a single file. The primarly difference we need to deal with is whether the processor supports a 32bit * 32bit -> 64bit multiply. Without it we need to do some shift scaling as well as use a 32bit * 32bit -> 32bit multiply. If building for a multi-CPU type kernel then we must use the simpler mult/shift scaling. This version of delay code allows the CPU32 family to use a 64bit mul, since it supports this instruction, the old code did not. The changes use macros where appropriate to try and optimize constant sized udelay times. And it removes the use of a fixed lib function for the non-mmu case. Code size on typical kernel configurations is similar, or only larger by a few tens of bytes. Also removed the unused muldiv() code from delay_mm.h. Build and run tested on ColdFire and ARAnyM. Build tested only on 68328 and 68360 (CPU32). Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: correctly use trap_initGreg Ungerer
Currently trap_init() is an empty function for m68knommu. Instead the vectors are being setup as part of the IRQ initialization. This is inconsistent with m68k and other architectures. Change the local init_vectors() to be trap_init(), and init the vectors at the correct time during startup. This will help merge of m68k and m68knommu trap code in the furture. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: merge ColdFire 5206 and 5206e platform codeGreg Ungerer
The ColdFire 5206 and 5206e CPU families are almost identical, we can easily merge the platform support code for them. All the differences are dealt with in the current include/asm/5206sim.h. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge mmu and non-mmu bitops.hGreg Ungerer
The following patch merges the mmu and non-mmu versions of the m68k bitops.h files. Now there is a good deal of difference between the two files, but none of it is actually an mmu specific difference. It is all about the specific m68k/coldfire varient we are targeting. So it makes an awful lot of sense to merge these into a single bitops.h. There is a number of ways I can see to factor this code. The approach I have taken here is to keep the various versions of each macro/function type together. This means that there is some ifdefery with each to handle each CPU type. I have added some comments in a couple of appropriate places to try and make it clear what the differences we are dealing with are. Specifically the instruction and addressing mode differences we have to deal with. The merged form keeps the same underlying optimizations for each CPU type for all the general bit clear/set/change and find bit operations. It does switch to using the generic le operations though, instead of any local varients. Build tested on ColdFire, 68328, 68360 (which is cpu32) and 68020+. Run tested on ColdFire and ARAnyM. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-07-25m68k: merge MMU and non MMU versions of system.hGreg Ungerer
The non-MMU m68k targets can use the same asm/system.h as the MMU targets. So switch the current system_mm.h to be system.h and remove system_no.h. The assembly support code for the non-MMU resume functions needs to be modified to match the now common switch_to() macro. Specifically this means correctly saving and restoring the status flags in the case of the ColdFire resume, and some reordering of the code to not use registers before they are saved or after they are restored. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge MMU and non-MMU versions of asm/hardirq.hGreg Ungerer
The contents of asm/hardirq.h are pretty strait forward for both the MMU (hardirq_mm.h) and non-MMU (hardirq_no.h) include files. Merge the two back into a single file. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68k: merge the non-mmu and mmu versions of module.cGreg Ungerer
The non-mmu and mmu versions of the module loader module.c are nearly identical. Merge them back to a single module.c. There is a little bit of re-ordering of the struct and enum definitions in module.h to keep the ifdefery to a minimum. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: Fix printk() format in free_initrd_mem()Geert Uytterhoeven
arch/m68k/mm/init_no.c:123: warning: format "%d" expects type "int", but argument 2 has type "long unsigned int" And use pr_notice() while we're at it. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-25m68knommu: Make empty_zero_page "void *", like on m68kGeert Uytterhoeven
This allows to get rid of the casts. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-07-24modules: make arch's use default loader hooksJonas Bonn
This patch removes all the module loader hook implementations in the architecture specific code where the functionality is the same as that now provided by the recently added default hooks. Signed-off-by: Jonas Bonn <jonas@southpole.se> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-07-14net: m68k/nfeth: Remove wrong usage of dev->flagsMichał Mirosław
Remove wrong setting of dev->flags. NETIF_F_NO_CSUM maps to IFF_DEBUG there, so looks like a mistake. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-20Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl-agn-rxon.c drivers/net/wireless/rtlwifi/pci.c net/netfilter/ipvs/ip_vs_core.c
2011-06-14m68k: use kernel processor defines for conditional optimizationsGreg Ungerer
Older m68k-linux compilers will include pre-defined symbols that confuse what processor it is being targeted for. For example gcc-4.1.2 will pre-define __mc68020__ even if you specify the target processor as -m68000 on the gcc command line. Newer versions of gcc have this corrected. In a few places the m68k code uses defined(__mc68020__) for optimizations that include instructions that are specific to the CPU 68020 and above. When compiling with older compilers this will be true even when we have selected to compile for the older 68000 processors. Switch to using the kernel processor defines, CONFIG_M68020 and friends. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: create config options for CPU classesGreg Ungerer
There are 3 families of CPU core types that we support in the m68knommu architecture branch. They are . traditional 68000 . CPU32 (a 68020 core derivative without MMU or bitfield instructions) . ColdFire It will be useful going forward to have a CONFIG_ option defined for each type. We already have one for ColdFire (CONFIG_COLDFIRE), so add for the other 2 families, CONFIG_M68000 and CONFIG_MCPU32. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-14m68knommu: fix linker script exported name sectionsGreg Ungerer
The recent commit titled "module: Sort exported symbols" (f02e8a65) changed the exported symbol name sections. Bring the m68knommu linker script into line with those changes - including the sorting of the symbol names. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-06-11net/m68k: Include <linux/interrupt.h> where neededGeert Uytterhoeven
arch/m68k/emu/nfeth.c: In function ‘nfeth_init’: arch/m68k/emu/nfeth.c:243: error: implicit declaration of function ‘request_irq’ arch/m68k/emu/nfeth.c:243: error: ‘IRQF_SHARED’ undeclared (first use in this function) arch/m68k/emu/nfeth.c:243: error: (Each undeclared identifier is reported only once arch/m68k/emu/nfeth.c:243: error: for each function it appears in.) arch/m68k/emu/nfeth.c: In function ‘nfeth_cleanup’: arch/m68k/emu/nfeth.c:266: error: implicit declaration of function ‘free_irq’ drivers/net/apne.c: In function ‘apne_probe’: drivers/net/apne.c:189: error: implicit declaration of function ‘free_irq’ drivers/net/apne.c: In function ‘apne_probe1’: drivers/net/apne.c:317: error: implicit declaration of function ‘request_irq’ drivers/net/apne.c:317: error: ‘IRQF_SHARED’ undeclared (first use in this function) drivers/net/apne.c:317: error: (Each undeclared identifier is reported only once drivers/net/apne.c:317: error: for each function it appears in.) Introduced by commit a6b7a407865a ("net: remove interrupt.h inclusion from netdevice.h"). Include <linux/interrupt.h> in the individual drivers to fix the build. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-28Merge branch 'setns'Linus Torvalds
* setns: ns: Wire up the setns system call Done as a merge to make it easier to fix up conflicts in arm due to addition of sendmmsg system call
2011-05-28ns: Wire up the setns system callEric W. Biederman
32bit and 64bit on x86 are tested and working. The rest I have looked at closely and I can't find any problems. setns is an easy system call to wire up. It just takes two ints so I don't expect any weird architecture porting problems. While doing this I have noticed that we have some architectures that are very slow to get new system calls. cris seems to be the slowest where the last system calls wired up were preadv and pwritev. avr32 is weird in that recvmmsg was wired up but never declared in unistd.h. frv is behind with perf_event_open being the last syscall wired up. On h8300 the last system call wired up was epoll_wait. On m32r the last system call wired up was fallocate. mn10300 has recvmmsg as the last system call wired up. The rest seem to at least have syncfs wired up which was new in the 2.6.39. v2: Most of the architecture support added by Daniel Lezcano <dlezcano@fr.ibm.com> v3: ported to v2.6.36-rc4 by: Eric W. Biederman <ebiederm@xmission.com> v4: Moved wiring up of the system call to another patch v5: ported to v2.6.39-rc6 v6: rebased onto parisc-next and net-next to avoid syscall conflicts. v7: ported to Linus's latest post 2.6.39 tree. >  arch/blackfin/include/asm/unistd.h     |    3 ++- >  arch/blackfin/mach-common/entry.S      |    1 + Acked-by: Mike Frysinger <vapier@gentoo.org> Oh - ia64 wiring looks good. Acked-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m68knommu: use generic find_next_bit_le()Akinobu Mita
The implementation of find_next_bit_le() on m68knommu is identical with the generic implementation of find_next_bit_le(). Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: remove CONFIG_GENERIC_FIND_{NEXT_BIT,BIT_LE,LAST_BIT}Akinobu Mita
By the previous style change, CONFIG_GENERIC_FIND_NEXT_BIT, CONFIG_GENERIC_FIND_BIT_LE, and CONFIG_GENERIC_FIND_LAST_BIT are not used to test for existence of find bitops anymore. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Russell King <linux@arm.linux.org.uk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26arch: add #define for each of optimized find bitopsAkinobu Mita
The style that we normally use in asm-generic is to test the macro itself for existence, so in asm-generic, do: #ifndef find_next_zero_bit_le extern unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset); #endif and in the architectures, write static inline unsigned long find_next_zero_bit_le(const void *addr, unsigned long size, unsigned long offset) #define find_next_zero_bit_le find_next_zero_bit_le This adds the #define for each of the optimized find bitops in the architectures. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Acked-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Ungerer <gerg@uclinux.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-26m68knommu: fix build error due to the lack of find_next_bit_le()Akinobu Mita
m68knommu can't build ext4, udf, and ocfs2 due to the lack of find_next_bit_le(). This implements find_next_bit_le() on m68knommu by duplicating the generic find_next_bit_le() in lib/find_next_bit.c. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-25mm: now that all old mmu_gather code is gone, remove the storagePeter Zijlstra
Fold all the mmu_gather rework patches into one for submission Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reported-by: Hugh Dickins <hughd@google.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Miller <davem@davemloft.net> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Richard Weinberger <richard@nod.at> Cc: Tony Luck <tony.luck@intel.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-24m68knommu: Use generic show_interrupts()Geert Uytterhoeven
Apart from whitespace differences, /proc/interrupts doesn't change by enabling GENERIC_IRQ_SHOW. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68k: merge the mmu and non-mmu versions of sys_m68k.cGreg Ungerer
There is a lot of common code in the sys_m68k.c files. The mmu and non-mmu versions can easily be merged into a single file. There is really only 2 functions that differ in the 2 cases. A single ifdef on CONFIG_MMU can take care of this. Alternatively we could break those 2 functions out and maintain sys_m68k_no.c and sys_m68k_mm.c with just this code in it (Makefile could then just build the right one). Does anyone have strong feelings on which way they want this done? Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-05-24m68knommu: use asm-generic/bitops/ext2-atomic.hAkinobu Mita
m68knommu can use generic implementation of ext2 atomic bitops. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
