path: root/arch/m68k/platform/coldfire/pit.c
2012-07-16m68knommu: use MCF_IRQ_PIT1 instead of MCFINT_VECBASE + MCFINT_PIT1Steven King
use MCF_IRQ_PIT1 instead of MCFINT_VECBASE + MCFINT_PIT1 so we can support those parts that have the pit1 interrupt on other than the first interrupt controller. Signed-off-by: Steven King <sfking@fdwdc.com> Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2012-03-05m68knommu: modify timer init code to make it consistent with m68k codeGreg Ungerer
With a few small changes we can make the m68knommu timer init code the same as the m68k code. By using the mach_sched_init function pointer and reworking the current timer initializers to keep track of the common m68k timer_interrupt() handler we end up with almost identical code for m68knommu. This will allow us to more easily merge the mmu and non-mmu m68k time.c in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-11-21clocksource: m86k: Convert to clocksource_register_hz/khzJohn Stultz
This converts the m86k clocksources to use clocksource_register_hz/khz CC: Geert Uytterhoeven <geert@linux-m68k.org> CC: Greg Ungerer <gerg@uclinux.org> Acked-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: John Stultz <johnstul@us.ibm.com>
2011-03-25m68k: merge m68k and m68knommu arch directoriesGreg Ungerer
There is a lot of common code that could be shared between the m68k and m68knommu arch branches. It makes sense to merge the two branches into a single directory structure so that we can more easily share that common code. This is a brute force merge, based on a script from Stephen King <sfking@fdwdc.com>, which was originally written by Arnd Bergmann <arnd@arndb.de>. > The script was inspired by the script Sam Ravnborg used to merge the > includes from m68knommu. For those files common to both arches but > differing in content, the m68k version of the file is renamed to > <file>_mm.<ext> and the m68knommu version of the file is moved into the > corresponding m68k directory and renamed <file>_no.<ext> and a small > wrapper file <file>.<ext> is used to select between the two version. Files > that are common to both but don't differ are removed from the m68knommu > tree and files and directories that are unique to the m68knommu tree are > moved to the m68k tree. Finally, the arch/m68knommu tree is removed. > > To select between the the versions of the files, the wrapper uses > > #ifdef CONFIG_MMU > #include <file>_mm.<ext> > #else > #include <file>_no.<ext> > #endif On top of this file merge I have done a simplistic merge of m68k and m68knommu Kconfig, which primarily attempts to keep existing options and menus in place. Other than a handful of options being moved it produces identical .config outputs on m68k and m68knommu targets I tested it on. With this in place there is now quite a bit of scope for merge cleanups in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
